Visitor Agreement.
Then again, I kinda drove into the ditch just to see if I could get out. Tires can't cure 'stupid', I guess.
V6 2wd is 3660 lbs (220 HP, 222 lb-ft)
4 cyl 2wd is 3500 lbs (155 HP, 163 lb-ft torque)
The 4 cylinder is only 160 lbs lighter, at 22.5 Lbs per HP, while the V6 is only 16.6 lbs per HP.
Come on - 160 lbs - that's about the weight of a passenger.
Did you get the 4 cyl 2WD or the 4WD?
Even though the V6 is a little less than 200 lbs heavier than the 4, that weight is right over the front wheels where there's already too much weight for ideal handling.
Anyway, we're patient people (well, I am, since it's not going to be my car...)...we'll wait. I just hope the rebate will be $2500 by August...and the Volvo doesn't need anymore expensive repairs. Which brings up this point - does anyone know of any major changes to the '04 HL??
I just picked up my custom-order HL V6 last Saturday, and it was fitted with Goodyears Integrity, were the Goodyeras and Bridgestone used interchangably or I was ripped off (astonishing!!)
with Michelin Cross Terrains. Sold old tires for $175. It was like driving another vehicle. Smoother,better traction by far, better steering,cornering. Read some of the other posts on original tires on Highlanders. You won't regret it.
My 2002 V6 Limited AWD got Goodyear Integrity on them.
I guess which brand of tires get mounted on the rims depends on which brand the factory has when the car is ready to be shipped off to North America.
Toyota simply has two tire suppliers for the Highlander.
But one thing for sure, you won't see the RX300 with Goodyear Integrity, the RX always get the Bridgestone Dueler.
The manufacturer's recommended tire pressure for the Highlander is 30 psi (posted inside the driver's door jam); 44 psi is way too high...
I have been doing some research as to replacement tires when needed and I'm thinking the Goodyear FORTERA may be a good choice for our type of driving needs.
Best regards, Philip
That's the problem (and research) that I'm doing.
Someone else posted about using "spacer" to make the next size tire (P235/70R16) fit the Highlanders, but I don't know enough about possible downside of modifying the suspension in any way to be comfortable with adding spacers.
My thought was to contact Goodyear and ask about making the Fortera in P225/70R16 for the Highlander market. And based on what I'm seeing on the road (other H/L's) that's a BIG market.
What thoughts do you have?
Philip
I'll post any reply that I get.
Philip
Mike
My current tires are 255/65-16s. You a need a spacer for those. :-)
My advise is to stay with the original tire size. Michelin X-Terrains are super tires for this vehicle. I have more than 30K miles on a set of them and they're still great in all conditions.
Also keep in mind that tire width is dependent on sidewall length and wheel rim width.
Sent by: Goodyear Tire & Rubber Company
Consumer Relations 739
1144 East Market Street
Akron, OH 44316
Voice #: (800) 321-2136
Fax #: (330) 796-3753
Mr. Goldston,
Thank you for contacting our website.
At this time we are not aware of any plans to produce the Fortera in the
P225/70R16 size.
We do however make the Wrangler HP in the P225/70R16 size. I have included
some information on this tire for you to look over.
Wrangler HP (P)
P-Metric Light Truck/P-Metric Highway
High Performance Radial With All-Season Traction
UTQG:
Treadwear 340
Traction A
Temperature B
Features ? Benefits
* Advanced tread pattern ? Excellent on and off-road traction in any
weather
* Lower profile sidewalls ? Improved responsiveness and handling
* Wide outer shoulders ? Quick handling and agility
* Wide circumferential channels ? Efficient water evacuation at highway
speeds
* Numerous strategically placed tread blades ? Enhanced all-weather
traction and a comfortable ride
If you would like further information please call us at 1-800-321-2136
during the hours of 8:00a.m. - 5:00p.m. eastern, Monday - Friday.
Again, thank you for contacting our website.
Jodi Bean
Representative
Consumer Relations
A few days later I started noticing some details on my leather seats and interior that didn't look right to me.
