GMC Sierra: Problems & Solutions
- Tim
It hasnt been maintained too well, but over all a good buy and pretty good shape.
I had to replace the water pump, tires, brakes.
What is driving me crazy is the popping in the front end as I turn.
Nothing on inspection showed wear and needing to be replaced. A front end man told me there was aa recall on this front end. he claims that the way the dealer fixed the popping was by placing a certian kind of grease in the joints.
I cant believe this, but it does not pop as bad after you grease the front end. After one week of driving the popping returns gradually and prossiveily louder......Comments welcome.
I hope these potential problems point you in the right direction.
I originally had just a radio, and I stuck his old one w/CD player in my dash and it's locked.
Apparently the RDS radios aren't as easy to reset.
These aren't the BOSE units - just the GM's.
Any one have a clue if I can reset this or should I buck up and take it to a dealer?
Thanks - Tim
I had one hit indicating that it could be the fuel pump going out...I had the gas tank off a year ago to replace the brake line and had to take the pump off because I broke the ground lead and had to drill through the plastic electrical housing to resolder the lead...coincidence? I did replace the gas filter and that did not solve my problem. I haven't replaced the fuel pump as of yet...
Now, I have taken a second look at the EGR valve. I took it off and cleaned it and tried to make sure that it was closing at idle. I didn't see any problem with it and stuck it back on. However, recently I disconnected the vacuum line, stuck a golf tee in the vacuum line and have been running it around and have noticed that my surging has cleared and the truck is running well. At highway speeds, after warmup, the Check Engine light comes on as expected, but the truck runs fine.
My assumption at this point is that the EGR valve is spring loaded and lost enough of its closing strength that the small vacuum present at idle is enough to keep the valve open and cause the stumble I am seeing at low throttle. At least I hope it is because I'm going to replace it shortly...
Another thing that has come to mind is that possibly there is too much vacuum at idle, indicating a malfunction of the EGR valve vacuum solenoid...It's probably the EGR valve because it takes alot of abuse in the form of heat and it is the original. Unfortunately, I don't have a vacuum gauge to give a definitive analysis.
Good luck...
If that aint it, I've always been suspicious of that EVO switch for the steering. They go bad very frequently on these trucks and when they do, they sometimes make it do some really weird stuff. Mostly the steering is affected, but I just don't trust it - wish they never put it on the vehicle.
- Tim
2. Anybody have problems with the digital odometer reading going off. If you bang the console sometimes it will come back on.
-Tim
Thanks, Dano!
It started as a noise (sounds like "aa"sound. It's a short noise. Well, I took the truck into the dealer, who ordered the part. Here's the bad part, the truck has one month over the the 3 year/ 30,000 miles (but only 24,500 miles). The dealer rep. said, they would install it free of charge, but I would have to foot the $350.00, for the replacement part. I grumbled a little, and the said, "OK".
Well, now the replacement part is starting to make that intermitted "aa" sound again. What's is really funny, is that I just got the Survey Letter about the speedometer noise fix, done last week or so.
There is a bulletin out, from GM to the Dealers, on this very subject.
Has anyone on this forum, know anything about it. Tenga Tom
http://www.startribune.com/viewers/story.php?template=print_a&story=3856014
my 2000 gmc sierra would make a thunk/clunk when starting up from a stop. i put in a new "nickel plated" slip yoke ($139.00 wholesale) with recommended grease ($33.00) and the problem has been sovled for 2 years now. a buddy and i did the install so total cost was under $175.00. i bet the dealership would charge at least $600 for parts and labor.
I'd be suprised a dealer doesn't carry this part.
Happy hunting. - Tim
When coming to a stop the pedal feels soft and travels half way down to the floor.
I have replaced master cylinders, flushed brake fluid and bled system, performed abs function tests,front brake pads and new rear brake shoes are 3/4 remaining.
when I adjusted rear shoes up to a slight drag the pedal feels pretty good but that last for about 1 week and then the pedal feels spongy again. I was told to try a bigger rear wheel cylinder to make the rear brakes work better. But it has a large dia. wheel cylinder already 1 3/16.
Any suggestions?
Brough it in for service for the rear clunking noise AND for squeaking rear suspension. Dealer said TSB for both (replacing the drive yoke with a nickle plated drive yoke for the clunk, and replacing all the leaf springs for the rear suspension squeaking).
Dealer also said BOTH items will be fixed under warranty! I was shocked. My truck is 3 yrs and 11 months old, and at 35,700 miles (just under the 36k). I thought it was 3yrs/36,000 warranty - whichever comes first, meaning I am past 3 years. I was so certain they missed the time thing I even called back and they said yeah it's still under warranty.
I haven't picked it back up yet, but am nervous, until it's in my hands without a bill.
I don't want to ask too many questions in case they missed it (as this is an expensive repair in labor i'm sure) - but am I wrong in thinking it's only 3 years?
I did mine , i belive it was causing carbon buildup on the pistons due to poor combustion . The carbon on the pistons caused pre ignition .
I used throttle body cleaning spray and a rag . I also needed to rest my computer after this becaue the sensors took a good shot of the cleaner as well.
This cured my growling noise.
No trouble codes are comming up ?( check engine light lit)
Does it seem to run hot? Possible catalytic converter partially plugged. Can you rev. it up past 1500 while in park or nuetral?
I don't know what to think about the noise, -maybe because it's in 4 - wheel and it's getting beat up because of it.
That front end sure sounds like the differential is somehow engaged or partially engaged. I guess you could yank that fron tdrive shaft off to try and rule it out, or try to get someone to watch the front shaft to see if it rotates while the truck is in motion first. Then again - it might not spin at a low speed while your trying to watch it on the driveway but just at a little higher speed. - something to try. - good luck .
- Tim
- Tim
just kidding. - How'd it turn out?
- Tim
Is this something it just started doing that it hasn't done before? That doen't explain the noise 'though unless the cv's or the ball joints are well worn.
Tough one. - wish you luck. - Tim
- Tim
all it was is the power sterring pump needed topping up. apperantly runs as a booster. top up the fluid
B
