I have a five minute commute to work, city driving (Los Angeles). What can I do to get the mileage where it should be? I'm very, very disappointed with this mileage.
17 mpg is pretty poor, but maybe not unreasonable for a five-minute commute to work in LA. Probably slow speed, lot of stops? Remember that while the car is still, the mpg is zero.
Yes, my commute speed is pretty slow - about 30 mph. And there are some traffic lights, as well as a couple small hills.
Lower speeds save gas. See right here on this site!
Look at the first three fuel economy tips tested. The biggest factor is you.
Most of the time when I'm driving my 2008 Fit Sport AT, I'm on cruise control at 60 mph (the speed limit on my commute). Otherwise, I'm taking it easy. I very seldom drepress the accelerator more than a tad bit. My last three tanks are all 35 mpg or above, and I feel good about tomorrow's fill up (today it's at 250 miles, 1/4 tank left).
If by changing your habits you could improve your mpg by 30%, then you'd be right there.
This is not a problem with your car; its a problem with your commute - and an unavoidable one at that. I have to ask: living so close to work, and in sunny Vegas, is biking/walking to work an option?
Filled up on Sunday, and again on Friday after work, so it was mostly used for the commute (more highway driving this tank )
Date......Gallons....Miles......MPG
26-Mar...6.128......195.3......31.870
2-Apr.....9.846......313.8......31.871
7-Apr.....7.615......285.6......37.505 (Shell gas from here on..)
14-Apr...9.324......333.4......35.757
20-Apr...9.386......330.6......35.223
25-Apr...7.833......297.6......37.993
....................total..35.034 mpg
........last 4 fill ups..36.513 mpg
Then mark the outside of the gas container with a magic marker, at exactly the correct 1 gallon level. (Some cans have a mark already). Dry it out real good and take it next time you gas up. Pump exactly 1 gallon of fuel into the tank according to your mark. Does the pump quantity and price agree?
Seem like a lot of trouble for nothing?
A few weeks ago the fuel light came on in our 03 Pilot. The needle was where it was supposed to be. All the other times when this has happened it took about 17 gallons to refill. So the tank has about 2.3 gallons reserve when the light comes on. This time I was about 2 miles from the station. Therefore very little gas was burned getting there. It took 18.7 or so to refill, and the normal 17-18 mpg, I usually calculate, dropped to barely 15 mpg. Something definitely wrong.
I deliberately let the fuel level drop enough to turn on the light again this time. It took 17.1 gallons to refill, and the mileage figured to the normal 17.8 mpg.
It only makes sense that the fillup in question was due to a faulty pump.
How can this happen? Aren't these things regulated and inspected by someone from a government agency. Yes they are, but read the link. It might be real beneficiary to do the gas can test and change pumps or stations if necessary.
http://www.comcast.net/news/articles/finance/2008/04/26/Bad.Gas.Pumps/
Kip
I have the 2007 honds fit sport. I get around 235 miles per tank. Can anyone advise me how to increase it.??? I commute to work everyday and maintain speed at around 55 to 60 with cruse with very few stops.
Please advise..
Your tank is specified as having a 10.8 gallon capacity. You should still have between one and two gallons remaining when the reserve light comes on, and you can gauge that level more precisely by recording how far you drive after the light comes on and then how much fuel you pump. If you stop at the first automatic shutoff, as many do, then your tank has a reduced capacity of about 10-10.3 gallons. If you never want to have less than 1/2 gallon left in reserve, then consider 9.5 gallons as the practical capacity. You can now calculate what range to expect. Once you determine your "predictable" mpg, multiply it by 9.5. That's what I would do. If I were getting 33 mpg I would expect my range to be 313 miles, and I would expect to have a safe margin of at least 1/2 gallon remaining, and after filling I would expect to have left at least 1/2 gallon of unfilled space. The interesting part would be to observe how far you get toward that 313 mile range before the reserve light comes on.
For that example I assumed the car is giving 33 mpg. Your results might vary considerably depending on type of terrain, amount of traffic, average and steady speeds, driving style, etc etc etc.
I hope that helps.
It sounds like you are driving the car conservatively, and I'm assuming you have an automatic transmission, not a manual. My son (age 21) and I (age 53) drive differently; he's kind of a leadfoot and I'm more conservative. We don't measure how many miles per tank, but go with miles-per-gallon to measure our economy. He has gotten anywhere from 25-31 MPG and I am consistently getting 30-33 MPG. We drive in-town and on the city Interstate/freeway, and neither of us have taken our Fits on a road trip (> 50 miles). However, since the 08 EPA rating for the Fit Sport are 28 city and 32 highway, you can't expect to get much better MPG on an Interstate road trip. If a person does a lot of Interstate and road trips they'd be better off with a Honda Civic; for example, the EPA 08 ratings for the Civic LX Sedan with Auto Trans are 25 in town (less than the Fit) and 35 on the highway (more than the Fit).
