hope this helps
:sick:
Any ideas?
The MAP sensor in my '04 Tahoe is located on top of the intake manifold in the back end of the engine. The harness is the 3-wire connector that connects to the sensor.
I got new connections from the dealer and soldered them on the wires myself. The dealer would not do anything and the vehicle was still well under warranty. The problem was fixed by the new connectors in the wires.
Arrie
Yesterday I tried punching the 2wd button while the 4wd low light was on, 2wd light flashed several times then came on, and I now have "Service 4WD" message on.
The transfer case now will not shift into other modes.
I assume it is the electronic actuator but I am wondering if anyone else has had similar probs/ fixes.
Thanks, Catam.
I'm always trying to rule out the obvious things. My wife drove around in 2nd gear all day once and complained about how hard it was to get up to speed on the highway... I was worried about all kinds of possible problems when 9 times out of 10 with some of us it's really just a goofy user error.
Arrie
:confuse:
:confuse: :confuse: :confuse:
we like...so ned to give up on chevy's cuz mum's boyfriend's tahoe is goin nuts and our burb is givin us problems..
Arrie
You could try a trick here: Disconnect the MAP sensor and try starting your car. It should start and run in a pre-programmed mode using factory set program in the computer, i.e. the computer would not use signal from the sensor. This would put your 'Service Engine Soon'-light ON but you should be able to drive it. Your fuel consumption could be a little bit higher though.
If your car still would shut down you can re-connect the MAP and try running with MAF disconnected. The same way the engine should run without using MAF with SES-light ON.
Arrie
Dealership attempted silicone twice -- which was not a permanent fix.
Northeast rep from GM attempted a different kind of maintenance -- definitely NOT a fix -- and Customer Assistance Center was notified immediately of the 'not a fix' situation.
GM just posted a bulletin on this problem.
How many others affected by this problem???
What is the fix???
Distressed Surburban Owner who always loved his Chevys
___________________________________________________________
What is the website address for this info?
We have had very minor rubbing type noises from the rubber door seals. Dealer did apply silicone which did quiet it for a bit. What does the GM bulliten say to do for the issue? I'm thinking as the rubber breaks in it'll quiet down.
-- Gregg
Boston, Mass
any ideeas or concerns would be greatly appreciated and thank you in advance.
It leaks worst when the vacuum inside manifold is the greatest, i.e. when you are driving slow or sitting still and idling. As soon as you apply gas pedal the pressure inside manifold raises (vacuum lowers) as the throttle opens and lets more air inside the intake. The engine will also use more air but typically during normal driving condition manifold pressure is higher than during slow speed and idle. It will start 'whining' with normal running speeds too if you don't have it fixed first.
You had the head gasket changed so obviously they did not torque the intake manifold bolts correctly or they need to be re-torqued after some period from installation.
The fix is to have your intake manifold bolts tightened to proper torque unless air leak has eaten the gasket requiring changing it.
Of course the correct gasket also must be used.
Arrie
yea becasue you mentioned the whining and oh boy was it whining before the head gasket blew!!!! now it doesnt whine AS MUCH but it really squeaks.
we really appreciate this info, but is it going to hurt anything?
The silicone is a temporary fix -- but with the heat and cold weather, eventually cracks and the noise is back.
Been there -- done that.
My vehicle sounds as if a door or window is open while driving.
Many others around town are experiencing the same problem.
Have a ticket opened with GM to get the bulletin which the dealership tells me is supposed to be the fix. Verbally I am told it is just siliconing.
But the Northeast service rep was given the day with the car and after 12 miles, the vehicle was returned to me with the top of the doors bent in and out of alignment.
Unbelievable.
He claims he only siliconed -- but silicone does not bend doors.
GM claims he has authority to do what he needs to do to get the job done and to satisfy customers.
If I had been asked if I would like the top of the doors bent into the rubber to silence the noise, well I think you know my answer: NO WAY -- don't touch this $55,000 vehicle.
The noise is still there and the car is now disfigured.
Still dealing with GM to get appropriate answers:
1. who is holding the service rep responsible?
2. when is the vehicle going to be fixed or replaced!
Loved my Chevy -- cannot believe they would allow someone to damage it over rubber noise issues.
Trying to find out how many others this was done to.
JR
Leaking intake manifold gasket can cause faster engine wear as the air entering the engine thru gasket is not filtered air.
The other thing it does is that it lowers your intake vacuum, i.e. increases intake manifold pressure that the MAP sensor reads. This can put your engine spark timing off and result in under power and lower gas mileage.
Tightening intake manifold bolts to proper torque does not harm anything. You only have good things to gain if you can stop the leak.
Arrie
again we thank you and hope to get it fixed sometime in the future
When you decide to do the fix that we talked about in the previous posts would you PLEASE post back to us if it fixed your problem or not. We all try to help each other here in the forum largely because we can not find help from the 'all so well knowing Chevy dealer shops'. Posting back your results will be appreciated by the users of this forum.
Arrie
P.S. If you really have a leak at intake manifold gasket as it seems like based on your posts I would not wait any longer to have it fixed.
i believe mum is going to have that looked at i believe next week.
do you know what i heard when i got out and closed the door earlier at wal-mart today???
chirp chirp chirp
yup yup is it possible for the manifold to squeak by closing the door???
it sounded like it was right under the front window...
what do you make of this...? :confuse:
