GMC Yukon, Yukon Denali Towing
on an older 1997-1999 Tahoe/Yukon what did the factory tow package consist of?
Supposed to include an upgraded radiator, Fan-coupling, alternator and Pre-wiring. Not sure how to prove any of that! What it doesn't include is trailer wiring harness or hitch or anything that goes on a hitch.
I am wondering if the 4.8 would pull 5,000 lbs or if I should go with a 5.3 liter.
Our 2000 Denali has a 5.7 liter and pulled a 6000-lb camper on several trips. It worked that engine plenty hard, esp on hills. I would expect a 4.8 would be disappointing for anything except local pulling with that sort of weight.
Is it possible to pull a 30' camper with a 1997 Yukon? It has the 5.7 V8 engine. The problem I'm having is when I hook up the camper the front end lifts up and it feels like I don't have alot of control in my steering. Is there something out there that can be added to help level out the camper and keep the front end from lifting up? The camper has a GVWR 9100 lbs. The Yukon has a GVWR 6800 lbs...I also have stabilizer bars cranked out to the max. Thanks for your help.
http://www.monroe.com/products/maxair.asp?currItem=_level0.mcMaxAirHeader&currSu- bItem=_level0.mcMaxAirHeader.mcHeader&rolloverObj=[object+Object]
I am not sure your exact model (i.e. 4-door or 2-door, either 2WD or 4WD), you may find your exact fitment via the e-catalog from Monroe:
http://www.monroe.com/catalog/ecatalog.asp
There are many brands and options out there for your application, a set of air shocks or Shocks with coiled over Helper Springs are probably one of the less expensive ways to enhance your Yukon's load capacity and control... I am only using Monroe as an example for your reference. Depends on how much time and money you plan to spend, there are some pretty extreme mods out there...
I'm talking with the dealership and there are working with me. They have asked to actually weigh the trailer on a truck scale and have mentioned an upgrade of my a axle ratio to 3.73. That would max me out to 7,500 lbs.
Looking for the "real deal" on the towing capacity. If there is anyone that can help my battle the dealership it would be appreciated.
I am from GM Customer Service. I am assuming that you have a 2008 2WD Yukon. If you purchased the flex fuel Yukon your max towing rating is 6400LBS. If you have regular gas and not flex fuel then it is 6500 LBS towing capacity. Trailering capacity may be limited by tow vehicle ability to carry trailer tongue weight. Addition of trailer tongue weight cannot cause vehicle weights to exceed Rear Gross Axle Weight Rating (RGAWR) or Gross Vehicle Weight Rating (GVWR). Even if you go to the 3.73 axel upgrade if you have the flex fuel your towing capacity is 7400lbs, and regular gas will be 7500lbs. If you have any further questions please let me know. Thank you,
Mariah GM Customer Service
Bottom line--we have purcharsed a travel trailer with a fullly loaded weight of a bit under 7000 lbs, and will this Yukon work with this size trailer. We will do a bit a traveling in the Colorado mountains, but no off-road excursions.
Thanks very much.
Will the AWD on the Yukon Denali XL be able to handle pulling the boat out of the water on steep boat ramps like my suburban does? My concern is on my suburban I can switch it to 4 wheel Low on the Denali I do not know how it works with AWD since there is no switch. Any thoughts?
The 2009 Yukon XL 4 wheel drive can pull 5400lbs normally. If you get the max trailering package you can pull up to 7900lbs. If you have any further questions please let me know. Thank you,
I want to purchase a travel trailer and need to know how big of a trailer will my Yukon safely pull. Any suggestions will be greatly appreciated.
http://www.sherline.com/lmbook.htm
Basically you need to find out the GCWR of your vehicle. Which is sometimes not published. The Max towing capacity is determined by GCWR - GVWR. GVWR is the total weight of your vehicle, passengers, cargo + tongue weight. You also have to be mindful of the Rear Axle Weight Limits.
