I have not driven an rx, but I am not impressed with the feel of the engine at idle nor upon acceleration. I have driven other hls, and find them to be about the same, some a little more, some a little less. My 94 intrepid with the 3.5 engine is much smoother.
When the car went in for its first, and hopefully only warranty work (the front end was out of alignment and the steering wheel was not centered from the time we took delivery) the vibration was looked at and npf,(no problem found). Forget about it and enjoy the car.
While on the board, some observations about the car after about 6 months. overall good, some small complaints - only prop rod for hood, no light under the hood, radio impossible to read during the day, paint job seems a little "thin", vehicle overpriced, even at invoice. My first Toyota, and maybe my last. Dealer service very good. Vehicle tows well within rated capacity. Hopefully, reliability is up to the Toyota reputation, as that will make it worth while.
By the way, I recently test drove the Toyota Sequia, and the tranmission shifts were not smooth, and overall I didn't like the way the vehicle felt. I have test driven Tahoes and Surbubans, and like them much better.
Don
I paid $31,500 for a car that was in mint condition and custom order White/Black leather, wood leather steering wheel, HID, premium package plus and heated seats w/memory with 14,000 miles.
The HL is not any less of a car and I would have been greatful to own one, but sometimes the better deal can be had when you cross shop the HL and RX (pre-driven).
The car now has 20k miles and rides smooth as glass. Oil changes at Lexus run $35.00 and you cant beat the great Lexus experience.
If I were looking for a new suv today I would most likely wait for the redesign Toyota 4Runner (03) Yeah baby!
Go Toyota
Larry
axelsenus, are you happy with the way the 90647 looks? Do you think it is less noticeable than the 70777?
A little dissapointed with the MPG, but not unexpected per posts here. First checked fill was 20 MPG, second 21 MPG, third 21.25 MPG. This is strictly highway driving. I hope it continues to improve.
I think the HL is geared too low, even the V6 2WD which is the highest ratio of the four combos. Really no need to turn the RPM's it is at highway speeds. Toyota could have geared them a bit higher yet at least on the 2WD units.
But I think Toyota did it that way for several reasons, among them to give it the feeling of having more power and responsiveness when in overdrive at higher speeds. I think mine will go faster in third gear than in overdrive.
The LSD manages only one axle.
-juice
I think the cloth seats on the Highlander require some kind of protection but have no idea if the dealer protection is any better than what I could do myself with some Scotchguard.
As for the pain sealant (er, *paint* sealant), it seems like a good idea in theory (my Highlander will be 'Indigo Ink' in color if that makes a difference)...but is the price quoted reasonable?
Sorry about the mundane questions. Oh, is dealer rustproofing *ever* worth it? The nice blonde woman they sent out after the salesguy was finished with me thought it quite essential.
Thanks for any input!
It should prove interesting as my experience tells me it may be a motor mount. Granted, these vehicles use electronic motor mounts that adjust with RPM; one could be defective. I hope for the best. Also, I read one of your early comments and am surprised that no other owner has experienced this, as I have test driven 3 other HLs at different dealers only to find that 2 of them had the same harshness. Ridiculous for $30K and up.
I certainly hope the dealer can resolve the problem for you. The HL is the quitest, smoothest vehicle I have even driven, and everyone should enjoy that feeling.
Happy HL'ing to all.
following up, i don't think its the engine,but it might be a bad motor mount. I have noticed that it varies somewhat, from almost not discernable to noticable at idle. It also depends if the a/c is on or not. To me, its most noticable upon acceleration. Also, several test reports on the hl mentioned the exhaust "growl", which could be adding to the feel upon acceleration.
please post the outcome of your service visit, as i would like to know if perhaps your dealer agrees its there, and what the fix is.
Again, i wouldn't be surprised if there is an offending motor mount. But, i clearly felt the same thing in other hls which i test drove, as recently as three weeks ago.
thanks.
Just wondering if any of you considered the VW Passat Wagon while considering your Highlander.
I was pretty set in my mind to go with the Highlander when I saw a Passat Wagon on the road.
I did some internet research and it looks like it might meet my needs better than the Highlander, though it seems to cost a bit more. My petite wife likes the lower-to-the ground stance of the VW in particular. (I wish Toyota made an AWD station wagon! I'm a Toyota loyalist, but they don't seem to make the one niche vehicle we're interested in.)
Anyway, while I'm still doing my homework on the Passat Wagon, I was wondering if any of you had taken a close look at it vs. the Highlander and what your take is.
Thanks for any input.
- Stuart
Stuart, I too cross-shopped the Passat. I think it's a great car but I ended up going for the Highlander in the hopes that it will win in the reliability dept. The Passat was great fun to drive and I would be happy with either vehicle, but I'm banking on Toyota quality...
Greg
I don't think the VW can compare to the HL in any way. Stick with the big 'T' and you'll not be sorry either.
