Visitor Agreement.
could be low brake fluid.
could be defective master cylinder,
Defiantly not right. My 03 has 7000 miles on it and has the best brake system of any vehicle I'v ever owned.
Im not happy with the steering. when I purchased it, It pulled to the right so I took it back and they checked the front end alignment and changed something. It doesn't pull to the right now, but in a curve on the highway It trys to hard to bring the steering wheel back to the center.
Very very small amount of vibration with air on. No more tha the last V6 Camry I owned.
Yes the brakes have a rather long pedal travel, but they are very easy to modulate with no grabing. Overall excellent. I do not believe the brakes are too small for the vehicle.
Keep after your dealer re: the vibration problem. Get Toyota involved if necessary.
That's as absurd as a Dodge Durango having a better ride than a Highlander.
At any rate, there is no such thing as "undersized brakes" on vehicles sold in the US. Pedal feel is very subjective and is decided upon by the brake engineers and their management.
A mushy pedal is often a sign of air in the system. Unlikely to come that way from the factory (the assembly line evac and fill process is automated and thorough) but if you've had work on the brake system done, a distinct possibility.
my murano has not had one problem, and although people have problems, i know of at least two people who had all sorts of problems with their highlanders, radio problems, alignment problems,
etc. since i have both vehicles, my perference is to drive the murano. its much sportier, quicker, and has a much better radio (and we have the ltd.).
also, the highlander does not have dual stage airbags, and if we knew that when we were shopping, it would have gone off the list immediately. i don't know if the 2004 has it, but hte 2002 and 2003 (tmk) did not. this is a huge issue.
however, there is no excuse for any vibration from a running engine in a $30,000 vehicle.
it will be interesting to see over the next few years which one has any significant problems. rr70
Also, can I get this vehicle without a 3rd seat ??
Do a search for the highlander and brakes. Here is a quote from one of the complaints -
"BRAKES ON NEW 2003 TOYOTA HIGHLINDER ARE INCOSISTENT AND PROVIDE LIMITED STOPPING POWER. DEALER SAYS BRAKES ARE SMALL FOR THE SIZE OF THE VEHICLE, THEY OVERHEAT EASILY AND THEY HAVE NUMEROUS COMPLAINTS FROM CUSTOMERS. RETURNED VEHICLE 3 DAYS AFTER PURCHASING IT AND REQUEST ATTENTION. AFTER SEVERAL TRIPS AND COMMUNICATIOS TO THE DEALER AND TOYOTA, I WAS TOLD THE BRAKES DON'T WORK WELL, BUT THAT IS HOW THEY WERE DESIGNED. I WAS TOLD I WOULD HAVE TO LEARN TO DRIVE THIS VEHICLE AS THE BRAKES ARE DIFFERENT THAN OTHER VEHICLES. THE VEHICLE IS VERY DANGEROUS TO DRIVE ON THE FREEWAY AND IS EXTREMELY DANGEROUS ON DOWNHILLS.IT IS SO DANGEROUS THAT WE AVOID DRIVING THE VEHICLE UNLESS NECESSARY. IF WE ARE TAKING THE FAMILY ON TRIP THROUGH HILLS OR THE MOUNTAINS WE RENT ANOTHER VEHICLE AS I VALUE THE LIFE OF MY FAMILY.*AK"
I don't have a problem with the brakes on my Highlander. I think they are fine. I just have a problem with the vibration. I tried turning the AC on at stoplights and guess what, the vibration goes away. The closest Toyota dealer is an hour away, so I won't be able to take it in for a while. Do any of you guys have any idea what could be causing the vibration? Shouldn't the car vibrate more when the AC is turned off? Not when it's turned on? It's a slight vibration, but you can definitely feel it in the steering wheel and in the seat sometimes.
braking until it feels right and then take it to another dealer or independent mechanic for their opinion.
Brake pedal requires way too much pressure to stop the vehicle.
Too much outside wind noise.
Vehicle vibrates when at a stop and tranny is in drive.
Buzzing vibration from glove box and dash.
Smooth ride only on a smooth road, other wise rough ride.
These are the problems that I have on my 2003 V6 HL. Where has the famous Toyota quality control gone?
You guys must have a different breed of dealer than in my area. If the vehicle is not leaking oil or being towed into the dealership then all of the problems are brushed off by saying, " we cant duplicate the problem " or "vibration is within factory tolerences ". If you read back through the Highlander message boards from 2001 to the present, you will see the problems I mentioned repeated over and over. Rather than waste time and loose the use of my vehicle for days at a time I accept the deficiencies of the HL and go on with life. For those HL owners who do have a perfect vehicle, good for you. For those of us who do have nagging problems, it will be Toyota's loss when new vehicle time rolls around.
Who knows, since it is a foreign vehicle, the office of Homeland Security may be able to help. <grin>
I went back into the lounge and waited. After one hour mgr gave me my keys and said that the motor mounts were tight and the vibration is minor and that I still have 4 years of warranty left. If the vibration becomes worse I am to bring the HL back. I drove the HL home.
Every week I plan to take the HL back to the dealer for the next problem on my list. Next week will be the windshield wind noise, they cant say that is normal.
It doesn't make any sense what so ever to make the oil company's any richer. Right now where I live Reg unleaded is $1.45 a gal and Super unleaded is $1.68.
My 03 v6 runs just as fast on the cheap and it will not harm the engine...............