Good luck with your Fit. Right now I'm trying to private-party sale my wife's 07 Ford Focus SES (sort of a "grandma" car) and buy her a new Fit (much more sporty and fun-to-drive), too.
My son and I each have an 08 Fit Sport automatic, and we have been using the Ethanol gas, because it's typically 10 cents/gallon cheaper than pure unleaded here in Nebraska. Am considering running several tankfulls of pure unleaded in each car and compare MPG readings for each car. Right now my son (21) is averaging 27-30 and I am averaging 30-33. It would be interesting to do this test and see if there is an improvement in MPG that more than offsets the higher cost of the 100% unleaded.
If there is anyone out there who has already done this, it would be interesting to hear the results you got.
Ethanol containes less energy per same fluid weight than non-ethanol-blended gasoline. So if you can avoid the "E," by all means do so.
About 40,000 miles on my 2007 Sport AT, almost all freeway 65-75mph, getting 36.5 MPG. Of course, that's with the pre-corrected inaccurate odometer.
The first tank was 28 mpg
2nd I forgot to check
3rd 30 MPG
and 4th 33 MPG
So its improving as its getting broken in with it and me adjusting to each other. My lead foot wife is still getting better MPG on her Civic bought the same day
If you look at fueleconomy.gov, you'll see the Fit owners are averaging about 32mpg over about 150 vehicles reporting, which is about what my average tends to be at 50/50 city/highway.
On a side note, if you look up the Civic, you'll find that it's about the same as the Fit, and the Corolla is probably closer to 33mpg average.
So based on my experience and from the hundreds of folks reporting on fueleconomy.com, the Fit's MPG is right there with the Corolla and Civic; however, like the Civic and Corolla, you'll have SOME people getting a lot better then the average (some 27mpg averages for the Civic and Corolla) and some getting way better than the average.
I believe that defrost or defrost/floor will automatically run the compressor?
...but you can press the 'AC' button to turn it off.
I don't think that is typical. But, I do think the Fit AT is efficient on the highway. It seems that the stick is better for city driving.
I think that driving styles could very well determine whether you get 30 mpg or 36 mpg on the highway.
I feel that the more that I drive with fuel efficiency in mind, the better I get at it. It takes some adjusting. I mostly use the Fit to commute to work. I try to cruise control at 60 mph. I am now anticipating where to click the cruise off so it doesn't downshift up an incline. I am learning to coast more - when that light turns red up ahead I let off the gas pedal. I know when I can let off the gas at highway exits and coast all the way up the ramp.
I swore that I wouldn't get too hyper-milage crazy, but I find myself following trucks sometimes.
Here's what I think helps the most, this is from hypermilage.com but the same advice is on many other sites.
- Drive smoothly. Avoid heavy acceleration or braking. Speeding, rapid acceleration and braking can lower your gasoline mileage by 5 percent at lower speeds around town, and by 33 percent at higher highway speeds.
- Use cruise control on major roads and in free-flowing traffic. Maintaining a constant speed can improve gasoline mileage.
- Avoid higher speeds. Gasoline mileage usually decreases when driving at speeds over 60 mph.
See if you can cruise control at 60 mph for a few tanks. What have you got to lose?
Good luck!
Thanks for clarifying that for me!
Is the fit the same? I'm thinking about a Fit for my wife in the next year or so.
I couldn't help but wonder what sort of mileage he gets, with the extra weight (I'm only 110 lbs and I always drive alone in my car, carry no extra weight in the car with me), and the fast driving. Obviously I couldn't know what transmission he had, but I thought of the people here in this forum who are complaining about their mileage, and wondered if he is one.
My '07 Sport MT is still holding steady at an average of 36 mpg, my last two tanks up at 38 mpg. The last time I filled up I bought the "up to" 10% ethanol regular for the first time, so we'll see if that makes a difference. I feel like I'm getting less mpg this tank, just watching the fuel gauge compared to the trip meter.
I used to have a 1992 Civic Si, which I adored, and in its prime, it got 40 mpg on the highway (51 mpg across Indiana, but that's flat as a pancake), How can there be Fits that get lower mileage than my old Civic Si????
Any thoughts?
