Visitor Agreement.
Peak hp occurs at 5600RPM
Peak lb.ft. occurs at 3600RPM.
A company as large and detail oriented as Toyota shouldnt be making stupid mistakes like this.
~alpha
Now does anyone know for sure if you can get heated leather seats in a 4 cylinder 2004 Toyota Highlander? One dealership told me yes, the other says no. I can't get a straight answer.
Angie
At first the gears kept shifting down when I thought the engine was delivering adequate power to sustain the speed. I tried taking it out of overdrive but that caused a 1000rpm jump, so I put it back into overdrive. I guess the gearbox must be adaptive, because after about 30 miles or so it settled down and really did a good job. There were no major hills on this 80 mile trip, but I did go up to 75 mph for a while. Cruising from 60 to 75 was quite comfortable.
I'll be taking my trailer on a long trip soon. It will be interesting to see how the 4 cyl copes with hills.
I chose the 4 cyl for the following reasons:
1. Better gas milage.
2. It is quiet, smooth and has adequate power for most of the driving I will do.
3. SWMBO said so.
Craig.
Angie
"ALL MODELS
AVAILABLE OPTIONS AND PACKAGES
Available Options:
Power tilt/slide moonroof with sunshade [2]
Driver and front passenger seat-mounted side and front- and second-row side curtain airbags [3]
Driver and front passenger heated seats [4]
JBL Premium 3-in-1 AM/FM Cassette/6-disc in-dash CD changer, eight speakers in six locations and in-glass antenna with FM diversity reception [5]
Rear-seat DVD entertainment system with rear-seat audio and two wireless headphones (includes 115V power outlet and RCA jacks) [6 , 7]"
The note [4] next to the description above dictates that you must choose the leather interior option, which in turn requires either the/a convenience or quick order package. You might just want to invest in some sheepfur covers for those winter days!!
Link: http://www.toyota.com/vehicles/2004/highlander/options.html
Angie
Oh well . . . What else will dealers think of next?
03 High has a decent rebate gng on rite now, so was planning to look at it but the AWD option comes out to around 28000. and does not seem to be a good buy. On the other hand, the endeavor looks good, has pretty good rebates gng but reliability is a key issue, evn though u take extended warranty. This will be my only car.
Can you plz advise?
Anyone know why?
Here's an eBrochure you can print.
Mike
FWD is front wheel drive.
By most common definitions, there is no such thing as a Highlander 4WD.
Someone is going to argue the point, about what distinguishes 4WD and AWD, but the Highlander is only available as FWD or AWD, not "4WD".
Please send in a Feedback Form about any pricing errors you see on our vehicle pages. Thanks!
'Build Your Own' at Toyota.com does not even list the HL V6 AWD option - only FWD (4x2).
What gives?
-srp
Should come preset with autolock once taken out of park. To disable this, put key in ignition and turn to accessory position. Within 10 seconds, hold the front of the power lock down for five seconds (accurate time is important here, or it won't work). After letting go, you should here a quick lock/unlock of the doors. Congrats, you just disabled to autolock once you shift out of park. To turn this setting back on, just repeat the procedure.
To set it for locking at 12 mph (which is the way I did it on the Sienna.....that way the doors don't lock until you're actually driving down the road). Again, put key into ignition and turn to accessory position. Within 10 seconds, move the shift lever into neutral (need to have foot on brake) and push down on the front of the power lock button for 5 seconds. Again, you should here the system lock and unlock quickly. Now the car will lock automatically after 12 mph. To take this setting off, just repeat the procedure.
There's also another setting you can do, but I don't recall what that is. I like the locking at 12 mph. I found the factory setting (autolock after taking it out of park) to be annoying. I would back the car out of the garage into the driveway and need to get out of the car, or someone needed to get in and I had to unlock the doors to do this. At 12 mph, you know you're done getting in and out of the car to load/unload, so I found this to be more practical.
The highlander had less than 400 miles on it.
While my wife was ok, (Slightly sore neck) and thank goodness my two year old son was not in the car. Initially I considered the damage to minimal, but the estimates blew me away. How about $4000 to fix a slightly crushed rear bumper and dented back panel. Of course this includes the car rental for 7-10 days as well.
I buy my wife a fully loaded Highlander with leather seats and DVD player, only to have some yahoo nail it. I guess her dream car will be on hold for a while.
The 17 year girl had no insurance, no license and no current registration. The CHP towed her vehicle to an impound yard and slapped her with a court date.
Sheesh, why is trouble actracted to a new car. My 95 Dodge Dakota was hit three times the first month I owned it!
Dan - San Diego
98.7% of all accidents happen within 25 miles of home, so I undo my seatbelt and relax as soon as I'm at least that far from my house ;o)
Maybe you should start parking any new car you buy for the first two months, then you'll be out of that risk zone you find yourself in.
Phil in N. Calif.
Secondly, you seem to have terrible luck ! Please give us you registration number so we can pull over if we see you down in SD ! :-)
Nicholas, OC
Prepare for the snow with SUV Highlander (Post-Gazette)
'01 2wd V6 Limited, 38K and still running strong...
Also, gwkiser, nice to see you still posting over the past couple of years - from what I have deduced over those past couple of years, I think you bought your '01 2wd V6 limited a bit before I purchased by '01 2wd V6 "unlimited" in June 2001. Like you, mine is still going strong. I still like it a LOT, with 43,550 miles on mine. Reliable, practical and - for me -perfect size. If something happened to mine, I would not hesitate to buy another HL to replace it. /Ron
However, if something major happened to ours, I can't say I'd get another, but only because I've got my eye on a 2-seater the next time around!
Per their online inventory, Longo Toyota in SoCal (huge dealer) has only rec’d two 4x4 models and both were non-Limited.
FWIW, they are quoting $1000 over invoice on the 04s (I inquired about a LTD V6 4x2). They still have lots of 03s.
What’s the hold-up on the 04 V6 AWD (4x4) models?
I’m gonna end up impulsively buying something else pretty soon...
-srp
