Just wondering if anyone could tell me the specs for an oil pressure test? I know I need to hook up a gauge to the oil pressure sensor hole, but I cant find the specs anywhere (like: xx psi at xx rpms). Or if someones got any ideas what is going on with my oil light. It comes on at idle and only after its warmed up. We just changed the pressure sensor, and nothing. Just recently changed the oil and filter (due to this problem) and ran a cleaner through it and the light didn't come on while idling (we put in 10w-30, if it helps). But as soon as the oil change was done, it started up again. If anyones got any ideas, or maybe a website, I would greatly appreciate it!
Thank in advance
My sons Accord is leaking water somewhere on the drivers side of the engine. I am not familiar with the water pumps on these cars. I followed the tube behind the engine where it hooks back up by the timing cover. I assume they have the pumped tucked behind there somewhere?? Of coarse it wouldn't leak when I was looking at it.
I saw an earlier post that said its about 5 hours with the a/c unit. I did my daughter timing belt about 8 years ago and that was a pain in the [non-permissible content removed]. I can't remember if I did the pump along with the belt but I must have. So does the front engine cover along with everything else have to come off to get to the pump???
Thanks Scott
Stop leak is ineffective against water pump leaks----so if the stop leak stops the problem, you know at least it wasn't the water pump.
Read this link, scroll up to the section on starting running problems. It may at least give you some ideas. I think it may be your ignition switch, but don't just take my word for it. There may be a recall on the ignition switch, so you might want to check on that too. Good luck
http://www.tegger.com/hondafaq/faq.html#transmission
Scott
I might have to get the car and drive it myself unless this might make sense to you. Car loose's water. He said it was on the drivers side somewhere. Okay, probably water pump. Now he gets to work to days in a row and says steam is coming out of the coolant tank but the temp gauge is still in the middle!! So I go over and start the car. No bubbles in the radiator, or water in the oil or oil in the water like a cracked head. Fans come on when the car gets to middle temp and it looks like water is flowing through the radiator. So I am thinking that possibly the thermostat could be intermitently getting stuck also?????
Scott
Corkscrew
http://www.techautorepairs.com/transmission.html#troubleshooting
Is their are difference with oxygen sensors? If their is, what is the difference.
I have a 92 accord 2.2L, FI, headers, downpipes, aftermarket catalytic converter, aftermarket resonator and a flowmaster muffler. When driving for 20 minutes, the CEL comes on and stays on. When I turn my engine off and restart it in about 15 minutes, the CEL stays off, then when I go for about 20 minutes, the light comes back on.
The car runs good with or without CEL so I was wondering if there were any differences with the 02 sensors. I just have to find out what is wrong, if anything is wrong.
I hope this makes sense.
94shadow
By the way how many 02 sensors does a 92 accord have.
The LX had a 125hp engine (F22A1) and the EX had a 140hp engine (F22A4)
The factory TCU's on these cars were:
93LX - 28100-PX4-722
93EX - 28100-PX4-732
92LX - 28100-PX4-722 (same as 93LX)
92EX - 28100-PX4-731 (Oki) or 27100-PX4-732 (same as 93EX)
91LX - 28100-PX0-823 (for whatever reason, this TCU costs twice the price of all the others's from the dealer!)
91EX - 28100-PXO-833
Before I bought another old one for $200, I would find out if it's been "recapped". If it hasn't, then it could fail tomorrow. A better option (in my opinion) would be to take the TCM out of your car and send it to one of the companies that will install new capacitors and resistors. You "could" recap one yourself, but that's not the easiest thing to do and the soldering can be a pain.
For a used, non-recapped, TCM I wouldn't pay more than $50 since it's a total gamble
Getting yours recapped should cost around $150
A new one from Honda (not worth the expense) is $600-$900 depending on the model.
I saw one TCM on ebay for $140 with lifetime warranty with free shipping.
Gonna try them out.
Sounds like a bad gas cap or one that's not tightened completely. Second guess is that your fuel filter needs replacing. Less fuel in the tank means lower vapor pressure in the fuel system (and I am an engineer, FWIW). A clue might be when you are gassing up - normally, you should hear a "hiss" when you open the cap on this car.
Newer Hondas do not have this problem, the rotors are now held on by screws, I just redid all pads and rotors on my 01 accord and was able to do it myself for under 200.
It's not a good idea to open the box for other reasons like what are you going to do anyways once you get inside it? The parts for these units are not sold at radio shack. The suppliers who deal with have a minimum order of $1,000 to buy components. The cost of getting a rebuilt unit is so reasonable when you take all the facts into account. Like what if a professional tech ruins the unit. Well that can happen and at that point we have to eat it. We also use special agents to strip the board from the enamel coating that seals the circuit board. After we are done working on the unit we seal it again with a acrylic coating to seal and protect the board. Once again most customers will not have or use these items so the job is not done right by this point alone.
Any ECm or ECU, TCM, BCM etc unit 5 years or older needs to be rebuilt or it can just miss function and or die while your on the road and cause a accident or get you stuck some place. I hope this helps you all...
A while ago I was grocery shopping and when I finished my car wouldn't start. I had someone give me a jump start but it did nothing. I had it brought to the mechanic, they replaced some old spark plugs and it ran fine... for about 30 minutes. It started shaking every few minutes and especially at red lights and then died on me again on my way to work. I brought it back to the mechanic and they replaced some old wires and it ran fine... for another 30 minutes. This time it wasn't shaking, but it kept stalling more and more frequently every few minutes until it was stalling every 30 seconds. My boyfriend got it home and it's been sitting uninsured for a while. My boyfriend took a look at it a few weeks ago and duct taped the air intake tube and the box so it was sealed better and it ran ok while I test drove it around the parkade for a bit, but when at idle the car got quieter and quieter like it was about to die but didn't. I just went down today to check on it and it would start again. I have no idea what is wrong with it and I can't keep spending so much money on it if the problem isn't going to get fixed. Does anyone have any ideas as to what the issue is?
Sorry for the novel, but I wanted to make sure all of the information was there.
