TOYOTA TACOMA vs FORD RANGER- Part XI
1535456585968
  • plutoniousplutonious Member Posts: 799
    According to Edmunds:
    Chevy 4.8L V8: 270hp@5200rpm / 285lbs torque@4000rpm
    Toyota 4.7L DOHC V8: 245hp@4800rpm / 315lbs torque@3400rpm
    We all know torque is what we need when we are talking about trucks. If DOHC is a waste on truck engines, then why is the smaller Toyota engine not only making 30lbs more torque than the Chevy, but also at 600rpms less?
    Doesn't this disprove some of your theories that DOHC is a waste on trucks because they can't make torque down low in the RPMs? I think this is a pretty convincing argument on the whole DOHC versus OHC/pushrod engine debate.
  • modvptnlmodvptnl Member Posts: 1,352
    Pluto, what is it about your comprehension or lack thereof???
    The GM/Toy comparo is EXACTLY why the DOHC is not using its full potential in a truck engine. Do you understand what varible valve timing is??? I've never said that 4 valve (which is really more what this discussion is about as opposed to DOHC tecnology)can't make the power down low. I've said that unless you are spinning a motor to the higher RPM's that make the peak HP that the OHC/4 valve set up is not being used to its potential. Do you not think for one moment that GM couldn't re-cam and re-intake that 4.7 and lose 30 HP but gain the torque down low???
    The bottom line is that most 4 valve motors need some sort of VVT or intake restriction for lower RPM use to make the same torque as a 2 valve motor that has a smaller total valve area.
    Where the 4 valve motors excel, at higher HP/RPM's, the truck motors don't need to run.
    The last physics lesson as it regards to engines is that at lower RPM's the larger the port volume and valve area the less efficient a motor is. This is due to lost velocity at lower engine speeds. This is why a VVT will limit the amount of air volume at lower engine speeds as it increases port velocity. Of course at higher RPM the VVT allows full valve lift. But guess what? At 4800 RPM who cares???!!! Now @ 6000-7000 and even the 8000 RPM's the Hondas turn the 4 valve DOHC(or SOHC) starts to show an advantage over a 2 valve set up.
  • cpousnrcpousnr Member Posts: 1,611
    I am not sure what pluto does not understand about torque and power and it's relationship with higher rpm motors.
    You need TORQUE to accomplish work, ie moving a 4X4 up a hill. Bottom line, the Ranger wins that statistic.
    The Tacoma, while a fine motor in the 3.4, cannot compare in the battle of torque. It may be faster, but that is also determined by the gear ratio of the tranny. And in that battle, I have shown before, the only gear that a Tacoma has a better crawl ratio, ie gearing for off-road, is in 1st gear. The Ranger has a better crawl ratio in every other gear, when both vehicles have a 4.10 rear differential.
    HP per liter is a real useless statistic. Sorry, your just wrong there. The REAL merit of an off-road vehicle comes in the low RPM torque curve, which the Ranger wins.
  • midnight_stangmidnight_stang Member Posts: 862
    First we were talking who's ontop with the HP war. Then it's 4 valve vs 2 valve. Then it's air/fuel buring efficiency. Now it's HP/ci, with a fictional toyota 4.0l thrown in. Pluto must obviously get the last word in.
    As far as which engine is heavier, I'm not about to look up the steel or aluminum alloy composites used to cast or forge each part on both engines. It's just a moot point.
    Just to make Pluto think he scored a point, yes at peak statistics, the 3.4l makes more HP per cubic inch than the 4.0l. Yet you still don't seem to comprehend the power curve inherant in 4 valve engines. They peak well, but off-peak they don't suck air well. (Point retracted) I'd love to show you the actual average torque/hp or complete power band. Then you'll have to move back to the pure stock off-road arguments.
    Arguing dealerships honoring their warranties is moot as well. Each market is different, and each relationship with the customer is different. Maybe I'm just blessed to be in a high competition market area, or maybe the Ford dealerships here just take that extra step to ensure customer satisfaction. I haven't been to any Toyota service departments, but I have heard many more horror stories. Maybe that reputation for reliability carries over to reluctance to repair.
    Mod and Stang, while your knowledge of engine dynamics is impressive, you keep beating around the bush. You said that DOHC is a waste in a truck engine.
