2007 Toyota Avalon
Dandydon
If the car is big enough, you can't go wrong. If you need the storage of an SUV, ok, stick with it. Measure the actual storage space in the SUV and compare.
I have a new 2007 Toyota Avalon.
As I am new to the vehicle and the vehicle is new to me, I am still fumbling for the correct switch, knob, etc.
This morning, Tuesday, while driving at about 10 Mph, I needed to raise the rear window sunshade. I reached down to the left and around the steering wheel and activated a switch. Instead of the rear sunshade switch, I inadvertently activated the trunk release and then the gas tank door release.
Both the trunk opened and the gas tank door opened while the vehicle was in motion (the transmission was in drive of course).
To me this is a major safety hazard, not to mention an annoyance.
Are these switches functioning properly, that is are they designed to permit activation when the vehicle is in gear?
Other vehicles that I have owned or rented lock these mechanisms from opening the trunk lid release when the vehicle is not in neutral or park.
Should my 2007 Toyota Avalon operate in the same safe manner as I indicate for other vehicles e.g.; lock out the switches unless the vehicle is in park or neutral?
The response from Toyota is:
We apologize for your dissatisfaction with the operation of the trunk opener switch and fuel filler door opener switch.
Please note: Toyota does not currently market a "lock out" feature for the trunk opener switch and fuel filler door opener switch for the 2007 Avalon.
Does anyone have any ideas to create a lock out?
But wouldn't it just make more sense to learn and then know where the proper switches are?
Seems to me you're asking for someone else to take responsibility for your failure to know how to operate these things.
What is so difficult for Toyota to prevent an accident, e.g.: the rear window is totally obscured and the contents of the trunk can be disgorged on the highway?
Reaching for a switch (manual effort), I don’t think so not at the prices Toyota charges.
As for shifting responsibility, I don’t think so either.
In this case to save maybe two dollars Toyota has created a safety issue and a highway hazard.
I also agree that the location of the trunk and gas tank lid switches is unfortunate and incovenient. We had discussion on this about two years ago in the Avalon 2005+ forum. It seems that even minor changes such as switch locations often don't happen until the next new model comes out (every 5 or 6 years) with Toyotas.
Well, maybe I spoke too soon on the 'responsibility' aspect.
It's not the driver's fault the switch is inconveniently located, I'll admit that.
But it seems to me that if most folks mistakenly opened the trunk once, they sure wouldn't repeat it a second time--especially if they felt so strongly it was a safety hazard.
We all have to accept some responsibilty for our actions, especially where safety is involved.
This issue still seems to me like blaming the gunmaker when you pull the trigger, knowing all the while the thing is going to fire!
This whole thing is really trivial IMO. The idea that an open trunk lid will obscure rear vision on the highway is pretty speculative.
At speeds beyond 15 MPH the airlow over the lid overcomes spring pressure anyway, so at best the lid will only be slightly open and won't obscure anything.
They all have a distinct feel (one has a bump the other doesn't) and very hard to hit by mistake. I disagree. Have you tried to activate them while wearing gloves?
Ergonomically, this switch placement is terrible. They are too close together and almost invisible. There is plenty of room elsewhere to relocate them. And they could be bigger, and illuminated, like the switches in the center of the dash.
Can this be installed easily by an owner?
Can the Lexus 350 camera system be installed in a Toyota Avalon?
This is my take, no intended offense to anyone. I used to use roofrack systems when I was younger. Now that I am an older person, I see things a little different. As far as I know, the Avalon (new model) can trail up to 1000lbs. I remember when I first noticed the new Avalons while in Canada, and the older couple looked like they were trailing a very small cute trailer with a hitch attached probably to the Canadian Maritines. I thought to myself, I should live that long and be so lucky. Nice car, that 2000 too. I purchased one in 2002 and have used a hitch regularly. i have 92K on the car.
Roofracks, are cumbersome, decrease gas mileage by at least 3 MPG, and worse make the car's handling characteristics markedly different, especially in cornering and emergency braking. While trailing in not without it own cautions, I would consider a small enlcosed trailer with a hitch.
Just a thought.
abfisch
http://mynewavalon.com/iGuide_Avalon.htm
There is no meaningful illumination on the rearview mirror so anything up there must be seen with reflected light or the courtesy inside lights. Or used by touch.
While these things are less than perfect they are not significant in the overall package unless night vision is problem. Hope this helps........
My dealer's service dept told me today before I read the item above that no tow kit is available for 2007 Avalons.
Does anyone know about this?
Jess70
NAV system is primitive. I would have purchased an aftermarket device and then had an auto shop install an aftermarket NAV that provides more functions at the same or lesser price.
Rear trunk and gasoline hatch open when vehicle is in motion, as there is no lock out once the transmission is engaged (unlike most other vehicles.)
Trunk has no convenient place to tie down anything.
The rear seats do not fold down as the stiffener struts block a clear passage from the trunk except for a small item.
One must press a button to obtain outside air temperature.
The power train has an anomaly that the vehicle surges on some but not all downshifts which is a safety hazard, requires additional brake pressure, wastes fuel and can lead to premature brake failure.
Rear view camera not available. Dealer refused to recommend someone or to do it themselves at the dealership as the dealer asserted it would void the warranty.
Auxiliary input to entertainment system would be useful.
:confuse:
There is a TSB for early 2007s regarding the Engine Control Module (ECM). I had it reflashed by the dealer last week and it has made a considerable improvement in how the engine and transmission behave. You may want to check with your dealer to see if your car is elgible. (based on your VIN)
Over all, I am very happy with my car.
cindy
Cj
I'm a newer owner of a 2007 Avalon Touring... now have 2500 miles on it and the darned seatbelt reminder chimes are killing me... is there an easy way to override or disconnect? I live a bit in the country so just going down the driveway to the mailbox without a belt on is enough to drive you crazy!
Mackabee
Mack
Cheers
Cj
Mack
Mr. Yuki Funo, Chairman & CEO
Toyota Motor North America
19001 South Western Ave., PO Box 2991
Torrance, Ca. 90509-2991
Katsuaki Watanabe, President
Mitsuo Kinoshita, Excutive Vice President
Toyota Motor Corporation
1Toyota Cho Toyota City
Aichi Prefecture 471-8571
Japan Mo 00000
81-565-28-2121
Good Luck. I received a phone call from a man named David who was the assistant to President of Toyota Corp.
