Dodge Durango
Running boards are std on SLT+ models
SLT & SLT+ models, new Special Appearance Group(Pewter accents on front and rear fascia, pewter colored bodyside molding, pewter running boards, pewter painted wheels)
New 15x7 & 16x8 cast alloy wheels
New exterior heated auto day/night mirrors
New Std dual zone climate control
New rear A/C with HEATER
New interior cloth seats, instrument panel
New electronic shift transfer case (dial system)
New overhead console with Homelink
New Power PASSENGER seat with POWER Lumbar
New Heated Leather seats
New std 6 speaker system
New load shedding battery (battery saver)
New Variable intermittent rear wiper
New Aerodynamic large mirrors with tow package
New Sentry Key Immogbilizer Module
New Seat Belt Pretensioners
2 New Colors - Lt Pewter Metallic (replaces driftwood) and Dark Garnet Red (replaces Aquamarine)
Eric
The dealer option cost is $1399.00. I'm sure it can be had for less.
MSRP 33075
Dis 2805
Rebate 1500 (with .09% loan
2500 without .09%)
I can purchase it for 28777
Thank You
Scott Q
Although there are numerous 'ball joints' on a vehicle, I beleive this discussion is about the ones that hold the front wheels in alignment. (2 joints on each wheel, one at top and one at the bottom) This allows the front wheels to steer and go over bumps all at the same time. There is a LOT of stress on these joints. Typically they last for over 100,000 miles if your roads are smooth. Potholes and dirt roads will shorten the life of ball joints. The DC shop manual calls out a grease fitting on the LOWER ball joint that needs to be lubed regularly.(on SOME vehicles)
Invoice total was $29,851
MSRP- $32,725
Has the SLT Plus decor package, leather, CDw/cassette,security,fog lamps,flairs, 26Gpackage
We were given $12,000 for a '97 Dodge B250 hi-top Conversion van ( front air only, no power seats,powerbed, TV/VCR, limo lighting, good body condition, 71,000 miles)our bottom line was $17,450(We opted for the $1000 cashback and 5% 60 mos. financing)We also purchased a 4 yr. 70,000 mi
extended warranty because we put so many miles on our vehicles, (It cost $1100) Good Deal???
I have heard (just rumor) that for 2001, ALL 4.7L engines will have the triple converters fitted.
In 2000, only seletetd states mandated this package. It has been discoverd that many people purchase their vehicles from out-of-state dealers thus bypassing the emmisions laws for their home state.
We had held off buying until this time of year hoping to see some strong discounts, this turned out to be a very worthwhile plan. We drove our D off the lot for $25995 vs a list price of $32,100.
While I gave up 4x4 that I had on the Blazer, I live in Atlanta and never have time to go off road so I am more than happy to save a little money up front and on maint. So far a great vehicle and surprisingly fun to drive..(when I can get it away from my wife!)
2001 Dodge Durango Feature Highlights
*NOTE: The information shown is preliminary and based on data available at the time of publication.
EQUIPMENT GROUPS
Special Appearance Group: 16-inch aluminum wheels, body side moldings, running boards and lower portions of fascias all with pewter accents - optional on SLT
POWERTRAIN
Next Generation 4.7-liter Magnum® V-8 engine and multi-speed 45RFE automatic transmission standard on 2WD models
NV233HD and NV244 electronically shifted 4WD transfer cases with rotary instrument panel control
P265/70R16 outline white letter tires and 16 x 8-inch Sparkle Silver-painted cast aluminum wheels in 4WD Tire, Wheel and Wheel Flare Group - available on SLT
CHASSIS
New standard 15 x 7-inch Sparkle-Silver-painted cast aluminum wheels
P255/65R16 outline white letter all-season tires and 16 x 8-inch Sparkle Silver-painted cast aluminum wheels in 2WD Tire, Wheel and Wheel Flare Group - available on SLT
BODY
New exterior colors - Dark Garnet Red Pearl Coat and Light Pewter Metallic
Variable-delay intermittent rear window wiper system
Automatic-dimming, heated, power 5x7-inch mirrors - available on SLT
New aerodynamic power foldaway mirrors - Trailer Tow Group
INTERIOR
New instrument panel with color-keyed components and surface-mounted controls for radio and HVAC system
New instrument cluster with engine oil level indicator
Vacuum fluorescent digital transmission range display in instrument cluster with 44RE and 46RE automatic transmissions
HomeLink® Universal Transmitter added to Overhead Convenience Group
New floor console with three cup holders, armrest, coin holder, tissue holder, pen holder, removable cassette and CD storage bin, cellular telephone compartment, 12-volt power outlet and interior lamp (only with bucket seats)
Woodgrain trim added to floor console - SLT Plus Group only
New sew patterns and materials on all cloth seats Optional bucket seats for Sport model New colors: Sandstone, Dark Slate Grey and Taupe
Manually adjustable lumbar support on passenger seat - SLT
Power passenger seat - SLT Plus Group only
Power lumbar support on driver and passenger power seats
Leather front seats include heaters with 2-level temperature control 2001
All-new interior trim panels
New standard tilt steering column provides additional positions
Improved HVAC (heating, ventilating and air conditioning) system with dual-zone front temperature controls, more heating and cooling capacity, two additional instrument panel outlets and recirculation available in bi-level mode
Rear HVAC system with separate second and third seat air conditioning outlets and a separate heater
Upgraded base and Infinity® speaker systems
ELECTRICAL & ELECTRONIC SYSTEMS
Battery saver system to prevent inadvertent battery discharge
New 160-ampere heavy-duty alternator
SAFETY & SECURITY
Front seat belt pretensioners Sentry Key™ engine immobilizer added to optional Security Group
sersmr@pa.net
Vagirl1952.