    Chevy 4.8L makes 285lbs torque at 4000rpm
    Ford 4.6L makes 293lbs torque at 3500rpm
    Toyota DOHC 4.7L makes 315lbs torque at 3400rpm
    Sorry, but the numbers speak for themselves. Being that the DOHC is so worthless and a disadvantage in a truck motor, don't you find it odd that this design beat all the others? In comparison reviews, why don't they ever put up Chevy's 4.8L or Ford's 4.6L against Toyota's 4.7L? Nope, can't do that, the competitors need to use a larger engine. No matter what you say about DOHC, Toyota has obviously done something right with their engine.
    Oh, and if the Ranger is so superior with low-end torque and crawl ratios, why has it NEVER beaten the Tacoma off-roading?
    Stang: "You still don't seem to comprehend the power curve inherent if 4 valve engines. They peak well, but off-peak they don't suck air well." Yeah, and I could say that your 2 valve engine may have a slightly more linear torque curve, but it doesn't peak as high in lbs/ft torque or as low in the rpms as the DOHC 4 valve engines. And let's be honest, anybody who talks trucks wants the highest torque at the lowest RPM.
    You know, over the years, you've probably noticed that the truck engines have become smaller yet more powerful. Carburetors were replaced with fuel injection, many pushrod designs were replaced with OHC designs, etc. Now the first DOHC V8 ever offered in a pick-up was introduced by Toyota, and it's stomping anything else in the same displacement range. The DOHC will probably be the next step in the evolution of pick-up engines becoming smaller and more powerful. I can't help to think that if Ford or Chevy made this engine, you guys would think it's the greatest thing in the world.
  • eagle63eagle63 Member Posts: 599
    Doesn't the tacoma weigh less than the ranger? I'm assuming it does, but I don't know how much of a difference there is. This is probably the biggest reason why the tacoma is so quick. personally, I think the 3.4 V6 is plenty of power in that size of vehicle. Being an explorer owner I can also appreciate the power of the 4.0 SOHC. regardless of hp per liter, torque curves, etc. I think both are pretty darn good engines.
    CP- that is impressive wheel travel in that pic you posted. Also, it doesn't look like the FX4 has that ugly plastic body molding that the "Edge" has. which is nice...
  • tbundertbunder Member Posts: 580
    yes, the FX4 has the same "ugly" body moldings as the edge. only difference is that the edge's are body-colored, and the XLT's, which is what the FX4 is only available with, are a charcoal color. body colored probably is why you think they're ugly.
    also, you all must remember that the FX4 rear-end's only difference with a regular ranger is its shocks. they will all articulate like that if asked. i know mine will.
    pluto- i saw a new '02 camry se, very nice. and i agree they are nicer than a taurus. however, they are still down on power, taurus is available with 200 horse, and the new altima can be had with a 240 horse V6. it's(the altima) also built by robots. all are nice, but the nissan takes the cake imo. although the new camry se is very cool.
    as far as american vs. japanese. i dont have anything against japanese, i just dont like it when people claim that their honda's, nissan's, toyota's are "made in USA". its simply not true. they're imports and always will be. my ranger has a build tag of made in usa. and it was. right up above me in the crappy state of MN.
    I'll type slow and make it as simple as possible.
    The 4 valve head IS NOT AT A DISADVANTAGE IN A TRUCK APPLICATION, ONLY because of the VVT technology......slow enough?
    A 4 valve head is NOT BEING USED FOR THE ADVANTAGES OF HIGH RPM BREATHING IN A TRUCK APPLICATION. Therefore a 4 valve OHC setup is not being utilized to its main advantage. Understand yet????
    The 4.6 2 valve SOHC in the Mustang makes 260 HP and over 300pound feet of torque. For whatever reason Ford tuned the truck 4.6 different. It's all in the tuning at these lower RPM's !!! Again I'll state that at the operating levels a truck motor runs at 4 valve technology offers no advantage.
    I think you're still confused on the DOHC issue. It's not the # cams that makes the difference.
  • toadmantoadman Member Posts: 39
    When the heck did Japan annex Fremont CA? Why am I the last to found out about these things? I had heard rumors that Japan was interested in buying Smyrna TN but I haven't heard if that deal has closed yet. I know that Japan is not crazy enough to make a bid on Detroit with all the other failed purchases made in the late '80 and early '90's.
