Land Rover Discovery and Discovery II
1626365676897
  • nanuqnanuq Member Posts: 765
    D99: I don't think the load space cover will work. I believe they extended that DII back end about 6" or a foot over the DI. Too bad, I just threw my load space cover away... haven't used it in 5 years.
    Tire sizes: You're not talking much difference in diameter, and if you don't need to travel far I wouldn't worry about it. You're running a very similar setup to what I have. The diffs will compensate, so you'll have a continuous speed difference between the sides of about 4.5% which I seriously doubt will activate the ETC. It's a good concern though...
    Tincup can you tell us the speed differential between wheels required to activate the ETC? And is there a road speed at which it shuts off?
    One thing to consider, you can put that extra 5th tire into the rotation as you move your wheels around between corners of the truck, and gain an extra 20% tread life over not having it. But it will cost 25% more to accomplish this. Which is why I don't do it. *grin*
    Take a look at some 265/75-16s. They'll look great and will rub only mildly with big articulation. A little lift to your suspension will help with that. Note these will require a lot of trimming to fit a DI.
    From another *very* technical website regarding Discos:
    Discovery Series I
    235/70-16: Stock tire size.
    205/80-16: Stock size in many other countries. same height as 235/70-16.
    255/65-16: same height as stock
    225/75-16: little taller than stock
    245/70-16: little taller and wider than the stock size. reportedly, no need for lift, just minor trimming to fit those tires.
    245/75-16: popular size for OME suspension lifted vehicles. require slight trimming on the rear wheel well fender, and may also call for adjustment on the steering bumpstops.
    215/85-16: same height as 245/75-16. but narrower. seems to be preferred for the snow and mud.
    265/70-16: about as tall as 245/75-16, but wider. will require more trimming and steering bump stops adjustments along with taller bump stops over the rear axle.
    265/75-16: almost 32" tall. Same as stock NAS D90 tires. Will require even more trimming.
    235/85-16: same height as 265/75-16 but narrower. And seems to be the most popular size with OME lift.
    255/85-16: about 33" tall...very few people have fitted this size. Lots of butchering for this one.
    285/75-16: about 33" also... but very very wide.
    Discovery Series II
    255/65-16: Stock tire size.
    255/70-16: Just a bit taller than stock.
    265/75-16: Taller and wider than stock, possible to fit without lift. minor rubbing. Looks real balanced with mild OME lift.
    285/75-16: even taller than 265/75-16, r requires a bit more lift than the regular OME lift. some have fitted OME751 from Discovery series I, and changed SLS sensor in the rear to achieve almost 3 inches. Gearing and shaft strenght become issues.
    255/85-16: a bit taller than 285/75-15 but narrower. Gearing and shaft strenght become issues.
  • tincup47tincup47 Member Posts: 1,508
    The workshop manual states that the ECU averages the speeds from the 4 ABS sensors. If any wheel speed increases from the average, then the system activates on that wheel. It does not give a specific threshold for activation.
     For traction control, from 0 to 31 mph,the ETC uses brake intervention to maintain torque distribution between wheels on the same axle. From 0 to 62 MPH ETC also uses brake intervention in axle pairs to maintain torque distribution between the front and rear axles.
  • ejohnsejohns Member Posts: 9
    I own a '99 Disco II with 66k miles - runs wonderful! In fact, I love my disco but lately, say in the last day or so, I've noticed that my steering gets stiff when slowing to come to a complete stop. At times its hard to turn. No lights are illuminated and everything else runs fine. Not sure what to make of the steering thing. I'm rolling with Goodyear which I hate, replacing quickly! Not mechanically inclined so any thoughts would be appreciated. Thanks.
  • disco99disco99 Member Posts: 74
    I guess I'll have to keep looking--
    I appreciate the info.
    Thanks again, Tincup.
    From those details I don't think I'd recommend running a different size tire as a spare for a DII. If it's trying to apply the brakes to that smaller tire as you drive, to slow it down to the same rotational speed as the other 3 wheels, then you can do significant damage.
    Now, if someone were to pull the fuse that runs the ETC system and ABS system, I suppose he could limp home that way, but... it's not a very smart idea.
    For the DI it's a different story... there's no ETC to mess with. You will still have differential speeds between wheels on the same axle but hey... that's what the diff is designed for, right? Just DO NOT lock anything... axle lockers if you have them installed, or the central diff lock. Then you should be okay for the (brief) drive to the repair shop.
