Jeep Grand Cherokee Vibration
jdejeephemi
Member Posts: 33
in Jeep
If anyone has this same problem please let me know. I bought my jeep in august and immediately noticed a vibration problem. I brought it to NTB and had them check the balance of the tires. They claimed they were out of balance but when i driove off i had the same vibration. When i brought it to the dealership they said the drive shaft was to blame and they replaced the drive shaft. drove home and noticed the same problem once again. Brought it back to the dealer....to make a long story short i have had my jeep in and out of the shop for months and still no solution. This only happens on the highway traveling 70-80mph. at 60 it fine at 100 it fine. What should i do and who should i speak to? Presently i am waiting for a "special tool" to come in to measure vibration within the vehicle and see if it is within reason. my passenger seat will move at least 1" from the vibration. I am very tired of this problem. please help.
Dave
john everett
Dave
IF YOU HAVE HAD A PROBLEM WITH TWO-REST ASSURED THE OTHER TWO ARE GOING THE SAME WAY-REPLACE THEM!
With this solution I have maintained a smooth ride and long tire life on suvs, vans, trucks and sports cars. It may be a pain in the [non-permissible content removed] but it is the solution.
Jeep does have software that can be downloaded to prevent a type of harmonic distortion in the axles. It's kind of like what happens when people walk in step crossing a bridge-there is a vibration caused by harmonics. The software repvents the axles from doing this.
Go to the site below for the info-hope it helps!
http://www.wkjeeps.com/tsb/tsb_wk_2100506.pdf
I also noticed that it has gotten worse in the last few days while on a long trip It also seems to make the sound when accelerating uphill in high gear.
Has anyone got to the bottom of this problem. I set up an appointment for next Tuesday 9/5 at a dealer.
FYI, I know the Goodyear tires were bad. I rotated them to the front and the car pulled to the right. I had new Michelin Latitudes 255/60/17 installed replacing the factory 245/65/17 Goodyears. They make the car handle great, very quite and smooth, but I still have the drivetrain vibration.
As far as balancing, the tire shop said it is very tricky to balance rims with the chrome cover upgrade as the balance equipment spacer does not fit very well against the chrome cladding.
I would concur with others, the vibration makes an otherwise great truck seem like a real piece of junk.
I noticed the TSB here however that is for the SRT 8, Is there a bulletin for the Limited 5.7 AWD?
The software aspect seems most reasonable for this AWD system. The actual failure of the seals ETC are probably the result of the bad code.
I also had a vibration noise in the front end during hard downhill braking. I went to Stellen Group in Torrance CA and got the slotted and drilled rotors with new pads. This made a big difference. It seems like the brake issues on Jeeps never go away. I have an 01 and we upgraded the brakes on it and never had a problem again.
http://www.wkjeeps.com/tsb/tsb_wh_1600105.pdf
It just seems odd with so many having this issue that there is no real clear solution.
The company that touts Hemi, Performance, Trail rated, Daytona R/T race chargers and they won't back their cars over 70MPH. Why do they design them to go over 70MPH. They either back their product or they don't, obviously they don't. The smug customer service rep then dared me to lemon law the vehicle stating you won't win . Well I would be silly not to try. I really only want to get my vehicle fixed and have chrysler back their product. Too bad chrysler chose to take this route. I'm really learning to like my wife's 4 runner that I have not had to replace a drive shaft in after 4M miles on and Toyota actually backs their cars.
In summary I believe this vibration is a huge problem, further than the drive shaft. I believe the entire Quadradrive 2 system has problems and damnler chrysler is covering it up or in better words trying not to cover it. Notice the drivetrain warrantee is no longer 7 years as it was in 05. wonder why? They know they have a problem and even though it is supposed to be covered, it isn't with their new policy. If the fix is the drive shaft why would you ave to replace it every 15M miles as other have. It is a design flaw with the quadradrive"supposedly trail rated" system. It would be amazing to me if this car could even make it down a path much less a trail. I find it amazing that the high level model, at a high level of cost, gets such low level,cusotmer service,warrantee and backing, it says something about the vehicle and the company. A jeep just isn't a real jeep any more. They have lost a loyal customer and many more if I can help it.<img src=" :lemon: :lemon:
Seemed like the vibration was much better. But then the Jeep started drifting left and right on the freeway. Had the alignment checked. it was off a little. Still drifted LEFT AND RIGHT.
I have a 2001 Jeep Grand Cherokee Limited with Michelin Cross Terrain 255X60X17 and they have been perfect. Went to Americas Tires and told the manager the story. Of course he wasn't buying and said drifting was normal on the freeway.
He would not do a full exchange for the tires. I had to give them another $312. They installed them and off I went.
Next the Jeep starts vibrating/shaking from 65 to 75 MPH. So the new tires were out of balance. Went to another America's Tire, told the story and they reluctantly balanced the tires again. I asked them to check them first, they did not. Guess what,the vibration is now 68 to 73 MPH after the re-balance.
So I figure I'll give it one more try at Les Schwab. Tell the manager the story and he seems like he really wants to solve the problem, even though I did not buy the tires there. He say's let's do re-balance on the road force machine. $21 / tire to do this.
This machine checks the quality of the rims and the tires. They also checked the balance on all 4 tires first - they were all out of balance. The rims and tires checked out good. Balanced the tires on the road force machine. They even double checked one tire by removing and re-installing on the machine. Handed me the keys and said go test drive and please call us to tell us if its fixed.
So I take Jeep out on a country road - hit 70 MPH and its as smooth as silk.......
The lessons I learned.
1. America's Tire / Discount Tire seems to have gotten too big and no longer seems to want to provide the service they use to - I'm done with them - Too bad since I have 9 cars and trucks
2. Chrome Clad wheels on 05 and 06 Jeep Grand Cherokee's require latest generation balancing equipment - I think older machines push out against the chrome covers
3. Do not use inside wheel weights - use the traditional weights on the edge of the rims
4. Goodyear tires may not be the problem -perhaps the tires get screwed up because the balancing is just slightly off
5. Michelin Latitudes DO NOT BELONG ON THIS JEEP they are really for luxury and cross over types
6. Michelin Cross Terrains work great
7. Michelin and America's Tire/Discount Tire sucks - They did not want to listen, saw me as a trouble maker and did not want to make things right.
8. I'm going to call Michelin direct and see if I can get somewhere directly with them. For all I know AT/DT never even called them.
9. I'm not crazy, even though everyone tried to make me believe that I was.
Now we'll see how long things go smooth. The only problem I have left is I hear a click sound on the left side at low speeds and the dealer does not seem to be able to find the cause. This started while on a long trip.
So 2 months and $1300 worth of tires and balancing I think the issue is solved.....
The tires are in great shape and I'll get lots more miles out of them.
I expressed my disappointment to the dealer and told them the solution I found. It is a good dealership that dropped the ball on this problem.
It's still, by far, the best vehicle I have owned.
I now have 29800 miles on the Jeep. Just had the 30K service. The Jeep is still driving perfect no vibration. So it appears that the road force process with the correct cone is mandatory to avoid this problem. Funny thing, I have a new 06 Dodge Ram Laramie 4X4 with 20's and the chrome clad rims. Started having the same vibration issue. Took it to Les Schwab had the road force done and the vibration was gone. In this case I got the problem fixed before the tires were destroyed.
I've only had 1 other problem with the Jeep, the side curtain airbag hardware started to rattle. Dealer had to remove the headline and tighten the brackets, they also added some type of tape to the headliner to stop the rattles. I was told this was the first Jeep they saw with this problem however they had seen the problem on the Magnum - man wagon.