    Toyota pickups are assembled by U.S. citizens with 75% parts contents made in the U.S.A. When my Nissan was built back in June of 1991 it was not quite 75% U.S.A parts but still was at least assembled in the U.S.A. Would you rather have a vehicle made in a foreign country and then sold in the U.S. where the only money that ends up in the U.S. is to the dealer? Or would you rather have a foreign owned corporation that has invested in plant/land and labor with the majority of cost to assemble a vehicle going to citizens of the U.S and the profits from the sale going back to Japan? Give me the latter every time.
    You're probably right, the DOHC design is not the only thing that makes the 4.7L Toyota perform so well. What makes it perform so well then, and how come Ford and Chevrolet haven't done the same thing, especially sooner, since they've been making V8 truck engines for so long? I'm not trying to start an argument, I would like to know, that's all.
    I think we (and just about every other thread with domestics compared against imports) have beaten this "made in America" thing to death. I'm going to play devil's advocate for a minute and suggest something to think about. After the September 11 attacks, I believe everyone of the Big 3 has made multi-million dollar contributions to relief programs. So far not a penny has come from Toyota motor corp, and Toyota has enjoyed some of its best quarterly sales recently. This should be making folks more angry than where parts are assembled. Even that ticks me off.
    you are mistaken on your nissan and other things you said. i heard it straight from the horses mouth. both nissan and toyota are shipped in parts from japan, and then american workers put the vehicles together. so many american companies are going global and closing up american factories (boeing) just to go to malaysia and other economically booming countries to open up factories where they can pay workers less than half of what they pay american workers to do the same thing (per william greider). why would japanese companies like nissan and toyota come to america and manufacture vehicles where its much more expensive to make parts and engineer vehicles? the only thing that nissan and toyota do in america is put a bunch of car and truck models together every day.
    my buddy bought a '93 Kawasaki Ninja ZX6 back in '93. on the tank was a huge sticker from the factory that read "made in USA". we laughed at it because right on the frame and engine, it said made in japan. if there is one part that came from america, and it was probably assembled in america (in nebraske probably), the japanese will brag about it and say it was made in america. when all along it wasn't even close to being american made. same thing with the toys, nissans, and hondas. do you really think those japanese honda guys over there would really let americans design and build their precious pocket rockets? not gonna happen. we simply use our tools and their parts to create their gems. but its not a bad thing. its fine. even though they do think their products are better and charge you more for them.
    I'm not sure what you're getting at with your last comment. While it's true the 4.7 Toy is a gem I don't see ANY advantage vs. the 5.3 or 5.4.
    The 2 valve 5.4 has more torque and aprox. the same fuel economy as the Toy. the GM 5.3 has more peak power(kinda paradoxical when you look at the technology) and it beats both modern OHC designs in fuel economy. So the 4.7 Toy is in a higher state of tune and actually uses more fuel than the larger more powerful motors. Advantage????
    the 4.6 and 4.8 vs the Toy is the same argument. The 2 valve motors use less fuel and one has close to the same torque and the other has more peak power than the Toy. Advantage??? Just depends on your priorities. Ford could easily tune the truck 4.6 in the same state as the Mustang GT 4.6 and out power both. Why don't they? Your guess is as good as mine!!!
    BTW, Ford does use DOHC 4 valve heads on the Lincoln trucks. This is to put them over 300 HP which GM still does with pushrods/2 valves on the Escalade. Advantage Ford??? I don't see it there either.
    1. You don't see any advantage the Toy 4.7 has over the Chevy 5.3? Well, the 5.3 only produces 10 lb/ft of torque more than the 4.7, and this comes at 600rpm higher (5.3 = 325lb/ft @ 4000rpm). Basically, that extra 10 lb/ft doesn't even exist because nobody is going to drive their 5.3 around at 4000rpms, unless you're into blowing up motors. Another advantage: the 4.7, I'm sure, is a lot smaller and lighter than the 5.3.
    2. How is the Toyota 4.7 in a "higher state of tune" when it is producing 30lbs/ft torque more than the 5.3 at 600rpms less?
    3. "the GM 5.3 has more peak power"...wait a minute, I thought we agreed that as far as trucks are concerned, HP isn't important, torque is (and especially at lower rpms).