    Man it could be almost anything. Maybe you have bad fuel and its idle speed drops waaaay down as you decelerate? Maybe the TPI (throttle position indicator) is going south? Does it otherwise idle and shift normally? Are your front tires low on air pressure? Perhaps a slipping belt to the power steering pump? Low fluid in the power steering reservoir? Are both front sets of brake pads in good shape? Maybe you're thru to the metal on one set and trying to brake with only one front wheel? Maybe the carpet beneath your feet got pushed forward so it's into the steering column as it turns? How about the steering damper, did it get bent and is now contacting the suspension components when you put on the brakes and the weight shifts forward?
    Look her over... it should be pretty obvious what's up. Watch the tach carefully when you do this... your RPM shouldn't drop below 700 RPM or so.
    Good luck, -Bob
  • bugnut23bugnut23 Member Posts: 8
    Thanks, Nanuq and Tincup for your learned responses. I also posed the same query on DiscoWeb and the comments were also overwhemingly against a smaller spare. Guess I'll go for 5 (or 6) new tires.
  • blockislandguyblockislandguy Member Posts: 336
    Smarticus, here in the colonies, the JGC has a lousy rep for safety and reliability. Yet, we have owned two that have each gone more than 110K with only brakes (three or four times each vehicle), shocks, tires, and a fair amount of A/C work (we Americans like our A/C but at $1500 a pop to fix a JGC we give up at 110K.)
    Naturally, we run Mobil 1, Red Line ATF, and are obsessive about fluid changes, regular detailing (at $100 a car, why not every couple of months? You might not trade a clean, shiny car so often.), running better than OEM tires, good shocks, slotted brakes, etc.
    Is a JGC a more reliable car than a Disco? Is it more fun? I suspect that the answers to those two questions believe it or not are culturally based. I think that one would say yes and no if you were in the States and, conversely, say no and yes, if you were a Brit. What do you think?
  • roveratlastroveratlast Member Posts: 7
    I have noticed a clunking noise (rear end?) in my '01 Disco when I brake to a slower speed and then press the accelerator to increase speed again. This sounds a bit like a precursor to a transmission problem to me, but the technician at my dealer says it is not an unusual situation for this rover. Any thoughts???
  • rkoeslerrkoesler Member Posts: 62
    "Roveratlast" go ahead and believe your dealer technician. My 2000 DII has an awful driveline clunk whenever I coast or slow down for a turn, etc. It sounds as if the rear is exploding, but it's just "normal" Rover noise. I'm not sure why there is so much slack in the gears, it's just a fact of life, I guess.
    Sometimes I get annoyed when I hear it, and make it go "bang" on purpose to see if I can get it to bust - but so far, at 37,800 miles it's still just fine. Maybe "tincup" can elaborate?
    AKA "klonk" in its various other incarnations, we have concluded the noise comes from the rear diff. It seems Lord Lucas has finally been captured and brough under control; we can only assume he's spending the rest of his foul eternity inside someone's greasy differential. It appears he's inside yours for this brief period of his torture. And lo he deserves it, for the misery he's foisted on the rest of us!
    Seriously. Discos have lots of drivetrain under there, including a gear-driven transfer case... I believe it's the only vehicle thus designed. Not having a chain drive, it cannot contain dampers to eliminate all slack in the mechanism. So any small play in any gear is magnified thru repeated torque transferances, down thru Hookes joints that also have their own play, down along driveline splines (having their own play) into your rear Hookes joint (with, you guessed it, its own play) into the pinions and ring gear of the rear end. It's cumulative, much the same as a locomotive starting out, taking up all the play in all the couplers ("bang bang bang bang") before he really gets on the gas.
    My Anuqa does it too, and like RKoesler I can't break her either. I'd almost guarantee you can't break your transmission, so just give her lots of fresh lube and (try to) learn to like it. It kinda grows on you.
  • buroskyburosky Member Posts: 90
    A while back I had my brake pads (front and back) replaced with after market pads. Recently, I noticed some squeaking when I am driving on a street with either houses or walls on both sides and I hit the brakes. I went to the dealer to have it checked. I was told that using after market pads will always cause a squeak. Is this true or do they just want me to have the pads replaced through them in the future? I'm not mechanically inclined at all. Can this squeaking cause further damage? Should I change the pad immediately or wait until it needs replacement again?
    I have replaced the pads on my DI a zillion times, and only once have I used the "real" pads. I've tried Wagners, Lockheed, you name it. I have never *ever* had my pads squeak, no matter what brand I use.
