Audi A3: Problems & Solutions
I had a very small creaking sound appear a few weeks back coming from the sunroof area, but it has since disappeared on its own.
Let's try to keep this discussion focused on actual problems - although it's good to see no one has had any yet!
The problem is that the vehicle will not start at times. Turn the key, everything lights up and works, but the engine won't crank. The service manager at my dealership has had the same with his vehicle and is aware of other customers who have also had the problem. Audi don't have an answer.
For me, the problem has occurred randomly and, with two exceptions, the vehicle has always started on the second turn of the key. However, the incidence of failure is increasing - from one or two times in the first few days, to more than 8 times in one day at the weekend.
It has not happened again, yet.
The general consensus seems to be that when this happens your turning the key to quickly after putting it in the ignition. This happened to me a few times when I first got the car. Once I started pausing briefly before cranking the engine this didn't happen again.
--Paul
--Paul
There are a number of Audi A3 forums that anybody reading this forum will also want to check out (in addition to this forum). Unfortunately, the "Rules of the Road" for this forum do not allow me to post links to these. However, google is your friend...
--Paul
By "this" I assume you mean highway noise with the OpenSky? I think blaming it on the hatchback design is just some salesman's way of trying to make the problem go away.
--Paul
At 4k the radiatior needed to be replaced. My car started leaking anti-freeze on the GW bridge in NYC (not a good place to stop). I was told that that issue was a 'bad design' and that the clamps that hold the fan to the radiator actually wore holes into the radiator thereby creating a radiator leak.
At 7k my AC stopped working (of course on a 4hr drive to a wedding on a 95 degree day). I was told that an air sensor needed replacement and that it's an issue that they are having in the new A4 & A3.
When it's running, it's really fun to drive.
Good Luck Al!!!!
You probably know that, but it doesn't hurt to state it: in VW/Audis, there are two settings for the mpg display. Instantaneous = will display instantaneous mileage with rapidly changing numbers, and average = average over trip.
Also, concerning the sunroof question, if your sunroof is not in the closed position and you close it with your key from outside, you may need to reset it to the zero/closed position on the dial before you can make it open, again.
Sounds to me you are hearing the pressure management of the turbo. The 2.0TFSI has several mechanisms to "recycle" the air instead of just blowing it off when not needed. This keeps the turbo spooling even if there is no load for a while, thus reducing turbo lag. This would happen in particular under varying loads, such as when shifting.
Many turbo aficionados love to hear the turbo.
Did anybody had "Speed Limit" warning in 3 gear on DSG?
Very odd: I was in traffic gem this morning moving rather slow (in "D") . Several times when reached 25 m/h DSG would indicate 3 gear and then MPH warning would come up.
I haven't set any speed limits yet on the car. Any ideas?
Otherwise - love it.
I am gutted by this as i have owned Audi and Vws in the past, that have been a lot older and have not shown any signs of rust.
Does anyone have similar problems..
Any idea why the days would be so far off?
OK, here's what happens.......when the vehicle is first delivered, the maintenence timer is set for 365 days because after the first (5000 mile) service, ...all the remaining services are all at 15000 miles intervals (aprox. one year or 365 days for the average driver).
So when you have the first (5000 mile) service completed, the system will be reset, and about 365 days later you will get the warning that the service is due because 365 more days have passed.
Disconnecting the battery does not interfere with the service reminder system.
Just purchasedand A3, although im having problems with oil emulsifying in the oil filler cap but not at the bottom of the dipstick. I have been informed by the Audi dealer that this is common on A3's?? has anyone had the same experience?? Usually the emusification relates to water/air etc getting into the oil.
Dennis
tyrant0303@yahoo.com
Dennis
Mr Shiftright
Really??? Where??? (Don't bother answering, the forum [non-permissible content removed] here will just delete the message).
But that's a load of **** anyway. I frequent all the major A3 message boards and there are very few problems being reported with this car. You shouldn't make stuff up like that.
30-32 highway
This engine delivers great mileage for its performance (or vice versa). You'll be hard pressed to find better.
I talked to the Audi dealer and they said it was an issue for all A3 keys with an "A" in the little serial number that you can see when the key is extended. They have ordered me new keys (which I will pick up in 2 weeks).
Just an FYI out there for anyone who is having issues locking & unlocking their car remotely.
There's a lot to like about the A3. I sincerely hope Audi USA does not fall into the VW arrogance trap (even if VW is its parent), gets its reliability up and improves support for their small dealer network.
I woul like to know if changing of the kyes was OK and if everything working good.
Please repaly to me asap. Thanks in advance
I wish I could tell you the "fix" worked or not, but since I don't have the new keys, I can't tell you. One thing I do know is that my current keys cannot remotely unlock or lock my car any more (except on very rare occasions).
I'll keep you posted.
Each time I have received a call telling me that Audi has sent wrong keys, or bad keys, or whatever.
They are now telling me they should have "good" keys in the next day or so.
I'm am extremely frustrated with Audi at this point. I have never owned an Audi before. The A3 is a good car, but the service so far has been horrid.
a very faint high pitch sound for just a few second?
It must have to do with the electronics, and I guess
I am quite sensitive, but it is a bit annoying.
Anyone else notice this or know what it is?
This is the only minor thing I have to complain about.
This car is pure fun.
Does Quattro version come with only that suspension setup? I did not see any sport options for Quattro at the audiusa site.
Maybe in 2007 there will be other options.
