Millenia Starting and Stalling Issues
Hi my '95 Mazda Millenia will not start now. It cranks like it's out of fuel, but I checked the fuel gauges and everything looks normal. Could it be a relay of some sort? I had a similar problem with my '99 Honda Accord and I switched out the relay in it and now it starts fine. Someone told me that it could be a fuel pump relay, is there such a relay on my car and if so where would it be? Of course I could have my car taken to a repair shop, but I would like to at least troubleshoot the problem prior to taking it in. I hope someone will provide some answers. Thank you in advance for any help.
I have a '97 Millenia and I had a problem before with my Millennia. Try what I did, put the car in Neutral then start it should help. I am having a problem with it starting today. These things have a characteristic of bad EGR valves. My mechanic is coming over later to fix it and I am having symptoms like the no turn over, dash battery drainage
Thanks for your assistants
I still have the car however every time I start it up blue/white smoke comes out of the exhaust, then it quickly stops after the car has idled for a minute. I don't know what to do about this. This is my first car and I don't think I can affort any more repairs! Do I keep the car or do I avaoid future headaches and sell it and get somthing else? The car is beautiful and looks great but if it dosent run then whats the point of keeping it? Someone help!
Now I am still getting occasional clunking where it feels like the engine for a brief second has stopped completely. It almost feels as if I have hit the brakes pretty hard for a brief second and then it keeps running fine like normal. This is at highway speed. A clunk and jerk all at the same time. At regular speeds when I get to a light, a few times it has just died - then restarted right afterwards.
I am thinking that the harmonic balancer thing is a symptom and not a cause. Something is freezing the engine for just a second on occasion. Is this something that a bad distributor could cause? I replaced it a year ago with a used one. I can't think of anything else. I don't lose power and everything else runs fine. I can't create a situation that makes it do this - it seems emtirely random.
It literally feels as if I am just driving along and the whole engine transmission stops for just a fraction of a second.
Keep in mind that a normal stall won't cause this jerking sudden stop motion. If it just dies, it should coast. This is more like tapping the brake with your left foot while still on the accelerator with the right - except the feeling is from the engine and not the wheels. It's really hard to explain. Any ideas?
please tell me the problem
I have the same one
fousto@mac.com
please help
and found moisture rust and corrosion on the inside
So Im just gonna rePlace it thanks
Now I'm thinking it might be something under the dash, because the neutral/safety switch should be on the linkage where it connects to the tranny.
Does anyone else have the same problem?
