Visitor Agreement.
Issues to date:
While waiting to turn at a stoplight after proceeding the DSG will stay in 2nd gear and will not change even if I slow to 5mph or if I hit redline. This has happened 3x once while making a easy left turn and 2x from dashing out trying to avoid oncoming cars. Also another issue I have seen is once I had turned on the cruise control while is 'S' mode and the car couldnt decide what gear to go in to. The display kept jumping back and fourth between 5th and 4th. I was going to bring this to my service advisor's attention once I take it in for a 5000mi oil change.
It is: http://audia3.net/misc/audi.tb.01-05-09.pdf
Also, that bulletin made particular mention of "tuned" ECM's, so Audi is aware folks are "chipping" this particular model and will void the warranty if they find evidence of it.
A3 tuners, you are being watched for !! :surprise:
The main purpose of "chipping" is to get more power out of the engine. Audi USA does not approve of this as reprogramming can foul up other engine parameters for emissions, knock resistance, etc.
Audi USA has said it will void the warranty on any vehicle discovered to have been "chipped" by anyone other than themselves.
None of the other cars I have owned have consumed this much oil. My friend has an Audi S4 and another friend has a VW Jetta - neither one is experiencing this kind of consumption. If this truly is the way the car was designed, Audi shouldn't recommend a 10k service interval between oil changes. If I follow this maintenance schedule, I will destroy my engine.
Statistics? No statistics, it's simply both common sense and fact. ANY car that only uses a quart of oil every 5,000 miles is to be considered in perfect operating condition. Don't believe me? Go over to some of the oil related discussions here at Edmunds and ask around.
Backing this discussion up a few years (err, decades) I used to turn a pretty fair wrench on cars, and when overhauling cylinder heads that didn't have replaceable valve guides we would "knurl" the guides. Knurling effectively reduces the inner diameter of the guide by displacing a small amount of metal from the creation of a spiral grove down the length of said guide. This would accomplish two things:
1) The reduction of the inner diameter would be limited to no smaller than the OEM spec for said guide thus allowing for better valve placement on its seat (which reduced the incidence of burning said valves), and
2) The grove effectively becomes a small oil gallery that snakes around the valve stem allowing for better lubrication within the guide area.
The drawback? Slightly increased oil consumption. The benefits? Greatly enhanced valve and valve guide life.
The fact remains that engines must use some oil, and a quart every 5,000 miles is a very good usage level. From what I've seen and heard, most manufacturers consider anything above a quart per 1,000 miles to be within spec (VW and Audi included). That a few out there use less than what your engine is using is irrelevant. That your previous cars didn't use as much oil as your current engine is also irrelevant.
Regarding your comment that said, "If this truly is the way the car was designed, Audi shouldn't recommend a 10k service interval between oil changes."
The truth of the matter is that one has absolutely nothing to do with the other. You change your oil when the manufacturer says to and you top off your oil when your dip-stick says you need to.
Regarding your comment that said, "If I follow this maintenance schedule, I will destroy my engine."
Ummm, why? Keep the oil within the allowable range and your engine will outlast the rest of your car. If it needs a quart, add the quart. Simple as that.
Best Regards,
Shipo
If I had an engine that used no oil whatsoever in 5K miles, I would probably start to add a small amount of "top oil" or "upper cylinder lubricant" to the fuel.
The above having been said, when you say, "Show me revelant [sic] current data, and we can discuss more." I suspect that what you are really asking for is scientific data, and as such, my guess is that you're asking for something that doesn't exist. Why? Because no company is dumb enough to fund a study that looks into the positive and negative effects of using a quart of oil every 5,000 miles. Why not? Because there have been hundreds of millions of engines built that use about that amount of oil and as such, the empirical evidence is extremely strong. What does that evidence show us? It shows us that an engine that uses a quart of oil every 5,000 miles is just about perfect.
Suffice to say, anybody who takes their car (of any make or model) in to the dealership and complains that it consumes the oft mentioned quart per 5,000 miles is going to get laughed at, maybe not to their face, but certainly after they leave.
Best Regards,
Shipo
Anyone have solutions until I take it in for my 5000K?
