Visitor Agreement.
Brake pedal seems a little tighter,after the service.
Good luck and thanks for all the info you guys input to this townhall
posting this on July 25). According to them, the special service campaign for the
brake reservoir filler cap issue is so new that the information had not been provided
to dealers yet. However, one of the two service locations I called in my area knew
about it when I contacted them, the other did not. For the location that knows about
it already, I was told by them that they do not have the replacement reservoir caps
yet. I have a co-worker who has had the work done by yet another dealership, though, so it seems some dealers are already performing the work, others may not quite yet be aware, and others don't have the caps yet. Toyota customer service told me last week or so that we owners should be receiving letters "next week", which would be about now (again, I am posting this on July 25). So, the word should be out to all soon, hopefully.
I just thought that you might find it interesting that empty appears to be the letter "E" and not that last "tick-mark" in the 4 mark gauge.
For what it's worth...
My question is about the wiring. Does my HL have some sort of "jack" to plug the HH wiring harness into? If so, where is it? BTW, I do have the Towing Prep option. Thanks
I also had oil change done at the same dealer and they installed Avalon oil filter. They said oil filters are interchangeable. Any problems?
On a similar note, I could not find any mention of the missing "Tool Kit" in the manual, that others received gift checks for. It sounds like there might be a couple versions of the manual in print out there already.
-Stach
Also, is the hitch as easy to install as I've read? Didn't someone have a problem with the exhaust pipe getting in the way?
What is the consensus on which hitch to buy and where. There seems to be some many options out there, from sportsrack, uhaul, bage.com, etc.
A large number of folks (including myself) have bought the Hidden Hitch 70777 from www.bageco.com for ~$130.00 (shipping included, no tax since out of state for me).
The installation was easy, the Hidden Hitch instructions tell you that you have to pull down slightly on the muffler to get the hitch in place and once its bolted in you can release the muffler back into position. I did this myself in my garage with no problem.
I then ordered the Thule 994 expressway hitch 4 bike carrier and have been happy with it ever since!
Does the 2wd highlander get the 22/27 mpg as listed?
Has there been any major/minor problems with the Highlander 2wd?
What are my chances of getting a White, 2wd in the Penna. area?
Our real-world MPG for the V6 2wd down here in San Antonio (read FLAT LAND) is 19 in town and 22-23 on the highway with the a/c set to 72. These figures are in line with what was posted on the window sticker. Based on that, I don't see why the figures estimated for the I-4 model would be too far off either.
Regarding fit / finish, the HL currently comes out of the same assembly plant in Japan as the Lexus RX 300 and it shows.
The only problems that we have heard about have been: (1) models with moonroof are making a "clicking" noise coming from somewhere near the surrounding trim. I can't be any more specific as I have never owned a vehicle with a moonroof/sunroof due to my fears of them leaking. (2) Wind "buffeting" noise when one or both of the rear windows are lowered (even slightly) without either of the front ones lowered. I always use the a/c so I don't have any complaint about this either. (3) Yesterday marked the first recall on the HL since it's release. It involves the cap to the brake master cylinder not sealing well, causing air to be drawn into the system. Here's more details: Recall # 01V228000, includes all models. See http://www.nhtsa.dot.gov/cars/problems/recalls/mmy.cfm for more details (go to bottom right of page and fill in info to get to report on the HL). All in all, the HL is holding up well for a brand new model. We have almost 4000 miles on our in the 3 months we've had it and I still get the "new car fever" every time I get in it.
Finally, I can't offer any help regarding a source in PA. My guess is that most sold up there are of the AWD / 4WD variety due to the winter conditions, whereas down South, the 2WD is more popular. Just my two cents worth. Good luck in your hunt.
Re the recall, I guess the recall on the Japanese Kluger V also do apply here on Highlander version. Go to posting 2996. It also refers you to a site that will show a diagram of the problem.
Hang in there. My RAV4 I4 mileage continues to improve. I am now over 9,000 miles, and I am impressed. I'm getting the top end of the EPA estimate, and it may improve even more. Maybe those tight little engines just need to loosen up with use.
How do you like the acceleration of that 4-cylinder in that size vehicle? Auto or stick?
ejp
Happy HL'ing to others.
The check engine light was most likely due to somebody not tightening the gas cap. This will happen on any new car but it unfortunate the your dealer didn't do its job when they filled the tank.
Kevin
(also posted this on the yahoo club board)
Then we found Dianne@earthlink.net.
