Dodge Nitro
I have only used the 4 wheel drive one time and it drove about 10 miles and then shuddered so bad I had to stop and try to pull out again and finally put it back into 2 wheel drive to go on my way.......in 10 inches of snow!!! Of course the dealer found no problem with it.............if I slow down going up a hill there is a transmission shudder and vibration of the whole car.......this is a continuing problem everytime I drive the vehicle.
I have also had problems with the dash lights coming on while driving at 55-60 miles an hour, and the radio cuts off when this happens. It only lasts about 10 seconds and then the lights go off.....as of yet I have not lost power during these episodes........the dealer finds no problems to repair for this either....suggests the car is "possessed".
I am having a lot problems with the vibration in the engine at a steady speed
40-45. there is a definate problem with the Nitro 3.7 and Chrysler is not on top of it.
At one point they told me there was not fix
Here is what they have done
4/18 Torch Converter replaced. did not work
Reprogrammed power train
4/18 Gas additive - Did not work 4/18
5/3 tansmission Friction Modifier 5/3 - Did not work
5/9 Cylinoid pack for Torch Converter which Made it worst, Darin said the factory thinks its a bad Torch converter and is shipping another one.
5/12 Picked up from Dodge and was told to pursue the Lemon Law on this car 5/12. Was told Their is a problem and the factory has no fix for it. ( see purchase order included)
5/15 sent certified letter to diamler defect notification.
5/27 factory called and wanted to attempt more repairs they have representative in town. I was told that, that did not work but they want to keep another day to work which is today)
5/28 Chrysler factory technician came in to work ont the car.
this is what he did
Applied TSB 02-005-07 - No change (Chrysler tech words)
Adjust front and rear suspension -- no changes
Shimmed transmission crossmember 1/2” to change angle - a little better
Shimmed it another 1/2” - no better (Chrysler tech words)
Shimmed it another 3/8” (Chrysler tech words)
Swapped out drive shaft for a stock unit - no change (Chrysler tech words)
Repositioned rear support links to adjust pinon angle - a little better (Chrysler tech words)
Replaced crankshaft damper - good (Chrysler tech words)
The dealer ship said I could pick the car up and that it was 90% better.
I drove it and Instead of vibrating at 40-45mph it does it 44-46 mph
I am getting everything together an contacting an attorney.
:sick:
The only major complaint was it has very uncomfortable seats for a person my size at 6'2" 260. It has very little thigh support.
I leased the vehicle because of the cheap price,convianant dealer, tow capasity and it made by a american company. If i was buying and not leasing I would not have gotten this vehicle because of the poor comfort, ride quality, and resale. Have had a number of Duangos, Rams, and a Liberty in the past, really liked them (except MPG).
I test drove most all the small SUV's last year and have to say the Honda CRV was my favorite.
Just waiting for something else to happen!!
I have buy a Nitro SXT 2,8 CRD in 4 July 2008, beginning with second day I have got some noise inside of the car and some vibrations at the wheel and pedals. This is taking at beginning 30min after that more. I was at service between 7 July and 8 august in every week for 7 times. The diagnostic was one pipe from fuel feed system it is in a wrong position, after that was fuel filter, then fuel pomp, after that they change the pipe. Every time they say you can drive safely do not worry, but in my hart I have a bad feeling. Finally I was happy with my nitro without any noise and vibrations, but in December 6 when I drive around 1000km, on the way back to home I have remark that average consumption have grow dramatically. The problem was the same pipe that was cut, in engine area, by the same vibration that comes back in this trip only when I accelerate.If is anybody here who can help me or to advice about what is happened in your country in same situations I will be glad. Honestly I'm afraid to drive this car again and I want to change the car or to get many back.
sorry if my english is not good becouse it is not my first lung
I am curious. How much are you paying for gasoline in Kuwait?
SUVs and Smart Shopper
http://en.wikipedia.org/wiki/Gasoline_and_diesel_usage_and_pricing
Recently had to take my nitro into the shop because my back breaks were metal to metal, however, the front breaks were fine. The mechanic was puzzled because the front breaks should have gone first. That was a 500.00 repair. This car is going to cost me a lot of money by the time everything is said and done. Unfortunately, I paid 25,000 for the car and now it's only worth 14,000
DETAILS:
DEFECT SUMMARY:
CHRYSLER IS RECALLING MODEL YEAR 2010 CHRYSLER SEBRING; DODGE AVENGER AND NITRO; JEEP LIBERTY, COMMANDER AND GRAND CHEROKEE; AND MODEL YEAR 2009-2010 DODGE RAM TRUCK. THESE VEHICLES MAY HAVE BEEN BUILT WITH AN IMPROPERLY FORMED OR MISSING BRAKE BOOSTER INPUT ROD RETAINING CLIP.
CONSEQUENCE SUMMARY:
THIS COULD RESULT IN BRAKE FAILURE WITHOUT WARNING WHICH COULD CAUSE A CRASH.
CORRECTIVE SUMMARY:
CHRYSLER WILL REPLACE THE BRAKE BOOSTER INPUT ROD RETAINING CLIP FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING JANUARY 2010. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Found this on LEMONFREE.COM
