Honda CR-V, Toyota RAV4 or Subaru Forester?
But hey, if fate is going to nail you, you can have a hummer H-1 and if you get hit by a Semi you lose. I had a semi (car carrier/low to ground) in a horrible rainstorm in Kansas a few weeks ago blow over into my lane. In all the spray all I could see was about three feet in front of me until I sensed (peripheral vision) a mass very close to me. I looked left and he was literaly 2 inches from my mirror and still coming.
I went right and across the rumble strip and right on the edge of the grass while he kept coming. I slammed on the brakes so I would be going slower and he would get by and he just barely missed me being about three quarters into my lane by the end of it.
If I had been in a massive SUV (roll over, size, slow response), I believe it could have been a very different outcome. Maneuverability, quickness and agility saved me... that day and that would be the third time I can firmly say Subaru all wheel drive and other factors kept me safe in the last 9 years with the other two being snow related.
I literally said, thank you subaru, speaking to my car. I then started cursing the truck driver and shaking.
-juice
During an extrication seminar I was conducting, several members of an area fire department approached me with a question and a challenge. They had encountered a Subaru Forester involved in a crash and were unable to cut through the B-pillar with any of their extrication tools. Their cutter and their reciprocating saw were both unable to sever the pillar. They actually went back to the junkyard the next day and used a gasoline-powered rotary saw with an abrasive blade to totally remove the B-pillar. They brought it to the seminar to show me.
When I saw the pillar, it was clear that something was different about the Forester B-pillar construction. It was eight layers thick! One of the layers was a round steel rod that resembled a concrete reinforcement bar (rebar). That B-pillar had more layers of steel than I had ever seen in a vehicle.
-Frank
.... mnf
I'd ask if you saw the rear differential (easiest way to tell) but I'm sure your XT wasn't behind him pulling away from a stop.
I test drove an '02 CR-V, AWD model, and it even had torque steer. It could chirp the tires in 2nd gear. So you can feel that it's FWD by default.
To be fair we're in the 5% or so of people that would even notice a difference in feel.
-juice
You mean not all manufacturers make AWD standard across the entire model line-up? :surprise:
-Frank
Actually, it is entirely FWD, until the wheel slip, which is when AWD becomes extra handy. Some people would say that Subaru wastes energy driving four wheels all the time, when two wheels would do just as well except when those two wheels lose traction. Of course, those "some people" would not own a Subaru anyway.
The limited time AWD is what gives better MPG. Subaru has made it's name on a niche market of people who desire full time 4WD. But their cars would get better MPG if they were part time 4WD instead. However, they would lose their market niche...
The AWD system in the CR-V is purely mechanical.
IIRC, the Subaru's can be defeated with the removal of a fuse... suggesting that at least part of it is electrical.
You actually insert a fuse, strangely enough, to put it in FWD only mode. This disengages the clutch pack completely. It does not operate in that manner by default, however, so it's never 100% FWD unless the fuse is in.
Also, the AWD is not designed/engineered to be used like that all the time, it's actually for when you get a flat or need to call a tow truck.
Funny part is you get an idiot light that says "FWD", like something is inherently wrong with that.
-juice
Check out the Real MPG strand. You will read that there is not all THAT much different between the 4 and 6 on the RAV 4....maybe 1 or 2 mpg. I have read on different forums that some people who bought the 4 cyln. wish they opted for the 6. I have talked to a couple RAV 4 owners who make the same comment.
Your point?
All wheel drive user for 15 years...
Subaru owner since they had part time AWD/4WD.
Hazards worthy of potential warnings:
* Service Engine Soon
* Check Engine light
* Fuel Level Low
* FRONT WHEEL DRIVE! AAAAAAAH! :surprise:
-juice
And the other thing is that while there are complaints about hesitation when you first hit the gas, the rate of complaints is higher with the 4 banger than it is with the V6.
Plus all the extra power, torque, and towing capacity.
IMO the V6 in the RAV4 is a no-brainer. You definitely pay the extra amount and get it. Very small investment for a very large payoff.
-juice
not the 6, since I have no need to tow.
The 2.4L in my gf's Solara is an impressive power plant,
strong, quiet and efficient.
I'd be saving money up front, in purchase cost,
and all thru the life of the vehicle, in lower fuel costs.
The mpg difference adds up.
I'm certain that I stretch the payload limits for whatever vehicle I drive.
So V6 for me, no question.
-juice
I'm certain that I stretch the payload limits for whatever vehicle I drive."
Is your last name Griswold?
-juice
VDC (stability control, finally!), 17" rims, and a really nice mesh grille. Nice package, hope it comes in that blue color.
