Actually a pint over 15 gallons is 1/120=0.66% error which is small. I suspect that the circumstances of each tankfull vary sufficiently to account for 0.5-4.5 mpg per tankful. Was it hilly, stop and go in part, very cold, very hot, were you in a hurry, was it raining, etc. The prime MPG seems to occur when the car is in 6th gear but not being whipped. I have a Mercury Milan 2010 which has given between 32-33 mpg since new in mixed driving. Actually slower driving where the lower gears hang on is not very fuel efficient at all. Thus I agree with the recommendation that the longer the interval under scrutiny, the more such variations will tend to cancel out. Any particular tankful will vary from any other. The trip computer, at least in the Milan, has been within 0.5 mpg of my calculated mpg using the odometer and fuel purchase numbers. It suggests that going about 65-67 on a flat road with the windows cracked and the a/c off (when you can sustain that speed, e.g. cruise control) the Milan I-4 will give over 40 mpg. The problem is that there is no such road or circumstance that applies over a tankful unless you are on a long trip through the midwest in the early morning when everyone else is sleeping or eating donuts. I think the ultimate mpg will settle out somewhere about 35-36mpg highway once the car loosens up a bit. I'm very pleased with the Milan which I chose over a 2010 Sonata because of the NVH difference. In the Sonata I could hear too much noise in the rear suspension even when the surface was reasonably clean.
And a pint (1/8th of a gal) difference over 400 miles in a car getting approx 30 mpg will indicate a difference in calculated mpg of 0.3 mpg. Very close to some of the reported differences between computer and manually calculated mpg.
You mixed your units of measure to arrive at a 0.66% error. While a pint is 1/8 of a gallon we were discussing miles per gallon. You figured based on one pint per 15 gallons and used that % per tankful. (1/120 = 0.83%).
I hate to burst everyone's bubble, but the Sonata Turbo posted mileage is a scam. I purchased a 2011 Turbo in November and have close to 1700 miles. I check the MPG via the "Trip" and manually. The difference between the two is about .5 - .75 mpg. I admit to having a heavy foot, but I had the same foot driving my 2000 Lexus RX300. Would you believe I get the same gas mileage. I am averaging 16-18 mpg driving a 70/30 city/hwy mix. I am so upset because I was going to buy the non-turbo but the guy convinced me the mileage difference was negligible. I then heard Costco gas could be the culprit. So I drove until empty and added an octane booster along with Unocal 76 89 octane. I have been using Unocal since and my mileage actually went up, but only about 1.5 mpg. I know it is not just me because I have a friend at work who purchased the Turbo and he is averaging 20mpg with mixed driving. All the new cars I purchased in the past usually averaged between the posted sticker mileage. This is the first vehicle in 30 years of driving that is so far off base. I am actually contemplating taking action against Hyundai. I would like to hear if anyone else purchased a Turbo and is having the same poor fuel economy. Thanks
With only 1700 miles on the car I would not really call on the big guns just yet. Why don't you first wait til after the first oil change and change where you get your gas, use Shell or BP gas, then let us know want your getting. I've never heard of Unocal 76 and maybe they way they treat their fuel is not agreeing with the car's engineering. And if after the first oil change your still getting 16-18mpg, consult with your nearest dealer.
By the way. You do know that if your vehicle is getting anywhere within the specified range that's in the fine print on the Maroney Label under the big numbers, that they will tell you it's operating to factory specs. I had tell that to a customer and they just didn't believe me.
I do not own a Turbo, I have a 2011 Sonata Limited and I am experiencing awful gas mileage, 18.75 mpg/city driving. I don't do much highway driving for an extended length of time but I would have certainly thought I would get better mileage. I had previously owned a 2003 Toyota Camry and averaged 23/city. I am quite upset, will be meeting with Regional Rep from Hyundai, I hope, but I don't know what to expect since the sticker is: quote "an estimate".
Well, right now most of the US is on winter-blend gas which is a reformulation that is supposed to be more emissions-friendly in cold weather. Downside is most folks see a 2-3MPG falloff in their fuel economy. So that might be part of your problem.