    The squeak isn't doing any harm at all, it's just an irritation. My motorcycle does it. Basically it's a high-frequency shuddering of the pads against the rotor surface as it turns, due to a little brake dust causing friction between the surfaces and between the pads and the calipers.
    How do I keep mine from doing it? Well, I'm in deep water or muck or snow every week or so, and that might keep 'em washed out. I'm not sure.
    There's some goo you can buy that sticks to the back of the aftermarket pads when you put 'em in that's supposed to cut down on squeal. I've never tried it... though I suppose it would work.
    You really should try doing your own brakes. It's a cinch, and it's really sorta fun! Seriously, I can do mine blindfolded now... they're that simple. If you do decide to give it a try, DO NOT push the old nasty brake fluid back up into the brake lines when you push the caliper pistons in. The pump does *not* like that. Just crack the bleed screws and let 'em squirt when you push the pistons in.
    Let me know if you want more details... it's a great, fun job.
    Thanks for the response. I have read a few of your postings about the pads before that's why I was suspicious about the advise I got from the dealer. I tend to trust people here since they don't have any ulterior motives. You are almost sure of getting the straight fact. I don't mind getting grease in my hands. Two things stop me from attempting though. I don't have the tools and more importantly, I just am too afraid of messing it up. The last time I tried fixing my old Toyota back in '82 I ended up spending more because I eventually took it to a shop to get it done right. I've tried looking at step by step instructions but there are some terms I just don't understand. Perhaps if there is a manual that has the description accompanied by step by step pictures and is specifically for Discos, I will be more brave. Sort of like a do-it-yourself minor repair and maintenance for dummies - Discovery II edition. Come to think of it, I haven't come across a car repair book that assumes it's readers to have no mechanical inclination at all. Sounds like something someone can make a lot of money off. I surely would buy one.
  • waskowasko Member Posts: 103
    Smarticus,
    Take a peak at http://www.highwaysafety.org/vehicle_ratings/ce/html/summary_mids- uv.htm#99009 - crash test data for mid-sized SUVs. Lots of marginals for the Jeep, one poor for the Disco, although the Disco scores higher.
    Just another datapoint for you two to help make your decision.
    On a sidenote, the new Ford Explorers have climbed to the top of the ranks. This could be fallout and tighter focus on quality engineering/assembly after the Firestone tire problems they were having. Either way, that should translate into goodness for Rover products assuming Ford shares best practices internally between auto groups.
    Thx, wasko
    I'm back and she did great! I took the scouts out for the weekend to make shelters and sleep in them. We got some nice cold weather and got to get some 4-wheeling in along the way. We had to get our gear and water and tarps and food waaaaay up onto a hillside and instead of carrying it the boys said "why don't you drive it up there?" I knew of an old "road" that had been cut up the hillside years ago by a Cat, and found it... all overgrown and muddy and rocky and steep. It took a few tries but darn if the Disco didn't make it! With all that gear and 5 people inside. The "trail" was steep enough that it's precarious just walking up or down it, with severe sidehill angles in places. The short wheelbase and short overhangs, with good ground clearance, got me right up there threading my way around boulders and between trees. What a hoot! Not a hiccup.
  • jburschjbursch Member Posts: 11
    I have an opportunity to purchase a disco for the GM 'x' price. Does anybody know what the 'X' price discount is to the dealer invoice? Also, what have the 03' discos been selling for in Southern Cal. Thanks in advance.
    jb.
  • freditfredit Member Posts: 8
    Do you mean the "Ford X plan"? My wife and I just purchased a '03 Disco "S". I believe the discount was $4,500 off sticker, plus during the month of September, we were given another $1,500 incentive if using the Ford "X" plan. Needless to say, with our downpayment added to the plan, we have a very reasonable (for us at least) monthly payment.
  • discofundiscofun Member Posts: 26
    I purchased an '03 Disco HSE in September under the X Plan and here was the breakout:
    - Starting point was invoice + 4%
    - Subtract $3,500 for the manufacturer to dealer cash
    - Subtract $2,000 for owner loyalty (I owned a '96 Disco)
    - Subtract $1,000 for an end-of-model-year X-Plan kicker
    Total to take off the base X Plan was $6,500.
    The owner loyalty and X-Plan kickers were due to expire 30 September.
    Bottom line was that after my Disco trade-in and the X-Plan, I got a rippin' deal for an awesome vehicle.
    Go for it!
    Some of the posts here mention problems in owning a Rover. Before anyone gets real upset, cruise over to the German car boards. People are irate over there. Very irate. The MB, Audi, and BMW crowd are ripping at lousy quality control, plummetting resale ( especially on out of warranty vehicles), mucho electronic glitches, spending 5K in one service visit to fix an E Series A/C, etc. etc. Apparently the more you pay for one of Munich's finest or Stuggart's wonders, the more the problems. And then in 24 months your 70K 745i is worth 40K. (No wonder they are mad, they are paying more per month in depreciation than most people pay on their mortgage!)
    All in all, if you want to have a little fun and recognize that nothing is perfect, the Disco seems the place to be: not so much money going in, lots of potential fun, and no major coronaries when you're done.
    I started a thread here years ago about "Reliability, what is it?" and it went on for quite awhile... got pretty heated too. But it came down to people's perception of quality and whether the perception is valid or not... and at what scale? Local or global?
    Some scream LEMON!!! at the first drop of oil on the garage floor... others just think of it as an opportunity to get under the truck again and turn some wrenches.
    I'll tell ya what, my Disco works absolutely flawlessly AT LEAST 99.5% of the time. The PC I'm sitting at works nowhere near that well... nor does my camping gear or my mtn bikes or my watches or my appliances or my wife's car (snicker). Get the drift? These are amazing machines when you look at them in perspective.
    Best regards to all, now I've got to go outside and do a snow dance. I want some SNOW!!!!!!!!
    -Bob
    OK, guys, I like the styling of the new front end on the 03's, the suspension is getting better and better, and with the full floating rear end, boxed chassis, etc. it is built really well. Not so incidentally, the price for a new '03 is now really good. And the thing should be some fun for not a whole lot of money.
    So, if I buy one to run around New England in good weather and bad, some modest off roading, and want to keep it for 10 to 15 years, what do you recommend I do?
    1) Aftermarket/performance disc brake pads to increase longevity?
    2) Does anyone make slotted and/or drilled rotors? If I UPS Next Day Air a set up to Nanuk, can he drill some holes for me?
    3) Do I not order it with a sun roof to avoid potential leakage problems, just have the local dealer put in one (aftermarket) to avoid the potential problem of two roofs, or just get the two OEM roofs?
    4)Tires. Not going to lift anything more than a cool drink after I buy it. Not going to off road that much. I am concerned with highway handling doing 75MPH on I95 and being able to cross some sand dunes in summer. In winter, the truck will be used for light commuting in the six months of crud that we get, deep Boston pot holes, and the occasional fire road, logging road. I do want to hear myself think though while on I95. What do you recommend for an all season tire? Then, I should throw on Artic Alpins, Hakkalapettas, of Blizzaks come winter? Can I negotiate the OEM tire that comes standard? (Sure I can!)
    5) The winter package with the heated windshield really appeals to me. But I have heard that on other older, non LR cars with heated windshields that they were expensive to replace when cracked and had problems. What is the Disco history?
    6) Recently, I've put PIAA Bright bulbs in our cars with good success. Are the Disco bulbls standard such that PIAA has them? How soon until xenon lighting as standard?
    7) Anyone mind if I use Mobil1/Red Line ATF/synthetic rear end lube right away after breakin? Whats the good long life coolant? Has anyone cut open an OEM filter to compare with Wix? (Synthetic oil and good filters are cheap; what I can't afford is the alternative)
    8) The English talk about Waxoly (sp?) and now Zeibart is back in business. Don't laugh, but how good is the factory undercoat? Should I have it done in the aftermarket?
    9)Shocks. I do dislike the body sway. Should I put on four Bilsteins? Another brand? Leaving body lean aside, are the OEM shocks any good, or should I replace them fairly soon with some aftermarket ones?
    10) How foldable/removable is the back seat? If removed is the floor then flat? I'm never, ever going to use it and it would look nice in my garage. Spare tire. Should I leave it where it is, bring it inside against the driver's side rear glass, put on roof?
    As you can see from the above, I'm interested in doing it right from the get go, and doing it for longevity and handling.
  • cwdavis4cwdavis4 Member Posts: 13
    Does anyone know the actual algorithm the Disco ’03 uses to engage the ETC? I tried to search on this topic but couldn’t find anything that states the actual speed differences in the wheel spin and / or a time required (ie 5 mph wheel spin difference for 5 seconds).
    I’m don’t think the ETC is aggressive enough but maybe I don’t understand what it takes to engage.
    Thanks...
    :) If you send me your rotors I'll be happy to lean them up against a tree at 100 yards and "drill" them for you. My son and I have been practicing and we can cut a playing card in half now, shooting it sideways 3 shots out of 10 at 50 feet with a .22 rifle. I doubt my accuracy is quite so good with a .30 magnum but I'll be happy to give it a try!
    1) Dunno about rotor longevity or if they've changed the metallic compound. I use soft pads and replace them often to extend the life of the rotors. It's like $40/axle to do the pads, maybe once a year.
    2) See above (but don't look too close)
    3) Don't do the sunroof. Drive to where you want to be and park it and get out to enjoy the sun.
    4) Avoid the Alpins and Blizzaks, they use a soft compound that wears really quickly. Try the Nokian Hakka LT-10s. I'm happy as a clam at high tide with mine. Consider a slightly taller tire to get more clearance. I did so and it brought my wildly inaccurate speedometer spot-on. They're wonderful on the highway and great in deep snot. DEEP tread pattern to let the goo out from under your tread.
    5) No idea. That's why God made ice scrapers. These trucks heat up so fast anyway that a remote starter will have it warm and de-iced before you get out there anyway. Cheaper than new glass too.
    6) I tried PIAA and IPF bulbs in the DI with mixed success. They burned out at 1 year consistently. I finally went to Osram 100w/100w clear bulbs and I can see *really* well. No charging issues, no alternator issues. If you want more you can always mount up some driving lights on the bumper or an A-frame.
    7) Do a google search for oil filter comparison, including the search term "mopar". There's a great site somewhere that has photos of all the filters cut open and discusses. By all means use synthetics! Note: it doesn't want ATF in the diffs. Just in case you're not quite sure. Coolant: use whatever's called for and change it every 2 years.
    8) My truck is aluminum and coated steel beneath, and the boxed frame railed have a wax coating on the *inside* to prevent internal rust. At 84k miles and plenty of offroading I have many gouges in my rails but zero rust under there.
    9) OEM shocks are the BEST! Assuming of course you're talking about Old Man Emu (grin). Seriously the stock shocks on the DI were fantastic shocks. My brother runs Rancho 9000s with the adjustability and he loves them. Quick to adjust too. Body sway is an artifact of soft springs and long travel suspension, which is what makes these beasts so darn good offroad.
    10) My back seat folds forward flat, then again forward so it's up against the back of the driver's seat. Dunno about taking it out. I believe the floor is indeed flat in a DI with the seat folded up and forward. I left my spare where it is and I can then get 2 mtn bikes inside the back with all gear and I can lock it when I leave for awhile. You can get an amazing amount of load in there, both for volume and weight.
    Regards, -Bob
  • jamiakmjamiakm Member Posts: 9
    I recently test drove a 1998 Discovery. Very clean, seemingly well maintained. I really, really want this vehicle. The current owner is a very good friend and is putting forth every effort to make sure any and everything that could possibly be wrong, is repaired. It has 125,500 miles (highway) and has been dealer maintained for the life of the vehicle. She says she has never had any major problems or breakdowns.
    She recently replaced the compressor and alternator. I am wondering with this mileage are there any other major repairs I can expect to have to make. I once knew of a Land rover Discovery owner who said that a new transmission would cost $12,000.00. Is this the going price for replacing a Discovery transmission and at what point would a transmission need to be replaced? Any advice would be appreciated.
    Thanks in advance,
    Jamia
  • peweepewee Member Posts: 6
    We have a 2003 Disco SE, so the following should apply to what you might purchase.
    I use a T-50 torx wrench on a 3/8 socket to remove my left side back seat when on long fishing trips. If memory serves me correctly, there is one torx behind the seat, when folded forward, and two in the front, sort of under the floor mat. The two front ones are on a spring loaded hinge. I did not have much trouble removing the seat, or reinstalling it. The floor is flat when the seat is removed, up to the little well where your feet would go. Does very nicely for laying 9 foot flyrods or hamstick radio antennas or canoe paddles flat.
    Re long highway trips - we have taken two one from Denver to Florida and back, and the second (the fishing trip) from Denver up thru Montana to Washington, Oregon, Idaho, Wyoming and back. The Disco was quite comfortable on both trips.
