Nissan Frontier Audio/Sound
I have an '05 Frontier Crew Cab and would like to swap out the single in-Dash Nissan SD player with the 6-Disc unit provided by Nissan. I just cannot afford the OEM price from the dealership.
I don't want to go with an aftermarket unit, since it is difficult to find a 6-Disc in dash unit. I also don't want a seperate 6-Disc changer.
I do not care if it is the Standard 6-Disc or the Robert Fosgate head unit. My only concern would be the wiring harness for the Fosgate, possibly not working with the existing wiring.
Thoughts, Suggestions?
While your in there, replace the radio. You'll be thrilled you did!
hth
hth
FWIW, I went with a double DIN JVC Mobile head unit from crutchfield. Only plays one CD (MP3 as well) but it looks classy in the fronty, sounds great and holds weeks worth of music all the time.
russ
Can anyone help me find JUST the tweeters for the doors and an in-wall subwoofer for the rear?
can you hook me up?
I start the car let it warm up in the garage back out, put it in neutral, change to 4 wheel drive,then change to 4 wheel drive low all while I am in neutral. Then I drop it into second all the while driving on level ground to save on my brakes its not a real steep grade so think this is the best way. Then I come to a step hill to to down while in second go down the hill. When I reach the bottom of the hill, I put it in 3rd as there still is some incline to go down. I get to the higway, stop and put it in neutral, put it out of 4 wheel low into 4 wheel drive, then take it and put it into 2 wheel drive. Put it in drive by then I am on the highway 90 percent of the time the indicator will show drive; 10 percent of the time it is showing 4th gear although my gear shift in the drive slot. I will reach 50 mph and its showing 4th gear as I do not look as it has only happened 2 times in a year. It does not want to come out of 4th gear into Drive ...what is going on or what am I doing wrong? you can tell after a bit you are in 4th and that is why I probably notice it but no huge difference.
To eleviate the problem I pull over and try putting it through the different gears and it still does not get it out of 4th. So today, did the same but turned the motor off and restarted the motor in park put it in Drive and it went back into Drive....
It should show D... Sure could use your help.... Thank You
kcram - Pickups/Wagons/Vans+Minivans Host
I was simulating what you would do with a standard transmission my question still is also why it would say it is in 4th gear when I am in drive when back in 2 wheel drive.
Downhill on a dirt road, 4WD will help keep the truck pointed in the right direction, but the transmission and brakes are what will keep your speed in check. In 4-Low, the transmission will shift rapidly and somewhat abruptly - as often as every 5 mph depending on gearing. You may find better control and less transmission wear if you use 4-High and 1st gear - this will allow some speed variance without all the excessive shifting.
Also, since this is a daily occurrence, you may want to invest in a set of high-performance brakes for the front - premium rotors, pads, and calipers will allow more use with less heat buildup and longer life.
So just use regualr gears for going down the hill? We had a Murano for 8 years and never used it but it was not as heavy so will just go back to that. Thank you!!
