Visitor Agreement.
Your Ford Auto Tech,
Terry
Keep Driving Fords!
Your Ford Auto Tech.
Terry
Terry.
why does the 5.4l v/8 in my 01 s-crew have so much of a gurgly/raspy sounding intake noise on acceleration? just wondering as i have owned quite a few new vehicles in the last decade and not one of them made this "sounds like a junker with 100k miles on it" noise.
also, i often times can here popping noises coming from my truck when i'm pulled up next to a building with the engine running and driver's window down. where is this coming from? i haven't been able to track it down.
thanks...
5.4's are notorius for leaking oil at poorly machined head/block junction.
Check out www.f150online.com and read all about it.
Greg
I've read about and observed these door cracks on at least 1/2 of the 97 and 98 f-150s on used car lots. Ford is working on a fix--I don't know if they have one yet. f150online.com has tons of info on this.
installed 3 weeks ago at 32K. My mechanic said that the left front brake
pad was worn to the rivets....Bought the truck at 22K miles and there
were no symptons until I detected the "grinding". The problem returned
last week and the truck has been with my mechanic for the past two
days as he works to figure out what is causing it....His last phone
message said that he believes it may be related to a suspension
problem...I am hoping it is something minor that is cheap to
correct. This is going to be my first and last FORD; I liked this
truck but cannot afford to have it in the shop so often....I will
pay more for Toyota
The 2000, with 10,000. has had two problems:
(1)At the parked position, the transmission would not shift into gear, and a valve was replaced. (2) the transmission would shift into gear, apparently, but not engage--but then would engage and bolt backwards. This happened twice and after weeks in the shop the transmission was replaced. No positive account could be given for the problem. I have driven Fords for years and never had any transmission problems. Has anyone else had similar problems?
What little service that I have had from ford has been far superior to what I have received from Dodge.
Thanks for taking the time to read this.
I have a 1997 F150 with the V-6. At 44,000 miles it developed a coolant
leak. Although it was out of warrantee,Ford elected to repair it because
this is a chronic problem with this engine due to the type of gasket used in
the original assembly. The repair, with a metal reinforced gasket solves
the problem.
During the course of the repair the dealer found coolant in the engine oil
due to the leaky gasket and Ford authorized the dealer to install a new
engine at no cost to me.
A couple of weeks after the new engine was installed, I took the truck back
for some rattles and squeaks coming from the engine compartment. A baffle
and the serpentine belt were the respective causes of these noises. I paid
about $300 to have this fixed. (I know I could have squawked about it, but
I just got a new engine for free, so I figured I'd just pay the money and
forget about it.)
So now, about 2 months and 1800 miles go by and I notice a new noise coming
from the engine. A ticking sound. It sounds like a bad hydraulic lifter,
occurs only under load, as in accelerating from a stop sign, and not when
the engine is revved slightly in neutral. After the engine warms up it
subsides (mostly). Also, the engine has developed a slight oil leak.
Now, I can't stand oil leaks so it was going back to the shop for that
regardless, and while it was in I asked them to check out the ticking sound.
They just called me and said "Your crankshaft has about a quarter inch of
slop." Ford has already authorized another new engine, it will arrive in
about 3 weeks.
This entire episode seems bizarre to me. Two factory crated engines?
Should he dealer have noticed the "slop" before or during the install?
Should I look into a deal from Ford on trading the truck in? And what is
crankshaft "slop" I know a little about engines... (and before someone else
says it, I will "knowing a little about engines is exactly the wrong amount
of knowledge.") and I thought crankshafts were highly accurate machined
parts, second only to the valve train in precision.
Has anyone else had this happen? What are your impressions?
Thanks in advance
thanks.
-Chris
