TOYOTA TACOMA vs FORD RANGER- Part XI
Here's the new place to discuss the Tacoma vs the
Ranger.
Also, try using the Topic Search for previous
Tacoma vs Ranger forums.
Happy Motoring. ;-)
Pocahontas,
Edmunds.com/Roving Host
Ranger.
Happy Motoring. ;-)
Pocahontas,
Spoog, keeps claiming that Rangers will "fall apart" if taken offroad... I am living proof they don't.
The Ranger is the best compact truck for value and everyday use. Ford engineered the Ranger for the majority not the minority. As was said over 90 percent of 4WD vehicles never see gravel. And most 4WD owners use their 4WD as a true 4WD maybe 5 percent of the time. So, I guess the TAcoma is better than the Ranger 5 percent of the time??? LOL!
Enjoy those open axles Toyota boys...
See you in the beautiful Cascade range...
Been there. Done that. Traded in for a 4wd truck as soon as the finances were willing.
If you get a 2wd truck without an LSD or a locker and live anywhere inclimate conditions might be common, you're nuts.
LSD helps you pull with two tires rather than one....
A neighber has a Toyota 4-runner. It had been raining so the streets were plenty wet. I asked if he would stomp on his gas pedal at a stand still. ONE rear tire spun! LOL!! When he engaged the 4wd system there was a decrease in tire spin. I stomped my Ranger in 2WD and both tires spun and grabbed. I have the better traction by far on wet pavement.
Vince: It is your OPINION that "the Ranger is the best truck." I believe it's the Tacoma but I don't make the statement: "The Tacoma is the best truck," because I respect the fact that others may have a different opinion that might interest me. That's what this bb is for dude. If you don't respect other people's opinions, then don't expect anyone to respect yours. I think you make some intereresting arguments but you tend to get carried away with your pro-Ranger feelings. Again, I'm not saying that the Ranger is a bad truck, it is quite capable in in just about every capacity for which I require a truck. At the time I purchased though, I could not their 4.0 with a manual tranny. I also feel the Tacoma is slightly more reliable than the Ranger, but not much. I don't think Toyota's are better Ford's in general and I don't think there is any prestige in owning a Toyota. If I wanted prestige, I would have bought Lexus or Lincoln.
Whenever we get a fresh snow, I use 4wd when going to work. After a day or two, the snow on the road melts and bare pavement starts showing. I don't like to use 4wd (a part time system)during this time because of the binding. On the slick patches that remain, a lsd will sometimes cause the vehicle's backend to kick out sideways. I think this is more likely to happen with manual transmissions. This is not good when you are stopped at a stoplight with someone beside you in the other lane. This is also dangerous if you should have the cruise on while going over an icy bridge. The same problems occur with a locker. In fact they might be worse.
I do go off the road, so I consider the advantage of a limited slip or locker in a 4x4 outweigh the disadvantages. I think a lsd provides advantages in these situations:
1. Extra traction when almost stuck.
2. Extra traction when using the transmission for braking down a steep/slick slope.
3. Providing traction to both rear wheels helps keep the vehicle moving if one wheel should leave the ground. Crossing a ditch or dry wash at an angle (to keep the bumpers from hanging) in an open diff 4X4 could leave you stuck if one front and one rear (oposite sides) leave the ground at the same time. You end up with kind of a teetering effect.
Cthompson21 is correct when talking about 2wds. 2wd open diff pickups are helpless during a snow. I would have to have a limited slip if I owned a 2wd. Despite the control risks.
I wouldn't worry about the traction loss (2wd or 4wd) on wet pavements. When I was younger (the late 80's), I used to own a 5.0 mustang with a traction lock. I learned quickly to never stomp the gas on that thing when the pavement was wet or frosty. Do it and you are in for one scary ride. The back bumper would kick out in a heartbeat.
I know I am going to stir it up, but for me the Toyota 4x4 gives me a locker that can be shut off. I consider that the best of everything. Control while in 2wd, less bind in 4wd while on road, and improved traction in extreme situations off road. The fact that it only works in lo range doesn't bother me because I am already in lo range in extreme situations. I don't need a locker if I am going faster than 5th gear/lo can provide. In a 4x4.
Everybody have a great turkey day.
I switched to BFG Comp T/A's all-terrain tires for the winter. I just didn't have the heart to go with pure snows, as they exact a severe penalty when it's nice and dry. Can't wait to see how the new tires fare when we get some snow.
Skipp, do you know the difference between a locker and LSD? With your last post I have to question your thoughts..
The locker is far more dangerous than an LSD. Lockers bind easier than an LSD too... lockers don't like sharp turns.
LSD is the most useful diff for the majority of truck users out there. LSD has many more advantages than an open diff. Lockers are better offroad than an LSD.
I had thought that their engines were all aluminum too. But, I can't say for sure.
Defect Investigations 1989-2000
Ford Ranger - 20
Dodge Dakota- 14
Chevy S10 - 51
Toyota Tacoma - 2
Safety Recalls 1989-2000
Ford Ranger- 32
Dodge Dakota - 28
Chevyy S10 - 47
Toyota Tacoma - 6
Technical Service Bulletins 1989-2000
Ford Ranger -2,279(yes, 2,279)
Dodge Dakota- 940
Chevy S10 -448
Toyota Tacoma - 150
So there you have it. All data is factual, and very telling. This is NOT "subjective".
A trucks reliability and build quality is NOT "subjective".
Not all trucks are built the same, as you can plainly see.
Here is the hard link:
http://www.nhtsa.dot.gov/cars/problems/
National Highway Traffic Safety Administration
kinda gives the hoodscoop effect.....cool.
Spoog, we have seen these stats over and over again. You want people to see the TOTAL numbers not read into it and see what the numbers really mean. Noone is going to take the time to read every TSB or recall. All the recalls are NOT for every built either...
Toyota does cut corners and their pedestal is slowly crumbling. I was at a Thanksgiving party and was talking to a person who purchased a new 2001 Camry. Problems, problems, problems, from electrical to the transmission... I was chuckling to mystelf wishing all these Toyota fanatics who think Toyota is perfect could hear this....
the top 20 selling vehicles in its 6 years of
production if its so great?"
You have ansered this for us a million times, THEY COST MORE AND ARE JAPANESE
I know this is way off topic, but as Cthompson pointed out, this room is getting stale.
But, I don't think that the Tacoma having a japanese nameplate has much of anything to do with it. On the contrary, the japanese nameplate (with the implied higher quality) seems to be a strong selling point. That's at least what the Tacoma guys on this board have to say about it.
What are the two top selling cars in the US? They're the Camry and Accord. They're japanese branded, and they seem to do okay.
Besides price, I think more of the Tacoma's low sales numbers lie with limited trim levels, option packaging, a somewhat stark interior, a very ugly 2wd truck, a tighter cab, and the weakest top level engine (currently anyways).
In other words, you don't tanglibly get more for your money than its competitors.
As for the [non-permissible content removed]-tek... Yuck!!!
Yes, the Celica is U G L Y! But hey, its a Toyota and its ok right.??
allknowing, 6 years... Your analogy of the Ferrari is a joke. The capacity to make Tacoma's is there. People just aren't buying them in droves like the Ranger.. Why? Ranger has been the most sought after compact truck for 14 years STRAIGHT. Some say sales don't matter... Bull...
Sales make MONEY.
Many of the full-sized truck owners seem to be older and have the "buy american" mentality.
Compact truck buyers are generally younger and buy their trucks for every day commuter vehicles. The domestic vs. import mentality seems like a very small factor.
advertised (on TV) $1,000 cash back on Tacomas. I
even called em up and asked them directly, "Do you
give $1,000 cash back on 2000 Tacomas?". "Yes",
they replied.
When I got up there and found a nice
PreRunner...just the color the wife liked, etc...
We got into negotations, but we were far apart.
When I brought up the $1,000 cash off on
Tacomas...their response was: "That dosen't apply
to PreRunners".
I was out of there quicker than a cat could lick
it's rearend...
Ford got my money and Toyota did me a favor - I
scored a better truck and it cost less. The Ford
dealership is on Thornton Road in Atlanta/Lithia
Springs. Pretty good place IMO.