There are other things to check to make sure the care is best positioned to maximize fuel economy. Things like making sure all tires are properly inflated, making sure the air filter isn't clogged, etc. You might also try a couple of tanks of gas from a top tier supplier ( http://www.toptiergas.com/retailers.html ) in case your current supplier isn't giving you a quality product.
EPA estimate is 22 city so you're only 3.25 MPG off. That could be due to winter gas, driving style, and your version of city driving (which may differ from my version and from the EPA's version). For instance, I call city driving anything non-highway. But I live in the suburbs and often can go for nice stretches at 40-45 MPH where my car is near peak efficiency.
My wife and I have over 700 miles on the car. We drive it about 70% surburban (not city) and 30. We are very conservative drivers, accellerating and braking very gently we don't speed, never exceeding the speed limit by 10%. It is mostly used with temperatures in the 30s. We use brand name gasoline of the recommended octane. The air conditioner is never on and the windows are closed choosing instead to use the car's filtered air coming through the vents. We never tow anything behind the car, the trunk never has more than a few bags of groceries and at most there is one adult and one toddler passenger. The tires are at 32psi.The car never idles more than 30 seconds except perhaps at traffic signals.
I think I have addressed all the mpg variables above. My wife and I are achieving 13.x mpg, all types of driving combined. We have used several different methods to measure mileage. Hyundai used their own unrealistically conservative test and got 16 mpg.
They will do nothing about this because the car "is operating within design parameters". I have gone up the chain of command even at the corporate level and have been basically told "mileage may vary" and I "have no recourse".
Anybody else with a similar horror story, either the mileage or their refusal to fix an obvious defect?
wow that is not very good-we also own a '11 sonata GLS but with manual transmission. We average over 30 MPG. The best so far has been 37.6 doing highway driving with the cruise control on. (5 over speed limit) Speed limit on the highway near us is 70 MPH. Our sonata, bought 7/10, has 11,000+ miles
Sounds to me like there is something seriously wrong. Could be your driving, but more likely the car. The car will get better mileage when fully broken in, but that still doesn't explain the mileage you're getting now. Do you have a trusted relative or friend that gets good gas mileage in their car? You might swap for a few days and see how they do. You might also try to get a loaner from your dealer and see how you do with that. Or, you might rent a Sonata and see how you do with that one.
This isn't going to cure your problem, but you should be able to figure out where the problem lies.
I just bought my car last week and am below 400 miles, but my mileage is not much better than 20 mpg. However I think I have a bigger problem. The car I test drove seemed like a real screamer and threw my head against the head rest when I buried the accelerator. That instantly made me want the car. I was nice to my car during the pre-purchase test drive since I was actually going to buy the car and didn't want to abuse it before the break in. After purchasing, I buried the accelerator on my car and it didn't jump like the test drive car. I don't know if the car is acting normal or if I have a lemon. It just feels like a it is missing about 100 hp. It gets up to 80 mph fast enough to be hang with freeway traffic, but I paid for 274 hp and I want 274 hp. I would like to know other owners' 30-60 mph acceleration time and the general behind the wheel feeling. .
The other test you could do, pretty easily, is remove as many variables as possible. Find a stretch of highway that runs 10 or more miles w/o stops, and preferably over flat terrain. Choose a time of day when you can drive at a constant speed -- maybe on a weekend. If there is any kind of wind, do the test in both directions. The warmer the day, the better--don't choose a day much below freezing. Check that the tire pressures are to spec, warm up the engine, get up to highway speed (at the posted speed), then reset the mpg meter. Set the cruise control if you have trouble maintaining constant speed with a light foot on the gas. If this test doesn't achieve over 30 mpg (and it should be mid-30s at least if the speed is under 70), I think there's something wrong. If it does get that kind of fuel economy, then I think you need to look closely at how you drive, including idle time (at 0 mpg), pressure on the gas pedal, and average speed (which the Sonata measures, right?).
The idea about swapping your car, e.g. swap Sonatas with your parents, is a good one. If they get poor fuel economy while driving your car, and you get much better fuel economy driving their car, that will tell you a lot. But if they get good fuel economy while driving your car... that will tell you a lot also.
