Dodge, Ford, or Chevy: Which one...?
2
  • cdeancdean Member Posts: 1,110
    Lariat,
    http://www.gmpowertrain.com/engines_cartruck/vortec_silver/53_torque.htm
    The "meat" of the torque range is the same all the way across.
    Jcmdie's experience is the only one I've heard like that. I know many owners of 5.3s and I've driven a couple. everyone will snap your neck with very little throttle off of idle. and the passing speed is plain scary.
    I would trade my Vortec 350 for a 5.3 in heartbeat.
    kcram,
    I feel your view is a little skewed. Honestly, what if you didn't have a tach in your truck or the rental unit? Would you have really known or cared what rpms your were at? Not likely, I say. Could you feel hesitation because you were waiting for an upshift? If you are waiting for an upshift, its becuz you were accelerating!
    Point is, even though you're used to the Cummins, it is giving you high horsepower in the 1500-2500 rpm range (due to the high torque). The new GM engines, as all gas engines do, run higher rpms because thats where their high horsepower is at...thats why gas trucks have different auto trannies than diesel trucks.
    So maybe its the diesel tranny you like?? ;)
    -the view from a gasoline driver
    I don't think wear and tear is really a big factor just because engines haver higher redlines. My old 350 would turn about 2500 rpms when towing in 3rd gear. The new 5.3 I towed with once turned around 2500, give or take 1K.
    The newer engines (of all models) should last longer than any of their predecssors. Just look at how far material sciences and tribology (lubrication engineering) has gone the past 3 or 4 years.
    cdean
    Then why did Ford raise its torque and horsepower ratings on their 5.4, but lower the rpm at where these peaks occur? :)
    As for the tach, neither of my F150s (302 V8 in both) had one. But knowing the formula for calculation, I knew that my rpm were approximately mph x 100 in 1st gear. They absolutely died at around 4400 or so, and were pretty gutless at that point. The Silverado I had as a loaner was driven identically as to how I drove my Cummins. But it just seemed as though the computer was set to make sure the transmission and throttle always got the engine up to higher rpm. I agree with lariat1's comment in #54.
    The reason I brought up the wear issue is the same reason you refute it. The advances in metallurgy and lubrication also have resulted in engine parts with MUCH tighter tolerances than ever before. Thirty years ago, a gas-station mechanic could fix your engine by making a new part fit 99%, and it worked just fine. Today, you almost have to have a dealer repeatedly adjust a repaired part until it hits that exact tolerance necessary, otherwise you have rough idle, poor throttle response, low fuel economy, etc. Add in these "extended maintenance intervals", and Joe Average will probably drive a truck for 100,000 miles without changing anything but the oil every 7500 miles, because he doesn't realize his coolant is shot, the trans fluid is cooked, the wires are hanging by a thread, and the engine is sludged. Meanwhile, "old-style" engines like my Cummins, the Ford 460, the Chevy 350 and 454, or anything similar will continue on indefinitely with simple rebuilding/overhauls.
    kcram
    Co-Host - Smart Shopper & FWI Conferences
    edmunds.com Town Hall
    i guess its all in preference.
    I can say that when the pedal is too the metal, the 5.3 will outpull the 5.4. (slightly) Magazine tests have documented that.
    Maybe thats why GM made their torque curves flat? ;)
    I still don't understand yours and Lariats suggestions (re: post 54). If you have 90% of your peak torque from idle to redline...exactly where is this 'meat' from the torque curve? It is meat the entire bandwidth!
    the tradeoff between the 5.4 and the 5.3 is that the 5.4 gives ~10% more torque from idle to 2500 and the 5.3 gives ~5-10% more torque from 2500 on up.
    idle to 2500 is your normal driving range in a half ton.
    2500 to redline is your towing rpm range (in a half ton, locked out O/d).
    make any sense of my gibberish?
    On the wear and tear issue, i don't see where you're coming from. Elaborate on an example of a 'repaired part' you mentioned.
    I thought we were talking about basic engine wear: Rings and bearings. haven't seen any ill-effects of worn components outside the engine on any vehicles i've been in contact with. interesting point, though.
    kcram,
    By the way, I have driven one of the new trucks with the Allison tranny. VERY sweet. truck I drove had the 8.1. The transmission behind any of the big 3's diesel engines would be a dream set up for RV'ers and heavy towers. I hope they put one behind the Cummins.