    Upon returning from Florida last winter we ran into the beginning of the 36 inch Colorado snow storm. I can vouch for the Disco's ability to handle at least 12" of snow with the Original Equipment Goodyear 18" tires.
    A great vehicle that seems purpose built for Colorado mountain country. The comfortable long range cross country drive was an unexpected plus!
    pewee
    A couple winters ago we had this snowstorm, dumping about 36" snow in 24 hours. I was one of the only people out there, besides the municipal plow trucks. I finally just left the tow strap tied to the rear and coiled up inside the back... I lost count of how many people I pulled out.
    That's an adult Golden Lab in the foreground. :) The Disco did just fine in the snow.
    Nanuk makes his dog sleep outside in the snow? Come on.
    Seriously, do you run a block heater?
    jamia,
    I've been looking at a discoI myself now for a couple of months(MY wife has fallen in love with my discoII)--
    The best lesson I've finally learned about my discoII is to just drive it and enjoy it until something actually stops working---I used to worry sick about potential problems that still haven't come at 60k--
    Don't be scared by the mileage--the maintenance record is a lot more important.
    As far as future repairs...well you have the compressor and the alternator out of the way---I've heard NANUQ SAY THAT ABS PUMP,STEERING PUMP USUALLY GO AROUND THAT MILEAGE--
    I have been told by many discolovers again like NANUQ that the powertrain on discos are made to last a long time--even if you needed a tranny down the road I think it would be about $4000.
    No no no, Buster was in the garage looking out at the snow. Doubtless thinking "WHAT ARE YOU WAITING FOR (PANTPANTPANTPANTPANT) LET'S GOOOOOOOOOOOOOO!!!"
    Block heater? I have one, but I've never needed it. Even on campouts with my BSA troop at -40F waaaayyyy out 1/2 a mile from the middle of nowhere, she has *always* started right up the next morning. I prepare for that by running 5/50w Castrol Syntec in the winter, and I don't actually drive her anywhere until she's making enough heat to defrost the windows on her own.
    But she is quite the crotchety old coot until she gets a few miles under her in the morning... when it's cold like that all the lubes are cold and stiff and she grumps along stiff and slow for a ways. Granted, she's running like a top... it's just that she's stirring the rest of the drivetrain too, and those lubes are about the consistency of cold molasses with no good way to warm up.
    Here's another picture of Buster the Mudhound, ample evidence of why God created pickup trucks... so the dog can ride in back!
  • discomandiscoman Member Posts: 110
    Does anyone know how to reset the service engine light on my '96 disco? I recently changed the Spark Plugs and Spark Plug wires, oil and filter and air filter. The service guy at LR says since I already did all the work they would have done, all I need to do is bring it in and they will reset the light for me. I would prefer to do it myself instead of having to take it in for this.
    Let's see if I remember this correctly. On pre-96 Discos there's a little box beneath the passenger seat, some funny color of reddish brown, having an oval Land-Rover sticker on it. On 96 Discos there's a solenoid in the panel at the passenger footwell, against the sidewall by the door. You open up the panel and you'll see a solenoid of the same color, with the same sticker on it. In both cases the sticker is covering a tiny hole in the plastic. Just poke a straightened paperclip (conductive metal) thru the sticker, into the hole. It shorts a couple of leads and resets the SE light. Next time you're in a wrecking yard, take a look at that piece and you'll see a nice little hole right in the middle of the sticker.
    Hope this helps. -Bob
    ps: as long as your hands are grubby anyway, why not change the transfer box and autobox lubes too? Maybe the swivels and diffs? It's a really easy job and makes the beasts run nearly forever.
    Thanks Bob. I will check when I get home tonight. I was planning on changing the fluids anyhow this weekend. I am only allowed so many hours at a time before the wife gets jealous. :-)
    I really appreciate the response to my concerns about becoming a Disco owner. I have long since admired the Land Rover Discovery and am very happy to be soon owning one.
    I visit this board often and really appreciate the Land Rover "brotherhood" that exists here. Despite some of the negative comments I've heard about Land Rover products, it is because of reading the comments on this board that I've been convinced to purchase and feel confident about my decision.
    I'm looking forward to enjoying many miles in this vehicle and it's nice to know that if I do have problems I have a great resource and wealth of Land Rover knowledge to draw from.
    Thanks again,
    Jamia
    Nanuk, if 5/50 Castrol really covers the range of 5 thru 50 AND is synthetic, why doesn't everyone use it in everything from October thru the end of March?? Winters in the Norheast can be tough and the urban start/stop errand cycles (Do they even have dry cleaning in Alaska? Do guys wear a laundered shirt to work every day?) can be tough on an engine when it is 20 degrees outside.
