Subaru Forester Tire/Wheel Questions
12346»
  • emememem Member Posts: 3
    ( wrong spelling) Falken
  • logtraillogtrail Member Posts: 74
    I have a 2006 Forester and last checked my air pressure in mid September. I usually do it every other week but I fractured my ankle in early October and have not been able to drive since and my wife has become my chauffer. Checked my air pressure yesterday and all 4 tires were at approx 15 lbs. My mazda, also with alloy wheels, is fine. I understand that sometimes air can leak around alloy wheels. OK. But is there any solution other than checking the pressure weekly?
  • laredo13laredo13 Member Posts: 6
    edited December 2010
    If you constantly drive on snowy roads do yourself a favor and buy a set of dedicated winter/snow tires. Buying dedicated snows will cost you more money now, but the money, aggravation and injuries you may save in the long run will be well worth the initial investment. If based on your driving conditions you choose all season tires than you won't be disappointed with the General Altimax HP. Falken tires are garbage. My father always told me that their are two things that are most important when it comes to a car. NEVER skimp on tires and brakes as your life may depend on it. Go to tirerack.com and do your research. Good luck and drive safe.
    Keep in mind the temperature drop may be largely responsible for the drop in tire pressure in this case. You need to check more often when the temps dip significantly.
    When it warms up, too, to let air out, else you may up with 40psi in summer!
    Falken Ziex 512s are fine, the one bad thing about them is tread life, but that doesn't make it a bad tire overall. Grip is actually far above average.
    I actually owned 3 sets of them - on an 03 Miata, 98 Forester, and 02 Legacy. Not a great winter tire, but good grip even in the wet otherwise.
    Again, my only complaint is short tread life.
  • xwesxxwesx Member Posts: 18,087
    In terms of tread life and all-season capability, I very much like the Goodyear Assurance TripleTread. I had a set on my 1996 Outback, and they were fantastic. Unfortunately, I was only able to use them for 13 months and about 25,000 miles before we (me and the car) parted ways, but I used them over two winters and they were great. They also only wore ~2/32 during that time.
    They will last you about three years with your driving habits and they'll give you very decent traction on snow and ice.
  • chitown21chitown21 Member Posts: 2
    I'm a Chicago woman who has a 2008 forester 2.5X (so my manual says) who is not an expert in cars. Apparently I haven't rotated my tires often enough and the sides of the two front tires are bald. My car just hit 28,000. The dealer wants me to buy two new Yokahama tires for the front, get an alignment and then rotate the backs to the front. We have had a horrendous winter with snow and ice. The Yokahamas never worked well in rain, and are nightmares in winter; I'm slipping and sliding. I've seen at least 10 suggested tires for the last 5 years of this blog. What do you recommend-are there any good ones out there? i need to get something ordered ASAP because my 2 and a half year old Suburu is a scary car to drive. I don't feel safe in it right now. By the way, what are suburbucks?
    Thanks....
    First, of all, I would run quick from that dealer! You definitely should not purchase only two tires to replace the worn ones. If you do that, you will put heavy stress on the center differential and may very well end up with much more serious problems (such as a center differential failure!) down the road.
    I agree that your tires, the Yokohama Geolandar, are horrendous (for winter conditions).
    Are you wanting to purchase an all-season tire that performs decently during winter, or have you considered running two sets - one for winter and one for summer? If you go with the two-set approach, you can probably run your Geolandars for another summer to help spread out the extra initial tire investment.
    The best all-season tire I have used is the Goodyear Assurance TripleTred. It has an excellent treadwear life as well. Tirerack.com is a good place to go to get an idea of how you can expect a tire to perform. They have a (subjective) rating system based on user feedback, so you can compare tires within a given class and read reviews.
    Second vote for RUNNIG from that dealer. Read your owners manual. It ought to say somewhere in there that you have to be careful about tire diameter - and that means tires have to be replaced in sets of 4.
    And the cause of the eneven wear is alignment. Get that fixed, too!
    edited January 2011
    With 28,000 miles on your set of Yokohama's I'd replace all four. Stay away from dealers and find a reputable mechanic for this type of repair. Bridgestone 960 or General Altima HP would be a great choice for an all season tire. The General is just as good at a much lower price. I love them. As I've said before, don't skimp on tires and brakes. These are two of the most important items where money should not override safety. Yes, it would also be a good idea to check alignment at this time. Good Luck...
  • danielldaniell Member Posts: 128
    edited January 2011
    I have a 2002 Forester S, automatic, with limited slip differential. I have religiously rotated my tires to keep their circumferences matched.