    4. "the 4.6 and the 4.8 vs. the Toy is the same argument. The 2 valve motors use less fuel and one has close to the same torque and the other has more peak power than the Toy." The Ford 4.6 = 231hp@4750rpm / 293lb/ft torque@3500rpm. No torque or hp advantage there (Toy 4.7 = 245hp@4800rpm / 315lb/ft torque@3400rpm). The Chevy 4.8L = 270hp@5200rpm / 285lb/ft torque at 4000rpm. In this case, Chevy does have a HP advantage, but again, lower torque figures at much higher rpms. Which would you rather have? Of course the 2 valve motors are using less fuel than the 4.7 - that's because they're not producing as much power, regardless of the different displacements of these engines. I would like the figures on fuel consumption, however. What's the difference? 1 or 2 mpg? Isn't that what you would expect for the gains in torque and/or HP when comparing ANY engines? Are such figures important to people who buy trucks?
    5. I can't believe that now you're entering the 5.4 into the argument. Just how big of an engine do you have to use as a "fair" comparison to the Toyota 4.7?
    6. Toyota could probably tune its 4.7 to produce as much power as the Mustang GT as well. Why don't they? Your guess is as good as mine as well!
    I see your point that the DOHC design of the 4.7L isn't the ONLY factor making this engine perform well. Still, I wonder why Chevy and Ford aren't making an engine in the 4.7L displacement range that stomps the Toyota, especially considering their experience making V8 truck engines.
    "my ranger has a build tag of made in usa. and it was. right up above me in the crappy state of MN."
    -hey, easy there chief. I'm from MN. (my buddy used to live right next to the Ranger plant.) I don't think you want me to pull out the Iowa jokes...
    1. 4000 RPM is peak torque when you "get on " your motor to pass or accelerate hard. 4000 vs 3400 aint no thing and I've run my V10 past 4000 pulling the Baker grade or Grapevine with no ill effects, this is why these motors redline @ 5-6K.
    Again what you're not understanding is GM could easily drop the 40 HP and move it down the powerband and have 350# torque. GM likes HP #'s.
    The motor still outperforms the 4.7 AND uses less fuel. so much for a 4 valve advantage.
    2. You're right. Should of said "different" state of tune.
    3. Agreed. See above
    4. Agreed again. But where's the advantage??? You gave up economy for performance. How did the 4 valve head help??? If you had this performance advantage PLUS a more efficient higher MPG I'd be sold. The bottom line here is a choice Toy doesn't offer. Besides, I think the 5.3 gets 1-2 MPG more, the 4.8/4.6 are more like 3-4 MPG more.
    5 Why not?? The 5.4 has more HP and Torque(260/355) than Toy and gets the same MPG. The HP/Torque to displacement is VERY close, how does the 4 valve technology benefit here???
    6 BINGO!!! I think you're finally getting it!!!! I believe the 4.7 DOHC 4 valve Toy motor COULD make more power than all the motors mentioned(except for the 5.4 with the 4 valve Cobra heads)!!! BUT IT'S NOT!!!! This is what I've been saying for MONTHS!!!! Unless you're going to utilize freer breathing/higher RPM capable heads they're really not necessary at these levels of power/RPM.
    Ford and GM have always based their marketing on incremental advances. They tend to leap frog each other every year, be it torque or HP. Both the LARGEST available Ford and GM motors do blow away the Toy motor when loaded and they are all within a hair empty.
    I stand by the statement that Toy had these motors in the Lexus/car lines and it was more cost effective to utilize them then to start over. Nothing wrong with that as GM/ford do the same thing. The DOHC/4 valve is not being utilized to their potential in this application.
    MOD--->Amidst all the engine talk, my favorite engine is still the 460 big block.
    Pluto--->You say, "Yeah, and I could say that your 2 valve engine may have a slightly more linear torque curve, but it doesn't peak as high in lbs/ft torque"
    Hmmm... 238lbs/ft@3000 vs your 220@3600
    "or as low in the rpms as the DOHC 4 valve engines"
    Are you using some form of reverse psychology here? See above.
    "And let's be honest, anybody who talks trucks wants the highest torque at the lowest RPM."
    Can we say Ford 4.0l. Woo Woo!
    Eagle--->I think you're right. On the average the Tacoma is probably about 200-300 pounds lighter than the Ranger. Quicker? Probably really depends on the gearing and drivetrain, or a little friendly competetition. I will say this though. I am dissapointed that for 2002 Ford will not offer the 4.0l with regular cab, only the 3.0l. Seems the 4.0l is restricted to 4x4 supercabs or one XLT Supercab with Appearance group. In 2001 you could get (order) a Edge Plus, a 2WD Regular cab 4.0l with manual. That would rock!