    So, why doesn't every one north of the Mason Dixon just chuck the good ol' 10-30 their fathers used?
    Bob
    Thanks for the assist. The service engine module was, in fact behind the right kikck panel, and though it wasn't as easy to reset, I did manage it. There are actually two holes in the top of the module. The center one does nothing. And I didn't find the other one until I had actually disassembled the module. After that there was no problem. I was actually considering taking it out altogether, since it doesn't seem to perform any other purpose than to be a timer for that idiot light. I was wondering why there are so many wires going into it, so I figured it sent signals to other places as well. I wouldn't want to screw something up, so I put it back in. Thanks again for the advice. Saved me some $$ and an unnecessary trip to LR.
    Charlie
    By the way. Anyone who needs parts can go to www.roverconnection.com and order just about anything. You get it in about a week anywhere, and it's amazing the savings on parts and accessories. I have used them a few times and would highly recommend them. If they don't have it listed, you can ask them and they will reply within a few hours.
    Check this link, it explains why 5w-50 is not recommended for year round use in all markets.
    www.reliabilityweb.com/excerpts/excerpts/oilchange.pdf
    The roverconnection website also has slotted/vented rotors for installation on the Disco I and II. These work really well. It has vastly improved my braking. I also recommend the Platimum +4 spark plugs and the Magnecor Plug wires. My Disco runs a lot smoother and the acceleration response improved quite a bit.
    Tincup, can you give me the history and opinion of my 96 Disco? Vin # SALJY1248TA532011. I got it a few months ago, and though I do like to tinker, and have always done my own maintenance and most repairs, I would like to know if there is something I should expect. It just went over 83K and runs strong. I wish I could get rid of the pulley squealing first thing in the morning. Once it warms up a little it goes away. Come to think of it my "98 Exploder does the same thing.
    Charlie
  • stopgo1stopgo1 Member Posts: 20
    Nanuq,
    I posted a while back about a shuddering/slipping I was feeling as the truck was shifting between 2nd and 3rd, or 3rd and 4th gears. I brought the truck in this week because it was happening with more frequency. I dropped it off, took their loaner and told them I was not coming back until they had figured something out.
    I was told yesterday that the techs were able to reproduce the problem and what they determined wwas that there were 4 loose bolts where the drive train meets the parking drum. Does this sound like a plausible explanation? If so, should I now be concerned that these parts were malfunctioning thus causing irregular wear to them?
    I plan on talking to the dealership manager about this as I am concerned about a major transmission failure after my warranty expires, I have 26K miles on it already and have been complaining about this from the first day I owned the truck. LR has only opted to do anything about it when I told them to keep it until it was fixed.
    Thanks in advance for your advice,
    Dave
    Is it true that kevlar pads are either required or recommended when using slotted rotors? A guy from Atlantic British told me that. I was considering using those but since I had OEM pads he swayed me to get the OEM rotors saying that the OEM pads are not good for those slotted rotors. Since they deal with Rovers all the time, I didn't question it. Besides, I am one of those mechanically challenged people.
    I have installed slotted/drilled rotors on every car I have ever owned. I have them on my 98 Exploder as well as my Jetta and my Disco And have never bought the Kevlar pads. I had them on my BMW 318 before that and ever since My teen racing days. Slotted/vented/drilled rotors are not made to work hotter, they are made to prevent hard braking from overheating your brakes and work cooler. They are used for high performance vehicles that need to stop from high speeds on a regular basis. The holes and slots help keep them cool to avoid warping them. The slots also help to prevent glazing, which is when the brake dust hardens and puts a glassy coat on the rotors. This in turn makes them squeal, and also can hurt your braking performance.
    Back to the original question. The only reason to put Kevlar pads is to prevent overheating from breaking down the pad material. Since the main reason to put these rotors on your Disco is to keep the brakes cooler, therefore improving braking, there is no reason to buy high temperature Kevlar. The guy is trying to sell you more expensive pads.
    If there are any other opinions on this I would More than welcome them.
    Guys, the jury is not yet back in on drilled rotors. Some "experts" say that putting those holes in just weakens it. Whatever you do, drilling holes in your rotors with your Sears drill press in your basement is not the way to go this winter. If you want drilled rotors, buy them off the shelf.
