2007 Toyota Avalon
Let's talk about what you'd like to see for next year's edition of the Avalon.
Here’s my list:
--6 speed transmission
--Eliminate sensitivity of accelerator pedal behavior to foot position
--Touring suspension, wheels/tires and trim bits should be an option package available on any of the other 3 models, rather than a separate model. Black leather should be simply a leather color choice, rather than a mandatory component of the Touring package. You should be able to buy a Limited with Touring package and ivory leather, or an XLS with black leather and the base suspension.
--Both suspensions need fine tuning. Base suspension should not get floaty on road undulations -- not even Buicks and Cadillacs do this nowadays. Both suspensions need flatter cornering. Target for base suspension handling should be Ford 500. Target for Touring handling should be Acura TL.
--Improve steering feel/centering at highway speeds.
--Driver’s seat should have one to two inches additional rearward travel and seat cushion should go one inch lower, to better accommodate tall drivers.
--Make JBL audio system available on XL.
--Both audio systems should play mp3 discs and have auxiliary input jacks.
I've adopted all your suggestions (1-8) with only minor modifications and added more here:
1. 6 speed transmission
2. Eliminate sensitivity of accelerator pedal behavior to foot position
3. Touring suspension, wheels/tires and trim bits should be an option package available on any of the other 3 models, rather than a separate model. Black leather should be simply a leather color choice, rather than a mandatory component of the Touring package. You should be able to buy a Limited with Touring package and ivory leather, or an XLS with black leather and the base suspension.
4. Both suspensions need fine tuning. Base suspension should not get floaty on road undulations -- not even Buicks and Cadillacs do this nowadays. Both suspensions need flatter cornering. Target for base suspension handling should be Ford 500. Target for Touring handling should be Acura TL.
5. Improve steering feel/centering at all speeds.
6. Driver’s seat should have one to two inches additional rearward travel and seat cushion should go one inch lower, to better accommodate tall drivers.
7. Make JBL audio system available on XL.
8. Both audio systems should play mp3 discs and have auxiliary input jacks.
9. Provide fuel ecomomy display that is switchable and resettable to show tank average, trip average or instantaneous fuel use.
10. Re-design front passenger seat belt so it does not rattle when retracted.
11. Provide option of 2-driver memory seats/mirrors on XLS and Touring, in addition to Limited (or make the Limited available in Canada).
12. Relocate and illuminate the buttons for trunk opening and gas filler door opening.
13. Exchange locations of sunglasses compartment and overhead lights, so that when the compartment door is opened it doesn't block the rearview mirror.
14. Offer factory-installed back-up sensors as an option.
havalongavalon
Bob
P
I had an opportunity to view the new Lexus ES350 today.
I believe that most of the items on your wishlist might be avaailable on the new 07 ES350. Lexus chose Kelowna to have automotive journalists test drive and review the new GS 350 and the GS 450 Hybrid as well as the ES 350. I think it might be a option for those Avalon owners who want more options or a firmer suspension. I didn't have an opportunity to drive this new Lexus but it looked very well finished and looks a little bit like the Avalon.
I still really love my Avy, besides on a recent trip to Calgary and back I was able to get 39 mpg. ( shown on my car's computer screen) Great mileage for this car. I may consider the new Lexus in another year or two but for now the Avalon is running great.
Take care!
I noticed you mentioned you were able to get 39 mpg as shown on your computer screen. Did you have to convert litres to kms or did you actually figure out how to make the screen show mpg. I have navigation system and can't seem to find a way to show the conversion. Any help would be appreciated. I tried the menu setup area but nothing changed.
MelBC
Bob
What a rare treat, to have a private first showing of new Lexi right on your own front yard!! Did you take any sneak pictures that you could post for us?
I bet you are right, the new GS 350 and the GS 450 Hybrid as well as the ES 350 may incorporate all or most of the features that we are wishing the next Avalons will have.
This reminds me to add another wish to the list: No changes in the Avalon price points!! (in US dollars, that is). On the other hand, the new Toyota Canada prices should really come way down, given the steady improvement in exchange rate... Toyota Canada, are YOU listening?
havalongavalon
2. general 'tightening' of suspension - feel that all trims except for the Touring way too soft and even the Touring could benefit from a little less body lean. The ride/handling tradeoff may alienate some of the traditional Avalon buyers?
3. the 6 speed tranny is fine and will almost certainly be std. on the 07 - and may make no difference from a operational point of view if Toyota persists in 'programming' the transmission the way it is (for economy). So the wish is for control improvements on whatever trans. ends up in the car BUT only if that change doesn't wind up costing too much at the gas pump.
I had to convert km. to miles and litres to gal. I have a handy slide rule type of converter which automatically displays the mpg. for me when I line up the litres used for any number of km. I was very impressed that I could get such a good average of mpg. I will have to read my owners manual to see if we can display miles per gallon averages instead of litres per 100 km. I think all the Canadian Avalons show only litres and km.
Take care!!
1. 6 speed tranny.
2. Fold down rear seats
3. A red dot in CR. Better fit and finish.
Mackabee
:shades:
Its actually a tough call for me between the Camry and the Avalon. Avalons have some good discounts on them.