  • jcmdiejcmdie Member Posts: 594
    I agree, the allison trans was great. Smooth but firm. Best thing GM did in HD.
  • mgdvhmanmgdvhman Member Posts: 4,157
    to get the Allison as well..
    - Tim
    cdean,
    We agree that the majority of driving is accomplished at lower rpm - I'll even give you 3000 instead of 2500. But how many of the trucks sold today haul much more than the owner? Half-tons are continually "softened" to attract the car crowd because they make more moeny for the manufacturer. Most of the people buying extended cab half-tons would have been buying an LTD or Caprice station wagon 20 years ago. These same people also have a sports sedan of some kind in the garage, and they asked for a wider powerband, not the hardcore truckers. Why does a semi have a redline of 2100 and 15 gears, instead of a "wide" high-rpm powerband and 7 gears? Because it's more efficient to keep the engine within a narrow rpm range and let the trans multiply or reduce the power.
    Friend of my dad is an old-school mechanic - Chester. Chet is one of those guys who doesn't read or write too well, but knows cars and trucks inside and out, any make, any model. He's worked on everything from econoboxes to Peterbilts. I watched that man drop and swap a transmission, start to finish, by himself in a couple of hours without opening a manual. He made parts fit, and made them work. If he was working on an 84 Pontiac, but he could only find the parts for an 86, he made it work. When I bought my police car at the state auction over 10 years ago, it failed emissions here in NJ. Until Chester went under the hood. That engine was a throttle-body fuel injected 302 - he did not open any parts boxes, just had a couple of screwdrivers. Fiddles around at the throttle body for a few minutes, tests the emissions, does it again, then a third time - presto - green zone.
    He hates working on new engines. Everything now is computer controlled, everything has to be exact, no trial and error, no fiddling, no Ford parts on a Chevy engine (because sometimes they worked better).
    Heck, you can't even fake a fanbelt any more - how many old stories are out there about a guy and his gal driving along, a belt snaps, and it's her pantyhose to the rescue? Can't do that with those serpentine belts.
    As for the Ally, I can't wait for that to show up in the new HD Ram, regardless of what diesel Dodge ends up using.
    kcram
  • bigsnagbigsnag Member Posts: 394
    Magazines confirmed this? Which magazines? I've read them all and haven't found this yet. I'd like to know the magazine and the date. I own almost all of the major truck articles for the past couple of years. Haven't seen this yet. As for the flat torque curves, the Ford's must be pretty dag-gone flat or it wouldn't be making 260 hp. Don't believe the hype. The 5.4 doesn't fall flat after 2500 RPM's. It pulls on out to at least 5000 RPM's. Where did you get the info about the 90% from idle to redline? I want to look at that, seriously. Thanks.
    Soon ill be able to real world compare a 5.4 with a 5.3. Cousin recently bought a F-150.
    Let the fun begin
    Ryan
  • jaijayjaijay Member Posts: 162
    There was another discussion group here at Edmunds on torque versus horsepower. In this discussion it was mentioned that "it is better to make lots of torque at a higher RPM than at a lower one". The reason state was that the transmission could then be used to use the RPM to multiply the torque without having to down shift. The anology of a water wheel on a saw mill was used and used it as an example of a high torque output. The author mentions that the water wheel produces loads of torque however at a steady 10 rpm. To produce higher RPM let say 1000 RPM, the torque output is divided over and over by gearing. The final result is a higher RPM output with much much less torque. Later in the article the author relates the example to engine output and an automobile transmission and why it is better to make torque at a higher RPM than a lower one or better yet a flat torque curve. If I can find the post I will put a pointer reference to it.
    Bigsnag,
    Go to gmpowertrain.com and you can take a look at the torque and hp curves for all GM engines
    per the 5.4 vs 5.3, look up the Truck Trend February '99 issue. The Chevrolet w/1000 lbs outran the Ford w/1000 lbs by .1 seconds. Empty, the Ford outran the Chevy. The GM had a 3.73 rear end and the Ford had a 3.55, but the transmission ratios kinda nuetralized them.
    kcram,
    I think the big-rig analogy is not an apples to apples arguement. I would say the argument to the advantage of the wide powerband is because you ARE limited by your transmission, and this type of engine overcomes that. I'm not sure what you mean by efficiency, but fuel efficiency is a big plus these days for Ford and GM, despite their very different engines.
