Visitor Agreement.
No that is not the wind noise that a lot of people are referring to (although that one has also been referred to on this site, it can be handled by ajusting the window opening as you mention).
The general complaint is about a howling noise that comes on at high speed in certain cross wind conditions. After 8,000 km on mine, I got to hear it recently while on the highway. It is very annoying and hopefully Toyota will do something about it. It appears to come from the front roof rack area.
Robert.
Is there anyone out there who is technical enough to know how to program the Toyota VIP RS3200 Plus security system for passive arming? The dealer, owner's manual, and previously provided links aren't much help.
Also, I saw some inquires about keyless entry tricks. Anyone figure anything out like hidden window controls or automatic locks?
The other is a very loud reedy howling that only occurs at high speed (60-70 mph+) with strong cross winds (around 30+ mph). Many haven't heard this, but I suspect that is because they haven't driven in the right conditions. I don't know if this affects all HLs, or only those made during a certain period. This noise is apparently caused by the door seals leaking air and vibrating. Supposedly Toyota is coming out with a fix soon. My HL is virtually undriveable in a heavy cross wind (common here in KS) because the noise is so loud and constant. I have discovered that I can stop the noise by closing a towel or something in the door to compress the seals, but my patience is starting to wear thin waiting for Toyota to fix the problem.
http://pressroom.toyota.com/mediakit/toyota/2001kit/2001highlanders.html
I find it odd that 4th gear really isn't an overdrive gear.
I have a 2000 4-Runner and I installed the same Toyota factory system in my vehicle. It should be the exact same system used in the HL except for the wiring harness. Unfortunately, I cannot find the installation manual and user guide right off hand.
I ordered mine over the counter from my dealer and when I looked in the box there were no details for connecting things up. After speaking with the dealer service manager he indicated that you have to call the fax-back system of the folks that make the unit (I believe it is Fujitsu-Ten) and they will send you via fax all that is required to install and setup/program the unit.
I can say that if you indeed do have the RS-3200 Plus system in your HL, then you should have the glass breakage sensor located in the dash to the left of the steering column. The sensitivity for this can be adjusted via a small adjustment hole in the side of the actual RS-3200 Plus control unit. If installation is similar between the 4-Runner and the HL, the control unit is under the dash to the left of the center console. It is a bear to reach, but you should see a small access hole that can be reached with a small screwdriver to adjust the sensitivity of the glass sensor. I do believe there are other programming options (which I did not activate) but I cannot recall them as it was almost 11 months ago.
Bottom line, your dealer's service manager should be able to provide you with the number for the manufacturer fax-back system so you can obtain what you need. It is possible that one of the service department mechanics may have a copy if they have installed any for customers after purchase.
I will see if I can locate where I put this install/programming manual and see about posting it up (if possible) in the event you cannot locate any info from the dealer.
As for the keyless entry tricks, if you find any out let us know as well. The systems are probably similar between the 4-Runner and the HL and it would be nice to be able to utilize those features. It is a shame Toyota does not put them in the manual, but that is probably due to they could change manufacturers and that would require reprinting all those owners manuals.
I hope this helps.
Anyone have an installed u-haul hitch?
Can anyone explain the RS3200 Security System? I could not find the alarm system in their standard option (V6, 2WD, on-limited). What is the best way to add the alarm? Thanks in advance.
My dealer included wheel locks for free, so I'm not exactly sure what they would cost, but they are available. KBB.com has wheel locks listed as an accessory for $52 MSRP, and $31 invoice. I bet you can get them from any Toyota dealer's parts department, or any other auto parts supplier as they don't appear to be anything special. Just make sure to get the right size and don't loose the key.
http://www.kbb.com/kb/ki.dll/kw.kc.tp?kbb&&1&nc1
I'm nervous about bringing it to the dealer until I hear of a definite solution. Don't want them tearing things apart on a hunch or guess.
Finding that fax-back number looks like my next step.
I did find the following link among the previous messages.
http://rav4world.com/brochure/alarms/rs3200plus/rs3200plus.html
I did notice the HL brochure apparently goofed by stating the RS3200 Plus Security System is for vehicles "without" keyless entry. Seems there is a separate non "Plus" model that's for vehicles without keyless entry.
BTW, good catch by the person that found the tow hitch error on Toyota's web site. Those are the kinds of errors usually found in Edmund's data. I wouldn't be too upset about it though, as the tow prep package is only $128 invoice and that's including all the upgrades. But it is listed correctly in the HL brochure as previously mentioned.
Will the local Toyota & Ford dealer allow you take the Highlander & Escape home overnight (middle of the week)? This would give you the extra time to make the right decision for you and your back.
Good luck and let us know the outcome.
Best regards,
Philip
Also is there a braket for the front license plate?
Going on 10,000 miles
Great SUV.
I think most everyone will agree Toyota will hold its value better.
Now before I get nailed for knocking Ford, let me say I have been driving Explorers for 10 years (now on the third one) and really can't complain all that much. Still, they don't compare to my experience with Toyota (I have had a pickup, 2 Camrys and 2 Celicas).
Highlander is currently at the top of my short list for replacing my Exploder, followed by Acura MDX (and maybe its new Honda cousin in 02 or 03)
Interesting note, some of the Toyota salespeople who post here are driving The Ford Explorer and Mecury Mountaineer. Go figure.
Do lots of research, don't put to much stock in any one opinion from someone else, then go with what feels right to you.
