GMC Sierra: Problems & Solutions
The tranny pan does have a drain plug if I recall but you should change the filter if you change the fluid. Curious as to why your changing the fluid? is there a problem? These systems are closed and not subject to outside contaminents, owners manual says not to touch it for 100k unless used for towing or heavy service then do it @ 50k.
My buddy who owns transimission repair business says the same thing, unless there is a problem don't mess with the tranny. He also stated that these quick oil change places push for the "flush" and change because it's a money maker not a necessity. They use questionable scare tactics in getting you to do it similar to selling you a "motor flush" because of sludge build-up. All smoke and mirrors to the unsuspecting or uninformed consumer.
Ray T.
Let us know the results. There is nothing under the dash that would cause a brake system air leak.
Ray T. :shades:
- Tim
Continuing to use DexCool probably will not harm your vehicle. Just understand that the 100,000 mile slogan is bogus. When you have your coolant changed, get the system fully flushed to remove the residue and continue change it every 2-3 years.
HELP??? :lemon:
kcram - Pickups Host
This is the motor with the cable type regulator.
1. Raise the window. If the window motor is inoperable, remove the window to gain access to the window motor retaining screws.
2. Remove the door trim panel.
3. Remove the water deflector.
4. Remove the door speaker.
5. Support the window.
6. Disconnect the wiring harness from the window regulator motor.
7. Remove the 3 bolts (1) from the window motor located on the front side of the motor. IMPORTANT: Do not allow the cable gear to come out of the housing. A failure will result with the cable coming off the spool.
8. Separate the motor from the cable housing by wiggling the window motor. Observe the orientation of the window motor.
9. Remove the motor from the door regulator assembly.
Install
1. Install the motor to the cable housing by wiggling it into place. NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the 3 bolts to the window motor. Tighten Tighten the bolts to 5 N.m (44 lb in).
3. Install the window, if removed.
4. Connect the wiring harness to the window regulator motor.
5. Remove the window support.
6. Connect the wire connector to the switch to inspect the operation of the window. After inspection disconnect the wiring harness and continue the installation.
7. Install the speaker.
8. Install the water deflector.
9. Install the door trim panel.
Ed
If all that stuff looks right, start looking for a short somewhere. I've had trailer harnesses go bad internally to the plug and cause this sort of thing even though the plug looked fine on the outside. Good luck.
- Tim
I just bought a 2000 GMC Ex-Cab 4.8L and already it has been taken back to the dealer twice for repairs all before my first payment!
I will tell you what has been done and then let you know my most recent problem.
1. Fuel Gauge Sensor Replaced -
2. PW - Window Regulator -
3. Power Steering Unit and Steering Shaft -
4. Heater Fan -
5. Alignment, Rotate Tires -
Now - Has anyone had this problem...
In the rear-end, Take off and not only hear a clunk noise, but feel it go through the driveline. Really notice it when taken off at an angle (forward or reverse) such as from a bottom of a hill.
For the most part, it when taking off from a stop.
The dealer has checked the universal joints, yoke, springs, shocks, u-bolts etc...
Dealers response? "This is normal"
I know when you shift gears from say, reverse to drive - yes it does make a "normal" noise, but what I am hearing is LOUD.
Note; This was not happening when I first bought the truck, maybe 3-4 weeks after.
Does anyone else have this problem?
Any suggestions?
Thanks All
I'm not having much luck with mine. I'm almost suspecting body flex at a seam but it's too difficult to diagnose unless I got a little guy to ride underneath when I go four wheelin'. Any takers?
Good luck. - Tim
Just got back from a 2 week trip, with out the 2002 2600HD crew cab. I went to move the seat backwards and only one side (rail) would move. The seat was then moved forward and again only one side would more (same side that moved to the rear). When I say moved, the movement is only 3/4 to an I ".
I look under the seat to see if the seat was catching on anything. As far as I could tell there was nothing on the rail or anything snagging the seat.
Your help would be appreciated. Tenga
Good luck. Watch out for those differentials, mine has 95k and both have been replaced.
And this fixed the problem, but now its back, my manual shows a coil driver in the manual but no description what it does, does anyone know if this could be the problem ?.
Its the small black thing on the same bracket as the coil, not sure if this is the problem or not, but I've replaced everything else.