    All--->On the built in USA issue. We all know both vehicles are ASSEMBLED in the USA, parts may come from the USA for the majority as well, although I cannot confirm this for the Tacoma. My only concern is where the profit margin is going.
    Also, it appears the Dakota no longer has a v8 available? Edmunds has now listing for a 2002 Dakots with anything more than a 3.9l v6.
    Those statements were regarding the V8 engines being discussed in full size work trucks, not V6s in compact pick-ups. Don't be taking things out of context. I don't consider an engine's ability to produce torque at the lowest possible rpm as criticial (or in some cases not even desireable) on compact pick-ups and certainly not sedans because these vehicles aren't used for heavy duty towing. The heavier the towing, the more torque you need at lower RPMs. Light towing, this is not so critical. No towing, let the torque/hp rip at higher rpms.
    In comparison tests, the Tacoma has won every performance segment - braking, acceleration, etc. I posted a link earlier on this. So the Tacoma's engine is more than capable. I do realize that now, however, the Ranger's MAX towing has been bumped up a few hundred more pounds than the Tacoma.
    Guys, I won't be around the next couple of days. My quest continues for the perfect buck, and maybe this season I'll get lucky...
    Just to clarify an re-iterate that both Nissan and Toyota compact pick-ups are built in the U.S.A. with the majority of parts mfg. in the U.S.A. as well. Anyone can verify this information with Nissan U.S.A. and Toyota Motors, U.S.A. Also, last time I checked, the Nissan Frontier was designed and engineered in Nissan's NDA facility in San Diego, CA. Also designed at NDA were the Altima, Maxima and Xterra.
    Anyone interested in where Ford gets their parts can also confirm this with Ford Motor Corp. And just a little help, they don't all come from the U.S.A.
    Stang,
    Don't be concerned about the small percentage of profits going back to Japan, Germany, Sweden, et al. The real value is in the prodution here in the states. Jobs, taxes generated by foreign corporations operating in the U.S.A. are where it counts.
    Definitely agree with you on point 5 and beyond. It's a shame Toyota isn't getting more out of the 3.4L engine. It's a good engine for the truck but it could be a great engine with a little extra effort from the engineers.
  • lspanglerlspangler Member Posts: 102
    Just some small information for you. I work for an auto supplier. We make parts for all OEM's. I am personally responsible for parts that go on Nissan, Toyota, Subaru and Isuzu. None of the Japanese companies ship parts here to be assembled. They may ship a few parts, such as an engine or a transmission but the majority of the parts are from American suppliers. The reason for this is that they have to pay duties on incoming parts and cars.
    Nissan and Toyota both have Tech centers in the Detroit area that employ Americans. I am at one or the other a couple times a week. Toyota also has a North American operations headquarters in Erlanger, KY. There are about 600 administrative people there as well as thier purchasing dept. They work with the North American suppliers.
    lspangler,
    You forgot to mention the drive shaft and engine plant for Nissan is located in Tennessee just outside of Smyrna, name escapes me at the moment. The other factor in Japan deciding to invest in American automotive production has to do with import tariffs on vehicles. Luxury and pick up truck import duties were particularly high in the '80's. Made perfect sense to avoid the import duties and build right here in the U.S.A. Too bad the U.S. couldn't figure that one out.
    There are over 500 suppliers in California for the NUMMI plant in Fremont, CA. The company I work for provides logistical support for parts coming from the mid-west via rail to supply the NUMMI plant.
    I know Delphi exports parts to Asia and they are a major supplier of electonic components to all the auto makers. I also know that each auto manufacture has different specifications for their parts. Same goes for tires.
    why they all say "made in japan" on them right? when a dealer will admit that their products are made in japan, i think ill believe them over you. they ma have plants all over the place here, but they're assembling, not manufacturing.
    Ispangler wrote:
    None of the Japanese companies ship parts here to be assembled (you're living in the dark if you think that's true my man). They may ship a few parts, such as an engine or a transmission but the majority of the parts are from American suppliers.
    what? this sentence doesn't make sense. is this a contradiction? how can you not ship parts here, but still build a truck with an engine and tranny that came from japan? the parts that matter on a nissan or toyota are made in japan. maybe the carpet or fuse relays are made in usa, but that's about it. why is it such a bad thing to admit that your truck is foreign? i mean, what's the big deal? that's why you chose it i assume, right? thinking you're getting better quality? and then your new tacoma's dash falls off or it starts leaking water in from a huge gap in the firewall someone forgot to close up. darn american worker anyways.