    But this gets away from my point, which I don't think I have gotten across yet:
    The GM philosophy is power across the board. This "meat" of the powerband: The entire powerband is meat. I'm talking 300+ ftlbs of torque at any speed, any rpm. Take into account your experience is with the 4.8, which is a step down in the torque department. I have driven the 4.8 and the 5.3 with the same gear ratio. The only difference I noticed was a major difference--low end torque. the 5.3 had a lot more than the 4.8.
    So you're saying the 5.3 needs to operate at lower rpms, while I'm saying it doesn't need to because it has power where competitors engines don't. That high end torque translates into horsepower advantage.
    Which brings me to the other point: You are correct, the majority of the market is now the commuter rather than the worker. And the GM engines to operate more sportier.
    BUT, for the 1/2 tons that ARE used to work and pull, tow: who has the advantage? I say GM, because 1/2 ton trucks do not pull below 2500 rpms (3rd gear cruising). the higher (and lower peaked) torque of the 5.4 is felt at low speeds and town driving, while on the highway and cruising, the 5.3 seems stronger.
    My experience is from pulling a 3500 lb boat with a 2000 model 5.3. running 70 mph @ 2500 rpms, the engine didn't even flinch at hills.
    We will obviously butt heads on different things that are important to us: thats why they make different brands!
    I understand your story about Chet. My dad is the same, he used to be able to make anything run. Now days, he is at the mercy of the dealer to do just about everything.
    Still doesn't explain to me how you think longevity is going to be reduced by higher RPM engines???????
    The Chevy has a lower first and second gear than the Ford so it actually made the gearing discepancy worse!!!
    cdean
    My opinions on high rpm engines comes from the experiences of econoboxes. Small four (and sometimes three) cylinder engines, winding out to 6000, 7000, even 8000 rpm. There's no power to get the car to move otherwise. The 3-cyl Chevy/Geo Metro came with a 4.39 axle ratio in order to make its 55 horsepower useful. These cars usually have nothing left after the first owners trades in. Want a larger-vehicle example? Ford Taurus SHO. Yamaha-designed V6, with a no-accessory redline of 10,000. You can't give that car away now. A 1996 SHO can't bring $10K on a trade, even in excellent condition, and that is a loaded luxury/performance vehicle (albeit a Taurus), that was originally sold at premium prices. My 1996 Ram is worth $17K, still half its original sticker.
    These engines all experience various upper cylinder maladies that, because of their design, are prohibitively expensive to repair, and these cars are usually left for dead at side-of-the-road used car lots.
    Who will be right about the GM 4.8/5.3/6.0, which are all based on the current Corvette 5.7? Don't know. GM has to hope they won't suffer the early teething problems of the Ford Triton engines, nor any longevity problems 6-7 years down the road.
    We agree, trucks are supposed to be designed to WORK, even if the buyer is a commuter buying a truck as a fad item. Let's also agree, in spite of the manufacturers' marketing efforts to get more of those commuters and families to buy trucks, that I'm wrong on this one. The 6.0 in the new HD Silverado/Sierra will be the most telling.
    kcram
    They already suffered those teething problems. Spark knock, cold start knock, etc. And it SEEMS to be at a higher rate of incidence than for the Ford engines. I'm not saying they are junk, just that they have had their share of problems and then some.
  • modvptnlmodvptnl Member Posts: 1,352
    excellent reply.
    Kcram, using Edmunds own used car values the SHO actually fairs very well against the Generals Caprice and Supercharged Bonneville. I realize the SHO may have had a higher sticker(probably on par with a S/C Bonneville) but you're smart enough to know that nobody paid close to that. In '97 I could have bought a $28000 SHO for $22,000. Bought the Cobra instead.
    Maybe the lack of interested buyers in American Sedans is the culprit rather than engine technology? Last I heard the before mentioned GM cars were using pushrods. BTW the last SHO's were V8's.
    Even though I hate to admit it, the higher revving Japanese mid to full size cars(and trucks) All use the evil OHC multi valve technology and we have to agree that the longevity on those vehicles is as good if not better than anything.
    You probably were upset when they got rid of flatheads and went to OHV. LOL!!!
    My last observation on this relates to your and Cdean's outlook on things. It seems one person is up to date and welcomes technology while one shuns it and wishes for "the good old days". If the good old boys took the time to use the new diagnostic equipment they'd find it much easier to reference codes to trouble shoot than try to make a Ford part work on a Chevy.
