1. Control of the car...with the manual and a tachometer, I can optimize the driving experience and rid myself of *most* of the unpleasant aspects of coupling a 1.5 or 1.6 engine to an automatic transmission (gears hunting on steep hills, less engine braking downhill, no push starts, less versatility in snow)
2. Performance -- while the paper stats don't show a big diff between 0-60 times on a manually equipped vs. an automatic subcompact, in fact to GET the best 0-60, the testers use the automatic in an unnatural way (often shifting it manually), giving the buyer the wrong impression of what THEY will experience. Thge manual transmission, if coupled to a small high revving and eager engine, can be a lot of fun.
3. Expense -- if you wipe out an automatic transmission and it's not under warranty, that's very expensive. On a subcompact over 5 years old, it might mean the wrecking yard.
It's pretty difficult to destroy a standard transmission..near impossible...at worst, you buy a clutch which is less than half the cost of an AT overhaul.
It is also prety darn hard to screw up an AT ... although some people insist on switching gears while the vehicle is in motion.
You can't push start a modern car with a manual either. Putting it in gear and shoving won't make the computer fire off the coilpacks and injectors.
Plus it is hard to "optimized" driving experience in heavy rush hour traffic that you are lucky to get over 35 MPH.
I am telling you, in my daily commute a standard transmission is a nightmare and a huge liability.
This is true for about half of the cars, currently, and is what I consider a true manual transmission - no computer overrides, lock-outs, or other silliness.
Audi, Mercedes, most of GM, half of Ford, Volvo, Saab... Your're right - no manual push-starts. But a few still do work the old way.
Here is a tip, buy a new battery.
I've had a AAA membership since I started driving. Plenty of perks other than jump starts and local towing...
I've push started a 2000 Saturn SW2 twice after two battery failures. Even with the battery dead, there was still enough charge to fire the initial few times and then the generator kicks in. The spark still comes from the battery or generator whether a computer controls the timing or a gear connected to the (crank or cam, can't remember which) via a distributor. If you have the ignition key, then wouldn't the chip in the key be considered an override? It confirms that the pusher is the owner.
I haven't had the opportunity or need to push start cars since that one.
I expected more progress in 22 years.
Technology exists to make the Fit (and all other cars) lighter. Replace metal with aluminum, carbon fibre and titanium wherever possible.
Carbon fibre is not easily recycled, however. The cost of replacing steel with any of the alternatives would put the price of the FIT over that of a BMW 3 Series as well.
So it has greater capacity, runs a bit quicker, has more safety equipment and a few more amenities, and does it all with the same displacement and relative economy. What's not to be impressed with? :confuse:
Once upon a time you could push-start automatic transmission cars too. I think it had something to do with where the transmission pump was. If it was mounted in the back then you could push-start it, but if it was somewhere else you couldn't. The owner's manual of my '57 DeSoto has a section on push-starting it. I think you have to get it up to about 15 mph. This guy's Maxima was able to fire up at oh, I guess about 4 mph.
But what daysailer said is also very pertinent - despite the very low weight of 80s Civics, most (including the SI) were significantly slower to 60 mph than today's Fit, which is due to gearing them faster today. Just an unfortunate consequence of the horsepower wars that have waged in the industry since time immemorial (and continue today), which have made all the cars on the road much faster and forced subcompact manufacturers to keep up at least modestly.
Maybe. I am no engineer. I would think the same engineering leading to improvements to bending and torsion helps improve safety as well.
Alonged with improved ride and handling, stiffer cars are more quiet and have a more refined ride, something most drivers in 2006 would not be willing to give up.
The economy is terrible when compared to Fit (33-38MPG or a Matrix(30-36MPG). The only car I see that is comparable to (or as bad) as the SX4 economy-wise is the Dodge Caliber, which still offers more power with its low economy.
I'm not condemning the car, because frankly, i don't know enough about it yet. I'm not trying to pick a battle here, either, but someone debating what I have to say won't hurt my feelings, I promise. I'm looking for the "why" factor for buying this car, other than AWD on a $16k car. I live in the South, so AWD would be moot to me. What can this car offer me that another vehicle can't (besides AWD, I don't want/need it)...
Just curious.