    My pathfinder is 100% Japanese made. What I am trying to tell you is that I work for an American company. We supply cables to all OEM's. I am responsible for all of our Asian business. For Nissan I supply Accel cables, hood release cables, fuel release and trunk release on the Altima, Sentra, Frontier, and Xterra. I am in prototype stage for the new Full size truck and the new minivan and the new Maxima. I am working on cables for Toyota's new minivan. What I meant to say in my previous post is that it would be extremely expensive for any manufacturer to attempt to ship all the parts from Japan for assembly here. It would be cheaper to send the vehicle assembled as it would take up less room. So the japanese may send over an engine or some other small assembly, American companies make the steel for the body and stamp it. American companies supply the interior components etc. Many of the Japanese vehicles are much more American than the big three's vehicles due to the fact that there is no UAW in the plants owned by Honda, Toyota, Nissan. In order to compete with a non-UAW plant in the US, the big three have gone to Mexico to have cars assembled with a blend of American and Mexican made parts. GM assembles trucks in Mexico and in Michigan and many of the component suppliers are going to third world countries to save money. We are looking at Turkey, hungry and chec republic to have our components manufactured in order to compete. Are these American made then?
    tblunder, I don't think you understand the automotive world very well. I grew up in it and I work in it everyday and to tell you the truth, I am far from an expert in defining what should be considered amerian made and what is foreign. Though I do know that a Camry has more american content than a Taurus, the Camry was even designed here by Americans in Toyota's tech center.
    In the end, you are definetely allowed to have your opinion, but I would do more research before making up your mind. If you'd like, I can try to do some more investigating as to content in Ford and Toyota vehicles. I have access to enough inside information to help you out. I guess the first step would be do define where to draw the line for being American?
    A part designed in the US, built in Hungry and assembled into a Ford in Mexico? or a part designed in america, built in america and assembled in america by toyota?
  • sonjaabsonjaab Member Posts: 1,057
    www.lear.com
    They make stuff for all auto makers
  • eharri3eharri3 Member Posts: 640
    And what I have good experiences with. Parents have '97 Toyota Corolla sedan because they like small cars and don't think anyone else except Honda makes as high a quality small car as Toyota. I agree. America makes many good cars, but their small cars are weak. Should they go out and buy a Ford Escort or a Neon anyway just because it's from an American company?
    I have 95 Ford Ranger 4x2: so far almost 80,000 miles with few problems, cheap parts, cheap labor. First, I dont really know what's made in America anymore, I know lots of American vehicles are manufactured in Mexico and Canada. So maybe I could buy a certain vehicle just because it's a domestic model, but if it was built in Mexico and sent north then I'm supporting Mexican workers while adding to the manufacturer's bottum line. American workers get nothing.
    I will not base car or truck-buying decisions only on where it's built. I will not miss out on great cars just because they're foreign or have garbage in my driveway just to keep someone else in their job. IF the domestics want us to buy American they should make the best vehicles. That is sometimes, but not always the case.
  • allknowingallknowing Member Posts: 866
    I've got to agree with your comment a month or so ago CP.
    tbunder has got to be vince8.
    Well went wheeling last weekend, a Ranger tried to assist a Jeep stuck on a hill.
    Long story short, the Ranger rolled 1 1/2 times, hitting the Jeep as it went over.
    http://board.rrorc.com/ubbcgi/ultimatebb.cgi?ubb=get_topic&f=1&t=007006
    Refilled the power steering fluid, fired up the engine, it kicked over right away after sitting on it's side for 45 min. It blew blue smoke for the firest 10 or so miles but it drove straight and maintained the speed limit on the ride south. He drove it maybe 50 miles, then towed it the additional 100 miles to his home.
    Built Ford tough!
  • sc0rpi0sc0rpi0 Member Posts: 897
    Let me see if I got it right......
    (from the message)
    The guy who drove the Ford ran into someone else (great driving).
    Ford lost all its windows save one.
    Now has a f***ed up engine.
    Lost most of its power fluid (You are not gonna say that the cap flew off the tank, are you?)
