There is something definitely wrong with our vehicle, but as I posted earlier, I can't wait till the new MPG standards are put in place in a couple of years. I just can't wait to see what we get in the towing department.
What is the average number of miles you drive during a typical local driving excursion?
I've found that it takes about 5 miles or so for the engine and exhaust system to warm up (further if it's cold out). During that initial warm-up period, I typically get 15 to 16 mpg. After the vehicle is warmed up, my mileage increases to 18 mpg. This is with typical stop and go city driving where you come to a light every mile or so. The biggest thing I do to increase my mileage is to bunch errands together so I can do most of my driving in one excursion, thereby taking advantage of a warm (more fuel efficient, less polluting) engine.
2007 SF AWD Limited with touring and premium packages
Dark Cherry Red with beige leather
I took one on an extended test drive today. It has 52100 miles and after 50.3 miles of mixed travel (50/50) I calculated 18.2 MPG. According to the dealer, the prior owner was meticulous on tracking mileage and got 23-25 on hwy and 16-18 in city. This is at or better than EPA estimates (remember it is ESTIMATES, not fact). Per the dealer, she refuses to call me or have me call her so I can't personally verify her stated numbers.
After filling up, I drove back to the dealer for a short 14 miles, 12 hwy. Still, I topped it off across the street with a meager .499 gals for 28 MPG. Same brand station but different location hence different pump. The car was still warm from my earlier drive.
It sounds like the 3.5L is the way to go in these cars. I would prefer the higher clearance of the 2005 but did like the ride in this 2004. And can't find many with the 3.5L engine on the used lot. They are all 2.7L and for good reason. I like this older style over the 2007 so am happier to find an older model. Good chance I will get this one Monday.
On a unrelated note, did any of you get your free coupon in the mail for an oil/filter change directly from Hyundai corporate? We bought our Santa FE in the end of DEC and just got the coupon last week. Anyone get their local dealer to get the auto-lock feature turned on for free?
I've got slightly over 6000 miles on my SF AWD and am averaging a bit more than 22 MPG.
I have to call the dealer again today too. I must still have something loose or worn already under the rear of this piece of crap. It's not the spare tire. They adjusted or looked at that the last time. Since then,(2 weeks ago) I have rotated my tires and and they must have increased the tire presure to expand the tire in it's carrier. There was almost 50 psi in it.
Overall the Santa Fe had plenty of power(I mainly used manual shift and 4th gear). The fully laden weight of our Fleetwood tent trailer is about 1800-2000 lbs plus the other items stored in the Santa Fe. The Santa Fe has a very pronounced rear sag from all of this weight, even with the touring package. I now have to investigate some sort of air shocks or some type of air bags that could be put in the rear coils? Any suggestions would be helpful
I had to regap my plugs and get a new air filter
Maybe I should go camping more to make me feel better.
Actually they can't. Those are numbers generated by the EPA (federal government) and are based on actually testing of the vehicle in both city/hwy conditions (simulated). The flaw is the testing does not emulate the real world. Highway is 55mph, no ac, no wind, etc. Thus you rarely get as good as the EPA numbers indicate. The EPA is changing their methodology, thus the numbers in the future should be a bit more realistic (and a lot lower).
I really doubt you will see a noticeable difference in MPG....IMHO the mobile One is the best choice of what you listed (would probably cost you more than what fuel you would save) BTW: Mobile one is not what is used to be...it is a tier 3 not IV as it used to be, with a little IV mixed it. Your driving habits are really the best choice. Still good oil though for better wear and tear on the engine. Oils have come a long way BUT THERE IS STILL THE FILTER TO CONSIDER (Forget about the extended oil changes with synthetics IMHO)! I think we are dealing with the weight and drag of the auto itself and dynamics of the engine.
Besides the way Hyundai is, they might take a shot at your warranty with the K&N which really does let a bit more dirt into the air intake than the stock one. WARRANTY would cost you a lot more than any savings in MPG if they take that road and something happens to the engine...this is a crossover...not an economy car or race car as you know.
Put a K&N on my mini cooper S and there was no difference at all that I could tell....sounded better though! Also if you over oil the K&N...you will cause potential damage
If I buy a Santa Fe, I plan on doing this. Inner air bag will work on the rear Santa Fe springs. Most new crossovers, will not because the shock or something else is in between the springs.
Seems to have been fairly consistent from day (mile) one, so probably no chance for increase with break-in.
I would let it pump more slowly near the end of the fill and be sure to have the nozzle centered so that it doesn't touch the neck of the tank. But don't overfill!
SUVs and Smart Shopper
Around Town: 18 mpg
Highway Trips: 24 - 25 mpg
The highway mileage has been a pleasant surprise.
One thing I am noticing is the difference between what everyone is getting as far as highway and city MPG. I do a lot of city driving in NJ. My MPG showed as low as 17.2. I did get a chance to go 200 miles on the highway and I thought it would be a great opportunity to see how highway mileage went. I drove very conservatively and only went 55mph max. I watched my computer update the MPG. It was very slow to change the numbers and I am wondering how much data is usuing to average things out. Mile after mile I would wait and every so often it would raise .1MPG I was able to max it out at 18.2MPG highway after 200 miles of 55mph driving. at the end of the trip I was at 1100 miles on the odo.
Do you think the longer you drive it, the more info it takes into account? I now have 1600 miles on it and it has never read higher than 18.2MPG. I am really wondering how people here are getting 22+MPG I have not had the first oil change done and I have not changed the air filter. I am also the only one driving hte car and rarely have more than myself in the seat with me.
Coming back east,I did get 29 mpg on a tankfull from New Mexico to Kansas.That was at 75 mph,with AC on,I'm mindfull that I was coming downhill out of the mountains with a tailwind.But still think that was outstanding.
I am running syn.oil,which also helps.
IMO,you won't get your best MPG until 10,000 miles or so.
Also,I got better mileage at 75mph,than 65mph.By about 2mpg,go figure?
My husband said the same thing at one point on our trip to Louisiana. The speed limit increased and we got close to 2 mpg better. We don't get it either!
My 2006, 2.7, still can't get over 17 mpg doing "normal" driving. I have 7500 miles on it
Yesterday, for an experiment which we can't normally do, we filled up and reset all the counters to zero, and immediately got on the freeway(Disneyland) and drove straight home (70 miles) using cruise control mostly and keeping the pedal at 61 to 68 mph. Amazingly we got 26.3 MPG