Just my opinion.
I used McGard #21156 locks for my HL with Aluminum wheels. They were about $25 if my memory is correct. As you probably know, they are 12mm x1.5 metric thread, and they are the shank type (.580 shank). No problems here.
-Steve
I bought a fully loaded Highlander back in February (with tow package, minus the hitch). The dealer wrote up in the deal documentation they would supply a hitch included in the price (which was list). Toyota has not made the hitch available (believe me, the dealer was not pro active in "finding this out"). When I told them the hitch would not be available, I suggested I get one fitted, and they reimburse me (this is now July). They told me the hitch cost $225. I said, ok, give me $300 to cover the hitch and an hour's labor, and we are done. They said they would not pay to have it fitted - "we just don't do that". They mailed me a check for $225 (which I will cash).
I really don't care about the small price difference, it is not worth any aggravation, but as the sales person kept telling me before making the deal, a deal is a deal. (The sales person said a few other things too which I didn't care for, because at the end of the day, the deal is the deal-I guess I didn't figure on not getting total delivery).
Is it worth putting this "on record" with Toyota Customer Service and / or the Better Business Bureau just so the dealership get some comeback for bad business practices (a mark on their record), or are these just a waste of time ?
On a happier note, my wife and I really like the car. It took us to July to experience the noises from cross winds, and with the rear window(s) open, but for me, these are either so rare or controllable (open a front window a bit or whatever) they are no big deal. I've kept an eye on this forum for a while now, and the people seem really good, so thanks to everyone.
I was wondering if anyone has applied Scotchguard to their Highlander themselves. I am wondering if there are any recommendations out there for or against this.
We have the light color cloth on our Highlander, and have two kids. enough said!
thanks.
p.s. LOVE this car....
You need to make you own decision. For me, the HL (V6, AWD, unlimited) is a wonderful vehicle. If drives so easily, and I am constantly pleased with the fit, finish, ride, power, economy, and quietness of it's ride. I am very grateful the Escape purchase failed!!
Happy HL'ing to all.
ejp
When will the 2002 HL arrive?
thanks in advance
Michael
1) Highlander's AWD system is basically FWB until slippage is detected, and traction is then sent to rear.
2) Traction is split 50%/50% until slippage is detected, then modified to suit the conditions.
1. Price increase - I was usually told 2-3%. Once about 1%. Once probably no price increase, Toyota usually increases prices Jan. 1.
2. I was told production for 2001 will end August 24. 2002 will commence August 27.
3. Personally, I suspect there will be no changes in 2002 from the 2001 model. If any, they would be very minor. Remember, this vehicle was released for sale in US in January. The 2001's were really not a full year production run.
I saw some at a local Target store, which were clear color. Not bad. Just wanted to see if anyone else has any recommendations.
thanks.
I'm considering waiting for the 2002's, that's also when my finacial situation will be on the positive.
svtcobra has is pretty much right by cliffy1 Jul 25, 2001 (11:04 am)
If you have a rear spoiler and want to be able to open the hatch with the cargo box attached, the box must be mounted forward far enough to clear the spoiler. That puts the front of the box just forward of the top of the windshield. This isn't bad, but it is quite a long distance forward of the front roof rack crossbar, which I didn't like. To solve this, I removed the 12 inch long rubber strips that are mounted near the front of the roof rack tracks and was able to slide the front crossbar forward enough to properly locate the cargo box mounting hardware. The reason the rubber strips are on the roof rack is to keep the crossbar from interfering with the operation of the moonroof. If I operated the tilt feature of the moonroof with the cargo box mounted, the moonroof would interfere and most likely break the glass. So I disconnected the power to the moonroof to avoid any accidental operation. If all this sounds like too much trouble, there are other boxes that are shorter and wider. Sears carries several models like this, but I noticed that the plastic was thinner and more flexible than the Thule or Yakima boxes. Good luck.
I sure do. My HL brakes suck. But I've read that others have had the dealer bleed them back to life, so that's what I'll suggest at the first service. Shouldn't be that way, tho.
Picked up HL V6 2WD yesterday for exactly $633 (about 2.6%) over invoice + regional advertising. Never would have thought that was possible in the great northeast. Only 80 miles so far but I cannot believe how smooth and quiet this vehicle is. Just like the ol' 93 Camry it replaced.
Thanks for all of the info over these many months of waiting.
NHTSA CAMPAIGN ID Number: 01V228000
Component: BRAKES:HYDRAULIC:MASTER CYLINDER:OTHER
Manufacturer: TOYOTA MOTOR CO., LTD.
Potential Number of Units Affected: 41169
Year: 2001
Make: TOYOTA
Model: HIGHLANDER
Manufactured From: AUG 2000 To: MAY 2001
Year of Recall: '01
Type of Report: Vehicle
Summary:
Vehicle Description: Sport utiity vehicles. The reservoir filler cap of the brake master cylinder may induce a vacuum, introducing some air into the brake
master cylinder reservoir. This could cause abnormal brake noise and increased pedal stroke when the brakes are applied.
The increased pedal stroke will lengthen the stopping distance of the vehicle, increasing the risk of a crash.
Dealers will bleed the air from the brake lines and replace the reservoir filler cap. Owner notification is expected to begin during July 2001. Owners who
take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact
Toyota at 1-800-331-4331. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT
(1-888-327-4236).
Thanks in advance.