I went back to the dealership and pointed out the flaws in my seats and also asked why my leather package didn't include perforated leather on the doors and the front fore/aft head restraints (mine are height adjustable only). The Sales Manager said that my Highlander had the "port-installed" leather option, which consisted of leather seats only. I told him that the Toyota options page, which the sales person gave me, said code LA = leather package: which included perforated leather seats, door panels and front fore/aft adjustable head restraints. He then said there are different codes on the window stickers LA1 = port-installed leather seats only; LAAT = factory installed leather package.
I felt like I was mislead about the leather code when I bought the HL and also, since I paid even more for seats only, I insisted the installation quality be upgraded to be at least as good as factory.
The Sales Manager referred me to the Service Department. The rep told me "the stitch man" found no defects in workmanship or quality of the leather. He said that the sections of leather seating that are detached from the seating surface are from the leather seat kit being folded in a box before installation. The folds, he said, would probably go away by themselves after we sat on them for awhile. He also said that the leather should not be tight to the seat because this would cause premature wear and tear. Then why are the factory installed seats nice and tight with no strange wrinkles?
When I asked for a side-by-side comparison of factory installed leather versus my port-installed leather, the service rep instead went to some other Toyota storage location and got another HL with port-installed seats for comparison. In my estimation, these seats were also sub-Toyota quality. The service rep then said this is what port-installed leather seats look like. I can come back at the 5,000-mile inspection. If the seat leather problems are still there, they will reevaluate the situation.
Why should I wait for months to have this resolved? Inferior seat installation won't just disappear by itself. Besides, they may then claim the problems are due to wear-and-tear or neglect on my part.
I also expressed my dissatisfaction to my sales person whose only solution was to take my Highlander in on trade. Gee, what a nice guy):
I left the dealership angry and frustrated but determined not to let this matter slide.
I'm hoping other owners can give me some advice on how to resolve my problem.
Who Should a talk to next?
How about asking for factory seats and the better front head restraint as replacements for the port-installed seats.
Can a trade-in be done without paying more for a similarly equipped HL with the factory leather package? After all it does cost less.
Or, since this whole situation has left me less than enthusiastic with my Toyota dealer, should I trade in the HL and upgrade to something like the Lexus RX330, Acura MDX or Volvo XC 90?
Thanks in advance for your help!
It's a real shame the states have laws preventing direct, mail order/internet vehicle purchases.
And I'll bet you even signed a document absolving the dealer of ALL warranty matters.
Don't let this slide as this is what they are counting on. I can't stand Toyota dealerships as just about all of them have this pompous holier than thou attitude. GO GET EM!!!
gwkiser Jul 30, 2001 8:16pm
Bottom line is that it took two sets of door panels and the problem still was not resolved. Finally, in a rather strong face-to-face with the Service Department Manager, I simply asked him if he were in my place, would he accept that quality on a $30K vehicle. His response was "no" and, after a few phone calls, he allowed me to take it(he offered to take it for me) to their #1 choice, Classic Soft Trim, a specialized auto leather shop, with instructions to "do whatever it takes". A tech there was able to partially remove the top of each panel, clean it, add new foam backing, and stretch and attach it back. Job done.
My advice to you is to stay cool as long as you can and persue this issue until you're satisfied. Just don't let it completely ruin the enjoyable experience of owning and driving the HL.
And by the way I have always felt that "port installed" is simply a method of defusing a customers possible concern if they actually said "dealer installed", which is more actually the case.
"Dealer installed" got a bad rap, justifiably, back when many manufacturers were taking dealers to task for failed engines as the result of aftermarket A/C installations without engine cooling system upgrades.
If I have a 1 lb. painting to hang, and can use a hook that can bear a max load of 1 lb., and one that can bear 1.5 lbs....
Toyota wants $175 and that is steep considering that parts stores sell converters for less than $20 but cannot be used - do not have same connector as Toyota
http://www.bageco.com/
http://www.clublexus.com/forums/showthread.php?s=f6f6e34c2852f5e5- 3eeb4e347bb87e7e&threadid=59139
2. The New Rx330 is using the new platform (6 inches longer overall ) ...does it mean the HL will too?
The RX 330's length is 186.2", and the RX 330's wheel base is the same as the current HL, 106.9".
