Ford Mustang Accessories and Modifications
swaping engines from 5.8 to 5.0 h.o engine but oil pan is holding up project. what oil pan can i use to replace 5.0 oil pan so that it won't hit center link.
Are you swapping a late model 5.0 HO(302) into a '69 Mustang? If this is the case, then it sounds like you need to get an early style front sump oil pan for a 302.
Or are you swapping a 351 from a '69 Mustang into a '93 chassis? Is it a 351W or 351C?
You might want to check with one of the many Mustang parts/restoration outfits for advice on swapping a late model drivetrain into a first gen Mustang.
http://www.fordracingparts.com/mustang/main-s4.asp?vehicleid=6&year=1996#fromFla- sh
Mark.
I Currently own a 2001 V6 Mustang with 17 Inch Custom Wheels. I am in the process of buying a 2007 Mustang GT. Will my 2001 Wheels fit the 2007 Mustang?
the reason i ask is i was installing a pony grill and when i went to hook up the wires to the light switch there were already wires in the terminals for the fog lights if this is the case has anybody seen the wire loom the main loom located in front of the radiator and is where the factory pics show the pony wires coming out of.
thanx
Only you can decide how much better it sounds so compare both with your own ears.
As far as the space the sub enclosure takes up in the trunk, it's a moot point. It doesn't take up that much space, and I can assure you an aftermarket sub setup will take up MUCH more space to produce not much more or better bass, IMO.
it turns out the wires on the light switch plug are all ground the grounds are what tells the relay to turn on
the system is all hooked up and looks grweat
This brand is a unheard name. But cheaper than a knn or injen.
Any one know about it?
Any feedback? experience, story would help.
All advice welcome.
I know an cold air intake may not sound complicated but do you really think these little 2 bit companys really do any true testing on the products they sell?
Also, on the Shelby GT, the Factory cold air intake installed by Shelby peeps only adds about 25 hp WHEN COMBINED with a rom flash. Do you really want to flash your rom with software from some 2 bit company?
Mark
http://img1.picturewizard.com/132413D/0/05v6front.jpg
But it still isn't right (the foglamps are too close together).
I know the two grilles have slightly different dimensions, slant angle etc, but I'm wondering if anyone has found a more accurate GT-style grille for the V6 Pony Package Mustang?
http://www.webelectricproducts.com/sts/stspage.htm
Won't need premium gas, but you may need a re-tune of your computer to compensate for the increased airflow. Some kits do, some don't...
www.steeda.com. They have tons of "dress up" stuff for mustangs. Including a Stainless Steel Polished Alternator Cover - '99-'04.
I also like http://www.americanmuscle.com/
A friend of our family used to own the 07 GT500 Cobra but recently got rid of it to order a 08 top-of-the-line Corvette (Corvettes have always been HIS dream car). Shortly after he bought the Cobra, though, he replaced the stock Cobra exhaust pipes with an even more upgraded pair. He kept the stock pair, however, and still has them as the buyer didn't want them when he picked the Cobra up from this friend. Since he doesn't plan on using the pipes again, he's offered them to me.
I own a 03 V6 Mustang, and my three questions are as follows:
1) Is it possible to replace the single stock pipe with the 07 cobra pipes given that the engine is completely different and the bodystyle is also not the same?
2) If it is possible, how much work would need to be done to replace the exhaust and about how much would it cost?
3) If it is possible, of much (if any) hp gains could I look for?
2) A lot! (in both regards)
3) Maybe 15 on the top end.
I know that for a proper fit, changing the rear bumper out for one with notches (I don't know the proper term) would be best, but how much would be necessary to retrofit the pipes onto my current engine? Do you know how much these changes would cost on average? Also, would it be best to change my stock headers for better performance ones (equal-length or shorty)?
