Honda Odyssey: Problems & Solutions (2005+ Models)
189101113
    the modus operandi appears to be, when an issue gets discussed a lot, they factor it out into its own forum / discussion.
    the primary argument for doing so is to help others avoid reading numerous posts they aren't interested in. a secondary argument which has been claimed by the hosts is it increases readership / participation, and reader retention.
    the argument(s) against this is a reader of this forum is probably gonna want to know about this anyway, and can skip by what they aren't interested in, plus its just simpler to have 1 than N Problem and Solutions forums.
    you're asking a very logical question.
  • deliciousbassdeliciousbass Member Posts: 18
    I own a 2003 Accord, and keep up with the discussions on that board. Now, I am trying to decide if I should purchase an '06 Odyssey for my wife. I would like to know if anyone can tell me what some of the problems are on the '06 that I should be aware of. Thanks for your time.
  • scottmtscottmt Member Posts: 21
    I just purchased on 06 Odyssey EX-L. (in New Hampshire) No problems yet. Two of the more common complaints I hear on this forum are steering wheel vibrations at highway speeds. I encountered the same issue during my test drive but I had the dealer perform a road-force-balance on the front tires and found that the factory tolerances were very "loose" - almost 5 grams on each tire - a significant difference. I have not heard any of the air "whistling" sounds that appear on the forums, which appear to be caused by improper adjustments on the exhaust A hanger. Last, but not least, I installed some gutter screen behind the lower grill assembly to protect the AC condenser and radiator - an $8.00 solution to a design issue that has "totally" been blown out of proportion on the Odyssey forum.
    If you have an appreciation for the handling characteristics of Honda automobiles, you will enjoy this vehicle. If you are looking for a genuine "soccer mom" van, go with the Sienna - less road feedback and more of a "floating the boat" feeling.
    Good luck, if you find a leftover 06 you may be able to pick it up for anywhere from $750 - $1250 below invoice.
  • blackexv6blackexv6 Member Posts: 503
    If you can wait, definitely hold out for the '07. It will get the stronger 4-shaft transmission that is in the Pilot and Ridgleline.
    I have an '06 EXL/NAV/RES and am pretty content with it.
    Here are some of the problems you will have:
    1. Droning noise at 2000 rpm. There is a TSB for the problem but the repair still doesn't fix it 100%.
    2. Road noise is quite apparent (similar to your Accord).
    3. Grade logic transmission downshifts are very abrupt (more so than the Accord V6).
    4. Question the lifespan of the transmission in the '06 (My old '03 Accord failed at 40k).
    5. Sliding door handles very difficult to open - Honda says it is normal operation (the '00-'04 generations are very easy to pull).
    6. Windows sound like they are off their tracks when down.
    7. Ride is much improved from the previous generation, however, for +$30k you shouldn't feel every imperfection in the road.
    8. Some people are reporting AC condensor failure from road debris hitting the exposed piping (under the front grille).
    That being said...if Honda resolves the droning noise, the '07 with the new tranny will be a good buy. The other items are nuisances.
  • dsrtrat2dsrtrat2 Member Posts: 223
    If you are thinking of getting the Touring model be sure to read the thread here about PAX tires. A well known and respected mechanic here says they haven't been perfected yet. Still the buyer must be the judge.
  • cgustafsoncgustafson Member Posts: 7
    Deliciousbass: I own a new 2006 Ody EX-L. Have had it for little over 2 mos. my experiences suggest you should go to the Odyssey Owners web-site at: www.odyclub.com/forums/register.php before making decision.
    Check on problems and solutions and you will get "real life" input from 06 Ody owners most of whom are/were died in wool Honda fans/worshippers...