    I agree that in theory at least all 4 tires should be changed at the same time. The manual says: "For safe vehicle operation SUBARU recommends replacing all four tires at the same time". There is a warning after that that mixing tires can produce damage to the drivetrain.
    However, even the flat tire change procedure described does not specify that the spare (I have full size spare on my 2002) needs to go to he back, nor are there any mileage or speed limitations stated in the manual. There is no requirement (as i have seen in many posts) to put the vehicle in FWD mode. Basically the manual describes the flat tire replacement as it would be for a FWD or RWD car. If a different spare tire circumference could cause problems, why isn't it stated in the manual?
    I am wondering if the manual transmission Subarus (50-50 traction F/R) have the more stringent requirements, while the autos do not.
    Daniel
    The automatics are definitely sensitive to differences. The speed limitation of using a "donut" tire is from the tire itself, not due to the stress it places on the drivetrain. If you have one tire that is of a different circumference, the stress will be on that axle's differential. If you have both tires on one axle different in circumference from the other axle, the stress then goes to the center differential.
    I can't imagine anyone driving on a donut for an extended period of time, but were that to happen, it could damage the differential because of the added stress, especially if the vehicle is driven on paved roads. On snow, ice, and gravel, the stress is more often relieved through tire slippage.
    Edited my previous post a bit to include specifically some info from the manual...
    I agree with everything you say, theoretically. All I am saying is that the manual does not seem to put any serious restrictions on the tire circumference. If so, it would require installing the spare in the back, putting the car in FWD mode etc. as described in other posts. The only cautionary words about tire replacement are: "Have the wheel nut torque checked at the nearest automotive sevice facility. Store the flat tire in the spare tire compartment". If circumference was such a big concern, they would have said something like "repair your flat tire at the closest facility if possible, and install it back". No such words, they allow you to use the spare permanently.
    edited January 2011
    It seems as though they have become more detailed in the owner's manual in recent years. In the 2010 manual, beginning on page 9-2, it states:
    CAUTION: Never use any temporary spare tire other than the original. Using other sizes may result in severe mechanical damage to the drive train of your vehicle.
    The temporary spare tire is smaller and lighter than a conventional tire and is designed for emergency use only. Remove the temporary spare tire and reinstall the conventional tire as soon as possible because the spare tire is designed only for temporary use. Check the inflation pressure of the temporary spare tire periodically to keep the tire ready for use. The correct pressure is 60 psi (420 kPa, 4.2 kg/cm2).
    When using the temporary spare tire, note the following.
    . Do not exceed 50 mph (80 km/h).
    . Do not put a tire chain on the temporary spare tire. Because of the smaller tire size, a tire chain will not fit properly.
    . Do not use two or more temporary spare tires at the same time.
    . Do not drive over obstacles. This tire has a smaller diameter, so road clearance is reduced.
    . When the wear indicator appears on the tread, replace the tire.
    . The temporary spare tire must be used only on a rear wheel. If a front wheel tire gets punctured, replace the wheel with a rear wheel and install the temporary spare tire in place of the removed rear wheel.
    Precautions for AWD models with automatic transmission:
    Your vehicle is equipped with the AWD (All-Wheel Drive) system. In addition, if your vehicle is an AT model, before driving your vehicle with the temporary spare tire, deactivate the AWD capability of the vehicle as follows.
    1. Turn the ignition switch to the “LOCK” position.
    2. Pull any one spare fuse out of the spare fuse holder in the engine compartment. Spare fuses are attached on the back side of the fuse holder cover. You may pick up any one fuse in the spare fuse holder.
    3. Put a spare fuse inside the FWD connector located in the cabin and confirm that the All-Wheel Drive warning light “ ” illuminates. The All-Wheel-Drive capability of the vehicle has now been deactivated.
    NOTE: After reinstalling the conventional tire, remove the spare fuse from the FWD connector in order to reactivate All-Wheel Drive. Make sure to restore the removed spare fuse in the spare fuse holder located in the engine compartment.
    Thank you for the detailed answer.
    It seems that most if not all of those additional precautions are caused by the doughnut spare tire being vastly different from the remaining 3 tires. My car came with the full size spare from the factory, and again, I see none of these additional steps in the manual. Based on that, it seems that the AWD can accomodate fairly different circumferences. Another pointer in that direction - the "light load" tire pressure recommended in the back is 28 psi, "heavy load" is 36 psi, and always 29 psi in the front (numbers from memory, but I believe I am right - wife has the car now). Big difference between 29 psi and 36 psi. Bottom line, acording to my 2002 manual at least, restrictions when replacing with same size tire as my spare is seem to be rather related to driving dynamics and traction characteristics than circumference.