I could set my watch with how this truck runs, almost right on an hour of running time it really starts stumbling and grumbling almost undriveable, if I stop and turn the truck off and wait five minutes, it runs fine when I start back up, but goes bad pretty quickly after that.
Any help would be appreciated, thanks. :sick:
The line that is leaking is the long hose which leads from the booster toward the front of the vehicle along the frame. I wish it were the 6 inch line which ran just underneath this longer line!
I'm trying to find an illustrated parts diagram showing or info about how and where this Intermediate brake line connects to other hoses at the front. This line looks very long, appearing longer than the standard 60" steel brake line length, and while the back connection to the booster is easy to get to, I've not yet found the front connection fitting.
Can anyone point me in the direction of a parts diagram - perhaps at an online catalog site, or even print catalog - showing the steel brake lines for this truck? Also, I'd welcome any suggestion on how to make this repair a bit easier. Due to all the rust, replacing the rear brake line attached to the left rear wheel was a killer. I'd like to find the most efficient solution to this challenge before I jump in.
Any suggestions are appreciated!
Bill B.
Pittsboro, NC
-David
I have a 1999 GMC Sierra SLE 4X4 Exteneded cab with a 5.3 engine. In April I noticed an engine noise that turned out to be piston slap. Very annoying. The engine had 45000 miles on it at that time. I had purchases an extended warranty 6/60. The dealership went to bat for me and I ended up with a new engine. I had the choice of a Texas rebuilt or a goodwrench engine for an additional $1300.00 I went for the GM engine. The problem is this: After the engine had been in for about 500 miles I had a flowmaster 50 series converter back exhaust installed. At about 1500 miles the truck developed a hesitation at take off. It has been to the dealer 6 times and still has not been repaired. New fuel pump, PCM, O2 sensors, Mass air flow sensor, Cleaned the fuel rails, New fuel filter, I have a K&N Air filter. The dealership flashed the PCM and things were fine until I turned on the A/C where the hesitation has returned. It has never logged a code. Fuel mileage is about 12 mpg.
Do you have any suggestion the the dealership might try?
Thank you for any help on this,
Tim
Any ideas??
Thanks a million!
The problem is a Fuel Sensor.
It's located on or around the Fuel Pump - I had the dealer fix mine. The day I bought the truck, the dealer filled the tank for me, before I drove off the lot, the Low Fuel Warning light came on and the fuel gauge dropped to E.
I believe they had to drop the gas tank to fix it.
It will probably cost you more for labor than parts.
This was just the begining of problems for my truck. See #1136 above.
Good Luck to Ya!
-David
Just thouht I throw that out there.
- Tim
I just bought a '91 GMC 2500 5.7 Liter V8. Its a nice truck in and out. Excellent condition. great running condition. Lots of power. Smooth running truck. Idles nicely even at startup. No hiccups. Nothing to indicate anything was wrong. Its been very well cared for over the years.
Except. I'm getting 5 MPG!!! yes FIVE! I dont know what's wrong. It was just smogged on thurs. It passed. I can go 30 miles and use up a 1/4 tank of gas. Its a 22 gallon tank. If its getting 5 MPG empty, I'd hate to see it pulling a loaded horse trailer!!!
Does anyone have any idea why its such a gas hog?? Its killing me. I'm just glad this truck isn't my main transportation. I wouldn't be able to afford to even go to work!
Lisa
Just a note for the Do_it_Yourself'ers. I just finished changing the internal Filter in my 2003 GMC Allison Transmission, actually a piece of cake, no external attachments to remove, drain plug in pan actually works and all pan bolts are easily accessible. The internal filter is about $29.00 and the external spin_on was about $20.00. I could not find the capacity listed anywhere, but to let you know, it was approx. 10 quarts.
"Fill after rebuild, 12.7 qts." and
"Fill after fluid and filter change, 7.4 qts."
Don't know why the discrepancy. You might double check the level being sure to use the procedure as stated in the Owners Manual. Kinda complicated.
Curious about the internal filter you mentioned. Can't find anything about it in the S.M. Is that its official name?
BTY - If there's an Allison dealer near by, you can get those spin-on filters for about $9.00.
-David
- Tim