  • RoclesRocles Member Posts: 982
    amora,
    I know this subject was awile ago but some of us "real" truck owners were working and using our trucks. Ever wonder why guys like me buy Fords over Chevy? Quality and bottom line.
    I was a Chevy fan growing up and it took years for me to realize that Ford was simply better when my repair budget was better focused.
    No fuzzy math there!!
    oh geez, mod, don't get me started on "diagnostic equipment".
    1993 Ford F150, 302 V8 - rough idle, not shifting smoothly, bad fuel economy. Dealer charged me $130 ($65 an hour for 2 hours) of diagnostic testing. Know what was wrong? Number 8 spark plug died. But because of all the computers, everything else went south too because they were trying to compensate. Tech changes spark plug in about 5 minutes, truck runs perfectly again. And I'm not THAT old - 36, but yeah, 20 years ago, a dead spark plug didn't cause transmission problems, and any gas station attendant could tell you what was wrong.
    I'm not against new technology. I just want it applied properly. Don't tell me I'm not able to shift a transfer case lever on the floor by only giving me a bank of pushbuttons. Give me an engine compartment that allows me to do routine maintenance if I choose, not one covered in huge black plastic shrouds that rarely go back on straight. Make ABS work correctly in a truck, instead of a system that kicks in when I don't want it and least expect it. I actually prefer common-rail fuel systems on diesels to improve their functionality. Heck, I just want headlights that show up on the pavement in front of me, not on the overhead highway signs... :)
    As for the SHO doing well against other Americans, that's all well and good, but compare its resale percentage against its European or Asian competition. Major nosedive when you make that comparison.
    kcram
  • amoraamora Member Posts: 204
    I reember the high RPM imports, YAMAHA heads on
    '89-92 manual tranny SHO jellybean Taurus',
    reason for limiter to 7,000 rpm was to prevent
    accessory brackets from breaking....
    Long life of ultra high RPM engines can now be
    same as low RPM engines due to low friction
    material composites. Check materials now being
    used in new 4.2 GM in-line sixes, very impressive,
    also use of 6061-T6 AL alloy throughout,
    it is the new materials being used. Remember
    your metallurgy classes. Class 30 cast iron
    was favorite by all Auto makers... The Taurus
    SHO had cast iron VULCAN Ford block, YAMAHA
    did the heads. The vehicle had equal half shafts,
    ideal in a FWD vehicle. Car and Driver in
    1989 call the Sho, "FASTEST AND BEST PRODUCTION
    CAR IN WORLD"..imagine a jelly bean shaped
    vehicle with DOHC V6 AND 4 DOORS smoking a
    LX MUSTANG 5.0 up to 140 mph. I know a few
    engineers that have them. they are not worth
    much now, but were expensive. Also remember the
    Buick GN 3.8 Turbo brutish muscle car that needed
    drive with hefty forarms to operate MACHO shifter,
    I drove one, G forces on acceleration will pin
    you to seat, lost of THRUST...
    opps sorry, off topic, DODGE, FORD, CHEVY =
    NO ONE WINS!! All very great, no loyality here
    all have problems, ALLL OF THEMMM!!! uh yea...
    Amora,I now think that my only purpose in life is to correct you!!!!LOL!! The SHO WAS NOT BASED ON A VULCAN BLOCK. And the RPM was limited to keep from overdriving the accessories, not the brackets. You could chip them and run underdrive pulleys and 8000 RPM+ wasn't a problem. And yes they may have been expensive but Ford ALWAYS ended up whoring them out. Example; I bought a '93 SHO that stickered around $25000 for $299 a month on a 2 year lease. Didn't care what it was worth after 2 years.
    Kcram, you seem like a mechanical type person. I've had that experience you're talking about and it was very recent. My feeling is on any motor I do the cheap stuff myself and if it don't fix it I'll pay the diagnostic fee. BTW, I think you got screwed. They charge 1 hour here to do the STAR test for about $60.
    Two examples this year, both on 302 EFI Broncos. The one with 125,000 miles started pinging. I did plugs, wires, adjusted timing still no fix. Took it to Ford, They ran a SBCS(?) test for $60 and found 2 injectors clogged. Bought a SET of injectors from a Ford site on the net for $99 and it's fixed. Total outlay less than $250. Ford wants $150 A PIECE for their injectors!!!
    2nd example '95 with 180,000+ miles started running rough. Started with plugs and wires and THAT FIXED IT!!! What's funny is I HATE carbs. Injection is actually easier for me.
