Dodge Dakota Problems. Please help!
Sorry could not be of more help to you.
One other item I found interesting was that the mechanic who replaced my engine said he would never add oil "cleaners" to the engine. He claimed that rather than dissolving the sludge they more often loosen it up and plug the pump suction screen. He said he had a flurry of engine replacements the week following the promotion of a new oil cleaner product. Interesting...
I was just thinking about him as I am getting ready to go for a ride today.
Of course, there were those occasions when screens were clogged just from infrequent oil changes or other improper maintenance. I once removed the oil drain plug from a Ford six and nothing came out, even though there was a reading on the dipstick.
Dusty
I called D/C roadside assistance, They sent a toe truck in 15 minutes, took me to Jack of diamonds dealership, which is the one I now use because they have a very good service dept. they replaced the battery, checked out the whole system and I was on my way in 20 minutes. They said they have a lot of delco batteries going bad. Didn't cost me a dime. Point is maybe you should check out another service dept.
I am not JUSTIFYING the unpainted steel. I noticed my driveshaft was rusting too. (from the copious roadsalt used in the winter) Heck...even the FRAME is painted... you would think that a presecion-balanced component like the driveshaft could get a coat of paint!
Which tranny do you have? NV3500, 45RFE...other?
As bpeebles stated, Ford and GM use aluminum driveshafts that indeed look nice for a long time.
But do you want aluminum for a driveshaft when you really have to work your truck? I wouldn't.
FYI....my Suzuki also has a steel driveshaft and even though it has yet to see winter, it also has rust on it.
The truck has been great, have 65,000mi now. Anybody else hear of this type of failure?
I would never try to use this vehicle for "work", it couldn't handle it. I bought the V6 because I didn't want the poor gas milage of a V8. In reality, it gets worse gas milage. My friend has the 4.7L V8 and gets 3-4 mpg better on the highway. This thing cannot go 65mph up a 3-4 % grade EMPTY in 5th gear. Besides all the other problems - stumbling, stiff/light steering, airbox that doesn't work properly, backlash in drivetrain, excessive pitch and roll - which are all "characteristic" according to the dealer, the gearbox failed at 230 miles. Now the new gearbox is leaking at the rear seal which is also "normal".
There is nothing wrong with aluminum. It is one third the strength but also one third the weight. It certainly would have plenty of strength for this thing but may not handle the fatigue of the lurching due to the backlash and stumbling.
FYI my '84 Mitsu 2.6L with 170k miles has no rust on the driveshaft and can go up the I5 grapevine at 70mph with my dirt bike and gear in back.
A warranty is not worth anything unless the dealer admits something is wrong. Two other same configuration vehicles I drove do not have the steering problem but they call it "characteristic" anyway.
It is a Piece of Crap.
The last time I was at our Chevy dealership to get a part, I noticed five or six used aluminum driveshafts laying on the floor next to the parts dept. I don't know why they had been replaced, but obviously there was a problem with them.
Dusty
Shoulda seen our old IH Pickup.....the driveshaft which was VERY rusty made the rest of the of the rig look positively pristine!
If the shaft is thick enough it could rust for years without a problem or at least until the warranty runs out. That is the sort of prehistoric engineering that goes into dodge vehicles.
Let me know if you are aware of driveshaft failure due to rust.
BTW...my Vitara driveshaft is rusty as well and the vehicle is not even a year old......think I should get rid of it?
With my Powerslot brake rotors, ceramic brake pads and Edelbrock IAS shock absorbers. My Dak may handle better than an SXT and definatly STOPS better.
And yes my RPMs tend to linger during shifting. It also reduces the engine-braking when slowing down.
You are correct about the rear axle having wayy to much "slop" in it. There is NO WAY that I can stay in first gear and try to go slow. The drivetrain just hammers back and forth between accelerate/decelerate. I have even considerd having it rebuilt to tighter tolerances.
bpeebles- I understand you replacing the shocks. This thing is badly underdamped. A local off-road shop says there isn't enough room in the front to put a real set of shocks. The "handling package" is a joke. A tiny rear sway bar that would be undersized on an MG. I don't know how you can rebuild the rear end to tighter tolerances. You might be able to shim the ring and pinion but I suspect most if it is either the splines in the transmission being too loose or the differential gears.
I usually take it out of gear when slowing for lights since it slows down faster. Another problem is it has absolutely no feel in the clutch pedal. Like stepping on a wet sponge. Not being able to hear the motor or feel the clutch you have to go by seat of the pants or watch the tachometer when starting off.
I don't know if the problem was rust but I have seen a fair number of trucks (mostly delivery type) with the drive shaft hanging down on the road. Obviously U-joint failure but wouldn't doubt it being due to poor fit due to the retainers rusting away. I don't think rust on a new vehicle is acceptable.
I am certainly not throwing a lot of money into this thing to fix dodge's problems. It already lost $6K in value rolling it out the door according to the dealer. Given the attitude of dodge and the dealer I would never waste my money on chrysler products again. They are a Piece of Crap.
Does that make the Dakota bad? Overall, no. MINE was but everyone at some point in their life gets a bad vehicle. Doesn't matter if its Asian, German, American,etc. One time or another, a lemon makes its way out the back door to a dealers lot.
I'm not sure I understand your issue with rust. Especially on the driveshaft. But you're entitled to rationalize your purchase.
Good luck with whatever vehicle you choose.
cookie monster, ft. ogden ,fla.
Bookitty
It sounds like the dealer has been replacing components. If so, despite the few components in one and the availability of specialty tools, correctly setting up a differential is a near a science. The technician who services one should be specifically trained, and a good one will be very experienced.
I've seen a lot of differentials serviced and I would estimate that 80% of them came back with a problem. It takes someone who's very patient and particular and your not likely to find a person like that in a flat rate service department.
I would strongly push for an entire third member (rear axle) assembly, housing and all. This would mean that the differential has been set up at the manufacturing facility and thereby take the field service factor out of the equation.
It's not that it can't be done, by I would have little confidence in the dealer's service dept to be able to do this type of repair competently. Differential problems are generally very rare and infrequent for most dealerships, giving little opportunity for a technician to become really proficient at servicing them.
Keep us posted.
Good luck and best regards,
Dusty
regards &later COOKIE
Get someone to rev engine while you hold a wood dowel to front of tranny, or however you can
listen closely to that clutch fork area. Gonna have to pull off tranny to get to throwout bearing.
Note: when replacing clutch, always replace throwout bearing. When I do those jobs, I also replace the fork.. My 2 cents.. Good luck. Ger
Robert
regards &later cookie
Good luck,
Robert
regards & later and thanks to all those who helped me cookie
Bookitty
I hope that this is it for you!
Robert
John
please, any suggestions or ideas before i start under the hood.
thank you
