Toyota Highlander
18586889091211
  • pdennardpdennard Member Posts: 1
    Is there a way to re-program the computer to automatically lock the doors when the transmission is taken out of park and to unlock the doors when transmission is placed in park?
    BTW, We have an '01 HL and love almost every aspect of it. I think the brakes feel a bit mushy but my wife doesn't. Matter of opinion I guess.....
  • 6cylawd6cylawd Member Posts: 4
    Have 100 miles on my 02 limited, 6cyl-awd. From the first mile, heard an engine "ticking" noise while it is idling. Next day brought to the dealer and insisted a mechanic take a look/listen. Said it was "normal" and related to the injectors. Anyone else heard a distinct tick-tick-tick from the engine? and if so... what were you told. I can hear it from inside the vehicle and more pronounced when I open the hood. Thanks!
  • rfhourfhou Member Posts: 47
    Just had the new master cylinder cap installed and the brake fluid flushed. What a difference! No more mushy brakes.
    Also, dealer ordered the left side door seal to correct "reed" type wind noise.
    Mine does not have the ticking noise -- I do have a steering wheel that "thumps" sometimes. It only "thumps" when the temperature outside is between 70 and 80 degrees - go figure!!!
  • llofgrenllofgren Member Posts: 129
    The ticking noise has been discussed both here (see posts #4231, 4303) and in the Toyota Highlander Club section under "Problems and Solutions." Consensus at this time is that it is either solenoid or injectors, is probably not anything bad, and is noticeable because of the extreme quietness of the vehicle.
  • svtcobraconvsvtcobraconv Member Posts: 85
    MIL ANDR
  • skyrebskyreb Member Posts: 129
    One of the wonderful things that we enjoy about our HL is the fact that the doors do not auto lock. We had two Explorer's prior to the HL, and the auto lock doors infuriated us more than any other feature.
    Maybe if they had auto unlocked it would not have been so bad. More than once at a car wash the attendant closed the door and the car was locked with the engine running and the keys inside. Every time I stopped and exited the vehicle to unload something from the rear, the door was locked.
    But, to each his own. I have no idea if the computer can be programmed to do as you request. For your sake, I hope so, but for me .... no thanks.
    Happy HL'ing to all.
  • jrfierojrfiero Member Posts: 123
    re #4356 of 4359 Brake Recall/Wind Noise - >Ticking Noise by rfhou Dec 20, 2001 (03:51 pm)
    I'm real interested to hear that. I had the MC fix done, with almost no change to the mushy brakes, and I took it back in because I'm sure they didn't completely bleed the system. Got the same ol' line "they all feel like that".
    How long did the MC fix and bleed take, if you waited for it? Toyota says it should take about an hour, mine took 20 minutes.
    Although certainly possible, a full brake system bleed in twenty minutes is pushing it, especially if this includes the time to take it into the service area, put it up on the hoist, set up and perform the bleeding process, technician test drive to check brakes, etc. I would be a little skeptical that this was done correctly.
  • little_pogilittle_pogi Member Posts: 149
    Svtcobracony is right about a 20 minutes brake bleed. Either the dealer has a some kind of a Superbionic service tech who could do jobs really fast or the the bleeding process was not done right. All 4 brake cylinders/calipers (one on each wheel) has to be bled. Try going to another dealer to do this service. The dealer I purchased my HL does a good job selling cars but has a lousy service department. Fortunately, my local dealer has a good service dept. and a sales dept. that sucks.
    They had my HL all day, so I'm not sure how long it took.
  • llamerollamero Member Posts: 10
    Has anyone worked through getting wheels for snow tires and the strange chain specs in the owners manual? As for snow tires, I'm planning on putting on Michelin Alpins, but my discount tire guys say that I'll be mounting them on stock wheels since aftermarket wheels aren't made to the 1/2 increment that is used on the HL. As for chains, there are some odd specs in the owners manual for chains specifying link sizes. Neither dealer nor stores have been able to make any sense of them and cant confirm that cable chains or low profile ("S" type) link chains actually meet these specs. I've got to carry the chains even if I never use them to keep the Washington State Patrol happy. Anyone else been through this cycle?