Perfect, swap cars with your parents for a few weeks. Keep excellent records. Give your local dealer and Hyundai Corporate the results. If the results are as far out of whack as I suspect they might be, you should get some action from Hyundai. You have a perfect Lemon Law case if Hyundai cannot rectify the situation after you take the car in X number of times for repair. X will vary depending on your states' Lemon Law. Fifty percent less mileage can't be within specs, that's ridiculous.
By the way, awful is spelled AWFUL, aweful would be something else.
Interestingly the numbers Hyundai achieved on their unrealistically CONSERVATIVE test were16 mpg "city" (and 22 highway). There were no cold starts, no stop and go traffic and little braking approaching stop signs, therefore little loss of kinetic energy/ wasted consumption of fuel. We coasted into stop signs at 2-3 mph
Hyundai has at various corporate levels told me the figures are within design parameters.
They have refused to "fix" the car because as far as they are concerned there is nothing wrong with the car. I am left only with pursuing the liberal New York State Lemon Law. I thought and still somehow hope Hyundai would, in the face of such a blatant defect, NOT tell me and the public, as I share my story of terrible mileage don't expect much of the 2011 Sonata. I continue to spread the word hoping the attention I get will "persuade" them to do the right thing. :mad: :lemon: :lemon: :lemon:
Swapping Sonatas with my parents is implausible since they live in Florida and we live in New York. However, as an example of our driving style my wife's 1995 civic still gets 27 mpg average and my 2004 civic gets 34 mpg average. The 2004's mpg has been calculated over the course every tank of gas since I bought the car 6.5 years ago. I am obsessive about it so when I share with you that we are very conservative drivers its based on very good record keeping.
So the temperature difference between NY and FL will account for some of the discrepancy.
How about renting a Sonata for a day or two, and driving it as you would your car? That would also provide evidence to Hyundai and/or lemon law officials that there is something wrong with your car--if the rental does a lot better than your car, under the same conditions.
How about trying the highway test I suggested? That would take little time, and provide further evidence.
Every drop of gas since I bought the Sonata has been documented and I have receipts for same along with photos of the odometer and the avg. mpg display along with notes about driving type (city or highway or mix) and photos of the odometer and avg. mpg as it may have changed a bit since the last trip.
My average of 13.x mpg is well documented. The dealership service manager said of his city driving test of 2 miles he achieved 23.8 mpg. When I arrived home (exactly 5 miles) the avg mpg, having been reset before he ran the test, went down to 13.4 mpg. Their alleged 23.8 mpg "result" is written on the dealership's work order. In order for the avg mpg to have dove from 23.8 to 13.4 mpg, the Sonata must have averaged 9.x mpg for the trip home.
Hyundai corporate had absolutely no interest in this falsified information even though Star Hyundai is their agent. I don't understand what's wrong with the Hyundai people. :confuse:
Did you look at the mpg meter before starting for home (from the dealer)? If so, you would have seen the results of their test, and if in fact the mpg were less than 23.8, you would have caught them red-handed (and if I were you, I would have confronted them with it right then). If you didn't look at the mpg meter before you left for home... how do you know they didn't reset it after their test?
You'd be right about my not knowing if they reset the counter right after they completed the test but for the fact that their service invoice explicitly says "left average mpg on display for customer to see" This was never brought to our attention, and quite frankly I wouldn't have trusted it anyway. They could have putthe car on rollers "dynanometer?" The service manager had already showed himself to be sneaky.
I never imagined the magnitude of their lying so I did not carefully read through the paperwork nor the avg mpg display. Since then I have been much more vigilant about keeping a diary, jeeping track of emails and conversations with their legal dept.
Could the mpg have gotten worse? Well yes it could have. On the current tank of gas only 40% or so has been used, but already over the course or 9 or so gallons we're averaging 11.5 mpg.
I guess Hyundai will act when my wife, son or I incur physical injury due to their car's defect or condition. Hey, they said there is nothing wrong with the car, on multiple occassions. :lemon:
Let's not get overly dramatic about this. Sure, the mpg you are getting is disappointing, but how is it a safety issue?
