Visitor Agreement.
Jim
Look at the Civic vs Civic hybrid, I know...different class of vehicle alltogether, but i think it is the onlyother comparison available to regular and hybrid versions of the same car. The regular Civic significantly outsells the hybrid new, and the KBB.com trade in values of both show that a one year old 2003 Civic EX autmatic w/side air bags and 15,000 miles retains 79% of it's new MSRP, and the Hybrid retains 76%.
Just my observations. I would love the idea of driving a hybrid, but the $ savings in gas doesn't justify the initial higher cost, and the resale value seems to be lower on the hybrid. I would guess that this will tend to change as the hybrids become more mainstream, but my personal opinion is that the Hybrid Highlandeer won't negatively effect the values of the regular version. There will still be pleanty of folks who want the lower initial enrty price. Just MHO All other ideas and thoughs are welcome. :-)
wwest, I think you have a Hybrid. Any comments on your experience with yours?
Happy HL'ing to all.
As for initial cost, if you are planning on buying this year, plan on paying MSRP at a minimum and the majority of them will be made in the Limited so $36,000 is a good starting point for price.
I am extremely interested in the hybrid but I am going to hold off until they become much more available and dealers are willing to deal. Supply is being kept low on purpose in order to drive up demand and help get dealers pushing these cars. It also makes good press to say "we can't make enough of them". --Hogwash!!! There will be much bigger supply in a couple of years but right now Toyota is keeping supply down in order to increase the demand!
Highlander was flawless and a pleasure to drive on the trip. Loved all the space that our car doesn't have. Not as smooth or quiet as my Lexus ES, but the Highlander is not a Lexus so my expectations were met and quite well. The HL provided a very comfortable, roomy ride.
You can fix this yourself simply by following the moonroof normalization routine described on p. 34 of the manual that came with the vehicle. Follow the instructions, precisely, on that page in the section that describes what to do if you had disconnected the battery (even though you hadn't).
After reading thru the Service Manual I came across the proceedure to reset this. (keep in mind, it starts the counter again to flash at 4.5K then come on solid again at 5K FROM the mileage it is reset from).
With the key in the ON/RUN position, push the odometer button until ODO is displayed.
Turn the key to OFF
Push and Hold the odometer button while turning the key to the ON/RUN position.
Hold for 5 seconds......Counter now reset to warn at the next 4.5k interval and come on solid 5k from now.
Hope this info helps other 'shade tree' mechanics.
The reason I wish to remove them for cleaning is all of the cleaning agents have an odor that agrivates my sinuses.
Just wanted to share those of you that have a moonroof.
Angie
#9160 of 9174 Moonroof operation by eastern1 Mar 17, 2004 (7:57 am)
Noticed an older post in this forum from "ohmygosh" on 2/29 about it being hard to tell if moonroof closes all the way. I suspect that his/her moonroof has not been properly normalized or initialized, because when it is, you don't need to guess--the moonroof will close properly and all the way in an automatic fashion with one brief touch of the button. We had this problem when we first took delivery of the vehicle and it was very easy to fix. Dealer should have caught this at prep, but apparently some slip through.
What is your experience with automatic car washes and stone deflectors. Are they safe to take through a soft cloth car wash?
Any information would be appreciated.
Maybe it doesn't do that - but I seem to recall reading about it somewhere.
If it does have the ability to "map" the shift points etc, how does one reset it - or will it continue to relearn a new style?
It may adjust, learn, for each individual restart of the engine but it can in no way know who just restarted the engine and thereby which "style" to use.
I was led to believe it was an algorithm that over time (say 10's of starts and 100's of hours of driving) collected data on how the car was driven. Does the car endure rapid acceleration when moving up through the gears - or does the driver use a light foot?. I assumed the data was moving average data set.
It in no was could predict who was driving - but it would take into consideration the last "x" hours of driving and use the appropriate algorithm.
My original question pertained to how big a sample it was using to determine the appropriate settings, and how long would it take to relearn a new driving style (say if one normally drove a short commute - lots of stops and starts, then one found a new job - and new commute on a freeway).
IMHO, it does learn (and so did I). Initially the AT and me hated each other; I was in a different gear every 30 secs, this being my first AT. Now at least, we respect each other, although with some lingering feelings of blame.
I thought the moonroof has limit switches on the limits of travel (and closed position)
In the case where you and your wife drive the same vehicle - if the ECU "learning" feature did exist - then it would simply average the extremes of driving inputs. Obviously - it wouldn't know who was driving - just that it had a bigger range of data to deal with.
I have emailed Toyota for an technical input.
"The ECU will self-adjust to accommodate an individual's driving habits/style. This adjustment will take place over a period of time and does not require any resetting of any kind. We apologize; we do not have any technical documents available for customers that explain this operation more thoroughly."
I would still like to know what it adjusts and what the length of the "period" of time is.
Not two individuals, AN individual.
Two drivers or more and you get "DOES NOT COMPUTE!".
"An individual" - must translate to mean the period of time for "sampling" must be shorter than the time interval between starting and stopping the engine.
I haven't given up yet - I have made enquiries at several other Toyota bulletin boards that specialize in performance enhancement relating to ECU's
nav, LTD My impressions are
Dislikes:
1 No rear opening window(why 4 runner etc not HL)
2 mushy brakes(pump once to get pedal up)
3 slow 1 to 2 tranny shift (1 sec)
4 interior lighting on secondary controls almost
nonexistant (windows steering wheel)
5 cruise should be on steering wheel
6 can't set Nav system while in motion. Real annoying since my passenger(wife and I travel alot and would like to reprogram on the move)
7 Can't reset average mpg, so one cannot check mpg on various legs of a trip.
8 No telescoping steering wheel
9 Heated seats need more heat
1 Power
2 Handling /ride(firm not harsh)
3 size (both in and out)
4 AWD (snowy winter weather did not stop this HL)
5 Solid feel (feels like it has lasting quality)
For me this would be a perfect vehicle if Toyota would address the dislikes.As it is its darn good
It would'nt take much to be perfect.
1. She never used this on our Explorer though I did.
2. Ours are not mushy.
3. No delay in 1-2 shift.
4. Not enough night driving to have noticed this.
5. agree
6. don't have nav
7. not a problem for us. This isn't accurate enough anyway.
8. Never had this so don't miss it.
9. Haven't used them yet.
I'm in agreement with your likes. My wife loves the vehicle. Better ride, better power, better mileage and much more refined than the 1996 Explorer we traded. We do miss the automatic door locks though.
I do have a Limited 2004 Highlander with the bug guard (or hood deflector) and have taken my Highlander through the automatic car wash with no problems at all. In fact a Kaddy Car Wash in Portland, OR to be exact.
Hope that helps.
Angie
I am considering the addition of a hood deflector due the number of stone chips I have been receiving on my new 04 Limited.
7) display avg mpg press and hold, it will reset to 0 and start a fresh avg until you reset again, works the same for avg mph
Other items, glove rattle started a while ago, found the glove box light switch rattles when vibrated by the door in closed position, no rattle when door open. Applied a bit of foam weather strip on either side of the latch next to the existing 2 rubber bumpers and no rattles heard any more.
Only other change was to switch to the Michelin CrossTerrains in the stock size, very happy with them.
Can't reset average mpg by pressing and holding button for 2004 models. Toyota changed this worthwhile item for 2004. Only way to reset is put gas in the tank.
