Ford F-Series Rough Idle/Vibration Problems
                    I have had my truck in 3 times so the dealer could check out a vibration I'm having. They dont seem to know what it is. I feel a vibration at idle around 550 RPM. If I push the gas a little it seems to smooth out. The vibration comes back around 1100 rpm then smooths out again then back at around 2200 rpm.  The dealer had a TSB about the electronic module needing to be reprogramed and they did that but it did not help. Then they did some adjustment with the engine mounts but that also did not help. It seems to me that the engine is out of balance. Has anyone here had this problem that has been solved? I would appreciate any info because I'm taking it back to the shop next week.
kcram - Pickups Host
To all reading this don't waste your time with ford, call an attorney. Maybe alittle extra pressure will get there asses moving.
thanks jimg
I will not accept this shimmy. Any ideas on where I go from here?
I got my truck back from the service dept. yesterday (2nd time in the shop). They worked on the alignment, checked the wheels and tires, and force balanced the truck. The vibration is still there, and maybe due to my higher awareness, seems to be even a little worse! I am taking the truck back into them in 3 days. They are ordering parts to do some work on the rack and pinion steering system.
I talked to the service person about the Ford bulletin that has been issued on this problem. They said there is a flow sheet that they will work through to try an fix the issue. I also asked whether or not they have had other trucks with the same problem, and they said "yes". The service person then told me that my vibration was only at 8-9 Hz and Ford will not even try to fix it if it is 8 or under. It sounds to me like they are setting up a "Well, your vibration could not be fixed, but it was not that bad anyway" scenario.
If they cannot fix this I will notify a lemon law attorney and try to force them to buy this truck back. Although my confidence is shaken (no pun intended), I still love Ford trucks and I would be willing to buy a 4x2 to avoid this issue.
It happened for the first time about a month ago, and it vibrated severely (more severly than any other unbalanced tire I have had). It stopped vibrating after I stopped at a traffic light. 2 weeks later it happened again and this time the steering wheel was shaking so intensely, I though my wheel was falling off and pull off the road. I am totally dumb founded. I had my personal mechanic take a look and he could not find anything.
I am going to take it to the dealer next week. Any insight on this issue would be appreciated.
Is there any other info on the F-150 vibration problems?
First timer, Ryan
You'll find an amazing number of them here: Ford F-Series: Problems & Solutions
Does anyone have the Bulletin Number for the fix so I can go in armed with something. :sick:
I joined this forum just recently as I was looking for some help for my own '96 V-8 F-250: it started to randomly go into high reps, which was especially nasty when stopping at a red light, but was also noticeable when driving slowly. I followed some advice I found under this topic here, i. e. I cleaned the connectors to the MAF and cleaned some vacuum connections on top of the engine, a week ago. It seemed to have soleved the problem, thanks to God!
I found the video of the Toyota shaking itself apart to be particularly compelling.
But then, you may not be looking for a tough truck.
Mark.
Mark.
Discovered this on my recent Christmas trip.
I have the same issue. It is a short buzz on acceleation, like going over stop sign alerts. It seems to pop up most when I let off the gas, then come back on, at speeds in the 50-70 range. I have not had the buzz when the cruise control is on. Did you ever solve your issue? I would appreciate any info on this.
AFGuy in NE.
Now I have unwillingly entered the Vibration problem zone. Within 40 miles of having the new tires put on I got the nasty vibration at speeds between 65-75 miles per hour. I took them back and they were way out of balance. 3 tires were 3.5 ounces off, so they rebalanced them. Within 40 miles again the same vibration problem again. Took the tires back in and they were unbalanced by the same weights again. This time they rebalanced them and put new larger rotors on because of a bulletin, but unfortunately not covered under warranty because of the time I've had the truck. (18 months or 18000 miles whatever comes first).
I asked them about indexing and they had no clue and they said that they did not have the equipment for that.
Now I am out $300.00 for the new rotors and back at square one.
Does anyone live in the Monterey bay area and know anyone who does " Indexing" ???
I am going to call or write Ford and see if I can get a response from them. I am a shareholder of their stock but all that will get me is probably a laugh. I would be glad to join up on any other action that may be going on with other truck owners.
Mark
I took it back the dealer at 750 miles to balance the tires and they said it was so bad they couldn't balance them so they put 4 new tires of the same brand on it. It has been fine ever since. Now have 2600 miles. Shimmy hasn't returned even once.
GO TO A DIFFERENT DEALER!
Mark.
