Ford F-150 Problems
 pocahontas
                    Member Posts: 802
pocahontas
                    Member Posts: 802
                    #0 of 0: (ratencio) Thu 30 Nov '00 (08:50 PM)
I dual gas tanks on an 86 ford f150. one tank
pushes fuel from tank to another. I have to switch tanks every 15 minutes. I replaced the relay but the truck will not stay on one tank. Does anybody have any ideas
Perhaps one of the people there may have a suggestion for you.
http://www.f150online.com/f150board/Forum1/HTML/000492.html
http://www.f150online.com/f150board/Forum1/HTML/000253.html
It isn't isolated because my truck does it too. Run your A/C for a while and switch it to floor/panel and let it run for a while then switch it back to A/C and let run, then shut the truck off. This produces the popping for me. Also happens when I turn the knob to off and then I turn it to A/C or floor/panel, let it run then turn back to off. Hasn't done it lately because I haven't used the A/C in a while(New England is a little chillier this time of year)but it pops in the summer when I keep playing with the A/C selector knob. I find it will definatly pop when you play with the A/C controls but it would sometimes pop even if I left the A/C knob turned to A/C for a long time. Fiddle with the controls you'll get it to pop.
2000 F150 4.6 v8 limited slip 2 wheel drive.
Was originally getting 16-17 city and 19-20
highway. On a trip through the Kentucky hills the
cruise control kicked in the throttle real hard to
maintain speed on an upslope. Every since then my
gas consumption has been increasing. Currently at
14-15 city and 16-17 highway. Dealer replaced
throttle control valve and reprogrammed computer
to
factory specs. Otherwise they say there is
nothing wrong with the vehicle.
Any help / suggestions welcome.
gk
Thanks for the info. I'm relieved to know it is normal.
Truckowner
BTW, the sound never bothered me anyway as I have often heard similar noises on other cars, especially on V8s. It's probably more noticeable on the F-150 than a car because of the ground clearance and other exposure allowing the sound to radiate from the AC pretty much unobstructed....
the other Tim
I think it could be that the normal driving noises (wind, tires etc.) hide the popping sound?
But you are right it sounds more prevalent when stopped.
Truckowner
I have heard some sounds in my super duty for 47K miles. No real problem yet. My only complaint is that the A/C doesn't get as cold as I would like when the temperature is 110+ outside.
Rich
If you are interested in possibly pursuing this
matter further, please leave an e-mail address
with your post.
At 60K miles your auto trans is having a problem. Suddenly it's a legal issue? Have it fixed and find out what is really wrong. It's quite possible that Ford may stand behind your problem. Have you got records showing that you've changed the fluid at the recommended 30K miles? If not, you may be out of luck.
Rich
#19 of 21: Ford troubles (af2c32) Wed 13 Dec '00 (08:30 PM)
I have a Ford E-150 van and it has been to Ford 15
times for air conditioning repairs. The freon has
leaked 11 times and I am on my 4th compressor.
The fight continues.
HELP--for Ford folks go to www.alldata.com and it
is a great resource to find tech service bulletins
and safety recalls for your vehicle.
Use this information with the regional
representative to help your argument.
#20 of 21: (rrichf1) Wed 13 Dec '00 (09:58 PM)
af2c32,
After about the third trip for A/C repairs I would
try another dealer.
Rich
#21 of 21: #0 of 1: (mheidemann1) Wed 13 Dec '00 (10:30 AM) (mheidemann1) Thu 14 Dec
'00 (11:41 AM)
'00 F-150 V-6 stalling (Topic #2522)
2 responses, 1 new, Last post on Wed 13 Dec '00 at
11:51 AM
I have a 2000 F-150 v-6, 5-speed that has some
type of electronic problem. At temperatures above
80F it will die, stall, stumble, run irradically
or all of the above. After it dies, if I run the
starter without switching to "off" first, it will
not start. If I tun the key all the way off and
then run the starter, it starts. Unfortunatley,
by the time I get it to the dealer, it runs fine
and they cannot find any error messages on their
computer. The speed and rpm guage generally go
wild during this "seizure". The dealer replaced
the instrument cluster, but the problem still
exists. Now that it is cold, the truck runs fine
so it is related to temperature. This has got to
have happened to someone else, can you help?
22 of 22: Trucker10 - Tranny problem (noller2g) Mon 18 Dec '00 (08:12 AM)
Transmission shudder is common in all pre-97 4R70W
trannys, Lincoln, Ford, Mercury. From Mustangs,
to F150, to Mark VIII's.
The clutch in the torque converter is shuddering
as it engages lock up.
There are several TSB's out there that deal with
this issue. Mostly, you need to change your fluid
(do a good power flush) and filter, and add a can
of Ford-Spec Friction Modifier.
There are also some TSB's that deal with the 1-2
shift acumulator piston and springs.
I seriously doubt you need an overhaul. Have your
dealer or a respected trans shop flush out your
system (about $150 if done right), fix the faulty
1-2 piston and spring (about $40 in parts, one hour
labor)and keep driving.
Change fluid every 20K miles or so.
Post 97 trannys are made better.
