2. Door ajar warning - does it show you which door? -- Yes
Does it include the sunroof if left opened? -- not sure
6. Is it true that the low-tire-pressure warning is just a light on dash, and doesn't tell you which tire is low?
-- just a light
7. Does it indicat whether it's in AWD mode or traction control when it is engaged?
-- if traction control is off, there will be a light. By default traction control is on.
The CX-9 GT's with the Grand Touring assistance package are currently being built with the power liftgate.
With the smart key in my pocket and a grocery bag in each hand, I can easily open the liftgate. I believe to utilize the power liftgate I would need to fish in my pocket to find the fob & press the correct button. I wouldn't be able to do that without setting one of the bags down.
Because Mazda has done such a good job balancing the liftgate, I put the power lift option in the "parlor tricks" category.
No absolute answer on how long my order will take. Somewhere between 3-4 months.
Does anyone know if there should be?
let me know
Also, I was playing around with the NAV....One thing that I wasn't too crazy about was the way the streets were written on the screen..(maybe somehow it could be changed by the user)( does anybody know ).....the letters used for the street names were "very very thin" (had to put on my glasses to read them)...almost like written with a pen or pencil (ya know,... single stroke). My friend has a portable Garmin and the street names are clear and "bold-er" and easier to read. Does anyone know if the screen setup allows that to be changed???
Seems like I'm getting a bit farther from CX-9.
GT is my only choice as it has HID. I also thought to get a T then add RES and other stuff to avoid the 20", but ended with a higher $.
I want these things, but unfortunatly am "forced" to get the 20 inchers in order to get that....I'm not liking that at all...Presenting a problem with my decision....Whats RES, that you mention?
I rate the harshness about the same as my 2006 Mazda 3i, which is tolerable.
The CX-9 has so many redeeming features that combine to make it like a good friend that I enjoy spending time with, that the harshness has become a non-issue. For specifics, see my post of a few weeks ago.
FYI: I'm a 72-year-old retired automotive engineer.
We just picked up our GT a few days ago and have the moonroof and Bose package.
Many features you can purchase separately except
- HID.
- silver- wood
- rain sensing wipers
The brochure has some details about it than the web.
Need to hear more about the 20", and of course have to check out the prices and availabilities.
Be careful comparing diameters & cirfumerence. Revs/mile is the critical factor. Tire Rack web site lists these for various tire sizes.
Really? Interesting. I can understand needing to calibrate for the NAV, but as far as odometer, it seems like consumers should not have access to that. What's to stop me from falsely calibrating my odometer so it reads short when I go to sell the car later on? And how much can you "calibrate" it by? 5%? 10%?
My statement wasn't very clear.
The driver doesn't do the calibration. He/she instructs the nav. system to do it. The nav. system then tells the driver to drive xx miles while it's comparing GPS distance with the odometer distance. Any difference results in an adjustment to the odometer.
That will help you keep the milaege low. But be careful, your speedometer will indicate less then your true speed as well.
The NAV system has nothing to do with the wheels, regardless of size. The whole point of GPS is that it is constantly sending a signal to the satellite to get position, location and speed.
Wrong. The series of the tire (50/60/70 etc.) is an aspect ratio of sidewall HEIGHT vs tread width. A 50 series tire has a profile height 50% of its numerical tread cross section in millimeters. ...i.e., a 245/50 series tire has a sidewall profile of around 123mm (half of 245). Add two of those 123 numbers plus the wheel diameter and you get close to the total height of the wheel as well as circumference - and therefore revs per mile.
If that's not related to the height of the tire, I don't know what is.
That's the way it once was. A gear is no longer used. The car can get an accurate measure of speed & distance using the ABS rings. The count and frequency of this signal is then converted to speed and distance electronically.
"The NAV system has nothing to do with the wheels, regardless of size. The whole point of GPS is that it is constantly sending a signal to the satellite to get position, location and speed."
That's true for add-on nav. systems.
The integral OEM nav. system has a great deal to do with wheel/tire size. When a satellite signal is lost, the car's nav. system will navigate very accurately using dead-reckoning. This is made possible because the nav. system is tied in with the odometer. If the odometer isn't corrected when tire size changes, then dead-reckoning navigation will be in error.
Correct!
Thx in advance.
Thx much
Thanks in advance!!
Unless you have the factory-installed nav. and use the calibration feature.
Stuart
The temps were around 20-25 degress outside. We went to the Touring model and I looked around, started the car... etc. The salesman then boasted about how easy the 2nd row seat was to move and proceeded to try to move it. We happened to be standing in snow, so our foot grip wasn't the greatest, but the 2nd row seat was really hard to move. My first guess was it had something to do with the cold. I didn't get a chance to try another vehicle on the lot. Was this due to the cold weather and the grease in the sliding mechanism?
Has anyone noticed any problems with the effort to slide the 2nd row seats on a cold day?
http://www.mazdausa.com/MusaWeb/displayHomepage.wireless.action
http://www.mazdausa.com/MusaWeb/configEntryPoint.action