    I agree on the American vs. import values. But that's on everything, even trucks. My point was the SHO was no worse than other American sedans.
    One other thing; My recall is the CAR&DRIVER cover stated "Fastest Sedan in the world for under $30,000" Don't remember anything about "best production car in the world."
    That's OK, I respect the elderly and their fading memory.LOL!!
    Whose junks were they....I hate working on anything with that much caked on gunk and crap after that many miles. Seems you enjoy working on junk...LOL!!
  • swobigswobig Member Posts: 634
    I could tell the same story with the fleet of Ford's I have. We have a couple GM's and they've been flawless. I know your a diehard Ford guy, but there is other good stuff out there. Ford and GM both make decent trucks...
  • eharri3eharri3 Member Posts: 640
    In reply to modvptnl's comment about how 'the good ole boys' would find it much easier to figure out trouble with today's diagnostic equipment, well, I agree, the equipment makes for a very useful aid for a KNOWLEGABLE MECHANIC. A mechanic should know how to trouble-shoot and diagnose an engine's problem without mechanical aids but should be able to use them if he's stumped.
    What I find to be the case far too often nowadays is that mechanics don't know jack about trouble shooting because they've come to depend so much on computers. All the time I hear from this site about people who went back to the dealer for problems, but the dealer plugs in the equipment, doesn't get any trouble codes, and tells them 'if the computer says nothin's wrong then nothin's wrong.' Only they find out later that what WAS wrong has only gotten worse cause nobody was able to use their common sense and say 'if it's making this noise, then this might be the problem.' But unfortunately, fewer and fewer mechanics nowadays are able to diagnose a car's problems by ear or by feel. That's why I love to listen to 'Car Talk' with Klick and Klack(If you don't know what I'm talkin about email me for the address to their site.) In short, computers are useful, but only if they help us think, not do our thinking for us.
  • lariat1lariat1 Member Posts: 461
    Nowadays the way business is run is to hire smart computers and dumb workers. It is a lot cheaper to buy a $2000 computer and pay journeymen mechanics than hire master mechanics. It is sad that is that way but its the future.
    vehicles would be plug and play and we can dump the mechanics...
    modvptnl, the '89-'90 Taurus SHO engine was
    a 3.0L vulcan block with the YAMAHA DOHC heads,
    according to Design News mag. They had a full
    technical article on it. Damn it!! I left
    the mag at the company i had quit. I drove the
    '89 model. Only had manual tranny. I thought
    it was awesome. I read FORD did not have
    a FWD auto tranny that would survive the
    high RPM motor. Chevy came out with a DOHC
    Lumina that was no match for SHO taurus. remember that. I hope you agree 1000% that the
    SHOGUN engine in those years had a vulcan cast
    iron block from the mudduck 3.0L engine in
    '88 TAURUS that editor DON SHERMAN of CAR AND
    DRIVER drove to 116 mph with a 0-60 time of
    10.0 sec. I bought my wife one of these
    indigo blue Taurus DL 3.0 cars. I got rid of that
    lemonaide of a jelly bean car 2 years later.
    there is not enough memory in this townhall
    to list all the problems i had with that car,
    FORD had over 2000 ECO's on that car (ENGINEERING
    CHANGE ORDERS). Anyway, i agree with you that
    my memory is fading and appreciate the enlightment. Hope your SHOGUN engine failures
    are minimal and that you truly realize the
    spectacular performance of the CHEVY SILVERADO
    SS with 6.0L, 395 HP super FORD killer truck..
    Do I still have to realize the spectacular performance of the SS in my dreams or are they actually going to produce it???
    it is a secret
    If I were a betting man.......I live in Vegas I AM A BETTING MAN!!!!! I will bet you a steak and lobster dinner when either of us visit each other's fair city that the SHO motors share NO parts whatsoever with the CAST IRON VULCAN motor INCLUDING the block, albeit MAYBE some electronics like EECIV and some sensors or harnesses. The main clue here is the SHO V6 was always a fully aluminum motor with multi bolt mains and 8500 RPM + capability. The Vulcan, as you know, is an iron block, 2 bolt main utility motor.
    I will admit the Vulcan block was considered and Yamaha said, "NO F'ing WAY!!" or something like that. Wager????
    had that magazine. Yes, the Vulcan was considered and probably used in initial test vehicles...If I
    wager, I may end up buying you a bucket of
    CRABS at Crabby Bob's here in Riverside, Ca.