With my off and on opensky buzzing and now this I am getting :mad:
Hope that clarifies my point of view on this.
rear wiper blade worked like it was 2+ years old
scratch on glove box plastic (could of been molding manufacturing issue) (Audi won't fix)
unravelling corner to cargo cover inside (could of been cause by me, but if so, poorly designed and not durable at all) (didn't bother Audi about this one)
Exhaust tips look like they came out of a junkyard; trying to get Audi to replace, so far I've been met with a brick wall of resistance. I'm angry at Audi for this one. They claim it is within their specification and quality standards. I hope to take pics and post on this forum in the near future to embarrass Audi as revenge, if they don't fix it soon!
Interior rear quarter panel trim did not fit right, was loose, and had about a 1/4" to 1/2" gap with other trim pieces (replaced under warranty)
Rearview mirror has a miniscule speck/scratch mirror defect (Audi says its the glass thats scratched, not the mirror, and therefore not covered)
Rearview mirror moves too freely, not nearly enough tension (design flaw; Audi says its normal for A3) moves everytime I put the sunshade up! annoying!)
First 1,000 miles, had rattles in the back, but they dissappeared!!! I'm going good at 6,000 + miles now.
DSG tranny acts up every so often (very rarely), its scary though, I hope if it fails, it fails before my warranties expired, and not right after
Gas mileage has been significantly less than reported by EPA, even with conservative driving, and especially with spirited driving. I was told the engine would continue to improve on mileage up to its breakin period of 15K miles by dealer. I'm at 6K now.
Audi blames the selling dealer and most of these issues as (outside influence), but what are the chances at least half of these issues are not dealer negligence or carelessness?
High!!! very high! They can't all be!
Audi needs to respect their customer's wishes more. My exhaust tips have a terrible finish and big burnt line going across the whole length horizontally. Even Kia's and Suzuki's have better exhaust tips than this!
Not covering scratches in glass in a freshly delivered car? My Saturn ION had that (with other problems) and Saturn ended up replacing the entire car!
Take heart that your info helps me with my desision whether or not to consider an A3 next year. Very unlikely to buy one new...Audis' warranty sounds worthless.
I wonder how Audi addresses DSG clutch wear? Is that covered at all? I understand the clutches are very expensive to replace.
They did replace my rear wiper blade no questions asked.
They did replace the ill fitting interior quarter panel trim in the rear left side no questions asked.
All of the other little minor things I've had problems with could easily have been "outside influence" and caused by the owner (being me). However, I can honestly testify that almost all of these issues were certainly already there when I purchased the car. I should have done a better delivery inspection, but it was overcast, and I was excited there were no mechanical flaws.
Fortunately, the car is a blast to drive, and the best and most fun vehicle I"ve ever driven. It handles like a dream, ESP keeps you out of trouble. The dunlop perfomance tires stick to the road like no other, but the powerful engine still can make them spin w/o too much effort on the gas pedal (until ESP quickly kicks in).
Mechanically, the car has been fantastic, and I've had no breakdowns or anythhing go wrong under the hood in 6K + miles. I'm just a bit upset over the number of tiny little cosmetic aesthetic issues. I'm really happy the car settled in and the rattles disappeared completely on their own.
as I am still thinking about one when I get into the right driving circumstances.
What is turbo lag like in your car? I keep getting different pictures of this (some pubs find a lot of lag, others say there is very little). Perhaps Audi changed the A3 engine programming over the model year??
A coworker acquired an Audi A4 FWD recently...felt quite large compared to the A3 interior. But felt very stern, sort of spartian (may have been due to its all black Teutonic interior).
When you push on the gas suddenly, the DSG might have to shift down more than 1 gear, which means if each clutch is on the "next" gear, it won't be able to do that magical .2 second shift from 6 to 4, or 6 to 3...
But I will tell you this, once your in gear, and once the rpm's approach 3,000, you're flying, pushed back into your seat, and up to 100 MPH in no time at all.
For example, here in the Audi A3 Group you'll now find an assortment of dicussions like:
Audi A3 Electrical Issues
Audi A3 Suspension Questions
Changes You'd Like To See in the A3
Audi A3 Test Drive - What Do You Think?
just to name a few.
So when you're going to post, please check the discussion list at the main Audi A3 Group page to find the appropriate discussion for your comments or question. If there does not appear to be a discussion about the issue or problem, please feel free to create a new discussion. We can deal with accidental duplicates as we go along.
Thanks for your understanding and help as we get things a bit more organized!
