GMC Jimmy 4WD Problems
I have a 2000 GMC Jimmy SLT that I purchased knowing the 4WD didn't work. Afetr the sale I put it in a small,private shop and they said (if I understood correctly) that an ABS sensor was out of alignment and something about a bearing was not allowing it to go into 4WD. They fixed it and after I left I tried it out. It now goes into four wheel drive but the following occurs.
1.If you press 4 Hi from 2 Hi.....the 2 Hi light goes out and 4 Hi light blinks but does not stop blinking although 4WD is engaged(I can feel it while turning).
2.When selecting the Auto 4WD button the Auto light starts blinking and instead of being in the 4WD "on demand" mode it goes directly into 4WD.
3.No code or check 4WD lights appear on the dash.
The repair facility had closed for the day when I discovered all of this and I plan on going back but I just wanted some ideas as to the problem before I do. Thanks for any help.
The front hubs each have an ABS sensor in the 1 piece hub for the ABS and Autotrac (only 4wd mode effected) to work. The rear sensor is in the transfer case.
The passenger side front axle has a coupler that engages the axle to the front differential when any 4wd mode is activated and a sensor tells the TCCM computer in the cab located in the pass side kick panel its engaged. That axle has a vac actuator under the battery that is vac activated and it pulls a cable from it to the axle. 99up have an additional electric switch for the vac mounted on the firewall. CHECK all vac hoses from the intake to reservior (in drivers front fender) to the firewall switch, to the actuator under the battery (5/32 small and 7/32 larger). Note that both front axles CVs always turn as well as front drive shaft. Thats covers Autotrac and 4Hi. For 4Lo the transfer case has an encoder motor that is on the transfer case that engages a lower gear when you stop, put trans in neutral and push 4 lo and a clunk is heard. Again a sensor on the transfer case to tell TCCM it is engaged. Hope that wasn't too confusing. Blinking dash light means the sensor did not work/actuator did not work/ or the TCCM computer is confused - yes it can happen. After you check all operations try and disconnect the battery for 30 min and then retry and that should have cleared any error. Finally, check the front diff fluid and make sure its full and the transfer case requires blue autotrak II GM fluid - this has a GM bulletin on it so do not use Dexron red in it due to the clutch packs in yours.
Assume 3 button 4wd (no Autotrac):
1. Check the vac hoses from the untake over to the reservior and T off to the actuator under the battery tray.
2. Chack the actuator (crawl under the pass side front) by looking /listening to see it the cable pulls the axle coupler.
3. Check the front axle coupler sensor(wires to it) by unscrewing and pushing the ball in) which tells the TCCM or 4wd computer that the axle is coupled for all 4wd modes.
4. Check the similar sensor on the transfer case for the encoder motor that engages the low gear for 4LO.
5. Check all connectors are tight and wires not cut all the way to the transfer case.
6. Disconnect the battery for 30 min and see if the TCCM reboots (must be a windows system - thats a joke) cause often this does fix it as it hangs up.
That rev/2/4 thing is caused by an internal broken Sunshell and the neck breaks off all at once usually from drivetrain shock as hard 4wd or towing. Noise could be many things as u-joints, hubs, brakes, tires etc so need to look under it and start checking. Also look at the transfer case fluid and change every 50k as well as trans fluid/filter.
Front drive shaft always turns and keeps both diffs at same speed, so when you depress the 4Hi vac makes the actuator under the battery tray pull a cable that couples the pass side CV axle to the diff (drives side always connected). If thats the bang then see if the actuator vac line is good and the actuator pulling the cable. The 4Lo will only work at a stop in neutral or a 3mph or less roll in neutral, then the lower gear in the transfer case engages. That really loud noise FIX needs to be looked at to see what they really did - if the 4Lo gear is being engaged when 4Hi is pressed you have a sensor problem - probably best to go back to the last work shop and ask or pay the dealer to determine - this gets very expense very fast. If you have 4 button Autotrac the transfer cases sometimes have clutch problems and use special blue syn fluid to smooth out.
If its 4Hi then have to look at the front actuator under battrey going to the pass side axle.
Because if I get under the jimmy I can put it in 4 wheel drive by hand, it's just when you try to put in 4 wheel drive with the push button it will not go.
Front sensor is on the pass side so look under the vehicle and see the electrical connector plugged into the soild outboard part of the front diff. Encoder motor is in the transfer case for 4Lo only and a sensor on top of the transfer for that too (hard to see). The TCCM or 4wd computer in the pass side compartment kick panel controls all operations. I must assume you are only engaging the encoder motor for 4LO by hand and if the front axle is not engaged and sensor tells TCCM then the light blinks and no go. #1 check all vac lines from the engine down to actuator first.
Transfer encoder motor is only for 4Lo.
Thanks Jay :sick:
Thanks Jay :confuse:
I need to get this problem resolved as I drive a long distance to work every day. Any suggestions?? TIA
The internal warning speaker (not sure of it's technical name somewhere inside the dash) is ALWAYS on as long as the key is in the ignition. It started last week, coming on periodically and now it progressed to non stop being all the time. i checked all fuses and they are ok, and i have no error codes displayed on my dash. Any ideas or advice? Were exactly is the speaker so i can remove it?
Tony
I am about to replace all the 4x4 vacuum hoses just to make sure they are right. I have read that they are 5/32" and 7/32". Some questions...
1. Tis is ID, correct?
2. Silicone hoses are OK?
3. Most hoses I find are metric, that is 4mm, 6mm... research is not clear but I believe I can use 4mm and 6mm, correct?
4. Approximately how much, in feet and meters, of each do I need to replace all the 4x4 related hoses?
Regards
RC