  • cstilescstiles Member Posts: 465
    I have a 2006 Odyssey Touring with 9,600 miles on it, and so far have had no problems at all. I do not experience the droning that a handful of posters here have mentioned. My transmission appears to shift smoothly. The road noise is a bit higher than what I experienced in my 2 previous Siennas, but I prefer the firmer ride of the Odyssey and the road noise is not an issue to me. My windows work great in all four locations. I have 3 kids who are pretty hard on them, and so far nothing has broken down. My PAX tires so far are wearing evenly and I've had no issues with them. Navigation, entertainment system, stereo all work fine. Satellite radio is great. My sliding doors work fine. The detente is the reverse of what it was in my Sienna (you pull the handles toward the front of the van, while in the Sienna you pull the handles toward the back of the van), but once you get used to the way the sliding doors work on the Odyssey, I think they work just fine.
    Basically, for me, it's been a great van and we have put almost 10,000 miles on it in 6 months without any issues. We have taken it on 6 longer distance trips and the van performed flawlessly. 70% of our mileage has been in town. I average about 19~20 mpg with this van...about 24~26 mpg on the highway and around 17~18 in town. I had it serviced once and the cost of the service was $42 so everything is great so far.
    The Sienna and the Odyssey drive differently, so you should compare the two and go with what appeals to you. Both are fine vehicles. The Sienna is a bit quieter and has a floatier ride. It drives more like a Camry. The Odyssey is more firm, like an Accord.
    Thank you to everyone who has replied to my post. You have saved me a great deal of time of looking through previous posts. Great information, I appreciate your time.
    Best Regards, D
  • rocharcrocharc Member Posts: 18
    I have 2006 EX-L since last September. It has been rock solid and I have not experienced any of the problems about droning, windows, heavy steering etc. In fact my van even went swimming during the New Hampshire floods last fall. Car came through with relatively minor damage that has been repaired with no after effects. We have about 12K on the odometer at this point. Great vehicle, less expensive than a similarly equipped Sienna (at least last fall) and rides better than the 2000 Sienna I traded in for it(which was a great van as well).
    Overall if I need another van this will be high on the list.
  • loncrayloncray Member Posts: 301
    Well, my wife's '06 Ody is around 4 months old now, and it's been an absolute dream. The Navi has been flawless (other than roads that didn't exist a few months ago), there's no extra road noise or droning, mileage is right around 20 mpg (mostly city, some highway) and it's the most comfortable vehicle either of us has ever owned. YMMV of course, but it's been great to us so far!
  • davidbhdavidbh Member Posts: 8
    I purchased Odyssey Ex- Nav last August.
    Personally, I don't recommend this van for others because so many problems (sliding door noise, humming noise, and power steeling pump)and poor finish as a brand new car. I visited Dealer 6 times but still my van has loud noise around 2000 Rpm. I am tired to contact to Dealer with problems. But this is my own opinion if you like to purchase this van please take a test drive first and decide later because I think every odyssey has different condition- excellent or very poor. I already have 5 people who changed their mind from Odyssey to Sienna. I will never purchase Honda car again.
    There does seem to be a set of extremes represented in here - the folks that love their Odys and the folks that hate them. I'm betting that at least part of that is just the nature of internet forums - the folks having problems want to complain about them, and the folks that love their machines want to proclaim that love - the huge majority in the middle doesn't care enough to report on it here.
  • sebring95sebring95 Member Posts: 3,241
    Agreed, statistically there's very little reliablity difference between the absolute worse and best performers these days. If there wasn't you'd see piles of these on tow-hooks or piled up around the dealers. A few posts here and there on problems means nothing in the scheme of things. And that goes for all brands. But that doesn't help the folks that actually do have problems! I've discovered fixes for problems by hanging out on these forums, so it's all good.
  • glevittglevitt Member Posts: 30
    I'm looking at an 05 Touring with low miles for 26k (non-nav/dvd). I have a Yukon and an S-10, so let's not talk about road noise and panel gaps b/c I think you are all spoiled!
    The question to you fine folks is, given the the age (2005), price (26k), miles (18k) and model (touring) and what you know, would you make the deal?
    Thanks all!
