Visitor Agreement.
Dusty
-David
could i need a new water pump?
HELP HELP Thanks
Steve
What exactly do I ask for?
When I make a turn to the left it feels (in the steering wheel) like little bumps or knocks like the joints are not working correctly.
If anyone has any information on how to get the dealer to replace the shaft please post it here. Warranty or otherwise.
I don't need it but if that is a good deal then I'll get it or tell you all where to find it.
Just curious was yours under warranty?
Not to change subject, but the code read info must give them fairly detailed info as they knew how many miles ago it happened. It's starting to be a little spooky as it won't be long until they will know where it happened, what time, who was driving, how fast you are going, etc. Guess the black boxes (EDRs) already provide much info if you are in an accident.
Something I am finding annoying is the dash button that controls whether outside air is circulated in the cab or not does NOT remember it's setting from one start to another LIKE IT DID in my 01' Sierra. It always defaults to letting outside air in. This wouldn't normally be a problem unless you're behind a diesel cement truck or near a dead skunk first thing in the morning on the way to work which occurs on a daily basis. It's not until you realize this and the cab is full of diesel exhaust and you push the button to lock all that lovely exhaust in the cab.
But seriously, this is really annoying. Why did they change this behavior? More importantly, how do I fix it so it remembers between starts OR how can I get it to default to closed (no outside air circulation).
Thanks for any help,
-Mark
The one thing that the Japanese do that Detroit doesn't is correct the root cause of the problem, as in the manufacturing process, etc. With Detroit they only fix the problems as they break but never figure why. That's the reason you may still have the same problem on an 04. With GM there must be no communications between dealer service and factory design people.
When Toyota gets to 70% market share maybe they'll figure it out. There is no reason why GM and others can't do it better in the USA.
They pretty much told me to pound sand and if I even thought of changing it's behavior, they'd void my warranty.
Boy, they really told me. ;-)
It only does it when I accelerate from a slow rate of speed or from a dead stop? Has anyone ever heard of this type of problem? The temperature guage is reading normal? Could this be a heater core problem? Any help would be greatly appreciated, thanks!
Common sense would say that GM, as the largest auto mfr in the world, would have a 1st rate quality control organization that would examine the root cause of failures and fix them.
Yet if you look at the poor reliability of many of their products in Consumer Reports, you can only shake your head in bewilderment. And its the same problems year after year.
There is only one reason that GM does not have the most reliable and highest quality car or truck in the world, and that is poor management.
2001 Gmc Sierra