    I am close to you. I'am in Moreno Vally next to
    March AFB, about 45 min from Palm Springs.
    I do remember reading that the FORD SVT people put
    a SHOGUN engine in a '90's Ranger, performance
    was stunning but the engine, tranny & electronics
    were over $10,000. I would have liked to have
    owned such a vehicle. I think FORD did that due
    to "TEENAGE MUTANT NINJA TURBO" GMC S10 Syclone.
    Vulcan is 60 deg V-block, so is SHOGUN motor.
    hmmmmm...remember the ROBOCOP movies...they used
    these charcoal grey colored Taurus's, sounded
    like they had V8's in them, I don't know, probably
    sound effects man. The Scorpio (German Taurus)
    had a 2.9L V6. Then they put a DOHC version of
    2.9L with 225 HP, I don't think they imported it.
    Scorpio was real wheel drive, cost over $40,000.
    If price were closer to $15,000, Lincoln Mercury might have sold more. I think Scorpio was better car...at least CAR & DRIVER liked it.
    kcram,
    I don't really see how the comparison to the cars you speak of applies to this situation. In this truck situation we're talking about a redline of 5500 ( I think) which is only 500 more than the previous generation Vortec and is the same or close to the same as the Ford engines. ANy Ford owner jump in with the redline correction for me.
    I think you are saying the new GM engines have to operate at a higher RPM range. I disagree by saying they are ABLE to, but 80% driving conditions-they do not.
    -Ford engine in O/D turns around 2000 rpms cruising.
    -GM engines in o/d turn around 2000 rpms cruising.
    -Ford engines towing in 3rd gear will turn around 2500 rpms.
    -GM engines in 3rd gear will turn around 2500 rpms.
    Give or take 200 rpms for gearing.
    I don't see either engine series spending a majority of their life span anywhere above 3500, under normal driving acceleration.
    Towing medium loads with the GM engine, acceleration can run up to 4500 rpms, but cruising usually stays in the mid 2K rpm range. If you are around 40 mph and you floor it, it will jump into 2nd gear and run up to 65 mph or so in 2nd gear and redline...if you hold it to the floor. That is the biggest difference I've seen between the new GM engines and the old and competitors.
    And by the way, the jump from 40 to 65 will put you back in your seat, even when towing.
    Trying to see your opinion, I don't know if the 4.8 is a bit of a dog or not, I have driven one, but only for a couple of miles. I have towed with 5.3 for a about 200 miles and I thought the engine felt powerful right from idle. From a stop sign the truck would jump forward with only slight throttle, seeming far more responsive than my 350. And the real advantages to the engine is at highway speed. the truck I drove had a 3.42 gear.
    Compare the 4.8 you drove with your ol' 302. Maybe you are expecting the small block to move a truck off of idle like your diesel does, which no ones gas engine does. Do you really think your 302 had more power in lower or higher rpms than the 4.8? I would bet the 4.8 had more power in all ranges.
    I loved the Scorpio!! Had a used '88 when I turned in the leased Turbo Coupe in '90. I believe the original sticker was in the 30's I picked up mine for around 15. Sold it a year later for like 11. The A/C was weak which was the only fault but one I couldn't live with.The rear seat even reclined in that thing and people in parking lots would ask what kind of car it was constantly.
    Robocop! LMAO!! Always wanted a SUX 6000!!!
    Last comment on the SHO. I actually worked for a Ford dealer from '84ish to 90 as an F&I manager so I was privy to a lot of cool info. You are one of the few people that realize that SHO was short for "SHOGUN" not Super High Output which seems to be the accepted answer when asked what SHO stands for. My '93 SHO was an Auto(YUK!) and would do an honest 140mph between LA and Vegas and was a true "Sleeper"
    I now know what it was about you that seemed so familiar. You were in the car selling industry....LOL!!
    I owned an '88 too. That thing would fly. It had the 2.9 like in the Rangers but it must have been hotter. It would smoke the new 3.0 and 3.8's in the Taurus. I used to set the cruise on 100 and let it roll. Talk about makin' time.
    Yea! But I left for idealogical(???) reasons!!! I'll tell you though, the money was INCREDIBLE. I make a little more than half of what I made then......but now only HAVE to work 10 days a month!!!! I think I was SCHEDULED for 60 hours a week back then.