You had a great opportunity to get some evidence in your favor when the dealer drove the car... had you driven along with them and confirmed the mpg result at the end of the test. You missed that opportunity, but you have other ways, some suggested to you here, to confirm that there is something abnormal with your car wrt fuel economy. Do you own or could you borrow a video recorder? You should take that with you when, for example, the dealer test-drives your car (you can record the mpg meter at the beginning and end), and if you should choose to take my advice and do a steady-speed highway test on your car. Or if you choose to test a rental Sonata--you can record its results. The video evidence could be very useful in an arbitration or lemon-law hearing.
Backy is correct. There are many things you can do to help yourself with this situation. You're the on that is going to have to do them, no one is going to do it for you. As far as keeping great records of your fuel consumption please understand that numbers written on a piece of paper are extremely easy to change. If you're thinking that the dealer would resort to somehow flim-flamming the mileage display at the end of their road test just imagine what they will think about the fuel consumption spreadsheet you keep talking about.
Wish you the best with this and I'm interested in the result. But..... You're going to have to rent a car and take pictures or video at this point. A fuel consumption spreadsheet is essentially worthless IMHO.
Pardon my ignorance, what what is IMHO? Also they haven't seriously contested my results. They said 16 mpg ,under the unrealistically conservative driving conditions, was within design parameters. Additonally, unless they are going to say I am falsifying the fuel credit card receipts all they have to do is look at their odometer, and the gas receipts and do the math.
I do have plenty of photographs of the odometer and the average mpg meter that support exactly what I am stating
Driving a rental will create a reference against which my numbers they can still say are falsified. I believe I am stuck with this lemon until I arbitrate under New York's Lemon Law, General Business LAw 198(a).
Until then I will continue to spread the word of my experince, giving people pause for thought when buying any Hyundai, given their lack of standing behind their own product(s).
The reason for testing your car on a constant-speed highway run and/or driving a different Sonata for awhile is to help verify that your car operates different than a typical Sonata. If you don't want to try those tests, that's your prerogative.
Realize however that a photograph of your car's mpg meter means nothing unless there is some context for it. If for example, someone were to take a video over your shoulder of the speedo and mpg meter while the car is running on the highway at, say, 60 mph, and the mpg meter says something abnormally low, THAT would provide some context.
Do you know someone in your area whom you trust and who knows how to drive economically? If so, you could ask that person to swap cars with you for a day or two. If he/she also gets abnormally low mpg, based on conditions, again you have evidence... and a witness.
Do your fuel receipts show a license number or something similar. Unless they do, they offer no proof of bad mileage for obvious reasons. In all probability, you're not going to be able to prove anything to Hyundai to the extent that they will fix the problem. You're going to have to prove something to support your "Lemon Law" case. Photos or videos may do that.
Renting a car is going to do two things for you. Number 1, you'll know for sure whether your driving style is the culprit. Number 2, renting the car will give you a chance to do a video which will probably be the best way to prove your case. Anything else, you may be just spinning your tires.
Being the impulsive, non-diplomatic person that I am I will just say that modern cars have no adjustable parameters that would account for this unbelievably low fuel economy. The only thing would be a fuel leak and the chances of this are slim and none (and slim left town). You sir can account for each and every drop of fuel pumped into this car but somehow I still wouldn't believe 11-to-13 mpg even taking into account winter cold, city (or suburban as you call it) stop and go or any other thing. I'm not saying you don't believe what you think you are getting but I think a V-8, 4 wheel drive, crew cab Chevrolet Silverado pick up truck hauling a car would get about that. Something is wrong here alright but exactly what? So, the sceptic has checked in and no the post isn't exactly constructive but sombody had to say it.
Did you buy the car you test drove? If their was anything that I learned when buying a new car is always buy the one you test drove and if you change your mind about color or content, drive that particular car as well before you buy. Most buyer's remorse are for the cars they didn't test drive.
Not to sound silly, but are you absolutely sure the transmission is in "D" and not in Manual mode stuck in some lower gear? What are the RPM's at, say, 70 MPH?
I can believe 13 mpg. In winter. In NY. Especially THIS winter. Assuming lots of idling (letting car warm up, stops, waiting etc.). Toss in a lead foot maybe (like my wife has). Sure, she drives conservatively in that she always drives at or under the speed limits. But she has that lead foot.