    Apparently some owners have/hear an engine ticking noise and some do not. It would be helpful to me, and I assume others, if those who do hear it would indicate what they were told by a technician/mechanic = "diagnosis" vs. a "consensus". I'm not satisfied that it is "probably" nothing bad vs. could be something very "bad" or serious. So....if anyone has been told specifically what is the cause and whether an adjustment is necessary/possible, I would very much appreciate your post.
    Happy Holidays and thanks in advance for your response.
    Chains CANNOT be installed on the rear of an RX300 and the HL is likely the same. Rx manual says use chains on the front ONLY. When I challenged them via email about the potential hazards of chains only on the front they said use snow tires all around and not use chains at all.
    If I remember correctly the Oregon state police will not allow chains only on the front.
    The only posts I have seen regarding technician's assessment of the ticking is in the posts I mentioned. I don't know if anyone else (on this board) has had a mechanic check the noise. The dealership told me it was "the fuel injector pulse" and someone else was told it was "a solenoid" and both said it was nothing to worry about. I think it would be great if others posted their experience, if any, regarding this. In the meantime, why don't YOU bring yours in and get it checked and give us the feedback??
    I already did. See #4355. I also appreciate your quick response. Anyone else out there?
  • tmc1417tmc1417 Member Posts: 11
    Responding to posters wondering about the HL's traction in snow...with AWD it boils down to the tires. My 01 HL has the standard Bridgestone tires. These tires were rated in Consumer Reports I believe a few months ago. They were rated highly in almost all categories....except one thing:performance in the snow. They were rated poor in snow. Check out the report. I'm in Minn. and we are still waiting for some snow to give it a test.I took it in to the dealer to get the tires rotated and specifically asked to rotate all 5 tires since the spare is full size on an alloy wheel (They even had it on the bill). but as usual, when I got home and checked, only 4 tires were rotated.
    I am reminded of the patient that spoke to the Doctor about "silent gas emissions" to which the Doctor said, first we need to check your hearing. I do not hear ticking, or the other sounds that some hear. When you consider all that is going on inside and outside an engine: pistons movong up and down, 4 cam shafts spinning, 24 valves openeing and closing, fuel metering and injected, plus belts, the generators, air compressor, and whatever else, if there were no sound I do not believe the engine would be running. The Toyota engine is an engineering marvel, and extremely quiet. I would be more concerned about a "knock" when climbing a hill than a wisper ticking sound that is barely heard, and only by persons with good hearing.
    Happy HL'ing to all ...... and Merry Christmas.
    PS, yesterday I washed and waxed my HL. My what a beautiful vehicle!!
    Yes you are very right on the ticking. It is very subtle and I can't believe I am even posting these messages! The only thing that has me somewhat interested and concerned is the similarity of the sound to a valve lifter tapping which I am quite familiar with. Thats why I brought mine in and had it checked. I am not sure that their explanation (fuel injector pulse) was accurate but I do accept their explanation that it is an OK thing.
    I am one month into having my V6 AWD silver non limited. I still just gawk at it every time I park somewhere and marvel at what an awesome vehichle it is. I had spent two years looking for an SUV (almost bought a CR-V, 4 Runner, Forester) and never thought I would find an SUV that was perfect. The Highlander is extremely close! I would like to wax mine too but the weather here is kinda bad right now. This is the second dumping of snow since I picked up the HL and I am overall very impressed with its traction and ground clearance and ability to get through snow.
  • kpt_krunchkpt_krunch Member Posts: 21
    I just drove the HL yesterday (it is the wife's vehicle - so unfortunately I don't get to drive it that much). The ticking is getting much more noticeable. Now, it could be it is cold here (-10 to -15 celcius) but it is definitly not a whisper. Once you step on the gas it gets muted, so I know it is definitly not a lifter. Actually, on a trip to safeway to get the Turkey, we heard another ticking from a '91 Dodge Caravan (it was behind us). Sure enough, as they accelerated, the ticking got a lot faster and louder. This, I told my wife, is a lifter problem. However, I don't like the fact that not everyone has this problem. I have a V6 AWD, built in August 2001 as a 2001 model. If this is "normal" than everyone should have this noise. Anyone with a 4 cyl. want to comment? Do the 2002's have this tick? When I take mine in I'm going to challenge the service department on this. I want them to tell me why some have it and some don't, and if possible, I want it gone, as it is rather annoying and it does make the vehicle sound like a "DODGE", yiiiiiiiiiii
  • cliffy1cliffy1 Member Posts: 3,581
    Well, now that this is being discussed at length, allow me to jump in with some information on another Toyota product that is known for cold weather ticking. The Tundra V8 is known for this, but the Land Cruiser is not, even though they have the same engine. There is one difference though. The Land Cruiser has much more insulation around the injectors.