    Based on all of this, IMO it does not seem completely unreasonable that replacing just 2 tires as opposed to all 4 is possible.
    Daniel
    Well, it is possible, but it will place additional stress on the center differential. If left in that state long enough, the differential is likely to fail. The driver might not even notice it happen, but that one time AWD is really needed, the front tires are going to be spinning and the rear will be doing nothing to help.
    If you have a full-size spare, there is much less of a difference in circumference and therefore much less stress on the system. If you keep the spare rotated in with the other tires, you could even drive on it regularly with no problems. But, if you only use it as the spare, you should swap it back off the car as soon as is reasonable.
    You're right - most of the precautions in the 2010 manual are specific to the donut spare. There would be no location or speed restrictions on a full-size. I did not realize that the 2002 model included a full-size from the factory. The 2009+ models can accommodate a full-size in the well, but come with a donut.
    edited January 2011
    One can put 2 new tires on the same side of the car, or opposite diagonally. That would move the mismatch from the center differential to the front and rear differentials. Lots of people with FWD and RWD cars change just one tire and differential failures as a problem are generally rare.
    Here is a very relevant article I found. It's not about Subaru or AWD, but shows real, measured impact of tire pressure. The author found that while the impact of tire pressure on circumference is very small, "The “roll-out” of the rear tires was reduced by 1” by simply reducing the tire pressures from 25 psi to 14 psi." Basically the same tire with 25 psi covered an extra inch on the ground with each rotation, compared to when inflated to 14 psi. One inch per rotation is huge, and that's just the impact of tire pressure. Below is the link. The guy even shows pictures of his measurements.
    http://www.onedirt.com/tech-stories/tire-pressure-101-the-cushion-of-air/
    Again, the range for the rear tire pressure recommended by Subaru is 28 psi to 36 psi based on load, quite big itself. Based on all of this, I will have no problem replacing just one tire (and perhaps fine tune the roll-out using the tire pressure) if needed.
    edited January 2011
    There are a lot of assumptions there!
    First, yes, you could put a new tire on each axle and take pressure off the center differential and transfer it to the other two differentials. I did replace a single tire as I didn't realize it would cause a problem; that was about 20,000 miles into a set of tires that were on the car for 75,000 miles. When on dry roads, I didn't even notice the difference. On slick roads, the axle with that tire would slip every 3-4 seconds and create a noticeable "wobble" in the movement of the car. At about 185,000 miles (on the odometer - I put a new set of tires on at around 196,000), I started to get some differential noise from the rear diffy that became more consistent over time, but it still operated fine on my open-differential '96 Outback through 220,000 miles when I ceased to own it.
    Second, you are making the assumption with tire pressure that the contact patch and sidewall height change in a linear fashion with tire pressure, which is not the case. The difference between 14 and 25 psi is worlds different from 28 to 36 psi. If you operated the car at the former difference for any length of time, it would create problems. At the latter, it would not. However, were one to drive the car at, say, an even 28 psi all around but carry a heavy load in the back at all times, it may cause additional stress on the drive line.
    In the end, it really all depends on your priorities. If you want a well-functioning and maintained car, it doesn't pay to scrimp or neglect. If you don't care and can pass it on to some unsuspecting victim before any problems become easily apparent, scrimp away.
    edited January 2011
    Not to worry, I completely realized the difference between 14-25 psi and 28-36 psi, and the likely non-linearity :) I am a mathematician, and I deal with stuff like that a lot in my job. Just did not want to go there. But I'd be willing to bet that the 28-36 increase in psi with a full load will cause more than the 1/4" Subaru demands.
    What bugged and still bugs me is that there is little information available about this issue. My suspicion is that the Subaru AWD can deal with more than the 1/4" circumference difference required, easily. Your own story proves that the Subaru AWD system can take a lot. I can only dream to reach that kind of mileage with my car (too many problems, in spite of being extremely well maintained). And simply we don't drive enough (reaching 90k miles in 9.5 years of ownership).
    I suspect a lot of requirements in the manual are due to the litigious world we live in. For example, the manual specifies front to back rotation on each side. I got non-directional tires from Sears, with lifetime rotation and balance, but they refuse to do a FWD-pattern or X-rotation, because of the specs in the manual. So I go to Sears, have my tires balanced, then go home and do a proper FWD rotation. That doesn't make sense. I assume the only reason that is in the manual is because some OEM tires they use are directional. Just for the record, I am doing the FWD rotation pattern rather than X (cross) rotation because my auto Forester has 90% forward bias. So far that has worked very well.