    The body now looks...well, like it's been rolled over.
    Where does the tough part come in?
    You'd think, a Tough Ford would roll over, bounce back, not a scratch on it, and no blue smoke from the exaust. Thats tough.
    What happened when it got back home? How much is the mechanic bill? Maybe this should be the new Ford commercial........rolling over in the mountains.
    No, when the Ranger went up the hill above the Jeep, to try to extract it, he backed down, got in the same ditch as the Jeep and started leaning. 2 Guys went up to put weight on the truck while he moved out of the ditch but it was not enough. It rolled over the Jeep, hitting the hood of the Jeep with the bed as he rolled.
    Yep, Pwr streeing cap broke off in the roll, refilled, put the cap on, started right up and he drove it away.
    Tough truck, takes a roll, drives away. No did not say anywhere his engine was screwed up, you embelished.
    Let me put it in perspective. My sons 94 Toyota p/u was hit by a Honda Civic. Crunched the right tire/suspension. That truck was totalled and was undrivable. The Ranger drove away.
    That's a funny story about the Ranger rolling over in the ditch. Personally, I've always thought there's a difference between being tough and being stupid, though
    Maybe that was tbunder behind the wheel. He seems to have experience flooding trucks as well..
    Momentum is what causes damage in vehicle accidents. Momentum = mass x velocity. It's easy to see how a 2800lb (estimate) civic going just 15mph (momentum "value" of 42,000) is capable of producing much more damage (about 3 times the damage, actually; probably even much more since the impact was focused on a small area - the Tacoma's wheel) than a 3600lb (estimate) Ranger's relatively large-surface bed impacting the earth/Jeep at around 4mph (rollover in ditch estimated speed / momentum "value" of 14,400).
    So your simplistic approach analyzing the Tacoma and Ranger accident and declaring the Tacoma wimpy doesn't really mean anything at all.
    I wonder if a Tacoma TRD would have slipped into that same ditch, being that it has a rear locker and all...guess Tbunder's beloved LSD wasn't up to the task, hehe
    Whether it's a Tacoma, Ranger, or S10, when such a dumb maneuver is attempted.
    wuzup? now who do you all think i am? whoever it is; im not, and i dont think plutonius is either.
    also, pluto- what makes you think that ranger had a lsd on it? it may have also had a locker on it. who knows. moral of the story is be more careful, and not to take jeeps so seriously anymore. ive always thought they were overrated anyway.
    Locker would not have helped, should have lashed the guy to the uphill tree until he got straightened out.
    Got himself in trouble backing down into that ditch, had left wheels low, right wheels high on aprox a 20 degree slope. Not a good combination.
    Was a 90 with the 7.5 inch 3.73 open differential.
    Point was it drove away, could actually have driven the 155 miles to the guys home, just not too much fun with a shattered windshield.
    The point was the durability of the truck, not the smarts of the driver or the people that were there.
    Dang, I am sorry I posted that now, seems the Toyota boys cannot rationalize my intenet, even though I thought it was crystal clear. Hmmm maybe I should search and see if I still have the picture of the TRD that spun off of a state hwy here when his locker engaged on a curve? It had to be towed away. . .was not driveable.
    Understand my main point now? 8^)
    Pluto--->You might want to leave the accident comparisons to the insurance adjusters. You're forgetting that while a truck rolls over, the weight of the vehicle is transferred from wheels to side metal (fenders, doors, bumpers) and then to roof, maybe the hood and probably the bed. The cycle continues for the other side metal, and then wheels, only to repeat for each "roll over".
    Engines are not made to hold contain oil in the heads, piston ring gaps will eventually leak oil into the combustion chamber (Hence the Blue Smoke), Power steering fluid reservoir lids are designed to keep contaminants out, and keep the splashing fluid inside, not hold the entire weight of the fluid like a drain plug.
    Would a Tacoma had done better? Maybe in a few years when they start to get old, so their owners take them out of the garage and onto the trails! :)
    this was great:
    Your post "Dang, I am sorry I posted that now, seems the Toyota boys cannot rationalize my intent, even though I thought it was crystal clear. Hmmm maybe I should search and see if I still have the picture of the TRD that spun off of a state hwy here when his locker engaged on a curve? It had to be towed away. . .was not driveable".
