can the S60 AWD get close to the S60R or just dreamin?
                    i really love the s60 r but was wondering if i could take the s60 AWD and give it some more hp over time.  any recommendations.  maybe the same with the s40 t5 AWD, could this car be pushing 300hp w/ mods.  but keep either of these cars as a daily driver. thanks fellas.
Also you have to consider the effects of high HP on an AWD system---you could end up eating clutches for breakfast.
Shifty- Both the S40 (new style) and S60 are 5 cylinders.
So anyway---50 more HP from CAI, intake, cat back exhaust and a chip....hmmmm......maybe, maybe, but I'd sure want to know what that chip is actually doing to my engine.
So if we have a chip that is messing with maximum boost, or a boost controller allowing you to manipulate that manually, lemmer might be right about this.
a gain. do you have any suggestions for manufactures and such? i understand
there are a limited # of them.
any suggestions for a clutch upgrade?
i plan on piecing stuff together in a good order and then getting it flashed
(hopefully i can find someone capable).
i don't want an ultimate car here just some modes to give it some more GUTS, i would really like to get the S60R and mod that to give my buddy w/ modded WRX a run for his money since he thinks volvos suck, i recently showed him some time slips of some s60r's that stomped some STi times.
But having said that, I think someone already recommended IPD for you, which is a great start for Volvo mods. I'm sure IPD could turn you on to other sources, too.
I agree with lemmer; find the nicest '98 (pre electronic throttle) S or V70 T5 you can find and mod the whee out of it. You'll be saving money over buying a new-ish S60 and you'll have a greater degree of latitude for what you can do, mod-wise, with the simpler engine management system.
You can crank that T5 up to R power with just an ECU and full exhaust ... but it still wouldn't have the R's AWD, nor would it have that cool adjustable suspension. But, heck, the T5 is still a fun ride, in my opinion (of course, I'm biased)
... although you are talking about front wheel drive versus all wheel, which with the same power FWD should be noticeably faster
And, like you said, without the drag and weight of AWD .... but then you have a lack of traction problem with putting that much through the front wheels.
I've gotta say you hit the nail on the head with your suspension comment. The S60 (let alone the S40 T5) doesn't have anything close to the suspension that's in the R. So on top of all the other differences in the engine, tranny, etc, you'd still have all that power and not the suspension to properly enjoy it.
You're right ... on the '05 and up. Up till '04, it was a 2.3. I never realized they bumped it up in size.
