Celica GT performance help needed.
 tommyboy2929
                    Member Posts: 1
tommyboy2929
                    Member Posts: 1
                    i just got a 03 celica gt and im lookin to do some more work to it.it already has a full AEM cold air intake, DC sport headers, and Magnaflow exaust but thats not enough.what can i do to get some more HP out of it?
Join www.alldata.com and join their DIY site. That will give you access to any recalls or TSB's that were released for the car.
I also thought this was a modification forum, not a problem solving one?
REPLACEMENT
Disconnect the negative battery cable.
Remove the trim panel from inside the trunk.
Remove the screws which secure the pump access plate to the fuel tank.
Withdraw the plate, gasket and pump assembly as one unit.
Disconnect all leads and hoses from the fuel pump.
Installation is in the reverse order of removal.
Always use a new gasket when installing the fuel pump.
Start the engine and check for any leaks.
TESTING
1975-79 Celica
Fig. 2: Connect a pressure gauge to the fuel filter outlet with a length of rubber hose
WARNING
Do not operate the fuel pump unless it is immersed in gasoline and connected to its resistor.
Disconnect the lead from the oil pressure warning light sender.
Unfasten the line from the outlet side of the fuel filter.
Connect a pressure gauge to the filter outlet with a length of rubber hose.
Turn the ignition switch to the ON position, but do not start the engine.
Check the pressure gauge reading against the figure given in the "Tune-Up Specifications" chart in Engine Performance and Tune-up . (2.2 to 4.3 psi)
Check for a clogged filter or pinched lines if the pressure is not up to specification.
If there is nothing wrong with the filter or lines, replace the fuel pump.
Turn the ignition OFF and reconnect the fuel line to the filter. Also connect the lead to the oil pressure sender.
-mike
-mike
Aside from the "resting on gearshift" bad habit, another bad habit is downshifting at too high a speed, boy-racer style.
-mike