    I think that all of Tacoma owners here will at least agree that your Rangers are as good as the aforementioned Tacoma that spun off the road and was towed away. A Tacoma in good condition though.........
    Actually, in 1997, my work at the time involved investigating boating accidents and preparing reports for insurance agencies to establish liability. So I do have some experience in accident investigation, though it isn't with vehicles. But many of the same principles apply. Anyways, my point is you can't compare 2 totally different types of accidents and draw conclusions as to which vehicle is more durable. Why do you think the NTSB and insurance companies frett to the Nth degree to exactly reproduce and standardize crash tests when rating cars?
    Tbunder, funny you said the Ranger MAY have had a locker on it. Now why would he want that, being that your LSD is so superior (though in this case it was an open diff with no locker)? BTW, I see quite a few old Toyotas on the trails, Landcruisers and trucks. Probably more-so than Rangers.
  • saddaddysaddaddy Member Posts: 566
    You don't have a clue. I keep mine pretty garage-ridden as you might call it, but go to tacomaterritory.com and you will see more 98-00 tacomas with solid axels shoved in them than you could imagine. Now if they stay in a garage, im a monkeys uncle. Most of the stuff you say is intelligent, but I think you prolly realize that that comment was way off base. Oh and this fresh from Ford's website: "We believe there are two ways of doing things. The right way, and the Built Ford Tough Way." LOL. Either the Built Ford Tough Way is not the "right way" (very possible), or the spokespeople for Ford are as dumb as the rest of the people who have anything to do with the company - blind consumers included. (Also very possible). Just thought I'd share. Haha
    Saddaddy-->I don't think what I said was a hard and fast rule, but it was just intended as a joke. Hence the smiley :) You either get a rise or a chuckle out of it. I'm trying to bring forth a more lighthearted approach to my posting. Besides since I'm using MY time on this board, I don't have to be hard-core serious all the time do I? I'll try to include more smileys next time.
    well, im not blind but i wear glasses. i also have a ranger that im not trying to get the president at ford to buy back.
    saddaddy- come to iowa and ill show you a built ford tough ranger. the 2001's and 2002's are the best rangers ever. more power than any other compact, and options galore for the price that your base comes with (dont get me wrong, i like tacomas too). 7000 miles and so far no rattles, squeaks, and 20 mpg. heck, i even fired up the a/c today since its around 80 here near des moines. smiley face!
    I agree that things should be more lighthearted around here. I know Ranger guys build up their rigs for off-roading -- but so do Tacoma owners. It cant be proven that one truck is built up more than the other. Just don't say that tacos stay in folks garages. Also the thing from the ford site was just a little propaganda. You might find a similar mispoken statement at any manufacturers site. Just kinda funny for me -- the opposition. I know full well what they meant. Don' worry.
    Stang -- I wasn't directing my comment to you, i apologize if it sounded as if I was. Just the other day I was saying that things needed to cool down. My only complaint is that my typed words couldn't convey the tongue in my cheek. Its all in fun and I know you guys feel the same way. None of my posts are in contempt, i appologize for them sounding that way. Take it EZ.
    Hey man, i agree with you on the new Rangers. If I wasn't a prerunner man and could afford 4x4, I would give the Rangers a good hard look (especially the FX4). Glad you could tell that I was pretty much kidding about the quote from the Ford folks. Take it EZ man!
    :o)
    Haven't seen the FX4 ranger, but I have seen a couple of FX4 F-150's. Pretty mean looking, and pretty impressive ride height.
    my local dealer here in a town of about 15000 has two FX4 rangers. even the huge dealer in des moines (svt dealer) doesn't even have any. they are really cool. but really expensive.
    I saw this option when looking at the F-150s on here. It is a $5k option and has something to do with propane. What in the world is this? Never heard of it. Can anyone enlighten me?
    8^) Good to see your around still!
    Hard to say if a Tacoma would have done better. When you are leaning already, right front wheel is off the ground, ya should wait until there is more help. The 90 Ranger did not. It was not a smart move. It is built btw with a James Duff lift, good offroad shocks, computer chip + and in all honesty, he was doing fine until it rolled (somewhere I seem to remember a joke somewhat like that "Famous last words: "Hey, watch this"."
    BTW, got an post from the guy and he wants to tow the Ranger up for on to the Thanksgiving days to wheel again! Can not drive it legal, but can still wheel off road.
    Like I said, Ranger is a tough truck.