    Slotted rotors on the other hand seem to have full acceptance.
    Like I said... send em up here! I'll be happy to fill them with .30 inch holes. (grin)
    Seriously, the holes/slots relieve the high pressure gasses that build between the disc/pad under heavy braking as the pad material burns away. They also provide escape points for water or mud that gets in there, so your brakes clear of the goo quicker after you've blasted a snow berm. Likewise, they keep your pads and rotors scraped nice and clean. It really is a win-win.
    I used to have a set of formulas that let you lay out a gorgeous set of spirals on your rotors, then you could drill them with a press and chamfer the edges. It really did work, amazingly enough. Great for motorcycles.
    Have you ever seen the pictures of Le Mans racers where they dive into the turn at the end of the Mulsanne straight? The discs glow bright red and pad material sparks and burns off. And that was happening long before Kevlar.
    (photo credit to Warren Sheehan)
    As for the transmission shudder, I bet the 4 bolts were maladjusted too TIGHT, and it activated the parking brake drum when you didn't expect it. Or they were too loose and it let the brake move and rub against its drum unexpectedly. This feels like transmission shudder because that's where the parking brake activates: at the transmission in the middle of the drivetrain. That way it can lock all 4 wheels at once. I wouldn't sweat it, if you only felt it rarely then there is probably almost zero wear on the brake material.
    When I pull my parking brake on snow it moves up maybe 1/3 of its travel before I feel it begin to "bite". Then it locks up solid. If I pull it halfheartedly then it shudders as it sorta pathetically half engages. If you have less free travel than that, chances are it was too tight.
    Note, this is an EXCELLENT way to play in the snow and set it up for powerslides and cool fun like that. BUT take that with a grain of salt: you will roll your truck if you're in a lovely 4-wheel full throttle drift and hit bare pavement sideways. It's also REALLY hard on your transfer case and brake. So don't do it. (wink wink)
    Regards, -Bob
    Tincup
    Were you able to find anything on my history? Vin # SALJY1248TA532011 I am curious because of all I have heard about the sticking valves and all. I am not sure the guy who previously owned my Disco did anything besides take it to Jiffy Lube for oil changes. When I got it the guy had actually never even taken off the cross bars on the roof rack. And it looked as if there was crap growing on the paint. I knew it was just poor upkeep. He took it to the car wash instead of washing it himself. I am in the Navy and I looked at it before I deployed overseas and came home to a "Surprise" I did find something in the glove box about him having work done for a jammed rear door lock, and the tire waranty was there too. I'm not too happy with them, but I will try to stick with them until the need replacement. I actually prefer Pirelli Scorpion AT's as they have given me excellent Performance on and off road in the past with other 4X4's. I am concerned about what was done on it and if I need to really look out for some things. Right now it has 83K and running strong. I don't have any of the problems I have heard of here or other places other than a light Power Steering fluid leak. But it's so minimal I'm not going to bother with it right now. I put cat litter on the floor of my garage (I don't even have a cat). and sweep it up once every month or so. I do most of my own maintenance/repair work, I do need to get some bigger wrences though. Seriously let me know what you come up with. I would really appreciate it.
    Not all '96s had the problem... if yours is still running strong at 83k miles then you're doubtless well past worrying about it. I've found that my '96 thrives on regular hard use, so I periodically "drive it like I stole it" and that seems to suit her just fine. I suspect it helps keep the valves free of crud too.
    About your power steering leak... look at the hoses coming from the underside of the catch tank, with the "ZF" molded into the cap. My hoses there get loose regularly and I just have to tighten the clamps a bit. Note, you want to refill with ATF, not power steering fluid.
    It will probably help your DI to change all the fluids. Chances are he has never changed the transfer case or swivels. Any wading can draw water in thru the seals as the swivels suddenly cool from the water, and contaminate the gear lube. They're all real easy to do but you'll have a ton of lube to recycle when you're done. Don't worry about using Hylomar on the diff, transfer or swivel plugs when you close them up... mine aren't sealed and they never leak.
    Rover on!
  • odiopusodiopus Member Posts: 47
    Thanks for all the responses, I will seriously have to re-consider my options. I would love to own a td5 defender.
    Odiopus
  • mikekavmikekav Member Posts: 1
    My 03 discovery also has the 3rd gear slippage at about 30 mph, it's been apparent at new, but is getting slightly worse, or I'm noticing it more, and now I've read that I'm not alone.
     Planning to call Land Rover service...