    Last week was at the dealers for meeting with GM. Ran into the F&I manager who I gave a cigar to the last time I was there. Well, he comes up to me and asks why I've been to the dealership so many times in the last year. I told him, "where have you seen me?". He said, "at the service dept". Moron. So we get to talking about the lemon law and he tells me, No don't do that...we'll set you up with a new truck on a trade. It's those friggin words that bothers me coming from an F&I guy..."set you up"!! I just laughed and walked away.
    "Set you up" can be unnerving but if you ever hear the words, "Lay down" "Grape Juice" or "Home Run" GET OUT NOW!!!!!!
    To make a long story short I made the owner over a million dollars a year with me getting 11% plus interest "juice". Ford had 3 warranties; Base, Plus and Total. I would ONLY sell the Total. Didn't care if it was for an Escort or Lincoln. Greedy ba$t!r& owner wanted me to sell the Base warranty that barely covered anything. I refused and have never been happier being out of that fugged up business!
    When leasing my '95 Mark VIII, the F&I guy tried to sell me the extended warranty. He looked at me confused when I explained to him that the Red Carpet lease was for 24 months. So after a little negotiating I got some freebies from the guy and bought the extended warranty. About two weeks after, called Ford leasing to cancel it as it was written into the lease....what will these guys stop at? Loved the freebies....
    Hey, that is what happened to me, on August 30th i traded in a '00 S10 Xtreme purchased in Jan. After 4th trip to dealer for horrific and dastardly engine stalling and quitting while on freeway at peak commute hour. Dealer could not fix problem, I told dealer I would seek legal assitance to invoke lemon buy-back law, they quickly said to pick out another truck and they would take care of me.....
    NO ONE!!
    I've been away for a few weeks and this new format is terrible. Just had to get that off my chest.
    Roc
  • james318james318 Member Posts: 4
    As those of you that love performance already know, chrysler will start putting a hemi in their pickups in 2002! It is a 5.7 liter, 353cid, with a modestly rated 353hp, and 353lb.ft. of torque! This is purely awesome! The silverado 5.3 has had to give up it's low end grunt just to get 270hp, which they brag about all the time. This engine will have balls! Tons of horsepower {way more than the chevy 6 liter}, and still bags of low end torque. These trucks will out pull everyone in their class, and slaughter them in a race. Just like old times in the muscle car era. My only concern between now and then, is that they don't screw up the sheet metal! There are also rumors of a 6.1 liter hemi!
  • f150rulezf150rulez Member Posts: 3
    Here's a website that posts updated sales figures every month. Unfortunately these do not break it down by Model Lineup but I'll bet that GM and Ford sales of the 1/2 ton's are pretty close. (And I am not trying to defend Ford in any way.)
    http://www.pickuptruck.com/html/otf0999.html
    My last Truck was a 1994 Chevy Silverado 1500 Z71. When I got rid of it it had 185,000 miles on it and I only had the tranny rebuilt once. That was one hell of a truck!
    I bought a 2000 Ford F-150 XLT 4x4 5.4L this time. I've got 18,000+ miles on it so far no problems.
    Ford and Chevy(GM) both make good solid trucks. It just depends on your own personal preference. I like the look of the new Ford's and the price was good. It handles great and tows just as much as my 1994 Chevy, if not more. I just didn't care for the price tag or looks of the new Chevrolet. I think the last model lineup of the Z71's looked alot better. I was hoping for a little bolder of a change in the Chevy lineup instead of rounding all the corners of the last series and slight updates to the fascia and interior.
    haha well ill be damned its a reincarnation
    Ryan
  • pocahontaspocahontas Member Posts: 802
    Copy/pasted for koontzy:
    Silverado 2500 HD vs. Ford F-250 SD vs. Dodge 2500???
    #1 of 4 Which of the three? by koontzy Jan 14, 2001 (02:56 pm)
    Soon i will be starting work for a Company called Bowen..They do construction,build bridges,lay pipe, concrete and all kind of other stuff..So I have to get a truck that can do the job...I have looked into these three trucks. but still cant decide...here some of the condition for my job..
    1.heavy duty hauling..
    2.mud-They are building a bride right now and they are down on a bank and to get up they have to drive up different slopes which are muddy as hell..
    3.hauling- will be hauling preety good sized loads.... these and other things will be smething I will have ot put up with..Including snow....
    Any opinions of these trucks wuld be appreciated..
    thx
    Ryan