So while I'm inclined to like the SX4 on general principles, the real test is in the driving.
Nope, and i wouldn't seriously consider the car myself. It really offers nothing over a lot of the competition except for the AWD which is needed only once in a blue moon.
while it isn't on topic I have to wonder about bump starts as well. Both of my manuals are 2001s or better and neither can be started unless the clutch pedal is on the floor. Even if I had the key to bump start you have to let the clutch pedal up far enough to engage the pressure plate. Once my clutch is off the floor the ignition won't engage the starter. Is bump starting possible then. Even in neutral my clutch pedal must be on the floor and it simply will not start if the pedal is up.
For the price, I would just as soon get the PZEV Rabbit. MPGs still not great. But the VW will no doubt ride and handle better.
Darn how did I miss that the first go around?
Suzuki does not have that much better a rep, however.
Maybe best of all worlds would be if the forth coming Saturn Astra ships to the US with the neat little 1.8 common rail diesel GM offers in the EU (and other markets as well).
Assuming we get the hatch and it has adequate filtering on the diesel exhaust, of course.
You just lucked out and get three bad ones.
I may not be crazy, I'm just fanatical about getting the most efficiency possible for the size/power of a vehicle.
I'm THRILLED with my 30 MPG average in my Accord EX I-4(lots of economy for the power (166 hp and 24/34 MPG), size (3,200 lbs), and price point (Mine was approx $22,000 - $1,800 below sticker...not great, but the 06 had JUST come out)).
It doesn't matter what diesel they might bring over for Saturn I won't see it. In california we would have to revolt and string up every member of CARB by the neck and toss every tree hugger in the state in the ocean before we will see a new diesel car for sale here.
Seriously, US Greens' opposition to diesel has always confused me.
And now that state has just filed a lawsuit against automakers because of greenhouse gasses. If the worlds automakers had any guts they would stop shipping anything to California and force all those idiots to walk.
And if that isn't bad enough, the State of California today filed suit against six leading auto manufacturers (GM, Ford, DC, Nissan, Toyota and Honda) for the greenhouse gases their cars, trucks and SUV's emit.
EDIT: Dang, snake beat me to the punch on that one.
Oops sorry.
Bringing the discussion back on topic ....
Why is it that in Europe, they refer to cars by letters - A, B, C, where A is subcompact (Yaris, etc.), B is compact (Focus, et al) and C is mid-sized (Mondeo, Passat), but in the US the lines between car sizes gets all fuzzy?
Some people use EPA interior volume, others use overall vehicle length. Smaller cars getting worse EPA (and real world) mileage than larger cars (SX4 vs. Accord being the most recently cited example, or, better yet, the Civic getting better highway MPG than the Fit).
Seems to me that the way they do it over there makes more sense.
Thoughts? Comments?
(now ducking....)
Many US Greens cannot adapt. They took a stand. Won. And refuse to accept changing times and tech.
A subcompact with a small common rail diesel and decent filter would be the best compromise auto possible imo.
The EU is better at forcing one standard on its members.
US has fed using one standard, industry another, large states like Cali and NY still another. So you get a hodge podge.
EU category makes sense from pure idea of the auto follower. But when you start to think about the power the EU bureaucrats have over the people ...
Now the lawsuit against the Big 6 is brand new news, so I have to read more about that, but my first impression is that one will go in the column marked "Misguided efforts". But that's not CARB doing that one, that's the state attorney general.
And how about this for a compromise to get better fuel economy from smaller cars (instead of making diesels widespread): sell models or versions of models that go about as fast as Explorers and 4-cylinder Camrys, rather than making them go faster. Heck, let them go a little slower than those perennial favorites. Also, stop worrying about how ignorant people that won't downshift on the highway will respond, and give these cars properly tall overdrive gears for better highway fuel economy. Any car that can pull 35 mph in its top gear without lugging or bogging is geared too short. Give these cars a chance, manufacturers!
makes no sense to me, they are most efficient in stop and go driving.
I've heard the Houston area is also like that as well, because the air masses off the Gulf and the air masses from the Rockies collide, and kind of just sit there. In the spring time you get fun things like tornadoes, but other times of the year it just kind of holds the pollution in and lets it build up.