As a result, our 2007 Sonata is struggling to hit 16 mpg in recent days. And that's with some time by me behind the wheel, on some urban freeways. Without that, the mpg could very well get close to 13 mpg. When I drive the car, I get low 20s in the worst-case weather (in MN), around town; mid-to-upper 20s in nice weather with some urban freeway; and low-to-mid 30s on the highway. Huge differences based on weather, driving pattern, driving style.
That's why I think a car swap would be very useful here. See if it's the car, or the drivers.
I am sorry to hear about the problem, and hope you have gotten it figured out by now, but in case not. I have a few suggestions. These may have been suggested already but I really didn't have time to read through everything.
1: are you a two footed driver? meaning do you use your left foot to brake. Often this causes really bad MPG as the foot rest on the brake. 2: oil? using 5w-20? This can have a huge effect 3: do you let the car warm up before leaving? or start the car and let it run for any length of time before leaving? 4: there are no brakes dragging, or bad wheel bearings? 5: You covered the rest.
Other than that it's engine rated my guess. Sorry if you know all this already.
My 2011 Hyundai Sonata had a problem with the front defroster not directing air thru the windshield vents. Now the dealer is saying it is an electrical problem and the entire wiring harness needs to be replaced. Anyone had the same problem????
For what it is worthy, I too am shocked at my low MPG - But I have a 2011 SE Turbo 2.0T and after 550 miles am getting only 13.1 MPG. Sure I do sometimes test the turbo - but nothing crazy. My driving is 90% city as I live in LA and well - that's LA for you!
But I do have one question - some of you mention idling - are you sure that idling at 5- 20 minutes several times a tank (while I do some office work by phone) affects the calculations?
Wouldn't any decent system realize the car is not moving and not count this time idling for the MPG???
I guess what you're suggesting is that fuel consumed while not moving not be considered in the MPG (Miles Per Gallon) computations. I'm not sure what the result would be called, but it certainly wouldn't be MPG. MPG is pretty self evident. How far you go on a gallon of gas. If you're seriously idling that much, you're not going to go very far on a gallon of gas.
I'm curious as to why you wouldn't shut it off if you know you're going to be sitting for longer than a minute?
I just never thought that simply idling would use that much gas - ?!
As for why I sit with the engine running, I will sometimes work from the car b/c I am on the road a lot for work - making phone calls, returning emails, taking notes, etc. - I will idle for the air, heat or just listening to the radio (for the radio, I thought idling was better than simply draining the battery).
I actually drove about 20 highway miles tonight after resetting the mpg. With eco on, keeping a steady speed of 60 mph (and no idling!) I was showing about 31mpg. So that's a good sign I guess - we'll see as I log more miles in the coming days.
How about this? Bite the bullet and do a tank without any idling longer than 30 seconds or so. You'll then be able to see just how much the idling is costing you. Be sure to reset the MPG computer when you refill.
Sitting in a car with the radio running and the engine off isn't going to hurt anything unless you do it for hours at a time. At this time of year you can get by without heat or A/C for longer periods especially if you're in socal.
There's also a (much debated) admonishment not to idle your turbo Sonata for more than 3 minutes to consider.
Thanks for the info jlindh - I will do that and hopefully see a significant inprovement. I'm reading that 1 hour can burn a gallon of gas so obviously this would hurt my readings.
No trim of Sonata should be getting 13mpg. Maybe if time idling exceeds time driven over the course of an entire tank AND the time driven was at uneconomical speeds (less than 25 or greater than 75). That could happen in daily nightmarish bumper-to-bumper traffic. Even my V8 caddy never falls below 15mpg though and is almost always 18-21.
If something is not right see the dealer. 13 is outside the range on the sticker isn't it?
After giving up my beloved 2004 Honda Accord with the V-6, I was looking forward to better gas mileage in my newly purchased Sonata 4 Banger.....Well after 200 miles, I am averaging 25 MPG City and just got back from a 50 Mile Trip on Highway - Averaged 38 MPG To and 34 From Destination while driving approx. 70 MPH. Needless to say, I am pretty excited. This is a new engine for goodness sake - can't wait to see if mileage improves with break in. Good job Hyundai...