    Injector noise is not a problem in terms of engine life or reliability. It can be a distraction though. Mine does it worse than others when cold and sounds like a diesel engine for a good 5 minutes in cold weather.
    There is a "fix" for this and it is a simple matter to wrap insulating tape around the injectors. I haven't bothered with it for mine.
    I don't know that this is the same thing ya'll are hearing, but it is a possibility.
    My HL is a 2002 built 10/1/01 so the '02's definitely can have the ticking.
    Cliffy....thanks for the info on the Tundra and LandCruiser. Thats very helpful.
    The tick (for me) is less noticeable when the engine is cold and is only there after it warms up a bit. As far as the outside temp goes....hey, its ALWAYS cold here :)
  • tommyg12tommyg12 Member Posts: 158
    Fortunately, we are right to assume that this is not a faulty lifter (although it sounds just like one). I do not notice the tick on startup nor do I notice it all of the time. It seems to happen more in cold weather after the engine has been running and of course a lifter would not be intermittently quiet(or as widespread). However, at times it is more audible and somewhat annoying. Isn't our configuration very close to the RX300? I have to assume that this will lead to a TSB if enough people complain. If the sound occured all of the time and was deemed normal, then maybe. But to be whisper quiet at times and tick at others puzzles me. Still a great vehicle and proud to be a member of the Toyota family.
  • markocmarkoc Member Posts: 1
    Question about running boards on this car - how do they look and are they worth it?
    We have the sport running boards on our HL - it looks great! I will have to post a Pic one day so you can see, but I think they look nice with the vehicle (also got the rear spoiler put on)
  • goldstongoldston Member Posts: 110
    I had the same mushy brakes on my Highlander that others have discussed here. I took my HL into the dealership for the master cylinder cap replacement and was told my HL didn't need it and that the brakes are normal. I explained the mushy pedal and how far the pedal goes to the floor and was told they're all that way.
    A week later I'm back at the dealership to explained that I was stopping for a yellow light and the brake pedal again went almost to the floor and I stopped through the crosswalk into the intersection. And would not continue to drive the HL with this kind of brake failure. (clue here... using the word "brake failure" causes service managers great anxiety they come out to talk with you :-))
    Anyway.. The manager comes out and explains that Toyota has never had a brake failure on any vehicle this is a very serious statement. I agree that is a very serious statement BECAUSE IT A VERY SERIOUS PROBLEM! (duh :-)
    He tells me that my HL has been checked over by a mechanic, that they bled the brakes as a precaution but that everything is fine. (I asked on my prior visit to have the brakes bled but was told it was not necessary). Now he take me for a drive in my HL (he's driving) so he can explain and demonstrate how the ABS works. Well, I'm a easy going guy, so I politely ride along and listen and after about 20 minutes we return to the dealership and thank him for his time and dedication to customer service (I give credit where credit is due) but my concern with mushy brake pedal and lack of stopping still continues. He explained that the work on my HL is now documented should something else happen. I thank him and he heads back to the service area. I get into the drivers seat, put it in gear and drive to the exit. (clue here.. this is the first time I've driven my HL since they bled the brakes) I step on the brake and WOW they stop.. like right now!
    Then I finally dawns on me that this service manager has been driven my HL around showing how great it stops and explaining that I must have mistaken to think that the brakes were mushy all the while I was ignorant that the brakes now are working great and not mushy like when I arrived at the dealership.
    So, long story short here. Have the brakes bled. Even if you have to take it to a brake place and pay to have it done. It makes a world of difference.
    Best regards and happy holidays,
    Philip
    Ps. I didn't tell my wife about the brake being bled (to make sure it wasn't me being hopeful) so when she returned from driving it, the first thing she said was "wow". What did they do to the brakes to make them work so great?
  • wcpwcp Member Posts: 40
    How can I find out my Highlander's build date from its VIN? Can anybody please help? Thanks.
  • hlltdhlltd Member Posts: 61
    Chip,
    Not sure that this is possible to figure out by the VIN? Others may know for sure, and I know they will jump in here to let us know if that is possible.
    You did know that the month of production is posted on a tag in the driver's door jam, didn't you?
    HTHs
    Happy Holidays.
    Imelda/388
    Mentioned in the 'Camry board and a lot of mentions in the Sequoia board. The Sequoia owners have apparently been told that there is a piston-slap issue. Yikes! Don't think that's our problem though. Merry Christmas everyone!
    Tommy,
    I certainly hope that piston slap is not the problem.
    As a matter of fact, I don't see how that could possibly be the problem given the precision and quality parts and close tolerances that I'm sure are built into all Toyota motors. One doesn't get the longevity that Toyotas are noted for by throwing motors together that have piston slap! Now if it was my ' 72 Fiat 128, I would agree with you, as mine did have piston slap big time. Took the factory rep. to okay a new set of pistons, and guess what? No more piston slap.
    But that was long ago, and far away.
    Piston slap occurs only when a motor is cold and has excessive clearances between the piston skirts and the cylinder walls, and can usually only be detected by loading the motor slightly, and then backing off from it being under a very slight load. It is not heard while at a steady idle. You must rev the engine slightly, and then allow it to come back to idle slowly and listen for the "slap" while the motor is slowing down. This slapping noise that can be heard is the skirt of the piston actually slapping the cylinder walls. It cannot be heard while the motor is idling at a steady idle unless a motor is purposely set up loosely as are motors built for racing.
    HTHs
    388
  • maxintoshmaxintosh Member Posts: 39
    The brakes on my 2002 are STRONG, especially when Brake Assist kicks in. Was there a running change in the brake system?
    The words "piston slap" are loaded. The discussion on the Sequoia board about a year ago had one participant describe it as this, but that was actually not the case. I know because I had a personal discussion with the Regional Toyota people about his situation. His issue was not the injector issue I mentioned the other day, but was not piston slap either. I forget the final diagnosis, but somebody had sued the term "slap" when describing it to him and he stuck with that even though it was not technically correct.
    BTW, Toyota bought his Sequoia back and he purchased a Land Cruiser AND an Avalon.
    Obviously, no consensus on the issue.
    Several "possibilities" seemingly for the same symptom (A definate audible tick,tick,tick, while it is idling, regardless of whether it is cold or warmed up.
    Injectors?
    Selonoids?
    Fuel injector pulse?
    Valves?
    Piston?
    KPT KRUNCH; I agree with your concern, re: why do SOME have it and some do not?? I also want it "gone". First step I believe is a consistent "DIAGNOSIS" via toyota technicians/mechanics. That's why it will be very helpfulf to those of us "Tickers" to share specifically what is said and what if anything can/should be done.
    p.s. Took it for a 300 mile partial break-in ride and it did not seem to impair performance, but who knows?
    PEACE, HEALTH AND HAPPINESS TO ALL.
    Maxintosh,
    After reading your statement about how strong your 2002 HL brakes are, it sounds like I need to go down and test drive a 2002 HL and see how it compares with my 2001 HL brakes.
    And, in answer to your question about changes in the braking system I'm not aware of any changes but maybe "cliffy1" would be more qualified to answer this question.
    Best regards,
    Philip
    From my dealer of purchase: "fuel-injector solenoid" and of course "they all do it". Now this is a very small dealer(only three service bays). Not to stereotype a small dealer, but the tech also told me that this was the first 'Lander he had gotten to work on(but yet he knows that "they all do it",hmmm). I had already planned to start another HL on the lot, but there were none in stock. I'm due for an oil change in about 500 miles, and I am going to use a very popular dealer in my area that has plenty of inventory. I'll report it to them and see what they have to say. So again, that's my "official" Toyota report: Fuel Injector Solenoid
    I believe that's close to what some other board members have been told. Others?
    Also, I don't think that it is internal (i.e. lifter, piston-slap) but it does merit an explanation. I'll post back after my next dealer visit.
    Guess I'll take the future son-in-law up on his offer to test drive his new identical to our FWD HL LTD. Ours is a late enough production 2001 to have the same brake reservior cap as his 2002, but I'm wondering IF there might be a difference somehow in the way all 2001s had their brakes bled?
    We will be seeing him this evening at the Christmas family gathering.
    388
  • trdgttrdgt Member Posts: 5
    Hi all,
    Just wanted to chime in on the engine ticking issue.
    I own a '00 Celica GT as well as our new '02 Highlander. I too have had the same engine ticking in my Celica, the dealer has told me this is normal for the Japanese produced engines.
    We have the 4 cyl in our H/L.The ticking is due to the louder fuel injectors used with these engines(so I was told).
    You should hear the Celi when it gets cold here (Ohio)sounds like a machine gun til it's warmed up
    but I have chalked it up to the nature of the beast.(I have had the injectors checked twice and both times they are fine).
    BTW the H/L has 10 more HP with the addition of A TRD licence plate frame!!!
    Happy Holidays and be Safe
    TRDgt
    I think anyone should be immediately suspect of dealers' service people who explain away a problem with 'they all do that.' There should be signs on the walls in service department rest rooms advising staff to never say that. As soon as I hear it, I know they don't know what they're talking about, and I assume they used to work for an domestic brand dealer.
    Clearly, not all HLs have mushy brakes, not all HLs that once did do now, not all HLs have the ticking noise.
    Don't accept it as an explanation for something you think is a problem. For your future reference, make the service writer explain exactly what your issue is in writing on the invoice or service form or whatever they call it, no matter how many pages it takes or how much they complain that the computer won't let them.
    If you are not satisfied with the service, email or write Toyota Customer Service.
    It's a pretty nice vehicle, but the service so far, sucks.
    You are right. I found the date on the sticker pm the doorjamb. Thanks.
    re a previous post with the following "I took it in to the dealer to get the tires rotated and specifically asked to rotate all 5 tires since the spare is full size on an alloy wheel (They even had it on the bill). but as usual, when I got home and checked, only 4 tires were rotated. "
    My experience also, only noted after I returned home and checked. Ourisman Fairfax Toyota in Fairfax VA only rotated the four tires on the car, and rotated them front to back, rather than across. Acrosss is the Toyota recommendation, in addition to including the spare.
    Also, the lug nut torque was way off. To check, I used a torque wrench to loosen the 4 non-locking nuts on the left front. Factory recommended torque is 76 ft-lbs. One nut loosened with the torque wrench set at 80, one at 90, one at 110, and one at 115. FYI, 115 ft-lbs is 151% of the factory spec. Other wheels were similarly uneven, although I didn't check the torque.
    Uneven lug nut torque is one of the causes of the dreaded warped brake rotor, so common these days, which makes your brake pedal pulsate in normal braking, and frequently requires replacement of the brake rotors (disks).
  • roadrunner70roadrunner70 Member Posts: 241
    has anyone installed a plexi bug shield on a 2002 hl?? if so, what brand, etc. where holes needed to be drilled? anything else to know about.
    also, we would like to cover the leather seats with seat covers. has anyone purchased toyota seat covers. thanks, harold.
  • budhinckleybudhinckley Member Posts: 25
    With 1,000 miles on my 10-day old 2002 AWD V6 Limited, I ended up rear ending a Civic.
    Strange because I was NOT in a hurry and NOT tailgating (both of which I am frequently guilty). I can tell you that I am sure the 2000 Land Cruiser I traded in WOULD have stopped with some margin.
    In this case, when I saw I had to stop quickly, the brake pedal travel was excessive and I just didn't seem to be have the braking power to stop the 4,300 pounds (car plus me and my girlfriend - she was impressed!). I was going 10-15 mph on contact. Thankfully, no indication at all on my HL. Really nothing on the Civic, although this guy I think is trying to say his cracked paint and loose exhaust pipe occurred because of the contact... not! (And he didn't get the police there, either....)
    By the way, ABS never activated even on the wet roads (confirming to me that it didn't brake as hard as it should have) and also ABS DID work the other day in snow in South Bend, Indiana.
    Bud Hinckley
  • deatricedeatrice Member Posts: 6
    My 2002, 4x2, V6-non-Limited, Bluestone Highlander was delivered to me on Christmas Eve and I LOVE IT!!! I never owned a car with such smoothness, and pick up. Even better it was delivered much sooner than the dealership had first quoted of 6 to 8 weeks. I received it in 3 weeks.
    I would like to thank all the message board members because without you I would have probably gotten another vehicle and not been satisfied as I am with the Highlander.
    Happy Highlanding to all and have a joyous New Year!!!
    budhinckley:
    If you have VSC then its deceleration sensor and yaw detector may have indicated that you never needed the ABS.
    Now I don't actually know why there is a deceleration sensor included in this VSC circuit, but...
    ABS is primarily intended to keep the vehicle from deviating from the desired line of travel during what would otherwise be "locked wheel" braking.
    The traditional ABS design could be readily improved through the use of the VSC's steering wheel position sensor and the yaw sensor to determine if the vehicle is following the correct line of travel during "locked wheel" braking.
    The only purpose I can think of for including a deceleration sensor in the vehicle at all is to determine if the "locked wheel" braking circumstance is actually providing enough, or adequate, braking HP.
    All of this is just a guess but I have had my 2001 RX300 exhibit the same symtoms you describe and the Lexus service manager explained it away by saying the 2001 version of ABS uses a more moderate pumping technique.
  • pdwspdws Member Posts: 3
    In reviewing the SE Toyota inventory online, I noticed there are two types of leather listings, 1) Ivory leather - leather package option at $1070 MSRP (described as leather trimmed seats with head rests and door trim)and 2) Leather - perforated leather faced seats at $1429 MSRP. What is the difference between these two? The only leather option reported by Edmunds is the leather package at $1070 MSRP.
    I do have VSC in my 2002 AWD limited. I was braking on a wet road with no puddles (early melted snow - but no snow or slush - that hadn't yet dried) when I had to hit the brake hard to stop - and the stopping power just wasn't there.
    A few days later, ABS did work perfectly in the snow and if anything it activated EARLIER than I would have expected.
    Going in tomorrow to have brakes checked...and my first oil change at 1,300 miles. I wonder if the Toyota dealer is going to give me grief when I bring my own Amsoil oil and filter......
    budhinckley,
    You have something wrong with your brake system!! Definitely have the dealer check it. Maybe your brake pads weren't seated well during your break-in.
    The excessive pedal travel is actually Brake Assist kicking in. It "sucks" the pedal all the way to the floor when it detects an emergency stop.
    I had to stop fast today for someone who slammed on their brakes, and the car stopped so hard I was thrown forward in my seat. Did not this car get best-in-class stopping distance from Consumer Reports??
    No way you were going that fast. If you hit a stopped Civic at 15 mph, there would be some nasty body damage done to both cars. The nose would be all shriveled up!
    http://autonet.ca/AutonetStories/Stories.cfm?storyID=3489
    "Published reports state Japanese automaker Toyota Motor Corp. is recalling more than 41,000 Highlander SUVs because of a potential problem with their brakes.
    The National Highway Traffic Safety Administration announced the Highlander brake problem in its monthly list of automotive recalls.
    The safety body said the problem with the Highlander's brakes stems from potential leakage of air into the braking system, which can lead to an increase in stopping distances and heightened risks of a crash.
    NHTSA said 41,169 of the SUVs from the 2001 model year were included in the recall."
  • gpoltgpolt Member Posts: 113
    What options did you get and what price did you pay on your Bluestone V6 FWD? Thanks.
    On my Highlander, I have the options PE, AG, RL, powered Moon roof,SR, Towing Package,TO, for my jet ski, and CQ. I paid 27,500 not including tax and title. When all was totaled I paid about $750 over invoice price. I got a good deal from my dealer and everything I needed in my HL. I hope this help...
  • bironbbironb Member Posts: 63
    I am interested in purchasing a Highlander with the “B” Package (M.S.R.P $39,300 Cnd). After checking the availability of said model in Indigo Ink, I found one that was on display in the showroom of one of the local dealers.
    Upon entering the showroom, I noticed that all the Toyota models on display had pinstripes including the HL. Now I don’t care for pinstripes whatsoever but figured they could be removed easily enough but things got worse. Upon checking the interior, I was surprised to see that the standard Metallic Instrument Panel Accents had been replaced with third party woodgrain ones. Except, now get this, the trim around the gearshift and cup holder in the centre console were still the standard metallic.
    After pointing out this mismatch, the sales manager’s only reaction was basically “Yeah what’s the problem with that”, unbelievable! I checked the price list for the vehicle and noticed that they were charging $585 Cdn for this disaster of an upgrade.
    Why Toyota allows their dealerships to change standard designed features in an automobile at their own whim and ruin them I don’t know.