    Having worked on Subarus for 10+ years, raced them for 10+ years and owned them for more than 12 years. I can tell you that you DO NOT want to drive a Subaru with a tire that is mis-matched for any extended period of time. You can drive it for say 200 or 300 miles but to drive it 30,000 or 40,000 miles WILL definitely cause your center diffy to fail eventually over time. If your subaru is equipped with a front or rear Limited Slip Differential, you should also put the mismatched tire on the axle w/o the LSD.
    -mike
    Subaru Guru and Track Instructor
    I completely agree with you. For short periods of time, such as under the heavy load scenario you presented in that same post, it will not cause any significant (lasting) stress. My goal here was simply to provide fair warning that stress will be introduced and it can lead to failure of very expensive systems.
    Wes, as you and I both said, short (even 1,000 miles) trips won't cause damage, however prolonged (over 1,000 miles) use of mismatched diameter tires will begin to wear down your center differential.
    This effect is similar to using the wrong offset of wheel, while using the wrong offset won't destroy your wheel bearings instantly, PROLONGED use will lead to premature failure.
    -mike
    I just want anyone who is interested to know that I got new tires for my Forester, after being told be the dealer just to put on two new Yokahamas. I went and spent the money on Michelin Primacy tires the day before the two and a half feet of snow hit Chicago. I put on four tires, not two, which was pricey, but well worth it. I am getting great traction and these tires handled the snow and ice pretty well after our monster storm. Good choice! Thanks for all your advice-I appreciate it.
    Chitown21
  • hutch52hutch52 Member Posts: 1
    I just replaced one tire on my 2002 Subaru Forester. I have been reading the forum comments about the possible problems with mismatched tires. Three of my tires are Firestone tires with a 55K warranty. Firestone does not make that exact tire anymore, but replaced it with a new model number with a 65K warranty. the tread pattern, and apearance of the tire is virtually identical. I would like to replace all four tires eventually, but am wondering if having replaced one tire with a new one of virtually the same tire is a problem. Any comments from the forum?
    edited June 2011
    How many miles are on the original 3? If they will need replacing in the next year I would have replaced all 4 now. Unless your tires are really worn down you shouldn't have any problems as long as you stick with the same exact brand and size. Go to tirerack.com and look up the specifications for your specific tires. Rev per mile, circumference, width etc. Different tires and manufacturers may have slightly different specifications even if they are listed as the same size (ie. 225 75R 15.) A good set of tires that STICK to the road in all weather conditions will probably last only 30K - 35K miles. I would be leery of a tires overall traction ability with a 60+K warranty. A tire that really STICKS to the road will never last 60K miles. Read the tirerack.com reviews, surveys and tests before you buy any more tires. Good luck.
    Even if it is an identical replacement, whether it is "okay" to replace just one all depends on how much wear is on the other three. You need to know the original tread depth and the current tread depth of the used tires. If the used tires are more than about 2/32" worn, you should have the replacement tire shaved to match so that you don't put excessive strain on the car's differentials.
  • crashdavisfmcrashdavisfm Member Posts: 22
    Hi guys,
    I had my '09 Forester XT Limited at the dealership for some routine maintenance yesterday. They found a roofing nail in the interior sidewall of one of the tires. The dealer quoted me a price for 4 tires including alignment, and I opted to go home, research on tirerack instead. I ended up buying the Kumho Ecsta LX Platinum tires, which should be delivered Mon or Tues next week.
    Dumb girl question 1: why would I need wheel alignment after replacing the tires if I don't need wheel alignment before replacing the tires? The service guy at the dealer was insistent that I compare prices including wheel alignment. I don't get it. Are they going to knock my alignment out while installing the tires?
    Dumb girl question 2: my tire sensor light came on 2-3 weeks ago. I added air to all four tires (can't remember if one was significantly lower than the others, but I think so), so I assume that's when I picked up the nail. However, the light had not been on since. I drove home from the dealer, and then an hour later went back out to run a short distance errand. The tire light came on almost immediately. I stopped for air and the bad tire was at 10 psi. Sorry, but WTF? So now what do I do? Not drive at all for three days? Carry a portable air pump with me and only drive short distances if necessary? Can I put a can of fix a flat in there for the interim (I read that can damage the TPMS).
    BTW, I hate hate hate the Geolanders, so although I am pissed about having to replace 4 tires at 21K miles, I'm not sad to see them go. That 's why I didn't even consider the option of shaving a tire down to match.
    aj
    I would ask the tire shop that installs the new Kumhos if they think an alignment is necessary.
    Did the old tires wear evenly? If so I'd be tempted to pass.