After some brief e-mail exchanges a build order was placed April 5, 200l. Car arrived 3-1/2 months later exactly as specified, i.e., AG, CQ, DR, HE, TO, VD and CF option codes. Made one trip to Carson to pick up our new HL.
What a delightful experience, compared to previous car buying hassles.
I am in process of buying a new Highlander v6 AWD. I had requested a quote from Carsdirect.com but they came up with a MSRP value.
Can anyone who has bought a Highlander from East Bay Area in CA share some info regarding the Sales person and Dealer.
Alpesh
I just helped a friend buy a Highlander (2WD, 4cyl) for $700 over invoice. All it took was one e-mail to Diane, after looking up the inventory on her website. She responded within half an hour and a deal was formed. Shipping was arranged to NorCal for $300.
I gave up the idea of getting a Highlander here in Sacramento because of the local prices. If I had heard of her earlier I might be driving a Highlander instead of a Passat. (love the Passat though)
I've got 2400 miles on my silver HL and love it, but I think I've got a serious problem. I took it to my dealer 5 weeks ago because I noticed wind noise at about 40mph which sounded like the the passenger's window was slightly open/cracked. The dealer checked it out and said it was normal wind turbulence.
About 3 weeks ago, the rear passenger's window started rattling off and on - I can stop it by gently pressing out on the window or upper part of the door. It doesn't always happen, and I can't pinpoint exactly where it is coming from or what triggers it to start.
Then, one day I opened the door and found my beautiful leather door trim on the rear passenger's side all sunken in and matted down along the entire length where it meets the window as well as half of the front passenger's trim. Cleaning and conditioning didn't help a bit.
Has anyone ever heard of such a problem? It looks like water damage to me, but maybe it's the adhesive under the trim... I really don't know.
If anyone can please help me, I'd be truly grateful!
-seemomgo
I just came back from little camping trip and we decided with 4WD we should be able to take this further down to the lake than where the road ends. Seeing how there is a semi-trail there to get to the best beach spot we decided to trek down with HL to that elusive perfect spot to do some daytime beach camping and a place to anchor the WaveRunners and for kids to play in sand and water.
The HL is definately a fun toy to have it did gets us there and back, to borrow line from Toyota ad. How we got back will undoubtedly add as a conversational piece when I meet my cousins again.
The HL had plenty of power to get out of soft sand with loose gravel in 110 plus degree temperature with A/C running and loaded 5 full sized adult men and 4 20 pounds of ice bags and coolers. But.... on a steep climb with this gear and with loose rock, fine sand I came close to digging a nice hole for the HL with less than 1500 miles. This is primary due to the tires (factory OEM) Bridgestone Duellar H/T are definately not made for biting in the sand. I recognize probably 98% of HL owners won't ever go off-road but should you ever decide to go off the beaten path, keep those tires in back of your mind before you get too far and get stuck!!
Other than that the truck/car gave us decent mileage of 19.2 MPG overall (includes fwy, hgwy, strt, off-road). Great truckar.
Happy HL'ing
See the SUV for Beach Sand discussion for more details.
Steve
Beyond the sloppiness of Red McCombs Toyota Service here in San Antonio, TX, I have no complaints with Toyota themselves. We have recieved many compliments on the HL and, even with this "bump in the road", enjoy it tremendously.
BTW, I think the HL brochure mixed up the pictures of Indigo Ink Pearl and Bluestone Metallic.
Though that is an interesting point you've brought up.
I thought at one time either in the 4Runners or the LandCruiser or Toyota Truck there were notices I remeber seeing about reducing the tire pressure if going off-road, now in my HL I don't think I saw it anywhere in glove box or door jambs or anywhere ? Has there been new tire technology reasons not needed or won't the tire possibly explode (maybe too dramatic word)or did Toyo. Product Mgrs, figure not needed if close to 98% of pop. won't need it so why bother putting any notices ?
Regardless, next time I will need to remember to reduce air if going off road.
Anyone have any ideas.
You gave an excellent description of the problem and mine is exactly as you described. I'm relieved (I think) that it's the foam and not from water.
Like you, I love the gray leather and am happy I ordered it, but I've already had one seat-back and one headrest replaced. They were very poorly installed and my sales person admitted the PIO leather is an ongoing problem.
Thanks again for the info, gwkiser. I'll let you know what happens. My HL goes in Thursday, and it will be interesting to hear what they say about it.
-seemomgo
7 New Sport Utility Vehicles Sustain Big Damage In 5 Mph Bumps
Steve
