Visitor Agreement.
I have experienced this on my wife's HL but I don't find it as annoying as some here. I certainly wouldn't call it a safety problem. Slow downshifts are a common complaint in many reviews, not just Toyotas. My Olds Intrigue is slow to downshift also.
The HL gives a smooth ride!
Does anyone know if the '05 Highlander has top and/or bottom LATCH connectors in the third row, and if so, are there connectors for only one carseat or two?
Thanks...
SDE
I do brake with my left foot, but I always completely remove my right foot from the gas before braking. Unless Mr. Weber has a video camera under the dashboard he or the Highlander cannot tell which foot I brake with.
Ah but I think it is the other way around. i.e. your left foot is still on the brake when you try to accelerate. That is when the hesitation occurs. As I'm sure you know from following other drivers; many left foot breakers unconsciously leave their foot on the brake as they drive using it as a foot rest I would guess. Hence the flickering stop lights on and off. Drives me crazy to follow one.
This leaves PLENTY of room for my TWO 80lb. Labs!!
They both find the cargo area very comfortable when I lay a small rug for them. They just love the view from the hatch window!
Also a lot of the hesitation problems seem to happen under acceleration when the brake wouldn't be applied.
It would be easier all around if Toyota would stop giving the impression that you can pick and choose exactly the options you want.
And since most people seem to prefer preset combinations, I doubt it would cause a ripple.
That's not too different than Honda's approach except Honda configurations are the same nationwide (in USA) but Toyota's are not.
we wanted a basic (not limited) hl but with side air bags.
dealer in beaufort, so carolina said there were only three in the SouthEast.
he told us where and the colors. one we liked was in Raleigh NC -200= miles away.
dealer sent someone that night and we bought it the next afternoon.
I do have one peeve though . . . the paint quality appears poor as small little chips on the hood are practically showing up out of nowhere. Has anyone else experienced this? Appreciate everyone's input.
Okay since then. However, I don't really like the looks of the stone/bug deflector and I am very hesitant to take the Highlander through an automatic car wash.
Does anyone know: if I mount my EZPass tag on the inside of the windshield right behind the mirror (which would be the usual location), will the close proximity of the tag to the mirror cause the compass to get screwed up?
SDE
I'm not sure I understand... you're saying that the compass doesn't affect the EZ Pass? I didn't think it would.
My question is: will the EZ Pass negatively affect the compass?
SDE
what mpg owners are getting?
I can only assume a 6 cyl will deliver somewhat less. But maybe a "6-er" out there can shed some light for you.
Incidentally, I am not at all sorry I got the 4cyl. I am TOTALLY satisfied with the performance since I don't have a need to tow.
Good Luck.
On trips over the hills of Eastern KY we averaged 24.5mpg
Despite the mediocre mileage, I wouldn't even consider the 4 in this size vehicle.
have found trip meters optimistic. i find them usually
2-3 mpg high. the 22.5 sounds ok but the 15-16 a
little expensive. i believe there is a hybrid coming
this year. maybe i'll try that before i buy.
on 70mph limit roads, got 24.5, on 65 mph roads 25.5. 2004 LTD V6 AWD medium grade gas.Cruise where ever possible, usually set a few mph over speed limit.
It's pretty much out of my control anyway.
Over the years, I have always recorded at least 20 mpg in town, and 24 on the highway. You will find it uses more gasoline in the winter (in New Hampshire we have oxygenated fuel and it is less efficient). I do not believe premimium fuel will make any difference. So often I see people eating a burger in the car with the engine running to keep warm. That is 0 mpg.
Merry Christmas to all.
http://www.invinca-shield.com/
Now we don't worry so much about rocks, love bugs, et al, and our HL looks like the day we drove it off the lot.
Some reviews have expressed an opinion that there is little difference between the 4 and 6 cylinder. Invoice price difference of approx. $1,700.00 would allow for a few more options. Any thoughts / comments? I'm fine without the third row option.
I pretty much know the options I want, but not sure about the towing prep. package - while I have no curent plans to tow, I figure that could always change so I was planning on adding that option. Any negative consequences?
Finally, in researching for a new car I look at the problems / solutions discussion - which in truth could scare you from buying ANY car. But the big issue seems to be a hesitation problem, which Toyota has recently acknowledged. Just how wide spread is that problem? Has everyone (or nearly everyone) experienced it? Is it all makes - 4 and 6 cyl.; 2W v. 4W drive? I have no other real concerns about the car, and would love to get one - but would hate to kick myself down the road if this problem ends up being serious.
Thanks for taking the time to read and respond.
Mike
But then again I would NEVER consider using a FWD or front torque biased AWD for towing. When you go to stop suddenly the weight of your "tow" will shift forward onto the hitch, "lifting", unweighting, the front of the tow vehicle, where the majority of the braking and ALL of the directional corrections would otherwise occur.
ABS will get VERY busy.
I can guarantee, however, that you'll find concerns being expressed about all of the others too.
Here's my take on the "hesitation" issue:
Somewhere between two and three hundred THOUSAND Highlanders are on the road at present.
Somewhere between twenty five and thirty five hesitation experiences have been reported in all the Edmunds forums.
Many more owners, including yours truly, have reported no problems at all.
The common denominator on the hesitation reports is that it apparently can be induced under very specific circumstances.
These circumstances, when reported,are as follows:
"Decelleration with no throttle applied until tranny is in low gear, then full throttle application. At that point there might be up to "one to two second hesitation" (reports vary from momentary to the full two seconds) at which time full power occurs."
Toyota has acknowledged the reports, and apparently are looking into it with the idea that a fix "may" be developed.
My guess is that Toyota's fix, if and when it ever happens, will be a TSB reprogram of the Eprom tranny controller which will prevent the phenomenon from being induced under any circumstances.
I further speculate that most owners have never, and won't likely ever, experience the hesitation.
I believe it may have been reported early on by a few owners who by coincidence managed to induce the hesitation, then subsequent followers of those reports went out and tried to induce it themselves. Some actually did, and reported their results also.
Now there's a full blown controversy over it, but I honestly believe it's been inflated out of proportion.
Is it a common problem? No.
Is it systemic across the board? Not at all.
Is it the life threatening safety issue some claim exists? Apparently not.
Having said all that, save yourself some undue anxiety.
Buy someone else's product. Toyota won't mind.