It's ironic that Subaru was the first in this segment to make ABS standard (1998, from the beginning) yet they were just about the last ones to offer stability control. :sick:
-juice
Toyota sold 11,154 units of the RAV4 including both the I4 and V6 models.
Honda sold 20,413 of the I4 only CR-V with reactive AWD.
No one is more shocked than I. Though probably not for the same reasons.
If not for that stupid rear door side-swing arrangement, and the spare on it, I would have purchased the CR-V in 2005 instead of my Forester. CR and others have always given it good reliability ratings. The edge went to Subaru for the safety equipment and CR's top ratings of it.
Now I am very pleased with my Subie, but I have to tell you guys, looking at the new 2007 CR-V, when I am ready to get another car to replace it (probably 2008), I will once again be giving Honda a long look.
That's for the new CR-V only?
"Sales of the all-new 2007 Honda CR-V totaled 20,413, representing an increase of 95.7 percent in its first full month of sales while shattering the previous all-time record by 3,744 units from July 2005."
Yahoo
Guess there was a lot of pent up demand to get that tire off the rear door, lol, but the numbers are a bit hard to believe. :shades:
Ah, just found another link that contradicts the 3,744 number:
"Import truck sales were indicative of Honda division selling 20,413 CR-V units, an increase of 95.7%, compared to 10,850 units in the same period a year ago." (Note that this blurb doesn't specify "all-new" CR-Vs, but it's still a 95% increase).
RealTimeTraders
How much does it affect mpg? etc.
THanks so much, I bought a Subaru yesterday, now having buyers' remorse about the lack of space in the rear for suitcases, etc.
I'm wondering how many of those were replacements for old gen CR-Vs?
The next time any of you are driving by a Honda dealer, glance over and see how many used CR-Vs are on the lot. I know this applies to all manufacturers but it has always seemed to me that Honda buyers are quicker to replace their 3-4 year old Honda with the latest and greatest. Anyone else notice this or have some data to back it up or shut me up? :P
Honda is right at the 4 year average in Canada, with the "younger" Kia and Hyundai population trading more often.
In the U.K. a study says that "CR-V owners are the least likely to change their car, with the model achieving the highest average length of ownership." link
Good stuff Steve but I'm not so sure that answers my question in any way. The CR-V is more or less a luxury vehicle in Europe so of course people will keep it longer over there. Also, varmint posted U.S. sales which that article has nothing to do with.
The remark about shattering an all-time sales record is comparing 10/06 vs 7/05.
Two different benchmarks.
True enough, but the lack of a full-size spare (and no place to put one), plus the ugly front end are the two reasons why I will not be purchasing this gen CR-V when I need a new vehicle.
It works both ways.
I've never seen anything which would support that.
Actually, if that were true, you'd think that the glut of used vehicles would drop the resale value of Hondas. Yet we know resale isn't a problem. Furthermore, it would be easier to suppose that the domestics are the ones with the quick turn over rate. They offer the most generous and well-publicized loyalty incentives.
I totally agree, Varmit, no need to [non-permissible content removed] for tat in forums. My post wasn't refuting you, but merely adding the reason I chose as I did.
But complaining about donuts is futile, as most cars have gone to them, and soon all will (except for truck-based real off-roaders), to meet mandated weight limits and MPG computations. The number of people who remember full-size spares and care about them is dwindling each month.
:confuse:
According to Automotive News Honda had a $750 incentive on the '05 CR-V, so maybe clearing out the 06s helped. But it looks like isellhondas is getting the last laugh, he was saying the new one would sell briskly even before they arrived.
Forester might get 5k on a good month. No way will it challenge those numbers, even the RAV4's.
-juice
I'm just going by what I see on the streets. Before I even saw the current gen Accord (2002 I believe it began?) in a mag or anywhere else I saw a bunch of them on the street. I rarely see an older CR-V, pre-2002, on the road anymore and I have seen two '07s already.
When we were shopping for our Explorer earlier this year we considered the Pilot and Odyssey. All of the Honda dealers we visited had loads and loads of last gen Odysseys on the lots as well as the pre-refreshed Pilots. Since they had few Odysseys on the lot, but plenty of Pilots, I assumed a lot of replacements were sold.
I'd love to argue with you on this point but this is not the place and we've been over this before I think.
It would be easier and so would assuming the Honda lots should be full of used domestics. But they're not from what I've seen.
On a side note varm I finally got that Mustang I was talking about forever back in late August. The "permasmile" hasn't worn off yet.
In other words, it's a skinny donut tire with the same circumference as a stock tire.
I am told that a full width, real tire will not fit in the same space as the donut spare. I haven't actually tried it myself, but it certainly doesn't look like there's enough clearance.