    It doesn't seem like a bad deal. I don't think you can get into a new EX-L for the same money. The only negative I can say about the Touring (and what kept me from buying one) was the missing 8th seat. I came out of a Tahoe as well, and generally always had a full load. The 8th seat isn't extremely comfortable for an adult, but we use it quite often. I'm also skeptical of the PAX tires, but would have put up with them to get the added "basic" features of the Touring.
    But if you don't need/want the touring features..I'm sure a used EX-L would save you a couple grand still.
  • master1master1 Member Posts: 340
    Kelly blue books value is $32,000 and you can pay 26,000 so it is a good deal according to them. Has the car been in an accident? How is it's condition? You need to factor that in too.
    Keep in mind, Kelly retail price is based on a dealers "asking" price. In most cases, it's extremely inflated over real selling prices. Private party value is closer to $26,000 on this vehicle so it doesn't seem to be glaringly cheap or anything. But yes, typical questions should be asked before jumping in.
    The PAX thing would bother me.
    If you are looking for a low-cost ODY, why not consider an '07 LX, or end of MY '06?
    Non Nav? Non DVD? Do you want leather? Do you need Auto Sliders?
    I was going to say that. It doesn't make sense to buy an used car for 26,000 when you can buy a new EX without leather for the same price. Do you really NEED leather? The LX goes for 24,000. Why buy a used car that someone else used when you can get a new one for the same price?
    The EX has upgraded fabric and is as comfortable as leather.
    You may want to think about that. Interest is also higher on used cars.
    You may want to think about that. Interest is also higher on used cars. In my opinion, leather, a power tailgate, and fancy gadgets are not that important.
  • nojonesnojones Member Posts: 13
    I bought a 2005 odyssey Touring. My front two tires with PAX are essentially bald on the outer few inches of the tire with 14k miles. I took it to Honda and they called Michelin. Michelin said that as a GOODWILL gesture they will replace one of them and I can replace the other one at a cost of $700 PER tire. You heard that correctly $700 per tire.
    We LOVE the odyssey, but I am really upset about this issue. Note that Toyota and Dunlop (maker of the Sienna's run-flats ) already have a class action lawsuit over this same issue.
    I am currently on hold with Michelin asking them where I can get just the tire. They are going to find out and call me back.
    So, you might want to think about this when buying the touring model. The Honda dealer has a meeting with Michelin on Thursday and I am going to request that I stop by and have the rep look at the tires.
  • dc_driverdc_driver Member Posts: 712
    I purchased an 06 Odyssey EX-L in April and have had zero problems. This was my first Honda, and I am very happy. I preferred the drive and performance over the Sienna and the Odyssey has better safety ratings/features.
  • augcarbuyeraugcarbuyer Member Posts: 18
    I got gas for my new Ody for the first time today. After I put the lid back, I can't close the fuel door. It just won't keep closed no matter how I push it. :mad: Drove back home, still can't close it. Drove to dealer they are able to close it without fixing anything. Don't know if this will happen again. Did anyone have such an experience?
    $700 for one PAX tire is ridiculous. My Honda dealer charges $200 to swap out a complete, new PAX tire/wheel assembly. There is something very wrong with your $700 quote if it came from a Honda dealer. In fact, I called 2 different Honda dealers and they both confirmed the $200 price.
    Did you rotate your tires at all? Although your tires should not be so bald as you described them, it's best to rotate any radial tire on 4K to 6K increments to even out the wear.
    I think $26k is an excellent price, assuming the van is in good to excellent condition. I assume it's coming from a private party. I would be curious why they are selling a nearly new van. If the van is coming from a dealer (doubtful at that price), see if you can get them to extend the warranty as if it is a Factory Certified Used Vehicle.
    PAX is an issue that you need to fully research to avoid any surprises. I am happy with my 2006 Touring, but the van may have more bells and whistles (and PAX) than you need.
  • nowakj66nowakj66 Member Posts: 709
    A heavy object bumped the rear bumper and left a 2" crack in the paint my wife's 2006 Odyssey Touring. Only the paint and clear coat are cracked but not the bumper itself. The crack was such that you could see the black bumper material below. I covered the black with touch up paint and it looks okay but not great.
    My rational side says to wait for bigger damage to the bumper before paying a body shop to repair it for this minor scratch.
    Beyond my touch up paint, is there anything short of sand, fill, repaint to be done?
    Has anyone had a rear bumper re painted on a touring? I know those parking sensors will have to be contended with which will add some labor. What was the cost of re painting your bumper?
  • hockeymikehockeymike Member Posts: 2
    I have an 06 Ody that I got in Nov.2005. At about 4,500 miles we took it in for a grinding noise in the front brakes. They replaced the pads and said they were updated to a new style pad. Then at 7,500 miles it started again and they replaced the pads and ground the rotors. Then at 11,000 we took it back again and they replaced the pads and rotors. I then went on a trip and on the way home developed a noise in the front left wheel. It turned out to be the wheel bearings at 13,000 miles. They replaced both sides front wheel bearings. I also had a heat shield rattle underneath and a loose A/F sensor that was rattling. Has anyone else had similar issues? I'm really not sure what will happen next and what, if anything I can do about it.
  • hondaoddityhondaoddity Member Posts: 25
    It sounds like your dealer did not install rotors completely when they replaced them. I had a similar problem with an Accord that had it's rotors replaced. The retaining bolt that keeps the rotor and bearings on the spindle had not been properly secured to the spindle. My rotors were sliding around on the spindle and the car felt like it was rocking side to side. I had to "make" the dealer (not Honda BTW) put the car up on the lift and pull the wheel. That's when it hit the fan...
    Gotta love incompetence. Trouble is trying to prove it.
  • kevterpskevterps Member Posts: 6
    I bought the Touring for the other "bells and whistles" but liked the idea of not having to stop on the side of a highway with a flat, especially with 2 young kids. I recently found a nail in one of my PAX. Honda dealership swapped it out for a new one fee of charge. I wanted to get a matching one since with 30k miles they are pretty well worn. They came back with a $500 price! What the F#$k is that about? I am thinking about getting out a nail gun and going to work on the tires and bringing them back for new ones aw well.
    I am definitely thinking about trading it in and getting an EXL so I don't have to deal with this in future. I also may just buy 4 new rims and 4 tires and get rid of PAX altogether!
  • drolfsdrolfs Member Posts: 2
    Got in my Ody after work Friday, turned the key and despite having a tank 3/4 full with gas, it just wouldn't turn over no matter what I tried. The battery was strong so I opened the manual and went through all the options for starting the vehicle when the btty is o.k. but the car won't start. Then I called and checked with my dealer to make sure the immobilizer key wasn't the issue. After reviewing the same procedures in the manual the Dealer told me to have it towed to the shop where they'll look at it on Monday. I also checked most of the fuses--incl. the fuel pump--just to be sure it wasn't an electrical issue.
    The van is just over a year old with less than 20,000 miles and we've already had it in for major paint defects, a whistling windshield and for a factory recall on the front brakes. With a new family of twins, I must say I expected more from Honda.
  • moses7moses7 Member Posts: 25
    Dear drolfs,
    What a shame!!!
    I think Honda is suffering from the "pangs of success"......
    They are not the company they once were,
    which separated them from the mundane... IMO
    We took delivery of our new 2006 LX almost 2 weeks ago. Here is the problem: When the van is first started, we back out of the garage, pull out onto the road, and then you can hear a noise and feel it at the gas pedal. It is tough to describe the sound - very brief but noticeable by the passenger as well. It seems to only occur one time after it is started and when it shifts to second (or shortly after). I know this is vague, and could be many things, but wondered if anyone else has experienced this "problem". I believe I read about transmission problems that were remedied by a change to the 2nd gear lubrication - that is the only thing that comes to mind when I hear/feel it. Thanks in advance for your comments.
    this would be the self test of the ABS system. it happens once and only once after starting when you move forward above some speed. it is perfectly normal and has been reported by many here on this forum, and the -2004 model forum for the ODY.
    if you are concerned, and you want to put your mind at ease, there is a TSB (technical service bulletin) for the dealerships that if you go in for service and request it, one of the service techs can manually trigger the self-test for you so you can hear and feel it and verify its the same as what you've been hearing and feeling.
    i would hope your owner's manual on the section on brakes, braking or ABS would mention this self-test.