I'm looking to purchase a 2011 Tahoe LTZ with 3.42. It has a max towing rating of 8500#, but the max GVWR of 7100#. I've also seen GCWR listed as 11000#.
Curb Weight of a vehicle is also a good number to know. It is the weight of the vehicle with options + all fluid levels topped off.
2011 Tahoe LTZ 2wd is 6029#. So some simple math here 11000 - 6029 = 4971. So how in the world can they list 8500# as the max towing. There is some major fuzzy math going on here.
As long as the weight of the trailer and cargo does not exceed 8100 pounds, you should not have a problem. Unfortunately I am unable to give feedback or advice on using the Denali to tow a 7300 pound trailer as i have not done so; however, Edmunds is a great resource to find people with this experience.
Thank you and have a wonderful weekend!
Caron, GM Customer Service
Looking for a TT to tow on trips to see family from TX-GA-TN-NC & CT .
Looking for suggestions as to what I should be looking for and what you are towing.
Not looking to Max out as we have parked our Excel 36' in NM and are looking for something with a QUEEN size bed, a potty and shower and kitchen. Want to stay under 30'.
I have towed a 4800 lb travel trailer approx 100 miles (one way) and noticed that my Yukon usually has a temperature of 210 degrees (even when not towing). However, when I'm towing the TT, as soon as I start any kind of hill or grade I can watch the temperature increase. I also noticed that the Transmission temperature increases as well...up to 232 degrees. Once I started back down the hill or grade the temp quickly returns back to the 210 degree mark. According to the RPO code and owner's manual, I have 3.73 gears and a towing capacity of 7500 lbs. However, I have read several other articles that state I only have 6500 lb towing capacity. Was wondering if I should be concerned about the fluctuation in temperature or if this is to be expected.
Also, should I tow with the "trailer" button on or not?
I understand your concern; I wanted to confirm with you that per GM the maximum trailer weight for your vehicle is 7500 pounds. It is also important to take the Gross Combination Weight Rating into account - essentially, the combined weight of your vehicle, cargo inside the vehicle itself, and the weight of the trailer should not exceed 13,000 pounds.
The Tow/Haul mode on your Yukon adjusts transmission shifts while hauling, making them less frequent and more predictable. This can perhaps be very noticeable on downhill grades.
As far as the fluctuation in engine temperature, engine coolant at higher altitudes will boil at a lower temperature than at or near sea level. If you turn your engine off immediately after towing at high altitude on steep uphill grades, your vehicle may show signs similar to engine overheating. I am not sure what altitude you are driving at, but thought that this might be useful to you.
I am going to ask our Technical Assistance Center about the fluctuation in engine temperature you mentioned, just to make sure you are within a healthy range and that this is normal. Once I hear back from them, I will be sure to relay this information to you.
Sarah
GM Customer Service
Just wondering what is the maximum weight the 2007 Yukon can tow?
Ashley
That's an exciting investment! If you were willing to send us the last 8 digits of your VIN, we'd be happy to look into this further. You can either put them here on the forum, or send an email to socialmedia@gm.com (include your question in the email as well so we will have a point of reference!).
All the best,
Sarah
GM Customer Service
Please see excerpt from owners manual page 3-47:
“It also provides an indicator of how hard your vehicle is
working. During a majority of the operation, the gage
will read 210°F (100°C) or less. If you are pulling a load
or going up hills, it is normal for the temperature to
fluctuate and approach the 250°F (122°C) mark. If the
gage reaches the 260°F (125°C) mark, it indicates
that the cooling system is working beyond its capacity.”
I hope this helps!
Sarah
GM Customer Service
Given your VIN, I found the following. I know it is a lot of terminology, and I hope that I can communicate it clearly for you!