Other points of interest, I bought it at invoice, according to Kelley Blue Book, the dealer kept the holdback. I looked a lot for a class II trailer hitch, dealer has a class III, and found the best deal at etrailer.com for about $90. It is draw tight brand and installed OK. The bolt holes were about one third of a hold diameter off from the frame but was able to flex it into place with out much trouble. It is low and well tucked under the bumper so it is not intrusive at all.
Southeast Toyota tends to put on what they call Toyo gaurd on most of their vehichles, at least the higher trim lines. This consists of paint sealant, interior sealant, undercoating and VIN etching in the glass. They charge just over $600 for this, Just under $200 from Gulf States Toyota. I think 600 is too much but may go for it at 200 as I feel the undercoating does reduce some of the interior noise from outside. Otherwise it is a lot of money for wax and scotchgaurd.
I feel the airconditioner vent on the drivers side of center is positioned so that it hits the steering wheel better than me. It seems to be slightly different in the RX300. However the air is very cold so it's not a big issue either. The passenger side front seat feels as if it is dumping you out on the floor, I wish the seat bottom was adjusted with the front portion up more. Has anyone thought of shimming with washers under the front two seat bolts in an attempt to tilt it back more??
And finally I have a 96 Avalon that I purchased new with the "1mz" engine, have changed the oil every 5000 miles and have no sludge problems. I know the HL has vvt but does that make any difference with the sludge problem? The dealer was sure to suggest about three times that I change the oil at 3000 miles because of this issue. We drive interstate miles about 15 each way to work. Anybody have comments on this??
I like the passat, it has been a good car. Here are a few pros and cons compared to HL
Passat pros:
-Sporty ride, handles well. Good brakes too.
-Good visability
-gas mileage
Cons:
-Power. We had a V4. Would have DEFINITELY gone with the V6 had we gotten another pasat
-Cheapo cupholders, tire jack.
-Hard seats become uncomfortable on long trips
Highlander
Pros:
-Smooth ride for and SUV
-cargo space
-Height. This was the deciding factor for us. It is much easier to get a child into the HL because it sits up higher. Putting a kid in the Passat with its low profile was hard on my wifes back.
-better seats
Cons:
-a few blind spots
-heavier car, longer brake time
Both are good cars. We bought the Passat in 1999 because we wanted the carrying capacity of and SUV but did not want the ride of a truck. Now with the emergence of the HL and other "crossovers", we can have the SUV without the truck-like ride.
we have a 2002 hl limited with heated seats. In the cool weather we are having in the NE, i used the heating on a long trip.
I noticed that it stays on for only a few minutes and shuts off for about 10 min, at which point it comes back on.
Is this normal? Is the duty cycle adjustable by the dealer?
BTW, HL is a fantastic vehicle.
thanks!
Whats that about?????? electronic motor mounts?
True?
My driving is similar to yours I have a 24-27 mile round trip commute that isn't stop and go unless there is something major going on. The bulk oil (Pennzoil 10-30) that the dealer used was totally shot at 2400 miles. Several knowledgeable folks commented on the results.
I'd recommend doing an oil analysis on your engine to make sure your oil is holding up for the service interval you are using. Based on the analysis I had done, I'm going to change the brand of oil and provide my own in bottles at the next change. Then I'm going to gradually lengthen the change interval based on oil analysis results. Right now I wouldn't trust the combination of this engine and the dealer's choice of bulk oil for anything over 3k miles.
I'm glad I know what my engine is doing. The dealer actually did this analysis at no charge but the cost is minimal ($25-30) to get the information I need to make sure I've got the right oil for the engine.
I still love my Highlander and appreciate Toyota developing the special policy regarding sludge/gelling. But I do recommend adjusting you service interval based on the condition of the oil as there appear to be a number of factors that may contribute to sludge in this engine.
I was just trying to make the point that you've got to use a quality oil and the stuff the dealer provides, purchased in bulk barrels, probably isn't protecting this engine for the 'normal' interval. My oil's base grade (30 wt.) had dropped to 20 wt by 2400 miles. Most of those miles were not 'severe' conditions. I don't think that oil would be protecting my engine over 3k miles so I'm switching oil. The only way you are going to be able to determine your status (your oil & your driving conditions) is by doing an oil analysis. Without doing the analyisis, I'd recommend following the often repeated advice of 3k changes.
For the record I have been using Valvoline 5w/30 with a fram filter in the 96 Avalon (now 72,000 miles). I mentioned to the dealer when I purchased the HL that I had the 1MZ engine in the Avalon too and that so far I was good with 5000 mile changes. They suggested that the 96 1MZ was not all aluminum as it is now (2002) and that is why in needs more frequent oil changes as it runs hotter. I'm not sure I buy that story as it was a sales person making the statement, but, I have not checked into it any further with a technical person.
Has anyone else had this problem, and how did you fix it? The dealer told me to take it to a leather shop they use and see if they can fix it. I really hate to let somebody mess with it without knowing what really needs to be done to solve the problem.
I'd appreciate any replies.
I bought the 4cyl/2wd, and while it's no screamer, the acceleration is not much different than a typical 4cyl sedan eg. the Accord. I'm very happy with the 4, esp. for the great price I got.
Thanks in advance!