    HTH
    Thanks HTH! You have certainly put my mind at ease. These boards are very useful thanks to users like you.
    Best Regards,
    D
  • I love this vehicle. I have an 06' with leather (not touring). I have approx. 10k miles on it and not a mechanical problem with it .
    My only complaint is the lack of thought devoted to storage.There is the top opening under the radio which is not very practical. And then there is the larger storage under that which is at floor level (Honda, could you make it any more inconvenient?).You cannot even see the road when you lean down to get something while driving.
    There is no place for coins so I keep them in one of my 8 cupholders in the front of the car (1 in each front door, 4 in the center tray and then 2 that extend from the dash board under the radio).
    There are two glove compartments. What is the point of this?
    There is no center storage area between the front seats. It is basically a tray that folds up and down. It is pretty useless.
    Now I hate to sound like a complainer because I love the vehicle although this is basic stuff here.
    My wife has a Pilot which I love even more and every one of these things I mentioned are included in her vehicle.
    One thing I love about the Pilot center storage area is that the front of it folds down and there is a space dedicated to store your cell phone.
    I know it seems small and trivial but I think twice before buying another Honda Odyssey because of these small issues.
    I would however buy a Honda Pilot.
    Anybody else agree with me on the lack of storage?
    BTW, that would be user777. you're most welcome.
    and BTW = by the way, HTH = hope that helps. ;)
    Fairly common for a minivan, as you get the walkthrough area to get to the rear seats. Having grandkids in the back, that was a big plus for us and one reason we switched to a minivan. But it does take away from your "finger tip" storage that comes with those massive center consoles that SUV's have. I think a lid on that folding tray would have been better, so you could put stuff in it and still fold it down to get to the back seat. Some at least offer a console for between the seats if you don't want access to the back. I've heard of folks adding an aftermarket console as well.
  • m_fordm_ford Member Posts: 10
    I just bought an 06' EX Odyssey on Thursday and both my husband and my self noticed a sound about 10 seconds into driving that sounds kind of like there are automatic locks locking (but there aren't) and you can also feel the noise in the gas pedal? Does anyone know what this is and if its normal and just how the van is? I asked the dealer and they said its probably the ABS breaks from dust and to give a day. Well its been 6 and we aren't using the break when it happens.
    It is definitely the ABS self check test.
    There is actually a procedure that your dealer can perform to duplicate the noise for you.
    Nothing to worry about.
    Your dealer is dumb. It is the ABS, but not from dust :sick:
    The ABS system turns on and self-tests when the vehicle crosses 8mph. It only does this after the vehicle is started. It's normal and every vehicle with ABS does this, however for some reason the Honda systems are a bit noisy compared to others.
    Thank you for the quick responses and setting my mind at ease.
    And it sounds right that its when I get to 8mph/a few seconds after driving. I'll know its that now and not worry.
    Thank you so much! :)
  • kozinatorkozinator Member Posts: 3
    Our 06 Odyssey may have a similar problem. We have approx 10K miles and recently my wife complained about a grinding noise/feel when breaking. I used the van for a day and did not notice anything. Last week, I used the van on a route that includes a steep hill with a stop sign at the bottom.
    I needed to break heavily to stop the van. ABS did not engage but there was definitely a grinding noise/feel that I experienced. I did a couple of tests and have found that the grinding is only apparrant when breaking hard.
    I am scheduled to take the van to the dealer next week to replace gasketing around both front doors (damn "creaking" noise always comes from the window/gasket interface). At that time i'll have them check the brakes too.
