If you're thinking about getting an Infiniti save some money and by a Kia; the Kia might just prove to be a better car.
Has anyone else ever seen anything like this?
SUVs and Smart Shopper
I completely share your frustration. I am in Denver, Colorado. We have two Infiniti dealers in town. Both compete for who can provide worse service. It is not as much about the car as the dealers. I took my car a few months ago to the East side dealer for them to take a "look." They billed me $110. For what? No services, no replacement, no advice; I came poorer. You infact feel scared.
I recently purchased a 2001 QX4, and in the last couple weeks of weeks, the Service Engine Soon light has come on and off and on again, etc. Also, it would occasionaly idle a bit rough, or would lack response when pressing the accelorator.
I took it to the local Infiniti service center here in Santa Monica, and they told me that the Airflow Meter needs replaced, and recommended a "Fuel Induction Servicing".
I have read all the threads in this forum regarding the SES, but have not seen or heard of anything regarding the Airflow Meter. Any thoughts? Does this sound right? What are the odds that even once they fix this, I will need a series of other things done to correct my problem?
I don't know what either of these really mean, or what benefit the latter would serve. Any suggestions?
Thank you all in advance for your input!
I would not let dealer perform any additional recommended service unless I know absolutely necessary. the more you let them do the more stuff needs service, that's the way they make money (not always of cause).
My question is: how difficult would it be for myself (or even a trained technician at Best Buy or otherwise) to install? The sound system that is in there is the factory Bose Premium Sound, and i'm not looking to upgrade it at all, just the head unit. Would the install be difficult due to the amps and speakers? I don't even know where the amps are, much less how they would affect the install of a new unit.
*for reference sake, the model of head unit i am looking to get is Sony's MEX-BT5100
Any advice would be greatly appreciated.
thanks!
Has anyone had any experience with replacing ignition coils? How long should they last, cost, etc.?
Here's essentially what i would get, if I had the money now:
Pioneer DEH-P7000BT - $249.99
Nissan In-dash Receiver Kit Fits select 2001-up Nissan and Infiniti models
Chassis size E - FREE
Nissan Antenna Adapter Diversity antenna to Motorola female (and male) - FREE
Nissan/Infiniti Factory Integration Adapter (THIS IS THE ADAPTER YOU NEED) - $19.99
http://www.crutchfield.com/p_142C4NN03/Nissan-Infiniti-Factory-Integration-Adapt- er.html?search=OEM+Amplifier+Adapter&tp=3486
PAC SWI-PS - $74.99
Mike
Mike
Mike
anybody know any good deals on one?
I have had the same issue with my QX4 and it turned out to be heat shield that goes around exhaust system that was making all the noise. Go to your local mechanic and ask him just to cut it off
Your car battery goes dead when the abs motor runs overnight.
My dealer told me that he is 99% sure that the problem is a bad abs relay. This relay is mounted on the side of the abs unit...mounted on the firewall, passenger side, under the hood. The relay cost about $170. Next time you hear it running when you shut off the car, try rapping the relay good with a screw driver or other tool. It just might fix it without spending the money. I can't try this fix until I return to my winter home next winter, but it will be the first thing I try!
I wish you well
weather/route or load (other then uphill) make no difference. Dealership couldn't find the problem of course, so any ideas would be very much appreciated!
"Welcome to the club! I, as well, have a 1997 QX4, with over 56K miles. Maintenance; look at post #46; you can get a free rear suspension upgrade (shocks,springs)if you tell your dealer the rear bottoms out with a full load or five people aboard. Bulletin #ITB97-026"
AJ
Most people get them replaced either when someone notices one is split or leaking or they start making noise. If you catch them before they start leaking, then you only need to replace the boot. I usually wind up having to replace the axle too since I don't notice the split in time.
So I had 2 people tell me change it. West Coast Auto, gave me a quote for $690 including CA tax (9.25% now) and what they said is a required Allignment. That breaks down as $145/side, and 1.5 hours of labor at about $90/hour. So total of about $600 when they offered the allignment for free.
Is that worth it for my 114,000, 1997 Infiniti QX4? I have never skimmed on proper maintanance but $600 gets steep for a car now worth around $5K. But my plan is to keep it while "low-maintance" perhaps for 3 more years thru 150,000 miles.
Thank you again.
I put a Raxles axle/boot on my Nissan Quest a few years back with the help of a friend for the price of the part ($170). The next one I let a mechanic do. $600 over 3 years is $200 a year, so that's ok. Cars that get as old as ours (I have a '97 and a '99) are more likely to require some maintenance and repair now and then though, and none of it is cheap. But it's rarely more expensive than 3 or 4 car payments would be.
You don't need a repair manual. Do you need to just replace the antenna mast or the whole unit? I had to replace my mast a few years ago and bought from these guys - http://antennamastsrus.com/Infiniti/QX4/Infiniti%20QX4%201997-2003.htm
Their site also provides links with instructions on how to do the replacement. It was pretty easy. I know they also sell complete units but have no experience with those.
Good luck!
Brought it to the dealership to discover that it's the check engine light bulb that's bad.
The friggin bulb is $37 but it's another $200 in labor(1.5 hrs) to remove the dashboard/instrument cluster to get to the bulb.
I know I'm getting ripped off but I'm thinking trying to reassemble everything isn't going to be an easy project. Am I wrong?
"If the selector lever cannot be moved
from the P position while the engine
is running and the brake pedal is depressed,
the stop lights may not
work. Malfunctioning stoplights
could cause an accident injuring
yourself and others."
Derek
derek.odette@atticbreeze.net
Also, where is the driver side headlight ballast located on the same vehicle? (HID Headlights).
I took to my local Nissan dealer who ran the tests. Said that they would have to "start" by replacing the computer and possibly more. For them the QX4 still started intermittently, mostly not.
I feel it could be the alternator, starter, the starter solenoid, bad battery cables... These are just guesses since I do not know much about cars.
If anyone has ideas on this please help! :sick:
About Heated Oxygen Sensors, each bank has two sensors front and rear. It is best to have a mechanic to replace them since they are hidden and will need a special socket to remove them. Also avoiding damage the sensor threads when remove and replace the sensors. Nissan car is sensitive with the O2 sensors, if it starts going bad, check engine will go off and on sporadically. If engine code does not show the sensor faulty, the chance is not the sensor.
