Subaru B9 Tribeca: Problems & Solutions
One, on the driver's side.
I don't think this is the case. We have virtually NO humidity out here (dew point in the single digits, and we're in another drought -- no rain since early October) and the AC comes on if you turn the temp settings anywhere below the outside temp. The AC seems to come on anytime I hit "Auto", too, which is ridiculous if it's 40 degrees outside. Drives me nuts, too... :P
-Karen in AZ-
If I run the defrost in my minivan (at any temperature), the A/C will come on.
Mine started doing this when it was still 100 degrees out...my dealer says Subaru claims it's more of a weight problem...poor planning, if you ask me.
The transmission sounds and feels as if it is going to slam through the floor when shifting through the gears when cold.
I have just began to notice something similar. When first driving a cold car, I hear one hard shift/jerk with loud noise between 2nd and 3rd (I think), and then it doesn't do it again until the car is cold again (overnight, usually). My '99 Forester did the exact same thing for the 6.5 years I had it. Subaru tested it, replaced the tranny's computer module (also AT), and it still did it. They said there was nothing wrong with it. I just learned to live with it in the cold weather (it was 25 degrees here last night/this morning).
The oil burning prob is likely an indication of something much more serious than this, though...get it checked ASAP! Let us know what you find out...
-Karen in AZ-
I am guessing that the Climate control systems in our beccas has no humidistat to read humidity. So it designed to make assumptions that when there is enough difference between the outside temp and the inside temp - both of which it knows it kicks the compressor into the mix. The fact that the light comes on does not mean the compressor is engaged.
I share the belief that Subarus design leaves a lot wanting.
Actual cabin temp vs temp set are no where near accurate
In cold weather warm air blow out of the 2 outboard vents on the dash, (no air come out of the inboard dash vents)
even though the mode display shows air only going to the feet.
Inboard dash vents can not be closed - only aimed.
In a LTD the system should blow warmed air from the ceiling registers. Would help greatly keeping the rear cabin warm and also be a big assist to defog the hatch window since it's heaters are useless.
When system is set to defrost the windshield, virtually no air come out the 2 front side window vents to defog them. Not very safe if the 2 front windows are cover with snow or are fogged up.
Nothing that they did wrong would have cost any more for them to do correctly.
Too bad.
I believe the ceiling vents in the 7 passenger models are only for A/C. All models have heating ducts under the front seats pointing toward the rear. I've had no trouble keeping the interior warm here in Minnesota. It may be different where the winters are tougher.
The system has vents in the ceiling why not be able to use them if necessary - that is all I am saying.
I have not had any trouble with the struts on the rear hatch- is it a faulty strut maybe? Dealer still hasn't received my replacement fog light yet!
AKA
Craig
You can get a Pretty nice Honda Pilot for that.
-juice
Your deductible is probably $500, so if the wheel is $500 & the reairs are $200. Your get check for $200 from insurance.
Insurance companies rate you first on the number of claims not the amount. So having a claim on your record for measly $200 or so hurts just as much as a $5,000 claim for the sake of ratings.
Even if it is covered - do yourself a favor and eat it.
http://www.wheelcollision.com/subaru1.htm
Anyone dealt with them before?
Most modern day systems will run the A/C compressor year 'round except in the above conditions. There is little or no cooling benefit to this when the OAT is below your comfort level by more than 5 degrees. These systems are kept running only in order to help keep, hopefully, the passenger cabin atmosphere's relative humidity well above the dewpoint of the cold windshield and windows.
The problem is that the ability for the A/C to dehumidify the incoming airstream efficiently is highly dependent on the local climatic conditions. As the outside temperature declines the probability that the A/C can efficiently perform this function also declines until at about ~47F OAT it is, for all practical purposes non-existent, and at ~35F it is non-existent.
B9s have 18" wheels. Either they have a typo or it is not a B9 wheel.
Too bad.
Touché!
-Karen-
Of course, from your discourse we are all assuming you are OK...please let us know that's the case!!!
-Karen in AZ-
Keep in mind it was probably damaged and fixed, which might be OK.
The price is good for a used rim. I looked last night and even the 16" stock alloys run $250 and up new.
-juice
got mine replaced under warranty thru the subaru regional rep Tuesday and today had the ExPel guy put on a 30 mil 3m film over them :shades:
he said that the film does not stretch when doing the headlights but you form it over them. He tried using the 30 mil from the kit for the headlights but even working on it for 30 mins was not happy with the look. He is going to come back next week and use a 6 or 8 mil film instead custom cut from the expel system for the B9. The 30 mil had small lines showing where the light bubble portion of the headlight. see I have 2 very very small pits already on the headlight plastic...
I did read over the directions for installation. It doesn't seem too complicated. With any luck, the lights will come in while I'm vacationing at home next week. That will give me a chance to install the X-PEL right away.
Subaru also responded to me as well stating they feel the dealers are the ones that can best evaluate the problem, and at this time no recall has been recomended.
So, I plan to respond to Subaru and tell them the above and that the problem still exists.
In the meantime I will keep my head low when opening the hatch. Happy Holidays to all.
the headlights were a nightmare, perfect size but even heating and spraying so he could form it... was way too tough to get it without bubbles or seams showing over the bubble area of the headlights. If they sent you the 30 mil headlights as part of the kit, I would have a pro attempt it or have them swap for a thinner mil film. Just too many complex shapes with the B9 Headlights.
I tried the first one in Cranberry but she wouldnt budge from $120 installed. I then saw there was another rep just north west of pittsburgh and he charged $90 installed plus tax.
Mine works fine (after 3 months). If I run into that problem, I'll get it swap out just before the warr. period is over. Nothing beats a fresh pair to last couple years after the warr. period.
:shades:
Marilyn
One option I dont have that I wish I got was the puddle lights. The only black 7 Passenger Limited B9 with NAV/DVD combo in stock didn't have the Puddle lights, but to take advantage of a $1000 rebate I had to buy one that was in stock. I got a great deal on the B9 anyway so I can live without them.
I wonder if the wires are still there and if I just need to install some type of lights to were the puddle light would go? That would be great if they still ran the wires even though it's not equiped with the puddle lights.
I've owned my B9 for 5-6 weeks now, and I love it. Although I've had a few minor problems. First was when I moved my steering colum up and down I would lose power to my Nav. and my A/C controls. I played with the colum up and down till I lost power all together. Subaru fixed it within two hours. It turned out to be a conector in the harness that wasn't fully snapped in from the factor, and my moving the colum up and down eventually unpluged it. Quick fix, I was very happy about that.
Next is a missing center clip on a molding that says Subaru when you open the drivers door. Without it you have to tuck in the carpet ever now and then.
Last is I found a chip in the molding that goes around the shifter. Both the shifter molding and the clip for the other molding are on order. Lord knows when those parts will be in.
I have 1200 miles on the B9 and thus far they've been great even with these few problems.
Thanks In Advance For Your Replies.
-juice
I was not as diligent as I should have been with respect to checking my oil but I found myself with no measurable oil on the dipstick. After adding 3 quarts I took my B9 to the dealer for an analysis of the problem. The service rep showed me a TSB that stated that the supply of certain oil filters is limited so do not use them until the customer complains of leakage. This was my second oil change. I had no problems after the first change at 3000 miles. As seems to be the case, there is no problem until the customer complains.
-juice
So far we've seen the hatch struts and the fog light covers are the weak spots, so expect supply of those to be short until they can adjust production.
-juice