Yes, I did take a few pictures, but you can see pictures of these new Lexus models on the Lexus.ca website. What I found interesting is that the new ES350 is priced just slightly higher than the Avalon XLS. The ES350 with premium package is priced at $46,500. CDN. The ultra premium package is priced at $54,000. If you go on the website you can check out the options included with both packages. If you have an extra 20 thousand, you could move up to the GS 450h Series.......Nice car. A little steep for my liking but a very classy automobile. I will try to get a test drive in the ES350 the next time I am in Vancouver, as we do not have a Lexus dealer here in
Kelowna. Will try to get some Pics here shortly.
Take care!!
1. A separate model name. It has younger crowd appeal as a "sport" type car with a more firm suspension but with family size room. This is not the same as a Limited with a "touring struts" option. Not to the person who really wants Acura TL handling, with a back seat and a trunk.
2. The car needs some interior upgrades. As is, it's a little plain. More options, better materials, nicer finish and a decent selection of colors. Basic stuff, nothing that runs up the price. It shouldn't be that hard to do.
Chances are, none of this makes any difference. Toyota does at it pleases.
Toyota didn't get where it is today by ignoring this kind of input, so I suspect that many of the improvements we are discussing are under consideration. Of course, the timeframe for their implementation is anybody's guess.
2. Redesigned dash. Remove the cover from the radio...it's just plain ugly.
3. Bluetooth.
4. The Limited should have the option of an Ebony interior.
4. Power tilt and telescope.
5. Passenger seat should have up/down capabilites.
And lastly, they should hurry up and release the 07 Avalon, because the 07 Camry seems like the better deal.
Redesign the parking brake to automatically release when transmission selector is moved from Park to Drive.
Add a pen/pencil holder to the inside of the glove box door.
Allow CD player to play MP3 recordings.
Add an easily accessible "input" jack to the stereo system to allow use of other audio sources (Digital audio players, etc.).
Lose the cassette player--Who needs it--Try to purchase a music cassette today; it's nearly impossible--(Cassettes are rapidly approaching antique status)--Can't believe Toyota still thinks this is an essential/desired item.
Illuminate the gas and trunk release buttons (Sometimes you have to use these things at night).
Make the glass portion of the rear view mirror larger; it is too small. (Could reduce/eliminate the frame size to give larger glass area without significantly increasing overall size)
Bob
What I would like to see is for Toyota to REALLY turn the Avalon into a 'poor man's Lexus' which some may contend it already is. Dropping the XL end of the line, and turning the engine 90d a certain way to do this along with a starting pricetag of $35k or so with a standard option level approaching what a full boat Ltd. is currently. And don't drop the 'sports model', a ticket back into that 60+ demographic in which the previous Avalons languished along with Buicks and Caddys.
FWIW, think there remains a very popular misconception that the Avalon is still a nondescript 'box'. My car is more often mistaken for a Lexus, even a BMW (from the rear, I guess) than it is for something as tame as what many folks think the Avalons are.
On another note, I agree with previous posts that the cover on the radio should go. I never close it, and it obsures the CD opening when open. One other thing that needs "updating" is the RDS and CD Text. Why don't they scroll? Having to hold down the text button to advance the display is a distraction. Every other vehicle I have driven with RDS scrolls the data.
More power to differenciate the Avalon from the Camry. This would help to justify the price premium.
Other car manufacturers do the same thing. BMW's latest 5 series looks like a smaller version of the 7 series....and the newest 3 series comes closer to this image than the previous 3 series. BMW uses similar engines in the 3 series and the 5 series (except that the 5 series offers a more powerful engine than the 2.5 and 3.0 liters common to both 3 and 5 series). Other than price, the thing that separates the 3 series from the 5 series from the 7 series is size/comfort/ride/driveability....the same things that separate the Camry from the Avalon.
the solution is a simple one for Avalons without seat warmers...add a little tray/cup in the spot where the seat warmer controls would otherwise exist. Alternatively, a flip out tray could be added under the trunk/gas release buttons.
There may be an issue with the cover not opening completely out of the way. If so, it could be re-designed for 2007 to more fully retract inside the instrument panel.
havalongavalon
2. The interior colors should be darker; no one wants to keep cleaning light carpet and the wood is too light.
3. Add BlueTooth
4. The Moon Roof should be an option (not mandatory) for those who want it. We live in Phoenix and no one wants the Moon Roof, it's already too hot!
5. Let the buyer select the options they want instead of the packages.
We would have already purchased a new Avalon except for the above. We're now driving a 98 Avalon and love it! The interior is much more useful (darker) and the car was ordered without a Moon Roof. But the car now has 140,000 miles and it's time to replace it.
Wish list? Far as I'm concerned they need not redesign the body. I wasn't exactly thrilled at what they did to the Camry. But right now, today, IMO it's the best deal in town. Update the Av with new tranny & bluetooth and you'd have a better looking car that has it all.
In my own mind I've reserved a 07 SE Camry when I'm ready to buy in a few months. If I hear Toyo announce the new Av will be updated with those features, there is a good chance I'll rethink the Camry.
2.The odometer on the 2005,s is so dim that it can hardly be seen in daylight. Use LED,s.
3.Make Back-up Sensor a factory option.
Tire pressure monitor would be a nice addition too -- this feature is showing up on lower priced vehicles now.
See http://www.msnbc.msn.com/id/8122995/