  • montztermontzter Member Posts: 72
    Hi:
    You may want to give the dealer a call before you go in. If I remember correctly, Honda may have updated brake pads available to correct that grinding noise. The call to the dealer might help ensure they have them in stock so they can swap them out while it's in, verses having to make another dealer visit. (Just a thought)
    Has everyone checked out www.odyclub.com yet? Lots of great information.
    There is a TSB Service Bulletin for the grinding noise.
    The original brake pads were formulated improperly.
    Take the car in to your dealership they will change the pads and resurface the rotors.
    I had my '06 Ody done last week - no questions asked.
  • boohondaboohonda Member Posts: 5
    please post the location of the bulletin
    c
    '05,'06 Odyssey TSB for groaning brakes
    link title
  • rorrrorr Member Posts: 3,630
    "Take the car in to your dealership they will change the pads and resurface the rotors.
    I had my '06 Ody done last week - no questions asked."
    I can second that. My wife took her '05 EX-L in a couple of weeks ago for an oil change. When the service writer asked if everything else was ok, she mention that occasionally the brakes made an odd noise. He checked the vehicle and the service records, mentioned to my wife that Honda had issued a TSB on this issue and that they would replace the pads and resurface the rotors for her under warranty. She couldn't wait (had only gone in for an oil change) so they immediately provided her with a loaner car and she picked up the van the next day.
    No muss, no fuss.
    drolfs,
    You could have had a fuel system vapor lock. Opening and closing the fuel filler cap might have resolved your problem. If this were the case, you might need a new filler cap.
    The other reason might be this: On my 93 Accord there was a control unit in the dash that shuts down the fuel system if it perceives an excessive under hood temperature. Logic behind it: if there's an engine fire, it will automatically kill fuel delivery to under the hood.
    I found out about this when my wife parked in an open parking lot for an entire day, under an extremely blazing sun. Same scenario, everything indicated the car should start, but it just wouldn't. For some unknown reason, my next door neighbor suggested pouring cold water over the fuel lines on top of the engine (he's an aircraft mechanic). Sure enough, after pouring on the water, the engine turned right over.
    After this happened, I took it to the dealer. That's when I found out about the in-dash control unit for the sensor. When the unit goes bad, it over-reacts to temperature. They replaced the control unit and the problem was resolved.
    If it wasn't any of these, I would be interested in what they determined the problem really was.
    Take care,
    Fred
  • danesidanesi Member Posts: 11
    Thank you forum. After a year of complaining to the dealer about the brake grinding noise on our 2005 Ody, we called the dealer, referenced the bulletin and got the service done.. No further issues. They did find there was excessive wear on the rotors and replaced them as well. Van has 32000 miles. Bulletin refers to all 2005 MY, so if you have one, based on what the dealer finally found, I would get the service done, even if the gridning noise is not an everday problem for you.
  • aaykayaaykay Member Posts: 539
    Hi All, I have not visited this thread in a long time..
    Just to provide an update on my van till date, it has had 2 issues in 35,000 miles:
    a) Grinding noise from the brakes - the dealer replaced my brake pads and turned the rotors under warranty. I really wish they had replaced the rotors instead of turning them.
    b) Faint Whistling sound from the windshield - the dealer replaced some kind of rubber moulding and it eliminated the sound. Even though the sound was faint, it got on my nerves while it lasted.
    The mileage improved considerably after around the 25,000 mile mark. Now on a pure highway/interstate trip, I get an incredible 28-30mpg at around 70-75mph relatively constant speed. City is around 17-19mpg. Very impressive for such a huge vehicle.
    I have done several long road trips, including 4-5 1500+ mile trips. The NAV has been fantastic, other than the fact that the total mileage computation is incorrect when the distance is over a 1000 miles...gets more precise when the destination gets closer. Either way, more of an irritant than a 'problem', since the guidance en-route is pin-point accurate.
    Absolutely problem-free, other than the above mentioned issues.
    Very pleased with the van and will unhesitatingly buy it again.
