Older Ford F-Series (20+ years) Questions
Is there any other option available to me short of drilling out the cylinder or replacing the entire ignition? :confuse:
There are no leaks anywhere on the engine, nor are the plugs showing any sign's of burning.
I run (1) PCV valve on left (passenger side) valve cover, and breather on right side. Any idea's on how to resolve this issue.
Side note, this is a nonemissions engine (no EGR valve ect.) and Im drawing vacume directly from the carb to the PVC valve.
Thanks!!
It shows what screws are possitive and negative but doesn't explain which flat connector goes on which screw for the female wires to clip onto.
The wires with the females on them are black (to thin male) and the other one is pink with black slashes (to wide male). I know black is usually negative but I don't know for sure with these.
Their website is www.LMCTRUCK.com