Just remember, when you are stopped with the engine running you are getting ZERO MPG. This is whether you are at a stop sign for 30 seconds, at a drive-up window for 5 minutes or doing paper work at the roadside.
Try this, reset your trip computer and drive a couple miles. Then pull over and sit there, noting your short drive MPG. Stay there stopped, as if doing your paperwork for 5 minutes or so and then check your average MPG.
I purchased a 2011 Sonata with 12 miles on it. I have taken several drives in this car with the gas mileage in mind each time, attempting to push the mileage boundaries. We recently took the vehicle from Kansas City, Missouri to St Louis Missouri, roughly 250 miles. The vehicle only averaged 27 mpg on the highway. I drove this vehicle at 70 mph with only a slow deliberate acceleration. My vehicle only has 1200 miles on it after the trip last week. I have managed to get 29 miles per gallon out of a 1995 corvette and 27 miles per gallon out of a 1988 mustang gt with the same driving style. I even switched to premium fuel in the Sonata before taking this trip. It was a 60 degree day with low humidity and the a/c was not used, not that it should have had that kind of an effect. Maybe someone has some real possible answers to this. I know the 2011 Elantra returned with lower than expect fuel mileage. Is this the new norm for Hyundai?
After we get a fill up we reset the trip mileage back to zero. Our "11 sonata with 6MT, bought 7/10, has 13,000+miles. Have been very pleased with the fuel mileage-over 30 MPG (figuring it the old fashion way also) On one trip from Vernon NJ to Fredricksburg, VA (gas stop) about 400 miles averaging 70MPH it was 37 MPG.
cpeny - yeah that doesn't sound quite right...I have my tires set at 33 PSI - have you checked your tire pressure lately? Also, I have noticed that the Sonata has a very sensitive gas pedal - if you just touch it, it seems the revs go up into the 2500 RPM area. I try to just feather the pedal and try and keep revs under 2000 RPM's. Last, I have the ECO button on at all times - don't know if this re-calibrates the RPM shift points, or not, but I am still getting pretty good gas mileage. So far I have driven my new 2011 Sonata Limited, Non-Turbo 300 Miles and I have 1 notch below half tank remaining; computer says I am averaging 29 MPG - this is with approx. 70% City and 30% Highway Driving...Hope things get better for you...
I concur..have followed all the rules of being a good sound driver. Check tires, etc. I am getting no higher than 26 mpg. I drive .5 miles to the highway, drive 10 miles on it and my exit to work is a few blocks. My Hyundai service team at the dealership said they "never heard of a car ever getting 35mpg". umm, that is why I bought the car from that very dealer that sold me on the 35 mpg! I am furious. I am now in the process of being a part of the "fuel consumption test" at that dealership. These guys look at me like I have 3 heads. They said the average should only be about 25. I have another 33 months on this lease. Coming from Honda's over the last 20 years, I am sick. My Honda Fit got close to 40 mpg. These service guys said that was unheard of. "nothing gets that good gas mileage". Are there lemons out there? I know several people with this car that are getting 35 to 40 mpg. Anyone out there from Hyundai that can help??? Please?
A manual calculation based on 1,000 or 1,500 miles will give a more accurate reading than a trip of 400 miles
Anybody else having same mileage issues?
Carla
In terms of driving style we drive conservatively. In fact on the highway where the limit is 55 we don't drive faster than 63 mph, and then we got <23mpg. The EPA statistics Hyundai so fondly embraces and promotes, are for 22mpg in the city and 35 mpg on the highway. The reals world results found at the EPA website: <a href="http://www.fueleconomy.gov/mpg/MPG.do?action=mpgData&vehicleID=30105&browser=true&details=on" target="_blank">http://www.fueleconomy.gov/mpg/MPG.do?action=mpgData&vehicleID=30105&browser=tru- e&details=on give an accurate picture of how insincere Hyundai is when they tell me 16 mpg is within design parameters.
www.urbandictionary.com/define.php?term=aweful
Time to go rent a car for a week or so, I'd say.
Thanks for the help!
I'm loving this forum!!