A totally loaded R/T stickers for $36,525 then you get $615 discount for a SLT discount and customer preferred discount. This brings it down to $35,910. Dodge has a mark up of approx. $3,000 and no matter what the sticker dollar figure is, you need to target $3,000 less as your final price to get a good deal. I found one that I received $5635 off after a week of wheeling and dealing but this also was a demo so I did better than anyone else could offer since it was the only demo within 100 miles from my home. A 50+ year old Sales Manager put all 3800 miles on it so I feel it was treated right during break-in. You would be amazed at the difference in feel while driving the R/T over the other packages. I am sure this model will be in higher demand down the road to help keep the value up. It definitely has a following unique of itself.
The check gauges light comes on and we find if you put it in park or drive off, the temp will quickly drop from 260 to 200 in a matter of a few seconds - its as if the fan is not kicking on appropriately, but when it does all is well.
i see a couple tsb's out there but not sure of the content - anyone know? i noticed a few comments about bad fan clutch assemblies on the nhtsa sight.
similar experiences anyone?
Kerry
http://www.durangoclub.com/ceilidh/xframe.html
There are well over 1000 members that may have insights and information.
any insite would help us please !!!!!
Durango for $28K minus the $1000 rebate the factory is offering. I wouldn't pay any more than $27k for that 2000 D.
Once they get to the over 24 lb seat, they are NO problem...it's just the rear facing seats that take up too much room to be comfortable in the Durango.
I struck a lease deal in Northern CA. 2000 Durango 4X4 SLT MSRP $31,655 including destination (edmunds invoice $28,597.)
My final sales price was $27,182, I got to use the $1,500 rebate also, towards drive-off. So no money out of my pocket, 60mo. at $360/mo. plus tax. I think it is a very good deal. Basically $6,000 off MSRP if the rebate is included.
It is 4.7 motor, but enough juice and better gas mileage. I was surprised at how smooth it ran both city and on freeway. Knock on wood it turns out to be reliable also, since I always had Toyotas before. I will report my actual mileage later.
All I can tell you that MY first rig at the age of 16 (Driving age in Vermont) was a 1976 FULL SIZE Blazer (Now Called YUKON?) It was BIGGER than the present day Durango.
The only complaint I got from my parents was my Mom telling me to wash the MUD off of it before bringing it home so my Dad would not see it.
(True Story)
I would drive in the woods on fire roads and across rivers (NO BRIDGE AVAILABLE) many miles from any pavement. I learned a LOT about traction and handling without having any other vehicles around to bump into. What else is there to do in the boonies of Vermont?
After all, I do not want to be stuck with a 6-cylinder piece of crap SUV. I am in love with the Durango, and would most likely go with a Used '98. Thank you.
your new D listing all the tires and the inflation
pressures.
to get numbers and problem descriptions. Just
had mine fixed.
dash
BTW, this sounds like a loose connection to the PCM. Have you verified that all three connectors are completely inserted and "locked" in place?
It occurs when I hit a higher rpm and continues from 40mph and above. It is a real high frequency but very audible. The rattle doesn't change speeds it stays the same at a fast paced rattle in sync with the engine rpm increase. When I take off the gas it goes away only to come back again. I'm thinking it is something in the engine rattling against the frame closest to the dash. I've popped the hood and looked but am not sure. My next move is to put sponges in between any engine part and the frame to see what that does. Not sure what else to do. I'll drive this sucker to Detroit if need be and have the quality control experts figure it out.
ALSO is this a good deal --> 2000 R/T Black fully loaded, with Off-Road Pkg ( Brush guard , etc) and sunroof for $33200
By that, I mean that it is a COMPLETELY NEW DESIGN that uses a unique "learning" process. This xmission needs time to figure out your driving habits and "learn" how to shift according to your habits. (Sharing the vehicle between drivers with differing habits keeps it thoroughly confused.)
Since the 4.7L with 4-speed autmatic has been available on EXACTLY 3 VEHICLES (Jeep Grand Cherokee, Dodge Dakota and the Durango) It has been relitivly easy to review the EDMUNDS forums and determine that this xmission is "troublesome"
... I orderd the 5-speed manual xmission!
Try the following site. It is the Durango Owners Club who have over a 1000 members. This link should take you straight to the forum page. The Michelin tire has been used on a few of the D's with much praise. Talk to the tirerack guy and let him know your driving style (On of Off-Road Mainly) the AT tire may not be advantages for you. When I called them they directed me towards the LTX "S" rated tire over the "H" Rated. S is suppose to give better snow handling and H is better for rain. Hope this helps.
Eric S.
the tranny and 4.7l being new and matched to each other. I don't think the learning system is totally unique to this vehicle however. A mechanic once told me that my 94 Camry "learned" my driving habits and adjusted itself to deliver maximum performance based on how I drove. I assumed that since two identical 00 D's did the same thing that it probably wasn't anything to be too concerned about. I have been deliberately trying to drive at different speeds etc. to give the engine a good break in. I'm sure that is confusing the heck out of the system.
