Ford Escape Power Windows
Is it normal that the rear power windows on the 2005 Escape only lower about half way ?
Is there a way to lower them all the way ?
Seen in ALL vehicles that have rear passenger door windows.
Has anyone had this happen to the hatchback window
power window on the driver side of my 2002 Ford Escape doesnt work, nothing happens when I press button, it stays closed.
All other windows work.
There is a light 'on' the window console and also on the button itself when driving at night.
Any ideas of what it could be ? how to fix it ?
Obviously don't want to spend much/any money.
Left master window switch is part# 3L8Z-14529-AAA ($148.08 MSRP)
Left front window regulator/motor is part #2L8Z-7823201-BA ($82.18 MSRP)
I am willing to bet that your problem is the regualtor and not your switch. It is also the cheaper route, so why not start there.
Thanks !
Took the door panel off this morning. Motor/switches are working, but will not raise or lower the window. Cable seems to be intact/not snapped.
I don't see anything broken (plastic gears, etc.)
Any idea what the problem is?