    I think it is far preferable to do one's own research and make a decision based on that versus taking the recommendation of a shop on faith. I couldn't agree more regarding the Geolandars, plus the cost of a single tire (at least at my location) is north of $200, which is just insulting considering the quality of the tire. I'm facing a similar situation to yours due to a sidewall puncture.
    As far as your questions go, you wouldn't "need" an alignment when replacing the tires. The benefit, if you did opt to have one, could be two fold: 1. you would ensure (presumably) the new tires would wear evenly, and 2. you would put some extra profit in the shop's pocket. ;) As AJ suggested, unless you see uneven wear on the current tires or the car is not tracking true, I wouldn't bother with it.
    The shop may (probably?) fiddled with the nail when they were inspecting, which may have caused the leak to worsen. Since you don't plan to keep the tires, I would just opt for the refill often option. Or, you could get a tire repair kit (pretty cheap, $5-10), pull the tire off and put a plug in it (absolutely an extremely short-term fix) and hope it holds for the day or two you need. if nothing else, you do have your spare on-hand should you need it. I'd recommend making sure it is at full pressure (60 psi) now, just in case.
  • once_for_allonce_for_all Member Posts: 1,640
    I've had several nail flats fixed by the plug method. I'd always been taught that the only proper way to fix a flat was to dismount the tire and patch the inside. Come to find out that "Discount Tires" aka "Americas Tires" has been fixing them with plugs for many years, and I've never had a problem with them so far.
    I've been using the Kumho KR21 Solus for several years, they are great tires (quiet, good riding, long lasting) at about $60-$80 (price has really been going up on these).
    John
    edited February 2013
    Hello Subaru experts.
    I recently bought a 2013 Forester Limited with the 17" wheels. I have an extra set of OEM 16" tires and wheels from my 2002 Forester S with all season tires. Bolt pattern and offset match. So today I installed the old wheels + tires 215/60-16 instead of the 225/55-17 the 2013 came with (as those old tires still have a lot of life in them). I realize my odometer is about 2% off, and the TPMS light came on as the old tires had no TPMS in them. My question however is about the front brakes - they only have 3/8" or so clearance with the 16" wheels. Wheels rotate freely, and a test drive including highway showed no problem. Is there any scenario in which this tight clearance could be a problem?
    --Daniel
    I don't think so...the brakes move with the wheels.
    You lose a tiny bit of ground clearance, right? I would just get taller tires when (if) you replace them.
    Thanks Juice!
    Yes, I am losing 0.5" of ground clearance. The plan is once I use these old tires to put snows on in the OEM size (for lower trims) 215/65-16.
    Daniel
    Meant 0.25", not 0.5"...
    --Daniel
    Yeah, half inch diameter. So not a big loss in clearance.
    Daniel, those 16" rims work just fine, and the planned 16" replacement tire size is perfect going forward, so if you are fine with the smaller size for now, go with it. You will be accumulating miles a little faster than actual, though, which will (slightly) shorten your warranty period depending on how long (miles-wise) you use the tires.
    I have a set of 16" steel rims off a 2007 Forester that I use on my 2010. I use those with my winter tires (same size as you noted - 215/65R16) and then use the 17" alloy wheels for the summer tires. No TPMS in the winter wheels, which is fine by me.
    Daniel,
    Between 2002 and 2013, the Forester put on weight. So Subaru put on tires with larger load carrying capacity.
    I STRONGLY recommend you do something other than put those 16" tires on your new Forester. Overloaded tires can fail - sometimes catastrophically and with little warning. You do not want to be part of that statistic.
    Thanks capriracer (and Wes) for your answers!
    Capriracer, I am fully aware of that. Weight went up by about 200 lbs., and tires went from 215/60-16 to 215/65-16 on base models and 225/55-17 on my limited. Load rating is 95 on my 225/55-17 vs. 94 on the old ones, very minor change. However for this very reason I am keeping my old tires 215/60-16 inflated by an additional 2-3 psi. I have them at 33 psi in the front, 32 in the back, so that should cover it. We also never get close to the load rating of the car of 900 lbs...
    -Daniel
    Hi Capriracer,
    I accidentally saw some of your posts in an engineering forum (you are/were an engineer for a "major tire manufacturer").
    http://www.eng-tips.com/viewthread.cfm?qid=159900
    Very good stuff there, I agree with you 100%. If I have a choice, I try to buy tires rated H and above for the reasons you mention.
    Daniel
  • papaya1040papaya1040 Member Posts: 26
    Heads up, DTD has pre labor day sale, 215/60R16
    96 X 4 = 384
    MFG rebate = 50
    DTD rebate = 75
    Free shipping
    = 259
    Other tires available, I ordered Conti PureContact, $376 shipped.
    Sale ends Mon...
