Our hybrid with 1,200 miles is averaging 40 MPG.
http://www.fueleconomy.gov/feg/findacar.htm
I am normally at the 27..and even city it stays at about 25.
Am I doing something wrong or do you think the display is all screwed up?
This last tank was the first time I saw it at 450 till empty. Normally it is about 387 when I fill up.
Help..
I do enjoy seeing all the posts on the Sonata. My is a basic GLS.
Mind you my first tank of gas was the best and then it was downhill from there. I always drive the same 10 miles to and from work each day on the highway. I am not sure what is happening all of a sudden but I am finally seeing why I bought the car in the first place. Keep me posted on your MPG and please let me know if you reset the trip stuff each time you get in the car..ok?? Thanks!
As always, YMMV.
I have a SE. (non-turbo) Driving was mostly around town, but some back roads with no lights.
I have a basic GLS. I am also at about 25 to 27 around town. Not so bad and I am feeling better about this car now, have it 7 months and 4850 miles on it. Oil change this weekend..and tire rotation. Thanks for posting!
What's good (or at least better) for the environment can be at odds with being good for our wallets.
Seems we got suckered into Big-Ag's Corn based moonshine subsidies and are now getting poorer mpgs, buying more fuel to compensate, seeing food prices going through the roof and tax payers money going to prop up this bad idea so they can continue to scam us.
Makes a good case for diesel engines, and that scares the hell out of the Corn for Fuel growers.
Hope Hyundai will bring over their new diesel engine, so I can get rid of my VW Jetta TDI someday soon.
87 and 91 octane are always pure and 89 octane is always 10%. 89 is also always the cheapest.
This is for South Dakota - sorry city dwellers. :P
Hybrid says 37.1 with heavy AC useage.
464.2 miles driven. Mostly around town.
17.168 gallons at fill-up.
MPG: 27.0
On board MPG stated 29.3 for tank, so on board calculation seems a bit high.
I looked for your 60/40 split on www.fueleconomy.gov and others are posting 28 to 29 mpgs.
At 2500 miles, if a 'break in' period is the problem, you should soon be seeing a slow steady increase in your numbers. It's confusing tho to see cars on the first tank of gas getting stellar numbers.
Makes you wonder what brand and octane the dealerships are putting in them, as others have reported the next tank can disappoint.
(I bought a new Nissan Versa SL with the CVT powertrain in 2007 that was also rated at 34 mpgs and after 40,000 miles it's still getting 28, tried to give it to my Grandson for a College Car last year, and he didn't want it)
I bought a 2011 Escape and the same thing happened. The first tank that was supplied by the dealer I got 29.5 MPG and ever since then I have been averaging 27-28MPG. I wonder if dealers are putting in gas that contains no ethanol or some other trick? I guess with the onboard computers spitting out the gas mileage they want them to read as high as possible.
Good point!
Whenever I test drive a car with the fuel info center, that's the first thing that catches my eye....interesting idea that the dealership could tweak the fuel to show a high number.
I have thought that for a real mpg check one should take the car overnight, fill it up drive it home, do some testing for a couple of hundred miles, bring it back, re-fill it and do the math.
It will probably be far short of the window sticker number and would be a good excuse to be a hard #ss during the negotiations or, if the mpg's were really dismal...then walk away.
440 miles
14.4 gallons
30.6 MPG
On board said 30.1. This is the opposite of my first two tanks where atual MPG lagged behind on board calculation.
Mostly local driving, probably 75-25. Car now has 1,300 miles on it and MPG seems to be improving.
Charlie
:confuse: :confuse: :confuse: It's possible that you'll get better mileage after 10,000. Talk to your dealer. I'd be curious what he has to say.
P.S. This is my first brand new car. I usually buy used cars from private sellers. I don't like car dealers.
You didn't mention the engine size in your 09'...was it a V6 or 4?
Seems some of the 2011 Sonata posters on this forum are getting great mpg's right off the lot, and some are seeing better mpg's after 3 to 5,000 miles. (in your case, 10,000 miles)
Your service manager sounds kind of clueless on the subject of break in allright but from what I read on these mpg links, break-in, or no break-in is still a subject that hasn't really been totally put to rest.
Perhaps you should fwd him a link to these posts and get him up to speed from real owners.
Charlie
Feel free to comment.
C
I was able to leave from Pensacola, FL going via I-10 to Gulfport, MS then US49 north to Jackson, MS then I-20 to Tallulah,LA and US65 north to Harrison, AR then return to Pensacola reversing the routes. My overall mileage was 1441miles door to door. By setting my car trip computer to zero at the beginning, and driving mostly at 70 on the interstates and 65 on the US routes,when possible, otherwise following the posted limits, exceeding only to pass occasionally. My GPS says I did hit an overall high of 88mph somewhere. The trip was most interesting to me regarding the overall mileages etc.
I hit Jackson MS, and Little Rock AR during their rush hours otherwise I was able to keep moving although some traffic areas demanded slower speeds.
My overall mileage with my 2006 Hyundai,LX, V6, 36lbs tire pressure, figuring by subtracting mileages divided by fuel, and also by the car trip computer my MPG came out to be 25.75mpg by my calculations, and 26.52mpg by the car trip computer round trip, when I refueled finally back in Pensacola. These mileages are the overall totals for the trip.
I also was using my GPS unit and a ScanGuage so I could see the instant mpg's too. Obviously my mpg varied on the ScanGuage instant read from below 10mpg to over 60+mpg (coasting). The most enlightening observation to me was on the flat roads when I was maintaining 65 - 70 mph the car got in the low-30's mpg instant readings, not sustained.
During this trip the car reached the 30,000 total miles mark from new...I am quite sure I will never get any better mileage. Overall, I am pretty happy with the resulting MPG although I would certainly like to be getting more miles per. Oh well...I can dream, those claims of 40mpg sure look good, but I know they are mostly with a 4 cylinder engine too and on a short flat track, measuring from point to point at hwy speed of probably less than 65mph, not reality.
When i look at instant read out, when i cost i get between 25-50 MPGs, but when i switch to the average all i see is 12.