The Gross Vehicle Weight Rating (GVWR) for your specific vehicle is 7200 lbs. This is the maximum number of pounds a tow vehicle may weigh. Everything that contributes to the weight of the tow vehicle is featured in this rating, including the weight of the vehicle, driver and all passengers, fuel, payload, trailer tongue weight, hitch weight and all optional equipment. The GVWR is displayed on the driver’s door or door-lock pillar label of your vehicle.
The GCWR (Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded vehicle and trailer including any passengers, cargo, equipment and conversions; the GCWR for the vehicle should not be exceeded) for your vehicle is 11,000 lbs and the maximum trailer weight per the owners manual is 5,500 lbs.
It looks as though the weight of your trailer and boat exceeds that of the recommended maximum trailer weight; as far as how this may affect your vehicle, I am unsure. It may be a good idea to speak with your dealership on this matter.
If we can look into anything further for you, please don't hesitate to contact us at socialmedia@gm.com
All the best,
Sarah
GM Customer Service
It's a 2007 Yukon Denali 6.2L AWD.
Any information would be great. Thanks, MM
Having also bought a 2009 XL with trailer tow option I found the rig came with a 3.42 axle and surprisingly NO transmission cooler. Although the mfg GVW ratings will restrict your 5.3 Yukon XL to 5400/5900#, with an adequate transmission cooler this rig will pull 8500# with out any shift scheduling or engine laboring while in trailer tow mode, however, make sure you have a transmission cooler. I found mixed reviews and also looked at Suburbans and Yukons and some do not have the transmission cooler.
Without this KEY element you can anticipate transmission overheat; I've experienced it!!
Also note the difference of a 3.73 vs 3.42 rear axle can make the total GVW decrease.
** Driving in extended hilly country without the 6.0 engine will place high demands on your engine but of relatively flat roads and moderate inclines you should have no issues.
Does this mean its' a mistake to bu that vehichle and that I should look for one with a 3.42 axle and HD towing (K5L).. or should I feel ok proceeding knowing that I am on the hairy edge? I think I'm seeing examples of posts of people not even at the limit with a 3.42 axle and stil lhaving overheating problems..which leads me to conclude it woudl be a big mistake.
the dealer did not push me towards doing it..wants me to do the right thing. He adsived tha [non-permissible content removed] wousdl not hurt hte enging, but that I would be a little sluggish on the hills.
Any advice from GM here?
My 1998 yukon seems to pull this boat fine, but it had a 3.73 axle..so I can't really do a comparison.
To be quite honest, if the person selling you the trailer knew you had the Yukon for a tow vehicle, they should have never sold you that trailer (I'm assuming you bought it new, from a salesperson).
Just my opinion, hope it helps you out.
Dave
I am towing with 2011 1500 Chevy Silverado EXT cab 4X, towing packages, 3.42 rear, the 5.3 ? 315hp engine, and according the manual my max towing weight is 9000 lbs. I was towing up steep mountain and the vehicle struggled. My biggest concern was a transmission temp of 210 degrees F. It dropped back to under 200 coming back down the other side of mountain pretty quick. Wondering if I need to go to 2500 truck. My camper is 1 ft smaller than yours and your max towing trailer weight is less than mine. I would deffinately re-think the camper purchase or plan on buying a tow vehicle.
I would like to know every ones opinion on the transmission running at 210 is that too hot. Am I stressing the transmssion?
The dealer network is not well informed which resulted in my having to sell a perfectly good rig that delivered great fuel economy a could have adequately pulled 7900# given the transmission cooler. This was a serious $50,000 mistake!!!
I would be pulling our camper today with a nice Yukon if it weren't for the lack of support in resolving my issue. I loved my Yukon which was far superior to a F150 eco-boost I'm currently driving; all because I was sold my Yukon with less than the MAXIMUM trailer tow by an ill informed sales person.
and you are margial for total weight. The big deal is transmission over heat which ca result in a $4000.00 drepair bill.
Note: While I love the Yukon, (nothing compares to the ride and overall use!) terrain, and where you plan on towing our drig can be factor of choice.