Greg
Wichita
clogged fuel filter
clogged air filter
timing not set right
clogged emission control system
bad plug or plug wire
electrical fault in ignition system
fuel injection not properly metered (i.e. too rich or too lean)
bad gasoline
cheap or too low octane gasoline (I run Chevron premium in all my cars and NEVER have pinging problems)
Can also be a combination of all of the above. Fuel filters should be replaced annually.
But..........
In early November my engine started squealing like crazy. When I first started the engine in the morning or after it had set for several hours it would squeal until the engine warmed up. I thought it was a bad belt. But after listening to it a little closer I decided that it was probably a bad bearing.
I took it to the dealership to get it looked at and I was told that the Crankshaft Damper was out of round. Needless to say they replaced it but they also had to replace the Tensioner Arm and Pulley and the Idler Pulley, along with a new belt.
Once all of this was replaced I noticed a slight gain in takeoff power and little less vibration in the pedal.
I can understand replacing the Crankshaft Damper and the belt, but, why everything else? It was all covered under warranty so I really didn't question it then. Although after reading through all of the discussion topics out here I thought I'd throw this out there to see if anyone has experienced this or know of someone who has? Maybe someone could tell me why they needed to replace all of the other parts.
Kev
my 2001 s-crew with 5.4l makes a raspy/gurgling type noise while accelerating. i'm having a hard time deciding if it is intake or exhaust noise. anyway, i think it is intake noise and it does sound slightly like pinging. however, i'm pretty sure it isn't actually pinging. btw, ford only recommends 87 octane for the 5.4l. anything else could cause poor performance. at least that is what my owner's manual says...you should probably check your manual to see what it says...
davesnothere,
most of the potential problems you suggest would cause the check engine light to illuminate. back in 96 the federal government required these things to be continuously monitored (obdII-on-board diagnostics) by the powertrain computers on all cars and i'm pretty sure light trucks, altho i'm not entirely positive about trucks...
for the rest of you,
i noticed you guys talking about "popping" noises. are you hearing this inside or outside the vehicle? i've noticed "popping" noise while pulling up along side a building, say while i'm waiting for my big mac at mickeyd's. the sound is very similar to that experienced after shutting off the truck and the exhaust is cooling down. is this what you guys are talking about? thanks.
Does anyone know a good, reliable independent Ford mechanic in the north San Diego County area?
Thanks, Jay.
rental car if the work is covered and will take several days. Thanks in advance
My question is, given the oil change/low oil level fiasco I described is there any speculation on where the clatter is coming from? And how long should I expect this engine to survive without major work?
The LT265 75R tires have a radius measurement of about 7.825 inches (265mm / 25.4mm-per-inch * 0.75).
Assuming that both were on 16 inch wheels, the respective circumferences would be 90.958 inches and 99.430 inches, meaning that the new tires are 8.472 inches more in circumference. This means that the original tires would have made about 696.585 revolutions per mile. The new tires would have carried you 1.093 miles in that many revolutions.
So, assuming I haven't made any horrible math or factual mistakes (and I trust someone will correct me if that is true), that means that your 13.5 mpg is actually more like 14.8 mpg and your 15.3 mpg is more like 16.7 mpg.
In addition you should notice that everyone else seems to be driving slower than they used to! ;-) (Your speedometer would be under-registering your speed as well as your odometer under-registering your miles.)
OK, engineers, how did I do on the calculations?
So, if I understand this correctly, by taking off the 235 tires and going to 265's (which I did about a month ago), will actually change my speedometer to show that I am actually going faster than it shows? By how much?
(Aspect Ratio x Tread width)
____________________________
25.4 X 2 + 16
You should come out with a tire diameter of 29.877" for the 235"s and 31.65" for the 265's.
HELP! Thanks in advance!
i think what you are experiencing is pretty common amoung many trucks. my 01' f150 supercrew 4x4 does the same thing. i really don't know what causes it. however, my dad had a 2wd gmc a few years ago that did the same thing. his dealership fixed it by lubricating a sleave somewhere on the driveshaft...just a thought.
coughs white smoke? I mean, a LOT of white smoke for quite some time... videotaped it and got
close to three minutes of smoke and water running out the tailpipe.
this is on an '00 stretch-cab XLT, dealer replaced the long block under warranty at 16K and the new motor
does it too. been to three different dealers with it, the usual response is "it's fine, don't worry about it, they all do that"... Ford has some kind of buyout assistance program and the dealer where I bought it's been
working that angle but it's taking way longer than I think it should, under that deal I would have to trade it
in on another Ford of some kind and I really don't want to do that.
and my local Dodge dealer is offering me nearly as much to trade it as the Ford store is with the tradein
assistance. time to cut my losses, I think.
now at 60,000 the engine is now being replaced at a cost of $3,000.
the engine clatter you are experiencing may be due to a bent/broken piston rod.
is is just the light that isn't working, or is the button not working...ie...can you shift in and out of overdrive?
Your Ford Auto Tech,
Terry
Keep Driving Fords!
Your Ford Auto Tech
Terry
Keep Driving Fords!