There's also an area in Anne Arundel County, Maryland, that's supposed to be one of the dirtiest areas in the country. It's up in an area called Brooklyn, or something like that. Basically as far as you can go in AA County without going into Baltimore. Supposedly it has something to do with wind currents, and the way the Patapsco River and the Chesapeake Bay water currents collide, and it just lets pollutants build up.
Anyway, this California thing certainly could set a precedent. If they're successful in suing the automakers for contributing to excessive greenhouse gases, who's next? Taco Bell? Cabbage farmers? That Golden Retriever that's always trying to hawk the Bush's Baked Beans recipe? :confuse:
None of this has much to do with sub compacts however. If people were even remotely interested in saving fuel and small cars they would be trying to get CARB to allow small diesels here like they have in other parts of the world. Just isn't going to happen. But perhaps the article I was reading this morning on synthetic jet fuel the air force is testing might lead to something. If we got some renewable fuel maybe the whole CARB thing would go away.
"What's the matter, are we a little nervous?"
"Not to worry, I'm a really good driver. There are a lot of bad drivers out there."
The SX4 gets only 23 city and 28 highway. No, I agree those are not sterling numbers. I'm in the research phase, which could include a test-drive at any time. The ghastly mileage is fine for me, not even an issue with this padre from Seattle.
BTW-today my son and I took the Sportage 35 miles west to Benson, AZ, for the Sportage's 120,000 mile timing belt replacement. They replaced the timing belt and found another cracked belt so replaced it. While the Sportsman was being worked on we walked around Benson. Guess what kind of car I saw at one of Benson's ghastly stations? Yep, a 2007 Suzuki SX4 in automatic transmission and silver color. I hopped over to the lady and asked her about her new baby.
"How do ya like your new SX4?"
"I love it!", she exclaimed.
As I grilled her about the handsome new rig from Suzuki of Japan I had to ask here about her ghastly mileage so far.
"How's your ghastly mileage in this thing?"
"Umm...", she blurted out.
"What, have you figured it up yet?", I had to know.
She hadn't figured up an average yet and she was also in a hurry so I didn't hear how her running ghastly mileage was going. The SX4 does come with a ghastly-mpg-a-meter that keeps tabs for you! How awesome is that? And a great CD player to boot! Welcome to new technology!
The silver import was small.
"Looks small", I commented.
"Yeah, it is," she replied.
Apparently Suzuki has done a good job with keeping the SX4 quiet. A popular complaint is that some people have been unhappy with their Suzuki's level of noise in the cabin as they accelerate. I have read two new write-ups on the SX4 in which the noise issue has been addressed. Apparently it has-Suzuki has blotted out some of the engine buzz with this one.
Yeah, my close-up look revealed a sharp looking little import, with those nice wrap-around headlamps looking good fronting the metallic silver paint job.
"I'm a cowboy, on a steel horse I ride...".
Seeing this little pup in person did not dampen my enthusiasm for the 2007 Suzuki SX4 a bit.
After that appointment I hadn't had enough maintenace yet for the Sporty. I took her in for a rear diff.fluid dump and re-load, a manual tranny fluid dump and re-load and a 4WD front diff.fluid dump and re-load. Coolant is up to the top and strong. The battery is strong. Mileage is at 120, 330 miles. Getting up there but she's running like an absolute top. The Sportage 4x4 is a great rig and is running great, too. We're not trading anytime soon. I know that the Sportage would get max.dollar, though, if I wanted to trade it in a week from now. I will demand top dollar in trade or I won't be trading with that particular dealer. End of story, eh?
It's all subcompacts for this padre and they all come from either Japan or South Korea. The only other car of interest comes from Brazil and it isn't quite here yet. It's a car-crazy globe and this car nut is enjoying the fruits of an Asian on-slaught that is both fun and reassuring. I know that buying a Kia or a Suzuki or a Toyota or a Scion in subcompact form is not only a smart thing, it is a conservative thing. It conserves money and it doesn't pollute like these dorky pick-em-up TTTRRRUUUCCCKKKKKSSSS from Detroit. A lot of us have figured it out but a lot more of us will need to get with the program eventually.
Small is hip. Small is smart. Small is penny-wise. Small is cool and small rocks the house. Over. And out, car nuts. :shades:
