Honda Element Tires and Wheels
Hey, like many I am about to replace my stock Goodyear Wranglers that gave me less than 30k miles before going bald. Any suggestions for ALL WEATHER tires. I am in the mid-atlantic and want a good tire for wet roads and one that is fairly quiet. Some help would be appreciated.
LT
sam's club on-online ($137) each.
just did it and like em.
nice tread pattern
They are great in the snow/wet/dry. I used to buy snow tires but no more, I'm tired of paying for storage.
probably the best place to buy tires is www.tirerack.com
Thanx Martin.
janis
We need some more information about your "tire wear problem"! It is normal wear, or is the vehicle "out of alignment"? If the vehicle is "out of alignment", with only 10,000 miles on the vehicle, I think you have an issue with Honda Corp., and the dealer. I would think that the "alignment" should be one of the things that would be checked as part of the "dealer get ready process" prior to delivery.
One of the vehicles that I am looking at for 2007 is the Honda Element. Should I decide to purchase the new "up-scale Element" that is going to be available for 2007, I will make an "alignment check" part of the sales contract!
The problem might also be the quality of the original tires. I would complain, in a professional manner, to both the selling dealer, and Honda Corp..
Best regards. ----- Dwayne
In college I briefly worked as a temp on the service drive of a dealership, so I'm familiar with their "tactics". Like I predicted, the service technician and manager denied there was anything wrong with the tires and that they had "another 30,000 miles to go" - which is such bull. Even though I don't know much about tires, I can even tell there's no way they'd come anywhere close to "another 30,000 miles". There is no alignment problem, and the tires have been rotated three times since I bought it. The wear is even on the tires - it's just low (you can see top of Lincoln's head with the penny test).
I stopped by my mechanic's on the way back and told him what they said, and of course, he said they're full of it (showing me that the wear is down to the tread bar). He said he'd go only another 500-1000 miles, definitely replacing them before winter - which I will anyway, since I'm going on another cross-country trip in November.
I did get kinda' bitchy with them, but I pretty much knew going in I wasn't going to get anywhere - and though my original plan was to go to the dealership manager if necessary - I've since decided it's not worth my aggravation. The only other thing I may do is send an email to the dealership manager and/or Honda and see what happens. Beyond that, I just don't want to deal with them (which I'm sure is what they're counting on). There's just too many other things to stress about lately!!
I wouldn't think the tires are necessarily defective - I just think they put crappy tires on it. I haven't heard many positive things about Goodyear tires, and I guess this only confirms that. I'll stick with Bridgestone's, which I've had good luck with in the past.
Aside from this tire thing, I LOVE the Element - and I just have the basic automatic AWD. Everything else has been fine. You just might want to check the type of tire that comes on your new Element. Maybe you can get better tires in the deal!!
Thanks again - and good luck with your purchase!
Janis :-)
I went with a slightly wider tire while staying close to original specs (235/60X16) using the yokohama Avide TRZ. It is a passenger tire, but since 98% of my driving is in city, they work great. They have an 80,000 mile tread warranty (UTOG rated at 700), I just returned from a trip to Wyoming and used the Element on back roads and in rain and the TRZs were great.
Good luck, consider it a case of the manufacturer spec being designed for the lowest cost tire possible. Seems like OEM tires don't last like regular stock tires, even Michelins, on other vehicles i've owned. 30,000 seems t be the max I get
The best part is that these tires have terrific rating's for all categories as posted on the tire rack. My experience with them so far is that they are nice and quiet, handle great, look terrific with the black raised letters out.
I bought this Element used with 26k miles in April 06. The prior owner did all the Honda Maint. per book. OEM Goodyears rotated and balanced every 5k. All was evenly worn right to last 1/8" of tread. New TIREs were a priority.
The tread pattern on the new ALENZA's were a strong selling point for me too. Vehicle ride's with more class now...
I took my car to Firestone and bought a lifetime Alignment and 2 new tires (same that the car came with from the manufacturer). I experimented with getting the car checked and/or aligned once a month along with having the tires rotated once a month. This does not fix the problem either.
If you replace your tires, replace all 4 at once and do NOT put the same crappy tires that your car had on it when you bought it. But don't think the more expensive tires are better. I have since put on the cheapest set of tires available at Discount Tire Company and the car runs smoothly and I have not had to replace the tires, rotate them or have the car aligned to keep from having the problem.
The issue is cheap tires used by the car manufacturers and having the car dealer and the tire companies all say it's the other's fault.
I would write letters to the car manufacturer and tire company and complain to the dealer....you might get somewhere or you might not, but it won't hurt to see what you can get them to say....probably all rubbish, but if you are lucky, they will buy you a new set of tires which will get you another 10,000 - 20,000 miles which is what the original tires should yield. By the way, My next car will more than likely be the 2006 or 2007 Element, with a better tire than the manufacturer supplies if I can get the dealer to upgrade them.
I can understand the Cali-Freeway and experienced it on a recent trip out there in particular between Brentwood and LAX Southbound on the 405.
I'm approaching 30K, so fully expect to replace the tires soon.
The lack of clearance on the E is driving me crazy -- yesterday I pranged the gas tank guard but good on a not-very-big rock. I'd love to raise the car a couple inches, but I understand that's more trouble than it's worth. Has anyone had any luck installing bigger tires? How much bigger have you gone? Even a half inch extra height would help, but a full inch would be groovy.
This has gotten to the point where I'm seriously thinking of trading the car in for a truck, much as I love it.
Mike
If so, did they decrease MPG?
I'm like you. I had pushed my OEM to the end. At about 58K, however, I had decided to go ahead and change them even though I believed I could squeeze out another 5-10K. I purchased BF Goodrich Long Trails from Costo. For a set of four, including all mounting, life time balancing, etc the price came out to $343. I absolutely love these tires. These are much quieter than the OEMs and I average 25 miles/gallon. I plan to squeeze out at least 60K out of these tires. It is noticeablly better in all conditions than the OEMs. I didn't have any problems with the OEMs but they were more than $100 a piece excluding all other charges that tire shop typically charges, which would make the total cost difference more than $100 between the two brands. Also,having driven on both brands, I would still buy the BF G's over the GY's even if there is no price advantage. I hope this helps.
